[PATCH 00/11] board/ti: k3 boards: Stop using findfdt
Hopefully the last time. Apologies on the screw ups. Ran CI loop[1] to be doubly sure that I have'nt yet again fat fingered something.
This is a wide cleanup to switch to setting fdtfile using env_set instead of scripted magic. 'fdtfile' is expected to be set by default. This allows the stdboot triggered efi loaders to find the correct OS device tree file even if regular boot process is interrupted by user intervention.
Fixes since V3: * fix up missing header for am62x evm (I seemed to have dropped the fixup somehow)
based on: master e8f2404e093d Merge branch 'master-779h0-r2' of https://source.denx.de/u-boot/custodians/u-boot-sh
Since this impacts out of box distro support, will be great to get it as part of 2024.04 release.
Testing (decided to retest it all): https://gist.github.com/nmenon/b9d49d752c27988aabdc062dcdc41e67
V3: https://lore.kernel.org/all/20240130130615.670783-1-nm@ti.com/ V2: https://lore.kernel.org/all/20240109191506.3820908-1-nm@ti.com/ V1: https://lore.kernel.org/all/20240108173301.2692332-1-nm@ti.com/
Nishanth Menon (11): board: ti: Add missing common/Kconfig references board: ti: common: Introduce a common fdt ops library board: ti: am62ax: Set fdtfile from C code instead of findfdt script board: ti: am62x: Set fdtfile from C code instead of findfdt script board: ti: am64x: Set fdtfile from C code instead of findfdt script board: ti: am65x: Set fdtfile from C code instead of findfdt script board: ti: j721e: Set fdtfile from C code instead of findfdt script board: ti: j721s2: Set fdtfile from C code instead of findfdt script board: beagle: beagleboneai64: Set fdtfile from C code instead of findfdt script board: beagle: beagleplay: Set fdtfile from C code instead of findfdt script include: env: ti: Drop default_findfdt
board/beagle/beagleboneai64/beagleboneai64.c | 14 ++++ .../beagle/beagleboneai64/beagleboneai64.env | 1 - board/beagle/beagleplay/beagleplay.c | 14 ++++ board/beagle/beagleplay/beagleplay.env | 1 - board/ti/am62ax/am62ax.env | 1 - board/ti/am62ax/evm.c | 10 +++ board/ti/am62x/am62x.env | 1 - board/ti/am62x/evm.c | 10 +++ board/ti/am64x/am64x.env | 9 --- board/ti/am64x/evm.c | 8 +++ board/ti/am65x/am65x.env | 3 - board/ti/am65x/evm.c | 2 + board/ti/common/Kconfig | 12 ++++ board/ti/common/Makefile | 1 + board/ti/common/fdt_ops.c | 64 +++++++++++++++++++ board/ti/common/fdt_ops.h | 42 ++++++++++++ board/ti/j721e/evm.c | 8 +++ board/ti/j721e/j721e.env | 10 --- board/ti/j721s2/evm.c | 8 +++ board/ti/j721s2/j721s2.env | 8 --- board/ti/omap3evm/Kconfig | 2 + board/ti/panda/Kconfig | 2 + board/ti/sdp4430/Kconfig | 2 + configs/am62ax_evm_a53_defconfig | 1 + configs/am62x_beagleplay_a53_defconfig | 3 +- configs/am62x_evm_a53_defconfig | 1 + configs/j721e_beagleboneai64_a72_defconfig | 3 +- include/env/ti/default_findfdt.env | 12 ---- 28 files changed, 205 insertions(+), 48 deletions(-) create mode 100644 board/ti/common/fdt_ops.c create mode 100644 board/ti/common/fdt_ops.h delete mode 100644 include/env/ti/default_findfdt.env
[1] https://github.com/u-boot/u-boot/pull/487
base-commit: e8f2404e093daf6cc3ac2b3233e3c6770d13e371
Add missing board/ti/common/Kconfig references for the platforms that missed it. The intent is for the common Kconfig to be usable across TI reference boards as required.
