[U-Boot] [PATCH 0/3] pci: pcie_fsl: add support for none PCIe devices
add support for devices with compatible property: "fsl,mpc8540-pci". Unfortunately we can not change the property name, as already defined in linux.
This patch superseeds patch [1]: http://patchwork.ozlabs.org/patch/1132418/
While working to integrate comments from Z.q. Hou to patch [1], I thought it may is the better idea, to use the already existing pcie_fsl driver and work in support for pci devices. Please comment!
If it is no good idea, I have also a v2 of [1] with the comments from Z.q. Hou worked in ready to post...
Travis build: https://travis-ci.org/hsdenx/u-boot-test/builds/595057579 (sheevaplug fails, but this is on discussion on list)
Heiko Schocher (3): pci: pcie_fsl: use pci_conv_size_to_32() pci: pcie_fsl: reorder addr check function pci: pcie_fsl: add support for "fsl,mpc8540-pci"
drivers/pci/pcie_fsl.c | 68 +++++++++++++++++++----------------------- drivers/pci/pcie_fsl.h | 1 + 2 files changed, 32 insertions(+), 37 deletions(-)
simplify read/write functions and use pci_conv_size_to_32().
Signed-off-by: Heiko Schocher hs@denx.de ---
drivers/pci/pcie_fsl.c | 35 ++--------------------------------- 1 file changed, 2 insertions(+), 33 deletions(-)
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index ab25aeee73..ada6e12e2f 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -58,21 +58,8 @@ static int fsl_pcie_read_config(struct udevice *bus, pci_dev_t bdf, bdf = bdf - PCI_BDF(bus->seq, 0, 0); val = bdf | (offset & 0xfc) | ((offset & 0xf00) << 16) | 0x80000000; out_be32(®s->cfg_addr, val); - sync(); - - switch (size) { - case PCI_SIZE_8: - *valuep = in_8((u8 *)®s->cfg_data + (offset & 3)); - break; - case PCI_SIZE_16: - *valuep = in_le16((u16 *)((u8 *)®s->cfg_data + - (offset & 2))); - break; - case PCI_SIZE_32: - *valuep = in_le32(®s->cfg_data); - break; - } + *valuep = pci_conv_32_to_size(in_le32(®s->cfg_data), offset, size);
return 0; } @@ -84,9 +71,6 @@ static int fsl_pcie_write_config(struct udevice *bus, pci_dev_t bdf, struct fsl_pcie *pcie = dev_get_priv(bus); ccsr_fsl_pci_t *regs = pcie->regs; u32 val; - u8 val_8; - u16 val_16; - u32 val_32;
if (fsl_pcie_addr_valid(pcie, bdf)) return 0; @@ -94,23 +78,8 @@ static int fsl_pcie_write_config(struct udevice *bus, pci_dev_t bdf, bdf = bdf - PCI_BDF(bus->seq, 0, 0); val = bdf | (offset & 0xfc) | ((offset & 0xf00) << 16) | 0x80000000; out_be32(®s->cfg_addr, val); - sync(); - - switch (size) { - case PCI_SIZE_8: - val_8 = value; - out_8((u8 *)®s->cfg_data + (offset & 3), val_8); - break; - case PCI_SIZE_16: - val_16 = value; - out_le16((u16 *)((u8 *)®s->cfg_data + (offset & 2)), val_16); - break; - case PCI_SIZE_32: - val_32 = value; - out_le32(®s->cfg_data, val_32); - break; - } + out_le32(®s->cfg_data, pci_conv_size_to_32(0, value, offset, size));
return 0; }
reorder checks in fsl_pcie_addr_valid(). Check first stuff, we also can check when we use driver for PCI devices.
