[PATCH 00/14] SCMI multi-channel and optee shm
Dear all,
This series implements 2 features in driver/firmware/scmi.
First, a single change adds support for SCMI OP-TEE transport to use OP-TEE native shared memory. See the 1st patch in this series: "firmware: scmi: optee: use TEE shared memory for SCMI messages".
Then come changes for supporting multi-channel in the SCMI drivers. I've split the implementation in 11 several small incremental changes in the hope it helps the review. Few minor fixup commits are also inserted in the series.
Regards, Etienne
Etienne Carriere (14): firmware: scmi: optee: use TEE shared memory for SCMI messages firmware: scmi: optee: fix inline description of PTA_SCMI_CMD_GET_CHANNEL firmware: scmi: prepare scmi uclass API to multi-channel firmware: scmi: prepare uclass to pass channel reference firmware: scmi: factorize scmi transport look up firmware: scmi: add multi-channel support firmware: scmi: mailbox transport: implement multi-channel firmware: scmi: smccc transport: implement multi-channel firmware: scmi: optee transport: implement multi-channel clk: scmi: support SCMI multi-channel reset: scmi: support SCMI multi-channel power: regulator: scmi: support SCMI multi-channel power: regulator: scmi: simplify scmi_voltd_set_enable() firmware: scmi: use multi channel in mailbox, optee and smccc agents
drivers/clk/clk_scmi.c | 23 +++- drivers/firmware/scmi/mailbox_agent.c | 65 +++++++-- drivers/firmware/scmi/optee_agent.c | 147 ++++++++++++++++----- drivers/firmware/scmi/sandbox-scmi_agent.c | 1 + drivers/firmware/scmi/scmi_agent-uclass.c | 48 +++++-- drivers/firmware/scmi/smccc_agent.c | 56 +++++++- drivers/firmware/scmi/smt.c | 53 +++++++- drivers/firmware/scmi/smt.h | 45 ++++++- drivers/power/regulator/scmi_regulator.c | 26 ++-- drivers/reset/reset-scmi.c | 15 ++- include/scmi_agent-uclass.h | 15 ++- include/scmi_agent.h | 14 +- 12 files changed, 431 insertions(+), 77 deletions(-)
Changes implementation when using TEE dynamically allocated shared memory to synchronize with the Linux implementation where the legacy SMT protocol cannot be used with such memory since it is expected from device mapped memory whereas OP-TEE shared memory is cached and hence should not be accessed using memcpy_toio()/memcpy_fromio().
This change implements the MSG shared memory protocol introduced in Linux [1]. The protocol uses a simplified SMT header of 32bit named MSG_SMT to carry SCMI protocol information and uses side channel means to carry exchanged buffer size information, as TEE invocation API parameters when used in the SCMI OP-TEE transport.
Link: [1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?i... Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/firmware/scmi/optee_agent.c | 68 ++++++++++++++++++++++------- drivers/firmware/scmi/smt.c | 53 +++++++++++++++++++++- drivers/firmware/scmi/smt.h | 45 ++++++++++++++++++- 3 files changed, 149 insertions(+), 17 deletions(-)
diff --git a/drivers/firmware/scmi/optee_agent.c b/drivers/firmware/scmi/optee_agent.c index 1f265922343..e76f738bbaf 100644 --- a/drivers/firmware/scmi/optee_agent.c +++ b/drivers/firmware/scmi/optee_agent.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2020-2021 Linaro Limited. + * Copyright (C) 2020-2022 Linaro Limited. */
#define LOG_CATEGORY UCLASS_SCMI_AGENT @@ -98,6 +98,22 @@ enum optee_smci_pta_cmd { * [in] value[0].b: Requested capabilities mask (enum pta_scmi_caps) */ PTA_SCMI_CMD_GET_CHANNEL = 3, + + /* + * PTA_SCMI_CMD_PROCESS_MSG_CHANNEL - Process SCMI message in MSG + * buffers pointed by memref parameters + * + * [in] value[0].a: Channel handle + * [in] memref[1]: Message buffer (MSG header and SCMI payload) + * [out] memref[2]: Response buffer (MSG header and SCMI payload) + * + * Shared memories used for SCMI message/response are MSG buffers + * referenced by param[1] and param[2]. MSG transport protocol + * uses a 32bit header to carry SCMI meta-data (protocol ID and + * protocol message ID) followed by the effective SCMI message + * payload. + */ + PTA_SCMI_CMD_PROCESS_MSG_CHANNEL = 4, };