Reported-by: Tom Rini trini@konsulko.com Signed-off-by: Nishanth Menon nm@ti.com --- Changes since V3: * No change
V3: https://lore.kernel.org/r/20240130130615.670783-2-nm@ti.com
board/ti/omap3evm/Kconfig | 2 ++ board/ti/panda/Kconfig | 2 ++ board/ti/sdp4430/Kconfig | 2 ++ 3 files changed, 6 insertions(+)
diff --git a/board/ti/omap3evm/Kconfig b/board/ti/omap3evm/Kconfig index 08a8aa20ae85..cd71fe083176 100644 --- a/board/ti/omap3evm/Kconfig +++ b/board/ti/omap3evm/Kconfig @@ -9,4 +9,6 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "omap3_evm"
+source "board/ti/common/Kconfig" + endif diff --git a/board/ti/panda/Kconfig b/board/ti/panda/Kconfig index 8f277b612a45..5912f69babe2 100644 --- a/board/ti/panda/Kconfig +++ b/board/ti/panda/Kconfig @@ -9,4 +9,6 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "omap4_panda"
+source "board/ti/common/Kconfig" + endif diff --git a/board/ti/sdp4430/Kconfig b/board/ti/sdp4430/Kconfig index 36f185282166..65e9107bc1b0 100644 --- a/board/ti/sdp4430/Kconfig +++ b/board/ti/sdp4430/Kconfig @@ -12,4 +12,6 @@ config SYS_CONFIG_NAME config CMD_BAT bool "Enable board-specific battery command"
Introduce a common fdt operations library for basic device tree operations that are common between various boards.
The first library to introduce here is the capability to set up fdtfile as a standard variable as part of board identification rather than depend on scripted ifdeffery.
Reviewed-by: Jonathan Humphreys j-humphreys@ti.com Reviewed-by: Roger Quadros rogerq@kernel.org Signed-off-by: Nishanth Menon nm@ti.com --- Changes since V3: * No change
V3: https://lore.kernel.org/r/20240130130615.670783-3-nm@ti.com
board/ti/common/Kconfig | 12 ++++++++ board/ti/common/Makefile | 1 + board/ti/common/fdt_ops.c | 64 +++++++++++++++++++++++++++++++++++++++ board/ti/common/fdt_ops.h | 42 +++++++++++++++++++++++++ 4 files changed, 119 insertions(+) create mode 100644 board/ti/common/fdt_ops.c create mode 100644 board/ti/common/fdt_ops.h
diff --git a/board/ti/common/Kconfig b/board/ti/common/Kconfig index 49edd98014ab..de44e4de2115 100644 --- a/board/ti/common/Kconfig +++ b/board/ti/common/Kconfig @@ -49,3 +49,15 @@ config TI_COMMON_CMD_OPTIONS imply CMD_SPI imply CMD_TIME imply CMD_USB if USB + +config TI_FDT_FOLDER_PATH + string "Location of Folder path where dtb is present" + default "ti/davinci" if ARCH_DAVINCI + default "ti/keystone" if ARCH_KEYSTONE + default "ti/omap" if ARCH_OMAP2PLUS + default "ti" if ARCH_K3 + depends on ARCH_DAVINCI || ARCH_KEYSTONE || ARCH_OMAP2PLUS || ARCH_K3 + help + Folder path for kernel device tree default. + This is used along with fdtfile path to locate the kernel + device tree blob. diff --git a/board/ti/common/Makefile b/board/ti/common/Makefile index 26bf12e2e6d5..5ac361ba7fcf 100644 --- a/board/ti/common/Makefile +++ b/board/ti/common/Makefile @@ -3,3 +3,4 @@