drivers/pci/pcie_fsl.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index ada6e12e2f..05b2522dac 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -30,13 +30,13 @@ static int fsl_pcie_addr_valid(struct fsl_pcie *pcie, pci_dev_t bdf) if (PCI_BUS(bdf) < bus->seq) return -EINVAL;
- if (PCI_BUS(bdf) > bus->seq && (!fsl_pcie_link_up(pcie) || pcie->mode)) + if (PCI_BUS(bdf) == (bus->seq + 1) && (PCI_DEV(bdf) > 0)) return -EINVAL;
- if (PCI_BUS(bdf) == bus->seq && (PCI_DEV(bdf) > 0 || PCI_FUNC(bdf) > 0)) + if (PCI_BUS(bdf) > bus->seq && (!fsl_pcie_link_up(pcie) || pcie->mode)) return -EINVAL;
- if (PCI_BUS(bdf) == (bus->seq + 1) && (PCI_DEV(bdf) > 0)) + if (PCI_BUS(bdf) == bus->seq && (PCI_DEV(bdf) > 0 || PCI_FUNC(bdf) > 0)) return -EINVAL;
add support for "fsl,mpc8540-pci":
- add flag "ispci" in struct fsl_pcie_data so we can code out differences to existing devices without breaking them
- changes if ispci is set: - in fsl_pcie_addr_valid() check only common checks - fsl_pcie_link_up( returns always 1 - in inbound setup, add flag PIWAR_MEM_2G - set pcie->enabled always to 1
drivers/pci/pcie_fsl.c | 27 ++++++++++++++++++++++++++- drivers/pci/pcie_fsl.h | 1 + 2 files changed, 27 insertions(+), 1 deletion(-)
diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index 05b2522dac..3c207e761e 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -23,6 +23,7 @@ static int fsl_pcie_link_up(struct fsl_pcie *pcie); static int fsl_pcie_addr_valid(struct fsl_pcie *pcie, pci_dev_t bdf) { struct udevice *bus = pcie->bus; + struct fsl_pcie_data *info = pcie->info;
if (!pcie->enabled) return -ENXIO; @@ -33,6 +34,9 @@ static int fsl_pcie_addr_valid(struct fsl_pcie *pcie, pci_dev_t bdf) if (PCI_BUS(bdf) == (bus->seq + 1) && (PCI_DEV(bdf) > 0)) return -EINVAL;
+ if (info->ispci) + return 0; + if (PCI_BUS(bdf) > bus->seq && (!fsl_pcie_link_up(pcie) || pcie->mode)) return -EINVAL;
@@ -161,9 +165,13 @@ static int fsl_pcie_hose_write_config_dword(struct fsl_pcie *pcie, uint offset,
static int fsl_pcie_link_up(struct fsl_pcie *pcie) { + struct fsl_pcie_data *info = pcie->info; ccsr_fsl_pci_t *regs = pcie->regs; u16 ltssm;
+ if (info->ispci) + return 1; + if (pcie->block_rev >= PEX_IP_BLK_REV_3_0) { ltssm = (in_be32(®s->pex_csr0) & PEX_CSR0_LTSSM_MASK) >> PEX_CSR0_LTSSM_SHIFT; @@ -251,6 +259,7 @@ static int fsl_pcie_setup_inbound_win(struct fsl_pcie *pcie, int idx, bool pf, u64 phys, u64 bus_addr, pci_size_t size) { + struct fsl_pcie_data *info = pcie->info; ccsr_fsl_pci_t *regs = pcie->regs; pit_t *pi = ®s->pit[idx]; u32 sz = (__ilog2_u64(size) - 1); @@ -275,6 +284,10 @@ static int fsl_pcie_setup_inbound_win(struct fsl_pcie *pcie, int idx, flag |= PIWAR_EN | PIWAR_READ_SNOOP | PIWAR_WRITE_SNOOP; if (pf) flag |= PIWAR_PF; + + if (info->ispci) + flag |= PIWAR_MEM_2G; + out_be32(&pi->piwar, flag | sz);
return 0; @@ -508,6 +521,7 @@ static int fsl_pcie_init_ep(struct fsl_pcie *pcie) static int fsl_pcie_probe(struct udevice *dev) { struct fsl_pcie *pcie = dev_get_priv(dev); + struct fsl_pcie_data *info = pcie->info; ccsr_fsl_pci_t *regs = pcie->regs; u16 val_16;