/* @@ -106,9 +122,17 @@ enum optee_smci_pta_cmd { * PTA_SCMI_CAPS_SMT_HEADER * When set, OP-TEE supports command using SMT header protocol (SCMI shmem) in * shared memory buffers to carry SCMI protocol synchronisation information. + * + * PTA_SCMI_CAPS_MSG_HEADER + * When set, OP-TEE supports command using MSG header protocol in an OP-TEE + * shared memory to carry SCMI protocol synchronisation information and SCMI + * message payload. */ #define PTA_SCMI_CAPS_NONE 0 #define PTA_SCMI_CAPS_SMT_HEADER BIT(0) +#define PTA_SCMI_CAPS_MSG_HEADER BIT(1) +#define PTA_SCMI_CAPS_MASK (PTA_SCMI_CAPS_SMT_HEADER | \ + PTA_SCMI_CAPS_MSG_HEADER)
static int open_channel(struct udevice *dev, struct channel_session *sess) { @@ -139,7 +163,10 @@ static int open_channel(struct udevice *dev, struct channel_session *sess)
param[0].attr = TEE_PARAM_ATTR_TYPE_VALUE_INOUT; param[0].u.value.a = chan->channel_id; - param[0].u.value.b = PTA_SCMI_CAPS_SMT_HEADER; + if (chan->dyn_shm) + param[0].u.value.b = PTA_SCMI_CAPS_MSG_HEADER; + else + param[0].u.value.b = PTA_SCMI_CAPS_SMT_HEADER;
ret = tee_invoke_func(sess->tee, &cmd_arg, ARRAY_SIZE(param), param); if (ret || cmd_arg.ret) { @@ -167,34 +194,48 @@ static int invoke_cmd(struct udevice *dev, struct channel_session *sess, { struct scmi_optee_channel *chan = dev_get_plat(dev); struct tee_invoke_arg arg = { }; - struct tee_param param[2] = { }; + struct tee_param param[3] = { }; int ret;
- scmi_write_msg_to_smt(dev, &chan->smt, msg); - arg.session = sess->tee_session; param[0].attr = TEE_PARAM_ATTR_TYPE_VALUE_INPUT; param[0].u.value.a = sess->channel_hdl;
- if (chan->dyn_shm) { - arg.func = PTA_SCMI_CMD_PROCESS_SMT_CHANNEL_MESSAGE; - param[1].attr = TEE_PARAM_ATTR_TYPE_MEMREF_INOUT; + if (sess->tee_shm) { + size_t in_size; + + ret = scmi_msg_to_smt_msg(dev, &chan->smt, msg, &in_size); + if (ret < 0) + return ret; + + arg.func = PTA_SCMI_CMD_PROCESS_MSG_CHANNEL; + param[1].attr = TEE_PARAM_ATTR_TYPE_MEMREF_INPUT; param[1].u.memref.shm = sess->tee_shm; - param[1].u.memref.size = SCMI_SHM_SIZE; + param[1].u.memref.size = in_size; + param[2].attr = TEE_PARAM_ATTR_TYPE_MEMREF_OUTPUT; + param[2].u.memref.shm = sess->tee_shm; + param[2].u.memref.size = sess->tee_shm->size; } else { arg.func = PTA_SCMI_CMD_PROCESS_SMT_CHANNEL; + scmi_write_msg_to_smt(dev, &chan->smt, msg); }
ret = tee_invoke_func(sess->tee, &arg, ARRAY_SIZE(param), param); if (ret || arg.ret) { if (!ret) ret = -EPROTO; + + return ret; + } + + if (sess->tee_shm) { + ret = scmi_msg_from_smt_msg(dev, &chan->smt, msg, + param[2].u.memref.size); } else { ret = scmi_read_resp_from_smt(dev, &chan->smt, msg); + scmi_clear_smt_channel(&chan->smt); }
- scmi_clear_smt_channel(&chan->smt); - return ret; }
@@ -217,9 +258,6 @@ static int prepare_shm(struct udevice *dev, struct channel_session *sess)
chan->smt.buf = sess->tee_shm->addr;
- /* Initialize shm buffer for message exchanges */ - scmi_clear_smt_channel(&chan->smt); - return 0; }
@@ -233,7 +271,7 @@ static void release_shm(struct udevice *dev, struct channel_session *sess)
static int scmi_optee_process_msg(struct udevice *dev, struct scmi_msg *msg) { - struct channel_session sess; + struct channel_session sess = { }; int ret;
ret = open_channel(dev, &sess); diff --git a/drivers/firmware/scmi/smt.c b/drivers/firmware/scmi/smt.c index e60c2aebc89..509ed618a99 100644 --- a/drivers/firmware/scmi/smt.c +++ b/drivers/firmware/scmi/smt.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0 /* * Copyright (c) 2015-2019, Arm Limited and Contributors. All rights reserved. - * Copyright (C) 2019-2020 Linaro Limited. + * Copyright (C) 2019-2022 Linaro Limited. */
#define LOG_CATEGORY UCLASS_SCMI_AGENT @@ -137,3 +137,54 @@ void scmi_clear_smt_channel(struct scmi_smt *smt)
hdr->channel_status &= ~SCMI_SHMEM_CHAN_STAT_CHANNEL_ERROR; } + +/** + * Write SCMI message @msg into a SMT_MSG shared buffer @smt. + * Return 0 on success and with a negative errno in case of error. + */ +int scmi_msg_to_smt_msg(struct udevice *dev, struct scmi_smt *smt, + struct scmi_msg *msg, size_t *buf_size) +{ + struct scmi_smt_msg_header *hdr = (void *)smt->buf; + + if ((!msg->in_msg && msg->in_msg_sz) || + (!msg->out_msg && msg->out_msg_sz)) + return -EINVAL; + + if (smt->size < (sizeof(*hdr) + msg->in_msg_sz) || + smt->size < (sizeof(*hdr) + msg->out_msg_sz)) { + dev_dbg(dev, "Buffer too small\n"); + return -ETOOSMALL; + } + + *buf_size = msg->in_msg_sz + sizeof(hdr->msg_header); + + hdr->msg_header = SMT_HEADER_TOKEN(0) | + SMT_HEADER_MESSAGE_TYPE(0) | + SMT_HEADER_PROTOCOL_ID(msg->protocol_id) | + SMT_HEADER_MESSAGE_ID(msg->message_id); + + memcpy(hdr->msg_payload, msg->in_msg, msg->in_msg_sz); + + return 0; +} + +/** + * Read