obj-${CONFIG_TI_I2C_BOARD_DETECT} += board_detect.o obj-${CONFIG_CMD_EXTENSION} += cape_detect.o +obj-${CONFIG_OF_LIBFDT} += fdt_ops.o diff --git a/board/ti/common/fdt_ops.c b/board/ti/common/fdt_ops.c new file mode 100644 index 000000000000..eb917be9e0da --- /dev/null +++ b/board/ti/common/fdt_ops.c @@ -0,0 +1,64 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Library to support FDT file operations which are common + * + * Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include <env.h> +#include <vsprintf.h> +#include "fdt_ops.h" + +void ti_set_fdt_env(const char *board_name, struct ti_fdt_map *fdt_map) +{ + char *fdt_file_name = NULL; + char fdtfile[TI_FDT_FILE_MAX]; + + if (board_name) { + while (fdt_map) { + /* Check for NULL terminator in the list */ + if (!fdt_map->board_name) + break; + if (!strncmp(fdt_map->board_name, board_name, TI_BOARD_NAME_MAX)) { + fdt_file_name = fdt_map->fdt_file_name; + break; + } + fdt_map++; + } + } + + /* match not found OR null board_name */ + if (!fdt_file_name) { + /* + * Prioritize CONFIG_DEFAULT_FDT_FILE - if that is not defined, + * or is empty, then use CONFIG_DEFAULT_DEVICE_TREE + */ +#ifdef CONFIG_DEFAULT_FDT_FILE + if (strlen(CONFIG_DEFAULT_FDT_FILE)) { + snprintf(fdtfile, sizeof(fdtfile), "%s/%s", + CONFIG_TI_FDT_FOLDER_PATH, CONFIG_DEFAULT_FDT_FILE); + } else +#endif + { + snprintf(fdtfile, sizeof(fdtfile), "%s/%s.dtb", + CONFIG_TI_FDT_FOLDER_PATH, CONFIG_DEFAULT_DEVICE_TREE); + } + } else { + snprintf(fdtfile, sizeof(fdtfile), "%s/%s", CONFIG_TI_FDT_FOLDER_PATH, + fdt_file_name); + } + + env_set("fdtfile", fdtfile); + + /* + * XXX: DEPRECATION WARNING: 2 u-boot versions (2024.10). + * + * Maintain compatibility with downstream scripts that may be using + * name_fdt + */ + if (board_name) + env_set("name_fdt", fdtfile); + /* Also set the findfdt legacy script to warn users to stop using this */ + env_set("findfdt", + "echo WARN: fdtfile already set. Stop using findfdt in script"); +} diff --git a/board/ti/common/fdt_ops.h b/board/ti/common/fdt_ops.h new file mode 100644 index 000000000000..5d304994fb6e --- /dev/null +++ b/board/ti/common/fdt_ops.h @@ -0,0 +1,42 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * Library to support common device tree manipulation for TI EVMs + * + * Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com + */ + +#ifndef __FDT_OPS_H +#define __FDT_OPS_H + +#define TI_BOARD_NAME_MAX 20 +#define TI_FDT_FILE_MAX 200 + +/** + * struct ti_fdt_map - mapping of device tree blob name to board name + * @board_name: board_name up to TI_BOARD_NAME_MAX long + * @fdt_file_name: device tree blob name as described by kernel + */ +struct ti_fdt_map { + const char *board_name; + char *fdt_file_name; +}; + +/** + * ti_set_fdt_env - Find the correct device tree file name based on the + * board name and set 'fdtfile' env variable with correct folder + * structure appropriate to the architecture and Linux kernel's + * 'make install_dtbs' conventions. This function is invoked typically + * as part of board_late_init. + * + * fdt name is picked by: + * a) If a board name match is found, use the match + * b) If not, CONFIG_DEFAULT_FDT_FILE (Boot OS device tree) if that is defined + * and not null + * c) If not, Use CONFIG_DEFAULT_DEVICE_TREE (DT control for bootloader) + * + * @board_name: match to search with (max of TI_BOARD_NAME_MAX chars) + * @fdt_map: NULL terminated array of device tree file name matches. + */ +void ti_set_fdt_env(const char *board_name, struct ti_fdt_map *fdt_map); + +#endif /* __FDT_OPS_H */
Stop using the findfdt script and switch to setting the fdtfile from C code.