@@ -515,7 +529,10 @@ static int fsl_pcie_probe(struct udevice *dev) pcie->block_rev = in_be32(®s->block_rev1);
list_add(&pcie->list, &fsl_pcie_list); - pcie->enabled = is_serdes_configured(PCIE1 + pcie->idx); + if (info->ispci) + pcie->enabled = 1; + else + pcie->enabled = is_serdes_configured(PCIE1 + pcie->idx); if (!pcie->enabled) { printf("PCIe%d: %s disabled\n", pcie->idx, dev->name); return 0; @@ -579,6 +596,13 @@ static const struct dm_pci_ops fsl_pcie_ops = { .write_config = fsl_pcie_write_config, };
+static struct fsl_pcie_data mpc85xx_data = { + .block_offset = 0x8000, + .block_offset_mask = 0xffff, + .stride = 0x1000, + .ispci = 1, +}; + static struct fsl_pcie_data p1_p2_data = { .block_offset = 0xa000, .block_offset_mask = 0xffff, @@ -598,6 +622,7 @@ static struct fsl_pcie_data t2080_data = { };
static const struct udevice_id fsl_pcie_ids[] = { + { .compatible = "fsl,mpc8540-pci", .data = (ulong)&mpc85xx_data }, { .compatible = "fsl,pcie-mpc8548", .data = (ulong)&p1_p2_data }, { .compatible = "fsl,pcie-p1_p2", .data = (ulong)&p1_p2_data }, { .compatible = "fsl,pcie-p2041", .data = (ulong)&p2041_data }, diff --git a/drivers/pci/pcie_fsl.h b/drivers/pci/pcie_fsl.h index dc8368d559..ef1b1ac8d4 100644 --- a/drivers/pci/pcie_fsl.h +++ b/drivers/pci/pcie_fsl.h @@ -47,6 +47,7 @@ struct fsl_pcie_data { u32 block_offset; /* Offset from CCSR of 1st controller */ u32 block_offset_mask; /* Mask out the CCSR base */ u32 stride; /* Offset stride between controllers */ + int ispci; /* if PCI only */ };
struct fsl_pcie {
Hi Heiko,
-----Original Message----- From: Heiko Schocher hs@denx.de Sent: 2019年10月9日 12:37 To: U-Boot Mailing List u-boot@lists.denx.de Cc: Heiko Schocher hs@denx.de; Bin Meng bmeng.cn@gmail.com; Z.q. Hou zhiqiang.hou@nxp.com; Prabhakar X prabhakar.kushwaha@nxp.com; Z.q. Hou zhiqiang.hou@nxp.com Subject: [PATCH 0/3] pci: pcie_fsl: add support for none PCIe devices
This patch superseeds patch [1]: https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fpatch work.ozlabs.org%2Fpatch%2F1132418%2F&data=02%7C01%7CZhiqian g.Hou%40nxp.com%7Cf3882a7d460748c51be308d74c726590%7C686ea1d3 bc2b4c6fa92cd99c5c301635%7C0%7C0%7C637061926547234336&sda ta=oxZBn89GDmItT5Orj1re2ASlVWa33H1BprL1Rxg%2FPDg%3D&reserv ed=0
I don't think it is a good idea to add PCI controller support into PCIe controller driver, see the drivers/pci/fsl_pci_init.c, which support both PCI and PCIe controllers, but it is not readable :(. So I think it is better to separate the PCI driver into a new file just like you did in V1.
Thanks, Zhiqiang
Travis build: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Ftravis -ci.org%2Fhsdenx%2Fu-boot-test%2Fbuilds%2F595057579&data=02%7 C01%7CZhiqiang.Hou%40nxp.com%7Cf3882a7d460748c51be308d74c72659 0%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C63706192654723 4336&sdata=3amAx0BH9zoY8MjT3GnVfmde4EJuqvYql7lO%2Fs9E15Q% 3D&reserved=0 (sheevaplug fails, but this is on discussion on list)
-- 2.21.0
Hello Z.q. Hou,
Am 11.10.2019 um 05:16 schrieb Z.q. Hou:
Hi Heiko,
Ok, fine, I send it soon!
bye, Heiko
Thanks, Zhiqiang
-- 2.21.0
Heiko Schocher
Z.q. Hou
