[U-Boot-Users] [PATCH 15/18] include/configs: Use new CONFIG_CMD_* in various [TUVWZYZ]* named board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/TASREG.h | 23 +++++++++++------- include/configs/TOP860.h | 38 +++++++++++++++---------------- include/configs/VCMA9.h | 45 +++++++++++++++++-------------------- include/configs/VOH405.h | 39 +++++++++++++++++--------------- include/configs/VOM405.h | 33 +++++++++++++++------------ include/configs/VoVPN-GW.h | 41 +++++++++++++++++---------------- include/configs/W7OLMC.h | 29 ++++++++++++++++-------- include/configs/W7OLMG.h | 31 +++++++++++++++++-------- include/configs/WUH405.h | 33 +++++++++++++++------------ include/configs/XPEDITE1K.h | 43 +++++++++++++++++------------------ include/configs/Yukon8220.h | 51 +++++++++++++++++++++---------------------- include/configs/ZPC1900.h | 26 +++++++++++---------- include/configs/ZUMA.h | 25 +++++++++++--------- 13 files changed, 245 insertions(+), 212 deletions(-)
diff --git a/include/configs/TASREG.h b/include/configs/TASREG.h index 119bc24..b0116e7 100644 --- a/include/configs/TASREG.h +++ b/include/configs/TASREG.h @@ -50,20 +50,25 @@
#undef CONFIG_MONITOR_IS_IN_RAM /* no pre-loader required!!! ;-) */
-#define CONFIG_COMMANDS ((CONFIG_CMD_DFL | \ - CFG_CMD_BSP | \ - CFG_CMD_EEPROM | \ - CFG_CMD_I2C ) & \ - ~(CFG_CMD_NET)) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_BSP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C + +#undef CONFIG_CMD_NET + + #define CONFIG_BOOTDELAY 3
#define CFG_PROMPT "=> " #define CFG_LONGHELP /* undef to save memory */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ diff --git a/include/configs/TOP860.h b/include/configs/TOP860.h index 2344b96..717b779 100644 --- a/include/configs/TOP860.h +++ b/include/configs/TOP860.h @@ -107,30 +107,28 @@ */ #define CFG_MATCH_PARTIAL_CMD
+ /* - * List of available monitor commands. Use the system default list - * plus add some of the "non-standard" commands back in. - * See ./cmd_confdefs.h - */ -#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DHCP | \ - CFG_CMD_I2C | \ - CFG_CMD_EEPROM | \ - CFG_CMD_REGINFO | \ - CFG_CMD_IMMAP | \ - CFG_CMD_ELF | \ - CFG_CMD_DATE | \ - CFG_CMD_MII | \ - CFG_CMD_BEDBUG \ - ) + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_IMMAP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_DATE +#define CONFIG_CMD_MII +#define CONFIG_CMD_BEDBUG +
#define CONFIG_AUTOSCRIPT 1 #define CFG_LOADS_BAUD_CHANGE 1 #undef CONFIG_LOADS_ECHO /* NO echo on for serial download */
#define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ @@ -141,7 +139,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -239,7 +237,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 5f48a70..ab802a3 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -48,27 +48,24 @@ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1
-/*********************************************************** - * Command definition - ***********************************************************/ -#define CONFIG_COMMANDS \ - (CONFIG_CMD_DFL | \ - CFG_CMD_CACHE | \ - /*CFG_CMD_JFFS2 |*/ \ - /*CFG_CMD_NAND |*/ \ - CFG_CMD_EEPROM | \ - CFG_CMD_I2C | \ - CFG_CMD_USB | \ - CFG_CMD_REGINFO | \ - CFG_CMD_FAT | \ - CFG_CMD_DATE | \ - CFG_CMD_ELF | \ - CFG_CMD_DHCP | \ - CFG_CMD_PING | \ - CFG_CMD_BSP) - -/* this must be included after the definiton of CONFIG_COMMANDS */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#define CONFIG_CMD_USB +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_FAT +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ELF +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_BSP +
#define CFG_HUSH_PARSER #define CFG_PROMPT_HUSH_PS2 "> " @@ -145,7 +142,7 @@ #define CONFIG_IPADDR 10.0.0.110 #define CONFIG_SERVERIP 10.0.0.1