While at this, replace findfdt in environment with a warning as it is no longer needed
V3: https://lore.kernel.org/r/20240130130615.670783-4-nm@ti.com
board/ti/am62ax/am62ax.env | 1 - board/ti/am62ax/evm.c | 10 ++++++++++ configs/am62ax_evm_a53_defconfig | 1 + 3 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/board/ti/am62ax/am62ax.env b/board/ti/am62ax/am62ax.env index a6d967e982d4..334374abb73e 100644 --- a/board/ti/am62ax/am62ax.env +++ b/board/ti/am62ax/am62ax.env @@ -1,5 +1,4 @@ #include <env/ti/ti_common.env> -#include <env/ti/default_findfdt.env> #include <env/ti/mmc.env>
name_kern=Image diff --git a/board/ti/am62ax/evm.c b/board/ti/am62ax/evm.c index cd3360a43029..62d3664936e7 100644 --- a/board/ti/am62ax/evm.c +++ b/board/ti/am62ax/evm.c @@ -13,6 +13,8 @@ #include <fdt_support.h> #include <spl.h>
+#include "../common/fdt_ops.h" + int board_init(void) { return 0; @@ -27,3 +29,11 @@ int dram_init_banksize(void) { return fdtdec_setup_memory_banksize(); } + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + ti_set_fdt_env(NULL, NULL); + return 0; +} +#endif diff --git a/configs/am62ax_evm_a53_defconfig b/configs/am62ax_evm_a53_defconfig index 38083586a3ec..e5fcd8cc5b6f 100644 --- a/configs/am62ax_evm_a53_defconfig +++ b/configs/am62ax_evm_a53_defconfig @@ -24,6 +24,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_BOOTSTD_FULL=y CONFIG_BOOTSTD_DEFAULTS=y CONFIG_BOOTCOMMAND="run envboot; bootflow scan -lb" +CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_PAD_TO=0x0 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y
Reviewed-by: Jonathan Humphreys j-humphreys@ti.com Reviewed-by: Roger Quadros rogerq@kernel.org Signed-off-by: Nishanth Menon nm@ti.com --- Changes since V3: * Add missing header file - have no idea how i dropped that fixup.. :(
V3: https://lore.kernel.org/r/20240130130615.670783-5-nm@ti.com
board/ti/am62x/am62x.env | 1 - board/ti/am62x/evm.c | 10 ++++++++++ configs/am62x_evm_a53_defconfig | 1 + 3 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/board/ti/am62x/am62x.env b/board/ti/am62x/am62x.env index e53a55c38fbb..9cb186c2a03c 100644 --- a/board/ti/am62x/am62x.env +++ b/board/ti/am62x/am62x.env @@ -1,5 +1,4 @@ #include <env/ti/ti_common.env> -#include <env/ti/default_findfdt.env> #include <env/ti/mmc.env>
name_kern=Image diff --git a/board/ti/am62x/evm.c b/board/ti/am62x/evm.c index 88e02155ee33..b3e8680dfab2 100644 --- a/board/ti/am62x/evm.c +++ b/board/ti/am62x/evm.c @@ -19,6 +19,8 @@ #include <asm/arch/hardware.h> #include <dm/uclass.h>
+#include "../common/fdt_ops.h" + DECLARE_GLOBAL_DATA_PTR;
#if CONFIG_IS_ENABLED(SPLASH_SCREEN) @@ -54,6 +56,14 @@ int dram_init(void) return fdtdec_setup_mem_size_base(); }
+#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + ti_set_fdt_env(NULL, NULL); + return 0; +} +#endif + int dram_init_banksize(void) { return fdtdec_setup_memory_banksize(); diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index 457931faf210..a39b82d05a63 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -32,6 +32,7 @@ CONFIG_BOOTSTD_FULL=y CONFIG_BOOTSTD_DEFAULTS=y CONFIG_SYS_BOOTM_LEN=0x800000 CONFIG_BOOTCOMMAND="run envboot; bootflow scan -lb" +CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80c80000
We now can provide a map and have the standard fdtfile variable set from code itself. This allows for bootstd to "just work".
While at this, replace findfdt in environment with a warning as it is no longer needed.
