[U-Boot] Pull request: u-boot-arm/master
Hi Wolfgang,
The following changes since commit 5721385b187b3154c7768e6c182501022f4e2e45:
Merge branch 'master' of git://git.denx.de/u-boot-mpc83xx (2011-11-08 07:44:52 +0100)
git://git.denx.de/u-boot-arm.git master
Alexander Holler (1): BeagleBoard: config: Switch to ttyO2
Asen Dimov (1): ARM: define CONFIG_MACH_TYPE for all ronetix boards
Christian Riesch (3): arm, davinci: Rename AM1808 lowlevel functions to DA850 arm, davinci: Remove the duplication of LPSC functions arm, davinci: Fix setting of the SDRAM configuration register
David Müller (ELSOFT AG) (2): ARM: re-add MACH_TYPE_XXXXXX for VCMA9 board and add CONFIG_MACH_TYPE ARM: remove superfluous setting of arch_number in board specific code.
Fabio Estevam (5): qong: Use generic function for configuring GPR register mx31: Remove duplicate definition for GPR register mx31: Use proper IO accessor for GPR register mx31: Fix checkpatch warnings in generic.c m28evk: Fix comment about the number of RAM banks
Heiko Schocher (3): arm, davinci: da850/dm365 lowlevel cleanup arm, davinci_emac: fix driver bug if more then 3 PHYs are detected arm, davinci: add DAVINCI_MMC_CLKID
Linus Walleij (7): integrator: do not test first part of the memory integrator: pass configs for core modules integrator: move text offset to config integrator: use io-accessors for board init integrator: make flash writeable on boot integrator: add system controller header integrator: enable Vpp and disable flash protection
Manjunath Hadli (2): dm646x: add new configuration for dm6467T dm646x: pass board revision info to kernel
Marek Vasut (27): SPL: Allow ARM926EJS to avoid compiling in the CPU support code iMX28: Initial support for iMX28 CPU iMX28: Add SSP MMC driver FEC: Add support for iMX28 quirks iMX28: Add PINMUX control iMX28: Add I2C bus driver iMX28: Add GPIO control iMX28: Add SPI driver iMX28: Add APBH DMA driver iMX28: Add GPMI NAND driver iMX28: Add driver for internal RTC iMX28: Add image header generator tool iMX28: Add u-boot.sb target to Makefile iMX28: Add support for DENX M28EVK board M28: Add MMC SPL M28: Add doc/README.m28 documentation iMX28: Fix ARM vector handling M28: Add memory detection into SPL iMX28: Add USB and USB PHY register definitions iMX28: Add USB HOST driver M28EVK: Enable USB HOST support PXA: Drop csb226 and innokom boards (unmaintained) PXA: Cleanup serial_pxa PXA: vpac270: Enable the new generic MMC driver OneNAND: Add simple OneNAND SPL GCC4.6: Fix common/usb.c on xscale GCC4.6: Squash warnings in onenand_base.c
Nagabhushana Netagunte (1): da850: add new config file for AM18xx
Po-Yu Chuang (1): arm: a320: fix broken timer
Prabhakar Lad (1): da8xxevm: fix build error
Sricharan (7): omap4: make omap4 code common for future reuse omap: Checkpatch fixes omap5: Add minimal support for omap5430. omap5: clocks: Add clocks support for omap5 platform. omap5: emif: Add emif/ddr configurations required for omap5 evm omap4/5: Add support for booting with CH. omap5: Add omap5_evm board build support.