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ /* what's this ? it's not used anywhere */ #define CONFIG_KGDB_SER_INDEX 1 /* which serial port to use */ @@ -246,7 +243,7 @@ /*----------------------------------------------------------------------- * NAND flash settings */ -#if (CONFIG_COMMANDS & CFG_CMD_NAND) +#if defined(CONFIG_CMD_NAND)
#define CFG_NAND_LEGACY #define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ @@ -280,6 +277,6 @@ #define CONFIG_MTD_NAND_VERIFY_WRITE 1 #define CONFIG_MTD_NAND_ECC_JFFS2 1
-#endif /* CONFIG_COMMANDS & CFG_CMD_NAND */ +#endif
#endif /* __CONFIG_H */ diff --git a/include/configs/VOH405.h b/include/configs/VOH405.h index 96f3d26..3f2c32b 100644 --- a/include/configs/VOH405.h +++ b/include/configs/VOH405.h @@ -58,28 +58,31 @@
#define CONFIG_PHY_CLK_FREQ EMAC_STACR_CLK_66MHZ /* 66 MHz OPB clock*/
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_DHCP | \ - CFG_CMD_PCI | \ - CFG_CMD_IRQ | \ - CFG_CMD_IDE | \ - CFG_CMD_FAT | \ - CFG_CMD_ELF | \ - CFG_CMD_NAND | \ - CFG_CMD_DATE | \ - CFG_CMD_I2C | \ - CFG_CMD_MII | \ - CFG_CMD_PING | \ - CFG_CMD_EEPROM ) + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PCI +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_IDE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_ELF +#define CONFIG_CMD_NAND +#define CONFIG_CMD_DATE +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_EEPROM +
#define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION
#define CONFIG_SUPPORT_VFAT
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - #undef CONFIG_WATCHDOG /* watchdog disabled */
#define CONFIG_RTC_MC146818 /* DS1685 is MC146818 compatible*/ @@ -98,7 +101,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -319,7 +322,7 @@ #define CFG_DCACHE_SIZE 16384 /* For AMCC 405 CPUs, older 405 ppc's */ /* have only 8kB, 16kB is save here */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index f2f3ea7..f312ea4 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -65,19 +65,22 @@ CONFIG_BOOTP_DNS2 | \ CONFIG_BOOTP_SEND_HOSTNAME )
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_DHCP | \ - CFG_CMD_BSP | \ - CFG_CMD_PCI | \ - CFG_CMD_IRQ | \ - CFG_CMD_ELF | \ - CFG_CMD_I2C | \ - CFG_CMD_MII | \ - CFG_CMD_PING | \ - CFG_CMD_EEPROM ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_BSP +#define CONFIG_CMD_PCI +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_ELF +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_EEPROM +
@@ -96,7 +99,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -244,7 +247,7 @@ #define CFG_DCACHE_SIZE 16384 /* For AMCC 405 CPUs, older 405 ppc's */ /* have only 8kB, 16kB is save here */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/VoVPN-GW.h b/include/configs/VoVPN-GW.h index 92bade5..8806244 100644 --- a/include/configs/VoVPN-GW.h +++ b/include/configs/VoVPN-GW.h @@ -138,24 +138,25 @@
#endif
-/* configure commands */ -#define CONFIG_COMMANDS ( CFG_CMD_AUTOSCRIPT | \ - CFG_CMD_BDI | \ - CFG_CMD_CONSOLE | \ - CFG_CMD_ECHO | \ - CFG_CMD_ENV | \ - CFG_CMD_FLASH | \ - CFG_CMD_IMI | \ - CFG_CMD_IMLS | \ - CFG_CMD_LOADB | \ - CFG_CMD_MEMORY | \ - CFG_CMD_MISC | \ - CFG_CMD_NET | \ - CFG_CMD_PING | \ - CFG_CMD_RUN ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ + +#define CONFIG_CMD_AUTOSCRIPT +#define CONFIG_CMD_BDI +#define CONFIG_CMD_CONSOLE +#define CONFIG_CMD_ECHO +#define CONFIG_CMD_ENV +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_IMI +#define CONFIG_CMD_IMLS +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_MISC +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_RUN +
/* * boot options & environment @@ -206,7 +207,7 @@ #define CFG_PROMPT "=> "
/* console i/o buffer size */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 #else #define CFG_CBSIZE 256 @@ -305,7 +306,7 @@
/* cache configuration */ #define CFG_CACHELINE_SIZE 32 /* for MPC8260 */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of above */ #endif