V3: https://lore.kernel.org/r/20240130130615.670783-6-nm@ti.com
board/ti/am64x/am64x.env | 9 --------- board/ti/am64x/evm.c | 8 ++++++++ 2 files changed, 8 insertions(+), 9 deletions(-)
diff --git a/board/ti/am64x/am64x.env b/board/ti/am64x/am64x.env index efd736b99be4..9a8812d4ee54 100644 --- a/board/ti/am64x/am64x.env +++ b/board/ti/am64x/am64x.env @@ -2,14 +2,6 @@ #include <env/ti/mmc.env> #include <env/ti/k3_dfu.env>
-findfdt= - if test $board_name = am64x_gpevm; then - setenv name_fdt ti/k3-am642-evm.dtb; fi; - if test $board_name = am64x_skevm; then - setenv name_fdt ti/k3-am642-sk.dtb; fi; - if test $name_fdt = undefined; then - echo WARNING: Could not determine device tree to use; fi; - setenv fdtfile ${name_fdt} name_kern=Image console=ttyS2,115200n8 args_all=setenv optargs earlycon=ns16550a,mmio32,0x02800000 ${mtdparts} @@ -43,7 +35,6 @@ get_fit_usb=load usb ${bootpart} ${addr_fit} usbboot=setenv boot usb; setenv bootpart 0:2; usb start; - run findfdt; run init_usb; run get_kern_usb; run get_fdt_usb; diff --git a/board/ti/am64x/evm.c b/board/ti/am64x/evm.c index a7ca6be436eb..b8de69da06c5 100644 --- a/board/ti/am64x/evm.c +++ b/board/ti/am64x/evm.c @@ -16,6 +16,7 @@ #include <env.h>
#include "../common/board_detect.h" +#include "../common/fdt_ops.h"
#define board_is_am64x_gpevm() (board_ti_k3_is("AM64-GPEVM") || \ board_ti_k3_is("AM64-EVM") || \ @@ -181,6 +182,12 @@ int checkboard(void) }
#ifdef CONFIG_BOARD_LATE_INIT +static struct ti_fdt_map ti_am64_evm_fdt_map[] = { + {"am64x_gpevm", "k3-am642-evm.dtb"}, + {"am64x_skevm", "k3-am642-sk.dtb"}, + { /* Sentinel. */ } +}; + static void setup_board_eeprom_env(void) { char *name = "am64x_gpevm"; @@ -198,6 +205,7 @@ static void setup_board_eeprom_env(void)
invalid_eeprom: set_board_info_env_am6(name); + ti_set_fdt_env(name, ti_am64_evm_fdt_map); }
static void setup_serial(void)
V3: https://lore.kernel.org/r/20240130130615.670783-7-nm@ti.com
board/ti/am65x/am65x.env | 3 --- board/ti/am65x/evm.c | 2 ++ 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/board/ti/am65x/am65x.env b/board/ti/am65x/am65x.env index 286b9c300c05..814374d68cf0 100644 --- a/board/ti/am65x/am65x.env +++ b/board/ti/am65x/am65x.env @@ -5,9 +5,6 @@ #include <env/ti/k3_rproc.env> #endif
-findfdt= - setenv name_fdt ti/k3-am654-base-board.dtb; - setenv fdtfile ${name_fdt} name_kern=Image console=ttyS2,115200n8 args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000 diff --git a/board/ti/am65x/evm.c b/board/ti/am65x/evm.c index df209021c1b7..3109c9a2acac 100644 --- a/board/ti/am65x/evm.c +++ b/board/ti/am65x/evm.c @@ -22,6 +22,7 @@ #include <linux/printk.h>
#define board_is_am65x_base_board() board_ti_is("AM6-COMPROCEVM")
@@ -141,6 +142,7 @@ static void setup_board_eeprom_env(void)
invalid_eeprom: set_board_info_env_am6(name); + ti_set_fdt_env(NULL, NULL); }
static int init_daughtercard_det_gpio(char *gpio_name, struct gpio_desc *desc)
V3: https://lore.kernel.org/r/20240130130615.670783-8-nm@ti.com
board/ti/j721e/evm.c | 8 ++++++++ board/ti/j721e/j721e.env | 10 ---------- 2 files changed, 8 insertions(+), 10 deletions(-)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index b77cffc5ef56..9dc3ed6dfffa 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -16,6 +16,7 @@ #include <dm.h>
#define board_is_j721e_som() (board_ti_k3_is("J721EX-PM1-SOM") || \ board_ti_k3_is("J721EX-PM2-SOM")) @@ -353,6 +354,12 @@ static int probe_daughtercards(void) #endif
