[U-Boot] [PATCH v2] usb: dwc2_udc_otg: support 8-bit interface
Define CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8 to allow the physical interface to be 8-bit (rather than 16-bit).
Signed-off-by: Steve Rae srae@broadcom.com --- from [1] (line ~124)
/* The Kona PHY supports an 8-bit wide UTMI interface */ [...snip...]
module_platform_driver(bcm_kona_usb2_driver);
MODULE_ALIAS("platform:bcm-kona-usb2"); MODULE_AUTHOR("Matt Porter mporter@linaro.org"); MODULE_DESCRIPTION("BCM Kona USB 2.0 PHY driver"); MODULE_LICENSE("GPL v2");
[1] https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers...
Changes in v2: - implement as Kconfig
configs/bcm11130_defconfig | 1 + configs/bcm11130_nand_defconfig | 1 + configs/bcm28155_ap_defconfig | 1 + configs/bcm28155_w1d_defconfig | 1 + drivers/usb/gadget/Kconfig | 10 ++++++++++ drivers/usb/gadget/dwc2_udc_otg.c | 4 ++++ 6 files changed, 18 insertions(+)
diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index b8ec8ac..2716868 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Broadcom Corporation" CONFIG_G_DNL_VENDOR_NUM=0x18d1 diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index 6021fd2..8e01c52 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Broadcom Corporation" CONFIG_G_DNL_VENDOR_NUM=0x18d1 diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index 4404f32..eb58401 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Broadcom Corporation" CONFIG_G_DNL_VENDOR_NUM=0x18d1 diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index 60eb328..35d04af 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Broadcom Corporation" CONFIG_G_DNL_VENDOR_NUM=0x18d1 diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index a35a1c7..39e5c03 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -52,6 +52,16 @@ config USB_GADGET_DWC2_OTG driver to operate in Peripheral mode. This option requires USB_GADGET to be enabled.
+if USB_GADGET_DWC2_OTG + +config USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8 + bool "DesignWare USB2.0 HS OTG controller PHY interface width" + help + Set the Designware USB2.0 high-speed OTG controller + PHY interface width to 8 bits, rather than the default (16 bits). + +endif # USB_GADGET_DWC2_OTG + config CI_UDC bool "ChipIdea device controller" select USB_GADGET_DUALSPEED diff --git a/drivers/usb/gadget/dwc2_udc_otg.c b/drivers/usb/gadget/dwc2_udc_otg.c index cb20b00..a23278d 100644 --- a/drivers/usb/gadget/dwc2_udc_otg.c +++ b/drivers/usb/gadget/dwc2_udc_otg.c @@ -415,7 +415,11 @@ static void reconfig_usbd(struct dwc2_udc *dev) |0<<7 /* Ulpi DDR sel*/ |0<<6 /* 0: high speed utmi+, 1: full speed serial*/ |0<<4 /* 0: utmi+, 1:ulpi*/ +#ifdef CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8 + |0<<3 /* phy i/f 0:8bit, 1:16bit*/ +#else |1<<3 /* phy i/f 0:8bit, 1:16bit*/ +#endif |0x7<<0; /* HS/FS Timeout**/
if (dev->pdata->usb_gusbcfg)
Hi, minor nits below.
/* The Kona PHY supports an 8-bit wide UTMI interface */ [...snip...] module_platform_driver(bcm_kona_usb2_driver); MODULE_ALIAS("platform:bcm-kona-usb2"); MODULE_AUTHOR("Matt Porter <mporter@linaro.org>"); MODULE_DESCRIPTION("BCM Kona USB 2.0 PHY driver"); MODULE_LICENSE("GPL v2");
Changes in v2:
Config file changes should go through the bcm tree or whoever picks those.
- bool "DesignWare USB2.0 HS OTG controller PHY interface width"
Rename it to "8-bit PHY bus width", otherwise the boolean value won't make sense here.
- help
Changes in v2:
As far as I know, "nobody" is assigned to pick the "bcm tree" I've added Albert (arm) ?!?!?
DONE = v3
help
-- Best regards, Marek Vasut
Changes in v2:
Yeah, either Albert or Tom then. Still ... this might be an indication that this situation needs to be fixed ;-)
DONE = v3
Thanks
help
Steve Rae