SCMI message from a SMT shared buffer @smt and copy it into @msg. + * Return 0 on success and with a negative errno in case of error. + */ +int scmi_msg_from_smt_msg(struct udevice *dev, struct scmi_smt *smt, + struct scmi_msg *msg, size_t buf_size) +{ + struct scmi_smt_msg_header *hdr = (void *)smt->buf; + + if (buf_size > msg->out_msg_sz + sizeof(hdr->msg_header)) { + dev_err(dev, "Buffer to small\n"); + return -ETOOSMALL; + } + + msg->out_msg_sz = buf_size - sizeof(hdr->msg_header); + memcpy(msg->out_msg, hdr->msg_payload, msg->out_msg_sz); + + return 0; +} diff --git a/drivers/firmware/scmi/smt.h b/drivers/firmware/scmi/smt.h index a8c0987bd30..9d669a6c922 100644 --- a/drivers/firmware/scmi/smt.h +++ b/drivers/firmware/scmi/smt.h @@ -1,7 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (c) 2015-2019, Arm Limited and Contributors. All rights reserved. - * Copyright (C) 2019-2020 Linaro Limited. + * Copyright (C) 2019-2022 Linaro Limited. */ #ifndef SCMI_SMT_H #define SCMI_SMT_H @@ -29,6 +29,17 @@ struct scmi_smt_header { u8 msg_payload[0]; };
+/** + * struct scmi_msg_header - Description of a MSG shared memory message buffer + * + * MSG communication protocol uses a 32bit header memory cell to store SCMI + * protocol data followed by the exchange SCMI message payload. + */ +struct scmi_smt_msg_header { + __le32 msg_header; + u8 msg_payload[0]; +}; + #define SMT_HEADER_TOKEN(token) (((token) << 18) & GENMASK(31, 18)) #define SMT_HEADER_PROTOCOL_ID(proto) (((proto) << 10) & GENMASK(17, 10)) #define SMT_HEADER_MESSAGE_TYPE(type) (((type) << 18) & GENMASK(9, 8)) @@ -75,12 +86,44 @@ static inline void scmi_smt_put_channel(struct scmi_smt *smt)
int scmi_dt_get_smt_buffer(struct udevice *dev, struct scmi_smt *smt);
+/* + * Write SCMI message to a SMT shared memory + * @dev: SCMI device + * @smt: Reference to shared memory using SMT header + * @msg: Input SCMI message transmitted + */ int scmi_write_msg_to_smt(struct udevice *dev, struct scmi_smt *smt, struct scmi_msg *msg);
+/* + * Read SCMI message from a SMT shared memory + * @dev: SCMI device + * @smt: Reference to shared memory using SMT header + * @msg: Output SCMI message received + */ int scmi_read_resp_from_smt(struct udevice *dev, struct scmi_smt *smt, struct scmi_msg *msg);
void scmi_clear_smt_channel(struct scmi_smt *smt);
+/* + * Write SCMI message to SMT_MSG shared memory + * @dev: SCMI device + * @smt: Reference to shared memory using SMT_MSG header + * @msg: Input SCMI message transmitted + * @buf_size: Size of the full SMT_MSG buffer transmitted + */ +int scmi_msg_to_smt_msg(struct udevice *dev, struct scmi_smt *smt, + struct scmi_msg *msg, size_t *buf_size); + +/* + * Read SCMI message from SMT_MSG shared memory + * @dev: SCMI device + * @smt: Reference to shared memory using SMT_MSG header + * @msg: Output SCMI message received + * @buf_size: Size of the full SMT_MSG buffer received + */ +int scmi_msg_from_smt_msg(struct udevice *dev, struct scmi_smt *smt, + struct scmi_msg *msg, size_t buf_size); + #endif /* SCMI_SMT_H */
Removes inaccurate inline description of OP-TEE SCMI PTA command PTA_SCMI_CMD_GET_CHANNEL.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/firmware/scmi/optee_agent.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/drivers/firmware/scmi/optee_agent.c b/drivers/firmware/scmi/optee_agent.c index e76f738bbaf..bf0647bafd1 100644 --- a/drivers/firmware/scmi/optee_agent.c +++ b/drivers/firmware/scmi/optee_agent.c @@ -91,8 +91,6 @@ enum optee_smci_pta_cmd { /* * PTA_SCMI_CMD_GET_CHANNEL - Get channel handle * - * SCMI shm information are 0 if agent expects to use OP-TEE regular SHM - * * [in] value[0].a: Channel identifier * [out] value[0].a: Returned channel handle * [in] value[0].b: Requested capabilities mask (enum pta_scmi_caps)
Changes SCMI driver API function devm_scmi_process_msg() to add an SCMI channel reference argument for when SCMI agent supports SCMI protocol specific channels. First argument of devm_scmi_process_msg() is also change to point to the caller SCMI protocol device rather than its parent device (the SCMI agent device).
The argument is a pointer to opaque struct scmi_channel known from the SCMI transport drivers. It is currently unused and caller a pass NULL value. A later change will enable such support once SCMI protocol drivers have means to get the channel reference during initialization.