#ifdef CONFIG_BOARD_LATE_INIT +static struct ti_fdt_map ti_j721e_evm_fdt_map[] = { + {"j721e", "k3-j721e-common-proc-board.dtb"}, + {"j721e-sk", "k3-j721e-sk.dtb"}, + {"j7200", "k3-j7200-common-proc-board.dtb"}, + { /* Sentinel. */ } +}; static void setup_board_eeprom_env(void) { char *name = "j721e"; @@ -372,6 +379,7 @@ static void setup_board_eeprom_env(void)
invalid_eeprom: set_board_info_env_am6(name); + ti_set_fdt_env(name, ti_j721e_evm_fdt_map); }
static void setup_serial(void) diff --git a/board/ti/j721e/j721e.env b/board/ti/j721e/j721e.env index cb27bf5e2b24..38bfd7d49634 100644 --- a/board/ti/j721e/j721e.env +++ b/board/ti/j721e/j721e.env @@ -7,16 +7,6 @@ #include <env/ti/k3_rproc.env> #endif
-default_device_tree=ti/k3-j721e-common-proc-board.dtb -findfdt= - setenv name_fdt ${default_device_tree}; - if test $board_name = j721e; then - setenv name_fdt ti/k3-j721e-common-proc-board.dtb; fi; - if test $board_name = j7200; then - setenv name_fdt ti/k3-j7200-common-proc-board.dtb; fi; - if test $board_name = j721e-eaik || test $board_name = j721e-sk; then - setenv name_fdt ti/k3-j721e-sk.dtb; fi; - setenv fdtfile ${name_fdt} name_kern=Image console=ttyS2,115200n8 args_all=setenv optargs earlycon=ns16550a,mmio32,0x02800000
V3: https://lore.kernel.org/r/20240130130615.670783-9-nm@ti.com
board/ti/j721s2/evm.c | 8 ++++++++ board/ti/j721s2/j721s2.env | 8 -------- 2 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index 1220cd84519b..5a0281d6b483 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -23,6 +23,7 @@ #include <dm/root.h>
@@ -114,6 +115,12 @@ int checkboard(void) return 0; }
+static struct ti_fdt_map ti_j721s2_evm_fdt_map[] = { + {"j721s2", "k3-j721s2-common-proc-board.dtb"}, + {"am68-sk", "k3-am68-sk-base-board.dtb"}, + { /* Sentinel. */ } +}; + static void setup_board_eeprom_env(void) { char *name = "j721s2"; @@ -131,6 +138,7 @@ static void setup_board_eeprom_env(void)
invalid_eeprom: set_board_info_env_am6(name); + ti_set_fdt_env(name, ti_j721s2_evm_fdt_map); }
static void setup_serial(void) diff --git a/board/ti/j721s2/j721s2.env b/board/ti/j721s2/j721s2.env index 64e3d9da85f0..9a03b9f30aee 100644 --- a/board/ti/j721s2/j721s2.env +++ b/board/ti/j721s2/j721s2.env @@ -7,14 +7,6 @@ #include <env/ti/k3_rproc.env> #endif
-default_device_tree=ti/k3-j721s2-common-proc-board.dtb -findfdt= - setenv name_fdt ${default_device_tree}; - if test $board_name = j721s2; then \ - setenv name_fdt ti/k3-j721s2-common-proc-board.dtb; fi; - if test $board_name = am68-sk; then - setenv name_fdt ti/k3-am68-sk-base-board.dtb; fi; - setenv fdtfile ${name_fdt} name_kern=Image console=ttyS2,115200n8 args_all=setenv optargs earlycon=ns16550a,mmio32,0x02880000
V3: https://lore.kernel.org/r/20240130130615.670783-10-nm@ti.com
board/beagle/beagleboneai64/beagleboneai64.c | 14 ++++++++++++++ board/beagle/beagleboneai64/beagleboneai64.env | 1 - configs/j721e_beagleboneai64_a72_defconfig | 3 ++- 3 files changed, 16 insertions(+), 2 deletions(-)
diff --git a/board/beagle/beagleboneai64/beagleboneai64.c b/board/beagle/beagleboneai64/beagleboneai64.c index c8c1c78ae5a2..c5b4ff7df47a 100644 --- a/board/beagle/beagleboneai64/beagleboneai64.c +++ b/board/beagle/beagleboneai64/beagleboneai64.c @@ -28,3 +28,17 @@ int dram_init_banksize(void) { return fdtdec_setup_memory_banksize(); } + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + char fdtfile[50]; + + snprintf(fdtfile, sizeof(fdtfile), "%s/%s.dtb", + CONFIG_TI_FDT_FOLDER_PATH, CONFIG_DEFAULT_DEVICE_TREE); + + env_set("fdtfile", fdtfile); + + return 0; +} +#endif diff --git a/board/beagle/beagleboneai64/beagleboneai64.env b/board/beagle/beagleboneai64/beagleboneai64.env index 4f0a94a8113e..647b25d14c8e 100644 --- a/board/beagle/beagleboneai64/beagleboneai64.env +++ b/board/beagle/beagleboneai64/beagleboneai64.env @@ -1,5 +1,4 @@ #include <env/ti/ti_common.env> -#include <env/ti/default_findfdt.env> #include <env/ti/mmc.env>