diff --git a/include/configs/W7OLMC.h b/include/configs/W7OLMC.h index 8dc623e..fd81096 100644 --- a/include/configs/W7OLMC.h +++ b/include/configs/W7OLMC.h @@ -70,13 +70,22 @@
#define CONFIG_RTC_M48T35A 1 /* ST Electronics M48 timekeeper */
-#define CONFIG_COMMANDS \ - (CONFIG_CMD_DFL | CFG_CMD_PCI | CFG_CMD_IRQ | CFG_CMD_ASKENV | \ - CFG_CMD_DHCP | CFG_CMD_BEDBUG | CFG_CMD_DATE | CFG_CMD_I2C | \ - CFG_CMD_EEPROM | CFG_CMD_ELF | CFG_CMD_BSP | CFG_CMD_REGINFO) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PCI +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_BEDBUG +#define CONFIG_CMD_DATE +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_BSP +#define CONFIG_CMD_REGINFO
#undef CONFIG_WATCHDOG /* watchdog disabled */ #define CONFIG_HW_WATCHDOG /* HW Watchdog, board specific */ @@ -92,7 +101,7 @@ #ifdef CFG_HUSH_PARSER #define CFG_PROMPT_HUSH_PS2 "> " #endif -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -277,7 +286,7 @@ */ #define CFG_DCACHE_SIZE 8192 /* For AMCC 405 CPUs */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above val. */ #endif
@@ -309,7 +318,7 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/W7OLMG.h b/include/configs/W7OLMG.h index 2bd98b3..a5ce685 100644 --- a/include/configs/W7OLMG.h +++ b/include/configs/W7OLMG.h @@ -75,14 +75,25 @@ #define CFG_DTT_LOW_TEMP -30 #define CFG_DTT_HYSTERESIS 3
-#define CONFIG_COMMANDS \ - (CONFIG_CMD_DFL | CFG_CMD_PCI | CFG_CMD_IRQ | CFG_CMD_ASKENV | \ - CFG_CMD_DHCP | CFG_CMD_BEDBUG | CFG_CMD_DATE | CFG_CMD_I2C | \ - CFG_CMD_EEPROM | CFG_CMD_ELF | CFG_CMD_BSP | CFG_CMD_REGINFO | \ - CFG_CMD_DTT)
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PCI +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_BEDBUG +#define CONFIG_CMD_DATE +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_BSP +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_DTT +
#undef CONFIG_WATCHDOG /* watchdog disabled */ #define CONFIG_HW_WATCHDOG /* HW Watchdog, board specific */ @@ -98,7 +109,7 @@ #ifdef CFG_HUSH_PARSER #define CFG_PROMPT_HUSH_PS2 "> " #endif -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -278,7 +289,7 @@ */ #define CFG_DCACHE_SIZE 8192 /* For AMCC 405 CPUs */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above val. */ #endif
@@ -310,7 +321,7 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/WUH405.h b/include/configs/WUH405.h index faf855d..f786520 100644 --- a/include/configs/WUH405.h +++ b/include/configs/WUH405.h @@ -60,19 +60,22 @@
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_DHCP | \ - CFG_CMD_IRQ | \ - CFG_CMD_ELF | \ - CFG_CMD_NAND | \ - CFG_CMD_DATE | \ - CFG_CMD_I2C | \ - CFG_CMD_MII | \ - CFG_CMD_PING | \ - CFG_CMD_EEPROM ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_ELF +#define CONFIG_CMD_NAND +#define CONFIG_CMD_DATE +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_EEPROM +
@@ -92,7 +95,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -270,7 +273,7 @@ #define CFG_DCACHE_SIZE 16384 /* For AMCC 405 CPUs, older 405 ppc's */ /* have only 8kB, 16kB is save here */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/XPEDITE1K.h b/include/configs/XPEDITE1K.h index f2ad097..4b8fbe6 100644 --- a/include/configs/XPEDITE1K.h +++ b/include/configs/XPEDITE1K.h @@ -182,25 +182,24 @@ extern void out32(unsigned int, unsigned long); #define CONFIG_HAS_ETH2 1 /* add support for "eth2addr" */ #define CONFIG_HAS_ETH3 1 /* add support for "eth3addr" */
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_PCI | \ - CFG_CMD_IRQ | \ - CFG_CMD_I2C | \ - CFG_CMD_DATE | \ - CFG_CMD_BEDBUG | \ - CFG_CMD_EEPROM | \ - CFG_CMD_PING | \ - CFG_CMD_ELF | \ - CFG_CMD_MII | \ - CFG_CMD_DIAG | \ - CFG_CMD_FAT ) - -/* CFG_CMD_DHCP | \ */ -/* CFG_CMD_KGDB | \ */ - - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PCI +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_I2C +#define CONFIG_CMD_DATE +#define CONFIG_CMD_BEDBUG +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_PING +#define CONFIG_CMD_ELF +#define CONFIG_CMD_MII +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_FAT +