Cc: Lukasz Majewski lukma@denx.de Cc: Sean Anderson seanga2@gmail.com Cc: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/clk/clk_scmi.c | 10 +++++----- drivers/firmware/scmi/scmi_agent-uclass.c | 3 ++- drivers/power/regulator/scmi_regulator.c | 10 +++++----- drivers/reset/reset-scmi.c | 4 ++-- include/scmi_agent-uclass.h | 2 +- include/scmi_agent.h | 5 ++++- 6 files changed, 19 insertions(+), 15 deletions(-)
diff --git a/drivers/clk/clk_scmi.c b/drivers/clk/clk_scmi.c index 5aaabcf0b44..0d0bb72eaf7 100644 --- a/drivers/clk/clk_scmi.c +++ b/drivers/clk/clk_scmi.c @@ -24,7 +24,7 @@ static int scmi_clk_get_num_clock(struct udevice *dev, size_t *num_clocks) }; int ret;
- ret = devm_scmi_process_msg(dev, &msg); + ret = devm_scmi_process_msg(dev, NULL, &msg); if (ret) return ret;
@@ -49,7 +49,7 @@ static int scmi_clk_get_attibute(struct udevice *dev, int clkid, char **name) }; int ret;
@@ -70,7 +70,7 @@ static int scmi_clk_gate(struct clk *clk, int enable) in, out); int ret;
- ret = devm_scmi_process_msg(clk->dev, &msg); + ret = devm_scmi_process_msg(clk->dev, NULL, &msg); if (ret) return ret;
@@ -98,7 +98,7 @@ static ulong scmi_clk_get_rate(struct clk *clk) in, out); int ret;
- ret = devm_scmi_process_msg(clk->dev, &msg); + ret = devm_scmi_process_msg(clk->dev, NULL, &msg); if (ret < 0) return ret;
@@ -123,7 +123,7 @@ static ulong scmi_clk_set_rate(struct clk *clk, ulong rate) in, out); int ret;
diff --git a/drivers/firmware/scmi/scmi_agent-uclass.c b/drivers/firmware/scmi/scmi_agent-uclass.c index 3819f2fa993..93cfc9c395b 100644 --- a/drivers/firmware/scmi/scmi_agent-uclass.c +++ b/drivers/firmware/scmi/scmi_agent-uclass.c @@ -114,7 +114,8 @@ static const struct scmi_agent_ops *transport_dev_ops(struct udevice *dev) return (const struct scmi_agent_ops *)dev->driver->ops; }
-int devm_scmi_process_msg(struct udevice *dev, struct scmi_msg *msg) +int devm_scmi_process_msg(struct udevice *dev, struct scmi_channel *channel, + struct scmi_msg *msg) { const struct scmi_agent_ops *ops; struct udevice *parent = dev; diff --git a/drivers/power/regulator/scmi_regulator.c b/drivers/power/regulator/scmi_regulator.c index 2966bdcf830..3325ddaf23b 100644 --- a/drivers/power/regulator/scmi_regulator.c +++ b/drivers/power/regulator/scmi_regulator.c @@ -38,7 +38,7 @@ static int scmi_voltd_set_enable(struct udevice *dev, bool enable) in, out); int ret;
@@ -61,7 +61,7 @@ static int scmi_voltd_get_enable(struct udevice *dev) in, out); int ret;
- ret = devm_scmi_process_msg(dev, &msg); + ret = devm_scmi_process_msg(dev, NULL, &msg); if (ret < 0) return ret;
@@ -85,7 +85,7 @@ static int scmi_voltd_set_voltage_level(struct udevice *dev, int uV) in, out); int ret;
@@ -104,7 +104,7 @@ static int scmi_voltd_get_voltage_level(struct udevice *dev) in, out); int ret;
@@ -147,7 +147,7 @@ static int scmi_regulator_probe(struct udevice *dev) /* Check voltage domain is known from SCMI server */ in.domain_id = pdata->domain_id;
- ret = devm_scmi_process_msg(dev, &scmi_msg); + ret = devm_scmi_process_msg(dev, NULL, &scmi_msg); if (ret) { dev_err(dev, "Failed to query voltage domain %u: %d\n", pdata->domain_id, ret); diff --git a/drivers/reset/reset-scmi.c b/drivers/reset/reset-scmi.c index 81d195a06a9..30b26ec9d31 100644 --- a/drivers/reset/reset-scmi.c +++ b/drivers/reset/reset-scmi.c @@ -26,7 +26,7 @@ static int scmi_reset_set_level(struct reset_ctl *rst, bool assert_not_deassert) in, out); int ret;
- ret = devm_scmi_process_msg(rst->dev, &msg); + ret = devm_scmi_process_msg(rst->dev, NULL, &msg); if (ret) return ret;
@@ -58,7 +58,7 @@ static int scmi_reset_request(struct reset_ctl *rst) * We don't really care about the attribute, just check * the reset domain exists. */ - ret = devm_scmi_process_msg(rst->dev, &msg); + ret = devm_scmi_process_msg(rst->dev, NULL, &msg); if (ret) return ret;
diff --git a/include/scmi_agent-uclass.h b/include/scmi_agent-uclass.h index a501d1b4825..861ac6d1100 100644 --- a/include/scmi_agent-uclass.h +++ b/include/scmi_agent-uclass.h @@ -15,7 +15,7 @@ struct scmi_agent_ops { /* * process_msg - Request transport to get the SCMI message processed * - * @agent: Agent using the transport + * @dev: SCMI protocol device using the transport * @msg: SCMI message to be transmitted */ int (*process_msg)(struct udevice *dev, struct scmi_msg *msg); diff --git a/include/scmi_agent.h b/include/scmi_agent.h index 18bcd48a9d4..f4d85cae773 100644 --- a/include/scmi_agent.h +++ b/include/scmi_agent.h @@ -13,6 +13,7 @@ #include <asm/types.h>
struct udevice; +struct scmi_channel;