Stefano Babic (1): MX25: zmx25: GCC4.6 fix build warnings
Tom Rini (2): devkit8000: Fix NAND SPL on boards with 256MB NAND OMAP3: Change omap3_evm maintainer
.gitignore | 1 + MAINTAINERS | 15 +- Makefile | 14 +- README | 6 + arch/arm/cpu/arm1136/mx31/generic.c | 11 +- arch/arm/cpu/arm920t/a320/timer.c | 134 +-- arch/arm/cpu/arm926ejs/Makefile | 6 + arch/arm/cpu/arm926ejs/davinci/Makefile | 2 +- arch/arm/cpu/arm926ejs/davinci/am1808_lowlevel.c | 428 ------- arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c | 311 +++++ arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c | 73 +- .../arm/cpu/arm926ejs/mx28}/Makefile | 11 +- arch/arm/cpu/arm926ejs/mx28/clock.c | 355 ++++++ arch/arm/cpu/arm926ejs/mx28/iomux.c | 109 ++ arch/arm/cpu/arm926ejs/mx28/mx28.c | 221 ++++ arch/arm/cpu/arm926ejs/mx28/timer.c | 141 +++ arch/arm/cpu/armv7/omap-common/Makefile | 13 + arch/arm/cpu/armv7/omap-common/clocks-common.c | 609 ++++++++++ arch/arm/cpu/armv7/omap-common/emif-common.c | 1140 +++++++++++++++++ arch/arm/cpu/armv7/omap-common/hwinit-common.c | 267 ++++ .../armv7/{omap4 => omap-common}/lowlevel_init.S | 37 +- .../{omap4/mem.c => omap-common/mem-common.c} | 0 arch/arm/cpu/armv7/omap-common/spl.c | 9 +- arch/arm/cpu/armv7/omap4/Makefile | 11 +- arch/arm/cpu/armv7/omap4/board.c | 384 ------ arch/arm/cpu/armv7/omap4/clocks.c | 628 ++-------- arch/arm/cpu/armv7/omap4/emif.c | 1135 +----------------- arch/arm/cpu/armv7/omap4/hwinit.c | 167 +++ arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 83 -- arch/arm/cpu/armv7/omap4/sdram_elpida.c | 2 +- arch/arm/cpu/armv7/omap5/Makefile | 48 + arch/arm/cpu/armv7/omap5/clocks.c | 432 +++++++ arch/arm/cpu/armv7/omap5/config.mk | 28 + arch/arm/cpu/armv7/omap5/emif.c | 105 ++ arch/arm/cpu/armv7/omap5/hwinit.c | 78 ++ arch/arm/cpu/armv7/omap5/sdram_elpida.c | 178 +++ arch/arm/include/asm/arch-davinci/aintc_defs.h | 2 + .../{am1808_lowlevel.h => da850_lowlevel.h} | 26 +- arch/arm/include/asm/arch-davinci/ddr2_defs.h | 4 + arch/arm/include/asm/arch-davinci/emif_defs.h | 1 + arch/arm/include/asm/arch-davinci/hardware.h | 22 + arch/arm/include/asm/arch-davinci/pll_defs.h | 14 + arch/arm/include/asm/arch-mx28/clock.h | 61 + arch/arm/include/asm/arch-mx28/dma.h | 170 +++ arch/arm/include/asm/arch-mx28/gpio.h | 32 + arch/arm/include/asm/arch-mx28/imx-regs.h | 39 + arch/arm/include/asm/arch-mx28/iomux-mx28.h | 537 ++++++++ arch/arm/include/asm/arch-mx28/iomux.h | 168 +++ arch/arm/include/asm/arch-mx28/regs-apbh.h | 466 +++++++ arch/arm/include/asm/arch-mx28/regs-base.h | 88 ++ arch/arm/include/asm/arch-mx28/regs-bch.h | 230 ++++ arch/arm/include/asm/arch-mx28/regs-clkctrl.h | 312 +++++ arch/arm/include/asm/arch-mx28/regs-common.h | 66 + arch/arm/include/asm/arch-mx28/regs-gpmi.h | 222 ++++ arch/arm/include/asm/arch-mx28/regs-i2c.h | 207 ++++ arch/arm/include/asm/arch-mx28/regs-ocotp.h | 173 +++ arch/arm/include/asm/arch-mx28/regs-pinctrl.h | 1284 ++++++++++++++++++++ arch/arm/include/asm/arch-mx28/regs-power.h | 413 +++++++ arch/arm/include/asm/arch-mx28/regs-rtc.h | 147 +++ arch/arm/include/asm/arch-mx28/regs-ssp.h | 349 ++++++ arch/arm/include/asm/arch-mx28/regs-timrot.h | 171 +++ arch/arm/include/asm/arch-mx28/regs-usb.h | 178 +++ arch/arm/include/asm/arch-mx28/regs-usbphy.h | 151 +++ arch/arm/include/asm/arch-mx28/sys_proto.h | 32 + arch/arm/include/asm/arch-mx31/imx-regs.h | 7 +- arch/arm/include/asm/arch-omap3/mmc_host_def.h | 11 +- arch/arm/include/asm/arch-omap4/clocks.h | 23 + arch/arm/include/asm/arch-omap4/emif.h | 1021 ---------------- arch/arm/include/asm/arch-omap4/mmc_host_def.h | 11 +- .../arm/include/asm/arch-omap4/{omap4.h => omap.h} | 46 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 38 +- arch/arm/include/asm/arch-omap5/clocks.h | 722 +++++++++++ arch/arm/include/asm/arch-omap5/cpu.h | 175 +++ arch/arm/include/asm/arch-omap5/gpio.h | 50 + arch/arm/include/asm/arch-omap5/i2c.h | 74 ++ arch/arm/include/asm/arch-omap5/mmc_host_def.h | 174 +++ arch/arm/include/asm/arch-omap5/mux_omap5.h | 344 ++++++ arch/arm/include/asm/arch-omap5/omap.h | 223 ++++ arch/arm/include/asm/arch-omap5/sys_proto.h | 122 ++ arch/arm/include/asm/arch-pxa/pxa-regs.h | 111 -- arch/arm/include/asm/arch-pxa/regs-uart.h | 109 ++ arch/arm/include/asm/armv7.h | 3 + arch/arm/include/asm/emif.h | 1035 ++++++++++++++++ arch/arm/include/asm/mach-types.h | 13 + arch/arm/include/asm/omap_common.h | 31 +- board/armltd/integrator/arm-ebi.h | 62 + board/armltd/integrator/config.mk | 5 - board/armltd/integrator/integrator-sc.h | 91 ++ board/armltd/integrator/integrator.c | 63 +- board/csb226/csb226.c | 166 --- board/csb226/flash.c | 368 ------ board/davedenx/qong/qong.c | 2 +- board/davinci/dm6467evm/dm6467evm.c | 20 + board/denx/m28evk/Makefile | 56 + .../sys_info.c => board/denx/m28evk/m28_init.h | 48 +- board/denx/m28evk/m28evk.c | 216 ++++ board/denx/m28evk/mem_init.c | 240 ++++ board/denx/m28evk/mmc_boot.c | 273 +++++ board/denx/m28evk/power_init.c | 913 ++++++++++++++ board/denx/m28evk/start.S | 234 ++++ board/denx/m28evk/u-boot-spl.lds | 87 ++ board/denx/m28evk/u-boot.bd | 14 + board/innokom/flash.c | 421 ------- board/innokom/innokom.c | 190 --- board/mpl/vcma9/vcma9.c | 3 - board/ronetix/pm9261/pm9261.c | 3 - board/ronetix/pm9263/pm9263.c | 3 - board/ronetix/pm9g45/pm9g45.c | 2 - board/syteco/zmx25/zmx25.c | 2 - board/{innokom => ti/omap5_evm}/Makefile | 12 +- board/ti/omap5_evm/evm.c | 101 ++ board/ti/omap5_evm/mux_data.h | 275 +++++ board/ti/panda/Makefile | 2 - board/ti/panda/panda.c | 27 +- board/ti/panda/panda_mux_data.h | 54 +- board/ti/sdp4430/Makefile | 4 +- board/ti/sdp4430/sdp.c | 27 +- board/ti/sdp4430/sdp4430_mux_data.h | 53 +- board/vpac270/vpac270.c | 9 + boards.cfg | 22 +- common/usb.c | 13 +- doc/README.m28 | 223 ++++ drivers/dma/Makefile | 1 + drivers/dma/apbh_dma.c | 691 +++++++++++ drivers/gpio/Makefile | 1 + drivers/gpio/mxs_gpio.c | 136 ++ drivers/i2c/Makefile | 1 + drivers/i2c/mxs_i2c.c | 246 ++++ drivers/mmc/Makefile | 1 + drivers/mmc/mxsmmc.c | 351 ++++++ drivers/mmc/omap_hsmmc.c | 26 +- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/mxs_nand.c | 1118 +++++++++++++++++ drivers/mtd/onenand/Makefile | 4 + drivers/mtd/onenand/onenand_base.c | 18 +- drivers/mtd/onenand/onenand_spl.c | 146 +++ drivers/net/davinci_emac.c | 24 +- drivers/net/fec_mxc.c | 44 +- drivers/rtc/Makefile | 1 + drivers/rtc/mxsrtc.c | 86 ++ drivers/serial/serial_pxa.c | 464 +++----- drivers/spi/Makefile | 1 + drivers/spi/mxs_spi.c | 186 +++ drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-mxs.c | 154 +++ include/configs/VCMA9.h | 4 + include/configs/csb226.h | 506 -------- include/configs/da850_am18xxevm.h | 245 ++++ include/configs/davinci_dm6467Tevm.h | 163 +++ include/configs/davinci_dm6467evm.h | 1 + include/configs/devkit8000.h | 1 + include/configs/innokom.h | 507 -------- include/configs/integratorap.h | 1 + include/configs/integratorcp.h | 1 + include/configs/m28evk.h | 303 +++++ include/configs/omap3_beagle.h | 2 +- include/configs/omap4_common.h | 7 +- include/configs/omap5_evm.h | 284 +++++ include/configs/pm9261.h | 3 + include/configs/pm9263.h | 3 + include/configs/pm9g45.h | 3 + include/configs/vpac270.h | 3 +- include/onenand_uboot.h | 3 + spl/Makefile | 4 + tools/.gitignore | 1 + tools/Makefile | 6 + tools/mxsboot.c | 684 +++++++++++ 167 files changed, 21354 insertions(+), 6487 deletions(-) delete mode 100644 arch/arm/cpu/arm926ejs/davinci/am1808_lowlevel.c create mode 100644 arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c rename {board/csb226 => arch/arm/cpu/arm926ejs/mx28}/Makefile (86%) create mode 100644 arch/arm/cpu/arm926ejs/mx28/clock.c create mode 100644 arch/arm/cpu/arm926ejs/mx28/iomux.c create mode 100644 arch/arm/cpu/arm926ejs/mx28/mx28.c create mode 100644 arch/arm/cpu/arm926ejs/mx28/timer.c create mode 100644 arch/arm/cpu/armv7/omap-common/clocks-common.c create mode 100644 arch/arm/cpu/armv7/omap-common/emif-common.c create mode 100644 arch/arm/cpu/armv7/omap-common/hwinit-common.c rename arch/arm/cpu/armv7/{omap4 => omap-common}/lowlevel_init.S (76%) rename arch/arm/cpu/armv7/{omap4/mem.c => omap-common/mem-common.c} (100%) delete mode 100644 arch/arm/cpu/armv7/omap4/board.c create mode 100644 arch/arm/cpu/armv7/omap4/hwinit.c delete mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h create mode 100644 arch/arm/cpu/armv7/omap5/Makefile create mode 100644 arch/arm/cpu/armv7/omap5/clocks.c create mode 100644 arch/arm/cpu/armv7/omap5/config.mk create mode 100644 arch/arm/cpu/armv7/omap5/emif.c create mode 100644 arch/arm/cpu/armv7/omap5/hwinit.c create mode 100644 arch/arm/cpu/armv7/omap5/sdram_elpida.c rename arch/arm/include/asm/arch-davinci/{am1808_lowlevel.h => da850_lowlevel.h} (63%) create mode 100644 arch/arm/include/asm/arch-mx28/clock.h create mode 100644 arch/arm/include/asm/arch-mx28/dma.h create mode 100644 arch/arm/include/asm/arch-mx28/gpio.h create mode 100644 arch/arm/include/asm/arch-mx28/imx-regs.h create mode 100644 arch/arm/include/asm/arch-mx28/iomux-mx28.h create mode 100644 arch/arm/include/asm/arch-mx28/iomux.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-apbh.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-base.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-bch.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-clkctrl.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-common.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-gpmi.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-i2c.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-ocotp.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-pinctrl.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-power.