@@ -209,7 +208,7 @@ extern void out32(unsigned int, unsigned long); */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -254,7 +253,7 @@ extern void out32(unsigned int, unsigned long); */ #define CFG_DCACHE_SIZE 8192 /* For AMCC 440GX CPUs */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
@@ -266,7 +265,7 @@ extern void out32(unsigned int, unsigned long); #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/Yukon8220.h b/include/configs/Yukon8220.h index 37ef105..07fab44 100644 --- a/include/configs/Yukon8220.h +++ b/include/configs/Yukon8220.h @@ -39,12 +39,6 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#define CFG_CACHELINE_SIZE 32 /* For MPC8220 CPUs */ - -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) -# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - /* * Serial console configuration */ @@ -70,31 +64,31 @@
#define CONFIG_TIMESTAMP /* Print image info with timestamp */
+ /* - * Supported commands + * Command line configuration. */ -#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_BOOTD | \ - CFG_CMD_CACHE | \ - CFG_CMD_DHCP | \ - CFG_CMD_DIAG | \ - CFG_CMD_EEPROM | \ - CFG_CMD_ELF | \ - CFG_CMD_I2C | \ - CFG_CMD_NET | \ - CFG_CMD_NFS | \ - CFG_CMD_PCI | \ - CFG_CMD_PING | \ - CFG_CMD_REGINFO | \ - CFG_CMD_SDRAM | \ - CFG_CMD_SNTP ) +#include <config_cmd_default.h> + +#define CONFIG_CMD_BOOTD +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_I2C +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_SNTP +
#define CONFIG_NET_MULTI #define CONFIG_MII
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - /* * Autobooting */ @@ -293,7 +287,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -309,6 +303,11 @@
#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */
+#define CFG_CACHELINE_SIZE 32 /* For MPC8220 CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + /* * Various low-level settings */ diff --git a/include/configs/ZPC1900.h b/include/configs/ZPC1900.h index 2b02fe7..30c7790 100644 --- a/include/configs/ZPC1900.h +++ b/include/configs/ZPC1900.h @@ -106,22 +106,24 @@
#define CONFIG_BAUDRATE 38400
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ - | CFG_CMD_ASKENV \ - | CFG_CMD_DHCP \ - | CFG_CMD_IMMAP \ - | CFG_CMD_MII \ - | CFG_CMD_PING \ - )
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_IMMAP +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +
#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ #define CONFIG_BOOTCOMMAND "dhcp;bootm" /* autoboot command */ #define CONFIG_BOOTARGS "root=/dev/nfs rw ip=:::::eth0:dhcp"
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #undef CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */ #define CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */ #undef CONFIG_KGDB_NONE /* define if kgdb on something else */ @@ -139,7 +141,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -223,7 +225,7 @@ #endif
#define CFG_CACHELINE_SIZE 32 /* For MPC8260 CPU */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/ZUMA.h b/include/configs/ZUMA.h index f163d00..6620938 100644 --- a/include/configs/ZUMA.h +++ b/include/configs/ZUMA.h @@ -106,12 +106,18 @@
#define CONFIG_MII /* enable MII commands */
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_BSP | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_MII | \ - CFG_CMD_DATE) + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_BSP +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MII +#define CONFIG_CMD_DATE +
/* * JFFS2 partitions @@ -131,15 +137,12 @@ #define MTDPARTS_DEFAULT "mtdparts=zuma-1:-(jffs2),zuma-2:-(user)" */
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - /* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -349,7 +352,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 /* For all MPC74xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
Jon Loeliger
