[PATCH 1/1] xilinx: disable Unicode capitalization
Save some KiB when building xilinx_versal_virt_defconfig by disabling Unicode capitalization support. This avoids build failures when adding new features for the UEFI sub-system.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- It would be preferable to have a size check for the u-boot binary. This would avoid seeing problems only during execution. --- configs/xilinx_versal_virt_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 707693713a..8bc2ff4a4c 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -111,3 +111,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_THOR=y CONFIG_OF_LIBFDT_OVERLAY=y +# CONFIG_EFI_UNICODE_CAPITALIZATION is not set -- 2.30.2
2.30.2
What's the build issue? Any log? U-Boot is getting bigger and bigger and we are enabling more and more features for our generic targets that's why fixing that problem is better than disabling some options.
Thanks, Michal
2.30.2
Hello Michal,
this job failed: https://source.denx.de/u-boot/custodians/u-boot-efi/-/jobs/269614
After deactivating CONFIG_EFI_UNICODE_CAPITALIZATION I get success: https://source.denx.de/u-boot/custodians/u-boot-efi/-/jobs/269620
I do not understand what you mean here.
CONFIG_EFI_UNICODE_CAPITALIZATION is enabled since years.
Best regards
Heinrich
Added Tom to Cc.
2.30.2
Hello Michal,
I had a similar, most likely related issue a few days ago:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=87&view=resul...
Tom git bi-sected this to this commit, which only adds a bit tiny bit of image size I assume:
"I bisected this down to: commit 368b3f6db4540f913c436e5287be8356bc9a2891 Author: Stefan Chulski stefanc@marvell.com Date: Mon May 3 08:08:44 2021 +0200
phy: introduce 1000BaseX and 2500BaseX modes
Signed-off-by: Stefan Chulski stefanc@marvell.com Signed-off-by: Stefan Roese sr@denx.de
And while I'm not sure off-hand how it does it, it's causing the breakage. Maybe something is overflowing now?"
Thanks, Stefan
On 5/17/21 11:04 AM, Stefan Roese wrote:
Added Tom to Cc.
2.30.2
Hello Michal,
I have rebase Heinrich patches on the top of HEAD + my queue and I can't see any issue https://source.denx.de/u-boot/custodians/u-boot-microblaze/-/tree/for-heinri...
It means likely what Stefan mentioned is likely correct.
Thanks, Michal
Hi Michal,
Added Tom to Cc.
2.30.2
Hello Michal,
The mentioned PHY patch was not pushed to mainline (yet). Please add it:
http://patchwork.ozlabs.org/project/uboot/patch/20210503060853.3743626-2-sr@...
and run the test again.
Thanks, Stefan
Hi Stefan,
On 5/17/21 11:40 AM, Stefan Roese wrote:
Hi Michal,
Added Tom to Cc.
Hello Michal,
https://pastebin.com/pd9i8LEi I have applied this patch and I can't see any issue. Also pipeline passed without any issue. https://source.denx.de/u-boot/custodians/u-boot-microblaze/-/pipelines/7558
Can you apply this one and try on your end? http://patchwork.ozlabs.org/project/uboot/patch/7a7c5d657a968190e0676251dbd8...
it is in my queue and when u-boot is bigger then certain limit it can cause issue with early stack allocation.
Thanks, Michal
On 5/17/21 11:47 AM, Michal Simek wrote:
Hi Stefan,
Hi Michal,
Added Tom to Cc.
On 5/16/21 11:17 AM, Heinrich Schuchardt wrote: > Save some KiB when building xilinx_versal_virt_defconfig by > disabling > Unicode capitalization support. This avoids build failures when > adding new > features for the UEFI sub-system. > > Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de > --- > It would be preferable to have a size check for the u-boot binary. > This would avoid seeing problems only during execution. > --- > configs/xilinx_versal_virt_defconfig | 1 + > 1 file changed, 1 insertion(+) > > diff --git a/configs/xilinx_versal_virt_defconfig > b/configs/xilinx_versal_virt_defconfig > index 707693713a..8bc2ff4a4c 100644 > --- a/configs/xilinx_versal_virt_defconfig > +++ b/configs/xilinx_versal_virt_defconfig > @@ -111,3 +111,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 > CONFIG_USB_GADGET_DOWNLOAD=y > CONFIG_USB_FUNCTION_THOR=y > CONFIG_OF_LIBFDT_OVERLAY=y > +# CONFIG_EFI_UNICODE_CAPITALIZATION is not set > -- > 2.30.2 >
Hello Michal,
Thanks, Michal
The patch "xilinx: versal: Enable CONFIG_POSITION_INDEPENDENT" with CONFIG_SYS_INIT_SP_BSS_OFFSET=1572864 solves the problem: https://source.denx.de/u-boot/custodians/u-boot-efi/-/jobs/269920
Please, consider adding it to a pull request for v2021.07-rc3.
Best regards
Heinrich
Hi Stefan,
Hi Michal,
Added Tom to Cc.
On 17.05.21 08:39, Michal Simek wrote: > > > On 5/16/21 11:17 AM, Heinrich Schuchardt wrote: >> Save some KiB when building xilinx_versal_virt_defconfig by >> disabling >> Unicode capitalization support. This avoids build failures when >> adding new >> features for the UEFI sub-system. >> >> Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de >> --- >> It would be preferable to have a size check for the u-boot binary. >> This would avoid seeing problems only during execution. >> --- >> configs/xilinx_versal_virt_defconfig | 1 + >> 1 file changed, 1 insertion(+) >> >> diff --git a/configs/xilinx_versal_virt_defconfig >> b/configs/xilinx_versal_virt_defconfig >> index 707693713a..8bc2ff4a4c 100644 >> --- a/configs/xilinx_versal_virt_defconfig >> +++ b/configs/xilinx_versal_virt_defconfig >> @@ -111,3 +111,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 >> CONFIG_USB_GADGET_DOWNLOAD=y >> CONFIG_USB_FUNCTION_THOR=y >> CONFIG_OF_LIBFDT_OVERLAY=y >> +# CONFIG_EFI_UNICODE_CAPITALIZATION is not set >> -- >> 2.30.2 >> > > What's the build issue? Any log? U-Boot is getting bigger and > bigger and
Hello Michal,
Thanks, Michal
That's the plan.
Thanks, Michal
Hi Michael,
On 17.05.21 11:47, Michal Simek wrote:
<snip>
Yes, I can confirm that this patch fixes the build issue.
Thanks, Stefan
Michal Simek
Stefan Roese