/* * struct scmi_msg - Context of a SCMI message sent and the response received @@ -52,10 +53,12 @@ struct scmi_msg { * On return, scmi_msg::out_msg_sz stores the response payload size. * * @dev: SCMI device + * @channel: Communication channel for the device * @msg: Message structure reference * Return: 0 on success and a negative errno on failure */ -int devm_scmi_process_msg(struct udevice *dev, struct scmi_msg *msg); +int devm_scmi_process_msg(struct udevice *dev, struct scmi_channel *channel, + struct scmi_msg *msg);
/** * scmi_to_linux_errno() - Convert an SCMI error code into a Linux errno code
Changes SCMI transport operator ::process_msg to pass the SCMI channel reference provided by caller SCMI protocol device.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/firmware/scmi/mailbox_agent.c | 4 +++- drivers/firmware/scmi/optee_agent.c | 4 +++- drivers/firmware/scmi/sandbox-scmi_agent.c | 1 + drivers/firmware/scmi/scmi_agent-uclass.c | 2 +- drivers/firmware/scmi/smccc_agent.c | 4 +++- include/scmi_agent-uclass.h | 4 +++- 6 files changed, 14 insertions(+), 5 deletions(-)
diff --git a/drivers/firmware/scmi/mailbox_agent.c b/drivers/firmware/scmi/mailbox_agent.c index 8e4af0c8faf..aa4929aafae 100644 --- a/drivers/firmware/scmi/mailbox_agent.c +++ b/drivers/firmware/scmi/mailbox_agent.c @@ -31,7 +31,9 @@ struct scmi_mbox_channel { ulong timeout_us; };
-static int scmi_mbox_process_msg(struct udevice *dev, struct scmi_msg *msg) +static int scmi_mbox_process_msg(struct udevice *dev, + struct scmi_channel *channel, + struct scmi_msg *msg) { struct scmi_mbox_channel *chan = dev_get_plat(dev); int ret; diff --git a/drivers/firmware/scmi/optee_agent.c b/drivers/firmware/scmi/optee_agent.c index bf0647bafd1..771fa25e989 100644 --- a/drivers/firmware/scmi/optee_agent.c +++ b/drivers/firmware/scmi/optee_agent.c @@ -267,7 +267,9 @@ static void release_shm(struct udevice *dev, struct channel_session *sess) tee_shm_free(sess->tee_shm); }
-static int scmi_optee_process_msg(struct udevice *dev, struct scmi_msg *msg) +static int scmi_optee_process_msg(struct udevice *dev, + struct scmi_channel *channel, + struct scmi_msg *msg) { struct channel_session sess = { }; int ret; diff --git a/drivers/firmware/scmi/sandbox-scmi_agent.c b/drivers/firmware/scmi/sandbox-scmi_agent.c index c555164d196..031882998df 100644 --- a/drivers/firmware/scmi/sandbox-scmi_agent.c +++ b/drivers/firmware/scmi/sandbox-scmi_agent.c @@ -471,6 +471,7 @@ static int sandbox_scmi_voltd_level_get(struct udevice *dev, }
static int sandbox_scmi_test_process_msg(struct udevice *dev, + struct scmi_channel *channel, struct scmi_msg *msg) { switch (msg->protocol_id) { diff --git a/drivers/firmware/scmi/scmi_agent-uclass.c b/drivers/firmware/scmi/scmi_agent-uclass.c index 93cfc9c395b..c9c9c00384a 100644 --- a/drivers/firmware/scmi/scmi_agent-uclass.c +++ b/drivers/firmware/scmi/scmi_agent-uclass.c @@ -133,7 +133,7 @@ int devm_scmi_process_msg(struct udevice *dev, struct scmi_channel *channel, ops = transport_dev_ops(parent);
if (ops->process_msg) - return ops->process_msg(parent, msg); + return ops->process_msg(parent, NULL, msg);
return -EPROTONOSUPPORT; } diff --git a/drivers/firmware/scmi/smccc_agent.c b/drivers/firmware/scmi/smccc_agent.c index 5e166ca93ee..b7a930b24df 100644 --- a/drivers/firmware/scmi/smccc_agent.c +++ b/drivers/firmware/scmi/smccc_agent.c @@ -30,7 +30,9 @@ struct scmi_smccc_channel { struct scmi_smt smt; };
-static int scmi_smccc_process_msg(struct udevice *dev, struct scmi_msg *msg) +static int scmi_smccc_process_msg(struct udevice *dev, + struct scmi_channel *channel, + struct scmi_msg *msg) { struct scmi_smccc_channel *chan = dev_get_plat(dev); struct arm_smccc_res res; diff --git a/include/scmi_agent-uclass.h b/include/scmi_agent-uclass.h index 861ac6d1100..562a4cc99af 100644 --- a/include/scmi_agent-uclass.h +++ b/include/scmi_agent-uclass.h @@ -7,6 +7,7 @@
struct udevice; struct scmi_msg; +struct scmi_channel;
/** * struct scmi_transport_ops - The functions that a SCMI transport layer must implement. @@ -18,7 +19,8 @@ struct scmi_agent_ops { * @dev: SCMI protocol device using the transport * @msg: SCMI message to be transmitted */ - int (*process_msg)(struct udevice *dev, struct scmi_msg *msg); + int (*process_msg)(struct udevice *dev, struct scmi_channel *channel, + struct scmi_msg *msg); };
#endif /* _SCMI_TRANSPORT_UCLASS_H */
Defines local helper function find_scmi_transport_device() with the instructions to find the SCMI transport device from a SCMI protocol device.