name_kern=Image diff --git a/configs/j721e_beagleboneai64_a72_defconfig b/configs/j721e_beagleboneai64_a72_defconfig index 4b019fa2f30e..3f061381f06c 100644 --- a/configs/j721e_beagleboneai64_a72_defconfig +++ b/configs/j721e_beagleboneai64_a72_defconfig @@ -34,7 +34,8 @@ CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_OF_SYSTEM_SETUP=y -CONFIG_BOOTCOMMAND="run set_led_state_start_load;run findfdt; run envboot; bootflow scan -lb;run set_led_state_fail_load" +CONFIG_BOOTCOMMAND="run set_led_state_start_load; run envboot; bootflow scan -lb;run set_led_state_fail_load" +CONFIG_BOARD_LATE_INIT=y CONFIG_LOGLEVEL=7 CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y
V3: https://lore.kernel.org/r/20240130130615.670783-11-nm@ti.com
board/beagle/beagleplay/beagleplay.c | 14 ++++++++++++++ board/beagle/beagleplay/beagleplay.env | 1 - configs/am62x_beagleplay_a53_defconfig | 3 ++- 3 files changed, 16 insertions(+), 2 deletions(-)
diff --git a/board/beagle/beagleplay/beagleplay.c b/board/beagle/beagleplay/beagleplay.c index 1c376dea372f..20819ecf45b4 100644 --- a/board/beagle/beagleplay/beagleplay.c +++ b/board/beagle/beagleplay/beagleplay.c @@ -27,3 +27,17 @@ int dram_init_banksize(void) { return fdtdec_setup_memory_banksize(); } + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + char fdtfile[50]; + + snprintf(fdtfile, sizeof(fdtfile), "%s/%s.dtb", + CONFIG_TI_FDT_FOLDER_PATH, CONFIG_DEFAULT_DEVICE_TREE); + + env_set("fdtfile", fdtfile); + + return 0; +} +#endif diff --git a/board/beagle/beagleplay/beagleplay.env b/board/beagle/beagleplay/beagleplay.env index 4f0a94a8113e..647b25d14c8e 100644 --- a/board/beagle/beagleplay/beagleplay.env +++ b/board/beagle/beagleplay/beagleplay.env @@ -1,5 +1,4 @@ #include <env/ti/ti_common.env> -#include <env/ti/default_findfdt.env> #include <env/ti/mmc.env>
name_kern=Image diff --git a/configs/am62x_beagleplay_a53_defconfig b/configs/am62x_beagleplay_a53_defconfig index 0be20045a974..1f43891d10bb 100644 --- a/configs/am62x_beagleplay_a53_defconfig +++ b/configs/am62x_beagleplay_a53_defconfig @@ -33,7 +33,8 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " -CONFIG_BOOTCOMMAND="run set_led_state_start_load;run findfdt; run envboot; bootflow scan -lb;run set_led_state_fail_load" +CONFIG_BOOTCOMMAND="run set_led_state_start_load; run envboot; bootflow scan -lb;run set_led_state_fail_load" +CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80c80000
We shouldn't need finfdt anymore. Drop the env script.
V3: https://lore.kernel.org/r/20240130130615.670783-12-nm@ti.com
include/env/ti/default_findfdt.env | 12 ------------ 1 file changed, 12 deletions(-) delete mode 100644 include/env/ti/default_findfdt.env
diff --git a/include/env/ti/default_findfdt.env b/include/env/ti/default_findfdt.env deleted file mode 100644 index a2b51dd923bb..000000000000 --- a/include/env/ti/default_findfdt.env +++ /dev/null @@ -1,12 +0,0 @@ -default_device_tree=CONFIG_DEFAULT_DEVICE_TREE -default_device_tree_arch=ti -#ifdef CONFIG_ARM64 -findfdt= - setenv name_fdt ${default_device_tree_arch}/${default_device_tree}.dtb; - setenv fdtfile ${name_fdt} -#else -default_device_tree_subarch=omap -findfdt= - setenv name_fdt ${default_device_tree_arch}/${default_device_tree_subarch}/${default_device_tree}.dtb; - setenv fdtfile ${name_fdt} -#endif
Nishanth Menon
