[U-Boot] [PATCH v4] sun6i: Add basic axp221 driver
The A31 uses the AXP221 pmic for various voltages.
Signed-off-by: Oliver Schinagl oliver@schinagl.nl Signed-off-by: Hans de Goede hdegoede@redhat.com -- Changes in v2: -Rebase Changes in v3: -Add support for all dldo and aldo-s -Add Kconfig option to select building AXP221 and to select voltage of dldo and aldo-s Changes in v4: -Add axp221_setbits helper function -Use symbolic names for enabled bits in CTRL1 - CTRL3 registers --- board/sunxi/board.c | 26 +++++++ drivers/power/Kconfig | 47 +++++++++++++ drivers/power/Makefile | 1 + drivers/power/axp221.c | 186 +++++++++++++++++++++++++++++++++++++++++++++++++ include/axp221.h | 50 +++++++++++++ 5 files changed, 310 insertions(+) create mode 100644 drivers/power/axp221.c create mode 100644 include/axp221.h
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 03890c8..e6ec5b8 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -19,6 +19,9 @@ #ifdef CONFIG_AXP209_POWER #include <axp209.h> #endif +#ifdef CONFIG_AXP221_POWER +#include <axp221.h> +#endif #include <asm/arch/clock.h> #include <asm/arch/cpu.h> #include <asm/arch/dram.h> @@ -169,6 +172,29 @@ void sunxi_board_init(void) power_failed |= axp209_set_ldo3(2800); power_failed |= axp209_set_ldo4(2800); #endif +#ifdef CONFIG_AXP221_POWER + power_failed = axp221_init(); + power_failed |= axp221_set_dcdc1(3000); + power_failed |= axp221_set_dcdc2(1200); + power_failed |= axp221_set_dcdc3(1200); + power_failed |= axp221_set_dcdc4(1200); + power_failed |= axp221_set_dcdc5(1500); +#if CONFIG_AXP221_DLDO1_VOLT != -1 + power_failed |= axp221_set_dldo1(CONFIG_AXP221_DLDO1_VOLT); +#endif +#if CONFIG_AXP221_DLDO4_VOLT != -1 + power_failed |= axp221_set_dldo4(CONFIG_AXP221_DLDO4_VOLT); +#endif +#if CONFIG_AXP221_ALDO1_VOLT != -1 + power_failed |= axp221_set_aldo1(CONFIG_AXP221_ALDO1_VOLT); +#endif +#if CONFIG_AXP221_ALDO2_VOLT != -1 + power_failed |= axp221_set_aldo2(CONFIG_AXP221_ALDO2_VOLT); +#endif +#if CONFIG_AXP221_ALDO3_VOLT != -1 + power_failed |= axp221_set_aldo3(CONFIG_AXP221_ALDO3_VOLT); +#endif +#endif
printf("DRAM:"); ramsize = sunxi_dram_init(); diff --git a/drivers/power/Kconfig b/drivers/power/Kconfig index e69de29..1ec7c0e 100644 --- a/drivers/power/Kconfig +++ b/drivers/power/Kconfig @@ -0,0 +1,47 @@ +config AXP221_POWER + boolean "axp221 pmic support" + depends on MACH_SUN6I + default y + ---help--- + Say y here to enable support for the axp221 pmic found on most sun6i + (A31) boards. + +config AXP221_DLDO1_VOLT + int "axp221 dldo1 voltage" + depends on AXP221_POWER + default -1 + ---help--- + Set the voltage (mV) to program the axp221 dldo1 at, set to -1 to + disable dldo1. + +config AXP221_DLDO4_VOLT + int "axp221 dldo4 voltage" + depends on AXP221_POWER + default -1 + ---help--- + Set the voltage (mV) to program the axp221 dldo4 at, set to -1 to + disable dldo4. + +config AXP221_ALDO1_VOLT + int "axp221 aldo1 voltage" + depends on AXP221_POWER + default -1 + ---help--- + Set the voltage (mV) to program the axp221 aldo1 at, set to -1 to + disable aldo1. + +config AXP221_ALDO2_VOLT + int "axp221 aldo2 voltage" + depends on AXP221_POWER + default -1 + ---help--- + Set the voltage (mV) to program the axp221 aldo2 at, set to -1 to + disable aldo2. + +config AXP221_ALDO3_VOLT + int "axp221 aldo3 voltage" + depends on AXP221_POWER + default -1 + ---help--- + Set the voltage (mV) to program the axp221 aldo3 at, set to -1 to + disable aldo3. diff --git a/drivers/power/Makefile b/drivers/power/Makefile index dc64e4d..04bd996 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -7,6 +7,7 @@
obj-$(CONFIG_AXP152_POWER) += axp152.o obj-$(CONFIG_AXP209_POWER) += axp209.o +obj-$(CONFIG_AXP221_POWER) += axp221.o obj-$(CONFIG_EXYNOS_TMU) += exynos-tmu.o obj-$(CONFIG_FTPMU010_POWER) += ftpmu010.o obj-$(CONFIG_TPS6586X_POWER) += tps6586x.o diff --git a/drivers/power/axp221.c b/drivers/power/axp221.c new file mode 100644 index 0000000..941193a --- /dev/null +++ b/drivers/power/axp221.c @@ -0,0 +1,186 @@ +/* + * (C) Copyright 2013 Oliver Schinagl oliver@schinagl.nl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <asm/arch/p2wi.h> +#include <axp221.h> + +static u8 axp221_mvolt_to_cfg(int mvolt, int min, int max, int div) +{ + if (mvolt < min) + mvolt = min; + else if (mvolt > max) + mvolt = max; + + return (mvolt - min) / div; +} + +static int axp221_setbits(u8 reg, u8 bits) +{ + int ret; + u8 val; + + ret = p2wi_read(reg, &val); + if (ret) + return ret; + + val |= bits; + return p2wi_write(reg, val); +} + +int axp221_set_dcdc1(unsigned int mvolt) +{ + int ret; + u8 cfg = axp221_mvolt_to_cfg(mvolt, 1600, 3400, 100); + + ret = p2wi_write(AXP221_DCDC1_CTRL, cfg); + if (ret) + return ret; + + return axp221_setbits(AXP221_OUTPUT_CTRL2, + AXP221_OUTPUT_CTRL2_DCDC1_EN); +} + +int axp221_set_dcdc2(unsigned int mvolt) +{ + u8 cfg = axp221_mvolt_to_cfg(mvolt, 600, 1540, 20); + + return p2wi_write(AXP221_DCDC2_CTRL, cfg); +} + +int axp221_set_dcdc3(unsigned int mvolt) +{ + u8 cfg = axp221_mvolt_to_cfg(mvolt, 600, 1860, 20); + + return p2wi_write(AXP221_DCDC3_CTRL, cfg); +} + +int axp221_set_dcdc4(unsigned int mvolt) +{ + u8 cfg = axp221_mvolt_to_cfg(mvolt, 600, 1540, 20); + + return p2wi_write(AXP221_DCDC4_CTRL, cfg); +} + +int axp221_set_dcdc5(unsigned int mvolt) +{ + u8 cfg = axp221_mvolt_to_cfg(mvolt, 1000, 2550, 50); + + return p2wi_write(AXP221_DCDC5_CTRL, cfg); +} + +int axp221_set_dldo1(unsigned int mvolt) +{ + int ret; + u8 cfg = axp221_mvolt_to_cfg(mvolt, 700, 3300, 100); + + ret = p2wi_write(AXP221_DLDO1_CTRL, cfg); + if (ret) + return ret; + + return axp221_setbits(AXP221_OUTPUT_CTRL2, + AXP221_OUTPUT_CTRL2_DLDO1_EN); +} + +int axp221_set_dldo2(unsigned int mvolt) +{ + int ret; + u8 cfg = axp221_mvolt_to_cfg(mvolt, 700, 3300, 100); + + ret = p2wi_write(AXP221_DLDO2_CTRL, cfg); + if (ret) + return ret; + + return axp221_setbits(AXP221_OUTPUT_CTRL2, + AXP221_OUTPUT_CTRL2_DLDO2_EN); +} + +int axp221_set_dldo3(unsigned int mvolt) +{ + int ret; + u8 cfg = axp221_mvolt_to_cfg(mvolt, 700, 3300, 100); + + ret = p2wi_write(AXP221_DLDO3_CTRL, cfg); + if (ret) + return ret; + + return axp221_setbits(AXP221_OUTPUT_CTRL2, + AXP221_OUTPUT_CTRL2_DLDO3_EN); +} + +int axp221_set_dldo4(unsigned int mvolt) +{ + int ret; + u8 cfg = axp221_mvolt_to_cfg(mvolt, 700, 3300, 100); + + ret = p2wi_write(AXP221_DLDO4_CTRL, cfg); + if (ret) + return ret; + + return axp221_setbits(AXP221_OUTPUT_CTRL2, + AXP221_OUTPUT_CTRL2_DLDO4_EN); +} + +int axp221_set_aldo1(unsigned int mvolt) +{ + int ret; + u8 cfg = axp221_mvolt_to_cfg(mvolt, 700, 3300, 100); + + ret = p2wi_write(AXP221_ALDO1_CTRL, cfg); + if (ret) + return ret; + + return axp221_setbits(AXP221_OUTPUT_CTRL1, + AXP221_OUTPUT_CTRL1_ALDO1_EN); +} + +int axp221_set_aldo2(unsigned int mvolt) +{ + int ret; + u8 cfg = axp221_mvolt_to_cfg(mvolt, 700, 3300, 100); + + ret = p2wi_write(AXP221_ALDO2_CTRL, cfg); + if (ret) + return ret; + + return axp221_setbits(AXP221_OUTPUT_CTRL1, + AXP221_OUTPUT_CTRL1_ALDO2_EN); +} + +int axp221_set_aldo3(unsigned int mvolt) +{ + int ret; + u8 cfg = axp221_mvolt_to_cfg(mvolt, 700, 3300, 100); + + ret = p2wi_write(AXP221_ALDO3_CTRL, cfg); + if (ret) + return ret; + + return axp221_setbits(AXP221_OUTPUT_CTRL3, + AXP221_OUTPUT_CTRL3_ALDO3_EN); +} + +int axp221_init(void) +{ + u8 axp_chip_id; + int ret; + + p2wi_init(); + ret = p2wi_change_to_p2wi_mode(AXP221_CHIP_ADDR, AXP221_CTRL_ADDR, + AXP221_INIT_DATA); + if (ret) + return ret; + + ret = p2wi_read(AXP221_CHIP_ID, &axp_chip_id); + if (ret) + return ret; + + if (!(axp_chip_id == 0x6 || axp_chip_id == 0x7 || axp_chip_id == 0x17)) + return -ENODEV; + + return 0; +} diff --git a/include/axp221.h b/include/axp221.h new file mode 100644 index 0000000..e3b4409 --- /dev/null +++ b/include/axp221.h @@ -0,0 +1,50 @@ +/* + * (C) Copyright 2013 Oliver Schinagl oliver@schinagl.nl + * + * X-Powers AXP221 Power Management IC driver + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define AXP221_CHIP_ADDR 0x68 +#define AXP221_CTRL_ADDR 0x3e +#define AXP221_INIT_DATA 0x3e + +#define AXP221_CHIP_ID 0x03 +#define AXP221_OUTPUT_CTRL1 0x10 +#define AXP221_OUTPUT_CTRL1_ALDO1_EN (1 << 6) +#define AXP221_OUTPUT_CTRL1_ALDO2_EN (1 << 7) +#define AXP221_OUTPUT_CTRL2 0x12 +#define AXP221_OUTPUT_CTRL2_DLDO1_EN (1 << 3) +#define AXP221_OUTPUT_CTRL2_DLDO2_EN (1 << 4) +#define AXP221_OUTPUT_CTRL2_DLDO3_EN (1 << 5) +#define AXP221_OUTPUT_CTRL2_DLDO4_EN (1 << 6) +#define AXP221_OUTPUT_CTRL2_DCDC1_EN (1 << 7) +#define AXP221_OUTPUT_CTRL3 0x13 +#define AXP221_OUTPUT_CTRL3_ALDO3_EN (1 << 7) +#define AXP221_DLDO1_CTRL 0x15 +#define AXP221_DLDO2_CTRL 0x16 +#define AXP221_DLDO3_CTRL 0x17 +#define AXP221_DLDO4_CTRL 0x18 +#define AXP221_DCDC1_CTRL 0x21 +#define AXP221_DCDC2_CTRL 0x22 +#define AXP221_DCDC3_CTRL 0x23 +#define AXP221_DCDC4_CTRL 0x24 +#define AXP221_DCDC5_CTRL 0x25 +#define AXP221_ALDO1_CTRL 0x28 +#define AXP221_ALDO2_CTRL 0x28 +#define AXP221_ALDO3_CTRL 0x2a + +int axp221_set_dcdc1(unsigned int mvolt); +int axp221_set_dcdc2(unsigned int mvolt); +int axp221_set_dcdc3(unsigned int mvolt); +int axp221_set_dcdc4(unsigned int mvolt); +int axp221_set_dcdc5(unsigned int mvolt); +int axp221_set_dldo1(unsigned int mvolt); +int axp221_set_dldo2(unsigned int mvolt); +int axp221_set_dldo3(unsigned int mvolt); +int axp221_set_dldo4(unsigned int mvolt); +int axp221_set_aldo1(unsigned int mvolt); +int axp221_set_aldo2(unsigned int mvolt); +int axp221_set_aldo3(unsigned int mvolt); +int axp221_init(void);
Acked-by: Ian Campbell ian.campbell@citrix.com
Thanks, I've taken the liberty to change this to:
Acked-by: Ian Campbell ijc@hellion.org.uk
And pushed the entire series to u-boot-sunxi/next
I'm somewhat tempted to send a PR with this to Tom, is there anything pending which we should get in first ?
Regards,
Hans
Right, thanks. Wrong set of finger macros loaded...
I seem to have http://patchwork.ozlabs.org/patch/403231/ delegated to me, but didn't you fix that already?
Ian.
Yes that is already fixed in master, I've moved this to accepted.
Regards,
Hans
- (C) Copyright 2013 Oliver Schinagl oliver@schinagl.nl
- X-Powers AXP221 Power Management IC driver
The register offset of ALDO2 seems to be incorrect here (same as ALDO1): http://linux-sunxi.org/AXP221#Reg_29h:_ALDO2_output_voltage
In the current u-boot master, ALDO2 is only used by: configs/Mele_M9_defconfig:+S:CONFIG_AXP221_ALDO1_VOLT=3300
$ cat Mele_M9_defconfig CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI,SUNXI_GMAC" CONFIG_FDTFILE="sun6i-a31-m9.dtb" +S:CONFIG_ARM=y +S:CONFIG_ARCH_SUNXI=y +S:CONFIG_MACH_SUN6I=y +S:CONFIG_TARGET_MELE_M9=y # Ethernet phy power +S:CONFIG_AXP221_DLDO1_VOLT=3300 # USB hub power +S:CONFIG_AXP221_DLDO4_VOLT=3300 # Wifi power +S:CONFIG_AXP221_ALDO1_VOLT=3300 # HDMI power ? +S:CONFIG_AXP221_ALDO2_VOLT=1800 +S:CONFIG_AXP221_ALDO3_VOLT=3000 # Vbus gpio for usb1 +S:CONFIG_USB1_VBUS_PIN="PC27" # No Vbus gpio for usb2 +S:CONFIG_USB2_VBUS_PIN=""
It means that the code in "boards/sunxi/board.c" is likely to set 1.8V for ALDO1 instead of 3.3V:
#if CONFIG_AXP221_ALDO1_VOLT != -1 power_failed |= axp221_set_aldo1(CONFIG_AXP221_ALDO1_VOLT); #endif #if CONFIG_AXP221_ALDO2_VOLT != -1 power_failed |= axp221_set_aldo2(CONFIG_AXP221_ALDO2_VOLT); #endif
Does Wifi actually work on Mele M9? And if not, then is this something that needs to be fixed in the v2015.01 release?
Also ALDO1/ALDO2 have much heavier use in the u-boot-sunxi "next" branch.
Ouch, good catch, I'll send a fix out right away and I'll try to get this included in v2015.01.
Regards,
Hans
Hans de Goede
Ian Campbell
Siarhei Siamashka