Cc: Patrick Delaunay patrick.delaunay@foss.st.com Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/firmware/scmi/scmi_agent-uclass.c | 26 +++++++++++++++-------- 1 file changed, 17 insertions(+), 9 deletions(-)
diff --git a/drivers/firmware/scmi/scmi_agent-uclass.c b/drivers/firmware/scmi/scmi_agent-uclass.c index c9c9c00384a..f7fa5df214c 100644 --- a/drivers/firmware/scmi/scmi_agent-uclass.c +++ b/drivers/firmware/scmi/scmi_agent-uclass.c @@ -109,6 +109,20 @@ static int scmi_bind_protocols(struct udevice *dev) return ret; }
+static struct udevice *find_scmi_transport_device(struct udevice *dev) +{ + struct udevice *parent = dev; + + do { + parent = dev_get_parent(parent); + } while (parent && device_get_uclass_id(parent) != UCLASS_SCMI_AGENT); + + if (!parent) + dev_err(dev, "Invalid SCMI device, agent not found\n"); + + return parent; +} + static const struct scmi_agent_ops *transport_dev_ops(struct udevice *dev) { return (const struct scmi_agent_ops *)dev->driver->ops; @@ -118,17 +132,11 @@ int devm_scmi_process_msg(struct udevice *dev, struct scmi_channel *channel, struct scmi_msg *msg) { const struct scmi_agent_ops *ops; - struct udevice *parent = dev; + struct udevice *parent;
- /* Find related SCMI agent device */ - do { - parent = dev_get_parent(parent); - } while (parent && device_get_uclass_id(parent) != UCLASS_SCMI_AGENT); - - if (!parent) { - dev_err(dev, "Invalid SCMI device, agent not found\n"); + parent = find_scmi_transport_device(dev); + if (!parent) return -ENODEV; - }
Adds resources for SCMI protocols to possibly use a dedicated SCMI channel instead of the default channel allocated by the SCMI agent during initialization. As per DT binding documentation, some SCMI transports can define a specific SCMI communication channel for given SCMI protocols. It allows SCMI protocols to pass messages concurrently each other.
This change introduces new scmi agent uclass API function devm_scmi_of_get_channel() for SCMI drivers probe sequences to get a reference to the SCMI channel assigned to its related SCMI protocol. The function queries the channel reference to its SCMI transport driver through new scmi agent uclass operator .of_get_channel that uses Device Tree information from related SCMI agent node.
Operator .of_get_channel returns a reference to the SCMI channel assigned to SCMI protocol used by the caller device. SCMI transport drivers that do not support multi-channel are not mandated to register this operator. When so, API function devm_scmi_of_get_channel() returns NULL and SCMI transport driver are expected to retrieve by their own means the reference to the unique SCMI channel, for example using platform data as these drivers currently do in U-Boot source tree.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/firmware/scmi/scmi_agent-uclass.c | 19 ++++++++++++++++++- include/scmi_agent-uclass.h | 9 +++++++++ include/scmi_agent.h | 9 +++++++++ 3 files changed, 36 insertions(+), 1 deletion(-)
diff --git a/drivers/firmware/scmi/scmi_agent-uclass.c b/drivers/firmware/scmi/scmi_agent-uclass.c index f7fa5df214c..2b6211c4e6a 100644 --- a/drivers/firmware/scmi/scmi_agent-uclass.c +++ b/drivers/firmware/scmi/scmi_agent-uclass.c @@ -128,6 +128,23 @@ static const struct scmi_agent_ops *transport_dev_ops(struct udevice *dev) return (const struct scmi_agent_ops *)dev->driver->ops; }
+int devm_scmi_of_get_channel(struct udevice *dev, struct scmi_channel **channel) +{ + struct udevice *parent; + + parent = find_scmi_transport_device(dev); + if (!parent) + return -ENODEV; + + if (transport_dev_ops(parent)->of_get_channel) + return transport_dev_ops(parent)->of_get_channel(dev, channel); + + /* Drivers without a get_channel operator don't need a channel ref */ + *channel = NULL; + + return 0; +} + int devm_scmi_process_msg(struct udevice *dev, struct scmi_channel *channel, struct scmi_msg *msg) { @@ -141,7 +158,7 @@ int devm_scmi_process_msg(struct udevice *dev, struct scmi_channel *channel, ops = transport_dev_ops(parent);
if (ops->process_msg) - return ops->process_msg(parent, NULL, msg); + return ops->process_msg(parent, channel, msg);
return -EPROTONOSUPPORT; } diff --git a/include/scmi_agent-uclass.h b/include/scmi_agent-uclass.h index 562a4cc99af..b1c93532c0e 100644 --- a/include/scmi_agent-uclass.h +++ b/include/scmi_agent-uclass.h @@ -13,6 +13,15 @@ struct scmi_channel; * struct scmi_transport_ops - The functions that a SCMI transport layer must implement. */ struct scmi_agent_ops { + /* + * of_get_channel - Get SCMI channel from SCMI agent device tree node + * + * @dev: SCMI protocol device using the transport + * @channel: Output reference to SCMI channel upon success + * Return 0 upon success and a negative errno on failure + */ + int (*of_get_channel)(struct udevice *dev, struct scmi_channel **channel); + /* * process_msg - Request transport to get the SCMI message processed * diff --git a/include/scmi_agent.h b/include/scmi_agent.h index f4d85cae773..ee6286366df 100644 --- a/include/scmi_agent.h +++ b/include/scmi_agent.h @@ -45,6 +45,15 @@ struct scmi_msg { .out_msg_sz = sizeof(_out_array), \ }