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-rtc.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-ssp.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-timrot.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-usb.h create mode 100644 arch/arm/include/asm/arch-mx28/regs-usbphy.h create mode 100644 arch/arm/include/asm/arch-mx28/sys_proto.h delete mode 100644 arch/arm/include/asm/arch-omap4/emif.h rename arch/arm/include/asm/arch-omap4/{omap4.h => omap.h} (87%) create mode 100644 arch/arm/include/asm/arch-omap5/clocks.h create mode 100644 arch/arm/include/asm/arch-omap5/cpu.h create mode 100644 arch/arm/include/asm/arch-omap5/gpio.h create mode 100644 arch/arm/include/asm/arch-omap5/i2c.h create mode 100644 arch/arm/include/asm/arch-omap5/mmc_host_def.h create mode 100644 arch/arm/include/asm/arch-omap5/mux_omap5.h create mode 100644 arch/arm/include/asm/arch-omap5/omap.h create mode 100644 arch/arm/include/asm/arch-omap5/sys_proto.h create mode 100644 arch/arm/include/asm/arch-pxa/regs-uart.h create mode 100644 arch/arm/include/asm/emif.h create mode 100644 board/armltd/integrator/arm-ebi.h delete mode 100644 board/armltd/integrator/config.mk create mode 100644 board/armltd/integrator/integrator-sc.h delete mode 100644 board/csb226/csb226.c delete mode 100644 board/csb226/flash.c create mode 100644 board/denx/m28evk/Makefile rename arch/arm/cpu/armv7/omap4/sys_info.c => board/denx/m28evk/m28_init.h (53%) create mode 100644 board/denx/m28evk/m28evk.c create mode 100644 board/denx/m28evk/mem_init.c create mode 100644 board/denx/m28evk/mmc_boot.c create mode 100644 board/denx/m28evk/power_init.c create mode 100644 board/denx/m28evk/start.S create mode 100644 board/denx/m28evk/u-boot-spl.lds create mode 100644 board/denx/m28evk/u-boot.bd delete mode 100644 board/innokom/flash.c delete mode 100644 board/innokom/innokom.c rename board/{innokom => ti/omap5_evm}/Makefile (86%) create mode 100644 board/ti/omap5_evm/evm.c create mode 100644 board/ti/omap5_evm/mux_data.h create mode 100644 doc/README.m28 create mode 100644 drivers/dma/apbh_dma.c create mode 100644 drivers/gpio/mxs_gpio.c create mode 100644 drivers/i2c/mxs_i2c.c create mode 100644 drivers/mmc/mxsmmc.c create mode 100644 drivers/mtd/nand/mxs_nand.c create mode 100644 drivers/mtd/onenand/onenand_spl.c create mode 100644 drivers/rtc/mxsrtc.c create mode 100644 drivers/spi/mxs_spi.c create mode 100644 drivers/usb/host/ehci-mxs.c delete mode 100644 include/configs/csb226.h create mode 100644 include/configs/da850_am18xxevm.h create mode 100644 include/configs/davinci_dm6467Tevm.h delete mode 100644 include/configs/innokom.h create mode 100644 include/configs/m28evk.h create mode 100644 include/configs/omap5_evm.h create mode 100644 tools/mxsboot.c
Amicalement,
Hi Albert,
On Tue, Nov 15, 2011 at 1:28 PM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Wolfgang,
As with the last pull request, I don't see the Tegra patches in your list here. Is the problem that we don't have our own Tegra maintainer?
Please can you suggest what we can do here to get things moving?
Amicalement,
Albert. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Albert,
Hi Wolfgang,
CCing Wolfgang.
It'd be good to get a tegra maintainer -- suggestions?