+/** + * devm_scmi_of_get_channel() - Get SCMI channel handle from SCMI agent DT node + * + * @dev: Device requesting a channel + * @channel: Output reference to the SCMI channel upon success + * @return 0 on success and a negative errno on failure + */ +int devm_scmi_of_get_channel(struct udevice *dev, struct scmi_channel **channel); + /** * devm_scmi_process_msg() - Send and process an SCMI message *
Updates SCMI mailbox transport driver to get SCMI channel reference at initialization and use when posting SCMI messages.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/firmware/scmi/mailbox_agent.c | 63 ++++++++++++++++++++++++--- 1 file changed, 57 insertions(+), 6 deletions(-)
diff --git a/drivers/firmware/scmi/mailbox_agent.c b/drivers/firmware/scmi/mailbox_agent.c index aa4929aafae..e63b67c5ee8 100644 --- a/drivers/firmware/scmi/mailbox_agent.c +++ b/drivers/firmware/scmi/mailbox_agent.c @@ -31,6 +31,14 @@ struct scmi_mbox_channel { ulong timeout_us; };
+/** + * struct scmi_channel - Channel instance referenced in SCMI drivers + * @ref: Reference to local channel instance + **/ +struct scmi_channel { + struct scmi_mbox_channel ref; +}; + static int scmi_mbox_process_msg(struct udevice *dev, struct scmi_channel *channel, struct scmi_msg *msg) @@ -38,6 +46,10 @@ static int scmi_mbox_process_msg(struct udevice *dev, struct scmi_mbox_channel *chan = dev_get_plat(dev); int ret;
+ /* Support SCMI drivers upgraded to of_get_channel operator */ + if (channel) + chan = &channel->ref; + ret = scmi_write_msg_to_smt(dev, &chan->smt, msg); if (ret) return ret; @@ -64,13 +76,10 @@ out: return ret; }
-int scmi_mbox_of_to_plat(struct udevice *dev) +static int setup_channel(struct udevice *dev, struct scmi_mbox_channel *chan) { - struct scmi_mbox_channel *chan = dev_get_plat(dev); int ret;
- chan->timeout_us = TIMEOUT_US_10MS; - ret = mbox_get_by_index(dev, 0, &chan->mbox); if (ret) { dev_err(dev, "Failed to find mailbox: %d\n", ret); @@ -78,10 +87,51 @@ int scmi_mbox_of_to_plat(struct udevice *dev) }
ret = scmi_dt_get_smt_buffer(dev, &chan->smt); - if (ret) + if (ret) { dev_err(dev, "Failed to get shm resources: %d\n", ret); + return ret; + }
- return ret; + chan->timeout_us = TIMEOUT_US_10MS; + + return 0; +} + +static int scmi_mbox_get_channel(struct udevice *dev, + struct scmi_channel **channel) +{ + struct scmi_mbox_channel *base_chan = dev_get_plat(dev->parent); + struct scmi_mbox_channel *chan; + int ret; + + if (!dev_read_prop(dev, "shmem", NULL)) { + /* Uses agent base channel */ + *channel = container_of(base_chan, struct scmi_channel, ref); + + return 0; + } + + chan = calloc(1, sizeof(*chan)); + if (!chan) + return -ENOMEM; + + /* Setup a dedicated channel for the protocol */ + ret = setup_channel(dev, chan); + if (ret) { + free(chan); + return ret; + } + + *channel = (void *)chan; + + return 0; +} + +int scmi_mbox_of_to_plat(struct udevice *dev) +{ + struct scmi_mbox_channel *chan = dev_get_plat(dev); + + return setup_channel(dev, chan); }
static const struct udevice_id scmi_mbox_ids[] = { @@ -90,6 +140,7 @@ static const struct udevice_id scmi_mbox_ids[] = { };
static const struct scmi_agent_ops scmi_mbox_ops = { + .of_get_channel = scmi_mbox_get_channel, .process_msg = scmi_mbox_process_msg, };
Updates SCMI SMCCC transport driver to get SCMI channel reference at initialization and use when posting SCMI messages.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/firmware/scmi/smccc_agent.c | 54 +++++++++++++++++++++++++++-- 1 file changed, 52 insertions(+), 2 deletions(-)
diff --git a/drivers/firmware/scmi/smccc_agent.c b/drivers/firmware/scmi/smccc_agent.c index b7a930b24df..73a7e0a844a 100644 --- a/drivers/firmware/scmi/smccc_agent.c +++ b/drivers/firmware/scmi/smccc_agent.c @@ -30,6 +30,14 @@ struct scmi_smccc_channel { struct scmi_smt smt; };
+/** + * struct scmi_channel - Channel instance referenced in SCMI drivers + * @ref: Reference to local channel instance + **/ +struct scmi_channel { + struct scmi_smccc_channel ref; +}; + static int scmi_smccc_process_msg(struct udevice *dev, struct scmi_channel *channel, struct scmi_msg *msg) @@ -38,6 +46,10 @@ static int scmi_smccc_process_msg(struct udevice *dev, struct arm_smccc_res res; int ret;
+ /* Support SCMI drivers upgraded to of_get_channel operator */ + if (channel) + chan = &channel->ref; + ret = scmi_write_msg_to_smt(dev, &chan->smt, msg); if (ret) return ret; @@ -53,9 +65,8 @@ static int scmi_smccc_process_msg(struct udevice *dev, return ret; }
-static int scmi_smccc_of_to_plat(struct udevice *dev) +static int setup_channel(struct udevice *dev, struct scmi_smccc_channel *chan) { - struct scmi_smccc_channel *chan = dev_get_plat(dev); u32 func_id; int ret;
@@ -73,12 +84,51 @@ static int scmi_smccc_of_to_plat(struct udevice *dev) return ret; }