M
On Tue, Nov 15, 2011 at 6:27 PM, Marek Vasut marek.vasut@gmail.com wrote:
Hi Albert,
Hi Wolfgang,
CCing Wolfgang.
+Mike also who has helped reviewing some of this and might have ideas.
If there is no better candidate I am happy to act as Tegra maintainer in the meantime (say 3 months) if it will help reduce workload on Albert. The main thing is to get things moving and I'm happy to help any way I can. There seems to be an enormous amount of activity in U-Boot at the moment, which is great, but it does create a load on the maintainers, particularly Wolfgang and Albert.
M
On Tuesday 15 November 2011 22:45:52 Simon Glass wrote:
On Tue, Nov 15, 2011 at 6:27 PM, Marek Vasut wrote:
On Tue, Nov 15, 2011 at 1:28 PM, Albert ARIBAUD wrote:
Hi Wolfgang,
CCing Wolfgang.
i thought Albert said he didn't want this last time we explicitly asked about creating an arm/tegra sub-arch tree ...
i think there should be one -mike
Hi Mike,
Hi Wolfgang,
CCing Wolfgang.
Yes, I found it, you said:
if people dont care either way, we can just set up a u-boot/u-boot-tegra.git tree for Albert to pull from
and Albert replied:
Seems like people don't care, and I'm fine with applying the patches myself, but I don't want to pull from a tree: I'll apply the patches as they appear on patchwork.
We have built up quite a large number of patches which are currently sitting in the Chromium tree - something like 200. If we continue to dribble these out at 10-20 a month it will take a while. Current mainline U-Boot support for Tegra is pretty basic, but with these patches it is pretty slick. It would be great to take advantage of the oppty at the moment to upstream this material. Tegra 30 is already starting to get into the kernel and I feel U-Boot is behind! We are the boot loader. We need to be ahead :-)
Dear Simon Glass,
In message CAPnjgZ0PO2ZdcGhtD-dt0PNv3G6sFDzZjsUTL_-6v1wQ10ASzw@mail.gmail.com you wrote:
Then let's try out this new u-boot-staging thing [1]. I suggest somebody (not the original poster, of course) reviews and pushes the stuff into a branch in this repo, and sends then a pull request to Albert. Either it works better, or else not much is lost either.
[1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/117084
Hi Mike,
Uhm, no, I don't think I said I was against creating a Tegra U-Boot repo. What I may have said is that I don't want to fetch from a repo located somewhere else that on the Denx git server. If a u-boot-tegra repo is created on the Denx server, I'll be happy to pull from it.
Amicalement,
i don't think we ever suggested the repo would be anywhere other than on the denx site, and i don't recall your response including "external to denx" qualifiers. but let's skip the semantics and on to the end game.
i think we need Wolfgang's support for setting up the repo. i don't think denx is running anything like gitolite for people to admin repos via ssh.
we need one name i think as the goto guy for the repo. i don't know of any other repo that allows more than one person to push to it, but i don't see a problem with allowing more than one ... -mike
Dear Mike Frysinger,
No problem with that. u-boot-tegra ? u-boot-tegra2 ? or ... ?
No.
Actually there are a few, even though this is not broadly announced - except for u-boot-staging, where all custodians have access.
Hi Wolfgang, Mike,
Simon will probably be better placed for answering. Personally I prefer boot-tegra if tegra and tegra2 have much in common.
Amicalement,
Hello Albert,
Hi Wolfgang,
missing here this patch:
[U-Boot,1/2] arm, arm926ejs: always do cpu critical inits http://patchwork.ozlabs.org/patch/124787/
Did you found time to look at it?
bye, Heiko
Dear Albert ARIBAUD,
In message 4EC2D979.6090301@aribaud.net you wrote:
Hi Wolfgang,
David M�ller (ELSOFT AG) (2): ARM: re-add MACH_TYPE_XXXXXX for VCMA9 board and add CONFIG_MACH_TYPE ARM: remove superfluous setting of arch_number in board specific code.
Applied, thanks.
participants (6)
Albert ARIBAUD
Heiko Schocher
Mike Frysinger