+static int scmi_smccc_get_channel(struct udevice *dev, + struct scmi_channel **channel) +{ + struct scmi_smccc_channel *base_chan = dev_get_plat(dev->parent); + struct scmi_smccc_channel *chan; + u32 func_id; + int ret; + + if (dev_read_u32(dev, "arm,smc-id", &func_id)) { + /* Uses agent base channel */ + *channel = container_of(base_chan, struct scmi_channel, ref); + + return 0; + } + + /* Setup a dedicated channel */ + chan = calloc(1, sizeof(*chan)); + if (!chan) + return -ENOMEM; + + ret = setup_channel(dev, chan); + if (ret) { + free(chan); + return ret; + } + + *channel = container_of(chan, struct scmi_channel, ref); + + return 0; +} + +static int scmi_smccc_of_to_plat(struct udevice *dev) +{ + struct scmi_smccc_channel *chan = dev_get_plat(dev); + + return setup_channel(dev, chan); +} + static const struct udevice_id scmi_smccc_ids[] = { { .compatible = "arm,scmi-smc" }, { } };
static const struct scmi_agent_ops scmi_smccc_ops = { + .of_get_channel = scmi_smccc_get_channel, .process_msg = scmi_smccc_process_msg, };
Implements multi SCMI channel support in OP-TEE SCMI transport. An SCMI protocol may use a dedicated channel, specified by the DT.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/firmware/scmi/optee_agent.c | 76 ++++++++++++++++++++++++----- 1 file changed, 63 insertions(+), 13 deletions(-)
diff --git a/drivers/firmware/scmi/optee_agent.c b/drivers/firmware/scmi/optee_agent.c index 771fa25e989..da5c2ec9754 100644 --- a/drivers/firmware/scmi/optee_agent.c +++ b/drivers/firmware/scmi/optee_agent.c @@ -35,6 +35,14 @@ struct scmi_optee_channel { bool dyn_shm; };
+/** + * struct scmi_channel - Channel instance referenced in SCMI drivers + * @ref: Reference to local channel instance + **/ +struct scmi_channel { + struct scmi_optee_channel ref; +}; + /** * struct channel_session - Aggreates SCMI service session context references * @tee: OP-TEE device to invoke @@ -132,10 +140,10 @@ enum optee_smci_pta_cmd { #define PTA_SCMI_CAPS_MASK (PTA_SCMI_CAPS_SMT_HEADER | \ PTA_SCMI_CAPS_MSG_HEADER)
-static int open_channel(struct udevice *dev, struct channel_session *sess) +static int open_channel(struct udevice *dev, struct scmi_optee_channel *chan, + struct channel_session *sess) { const struct tee_optee_ta_uuid uuid = TA_SCMI_UUID; - struct scmi_optee_channel *chan = dev_get_plat(dev); struct tee_open_session_arg sess_arg = { }; struct tee_invoke_arg cmd_arg = { }; struct tee_param param[1] = { }; @@ -187,10 +195,9 @@ static void close_channel(struct channel_session *sess) tee_close_session(sess->tee, sess->tee_session); }
-static int invoke_cmd(struct udevice *dev, struct channel_session *sess, - struct scmi_msg *msg) +static int invoke_cmd(struct udevice *dev, struct scmi_optee_channel *chan, + struct channel_session *sess, struct scmi_msg *msg) { - struct scmi_optee_channel *chan = dev_get_plat(dev); struct tee_invoke_arg arg = { }; struct tee_param param[3] = { }; int ret; @@ -237,9 +244,9 @@ static int invoke_cmd(struct udevice *dev, struct channel_session *sess, return ret; }
-static int prepare_shm(struct udevice *dev, struct channel_session *sess) +static int prepare_shm(struct udevice *dev, struct scmi_optee_channel *chan, + struct channel_session *sess) { - struct scmi_optee_channel *chan = dev_get_plat(dev); int ret;
/* Static shm is already prepared by the firmware: nothing to do */ @@ -274,15 +281,19 @@ static int scmi_optee_process_msg(struct udevice *dev, struct channel_session sess = { }; int ret;
- ret = open_channel(dev, &sess); + /* Support SCMI drivers upgraded to of_get_channel operator */ + if (channel) + chan = &channel->ref; + + ret = open_channel(dev, chan, &sess); if (ret) return ret;
- ret = prepare_shm(dev, &sess); + ret = prepare_shm(dev, chan, &sess); if (ret) goto out;
- ret = invoke_cmd(dev, &sess, msg); + ret = invoke_cmd(dev, chan, &sess, msg);
release_shm(dev, &sess);
@@ -292,9 +303,8 @@ out: return ret; }
-static int scmi_optee_of_to_plat(struct udevice *dev) +static int setup_channel(struct udevice *dev, struct scmi_optee_channel *chan) { - struct scmi_optee_channel *chan = dev_get_plat(dev); int ret;
if (dev_read_u32(dev, "linaro,optee-channel-id", &chan->channel_id)) { @@ -316,13 +326,52 @@ static int scmi_optee_of_to_plat(struct udevice *dev) return 0; }
+static int scmi_optee_get_channel(struct udevice *dev, + struct scmi_channel **channel) +{ + struct scmi_optee_channel *base_chan = dev_get_plat(dev->parent); + struct scmi_optee_channel *chan; + u32 channel_id; + int ret; + + if (dev_read_u32(dev, "linaro,optee-channel-id", &channel_id)) { + /* Uses agent base channel */ + *channel = container_of(base_chan, struct scmi_channel, ref); + + return 0; + } + + /* Setup a dedicated channel */ + chan = calloc(1, sizeof(*chan)); + if (!chan) + return -ENOMEM; + + ret = setup_channel(dev, chan); + if (ret) { + free(chan); + return ret; + } + + *channel = container_of(chan, struct scmi_channel, ref); + + return 0; +} + +static int scmi_optee_of_to_plat(struct udevice *dev) +{ + struct scmi_optee_channel *chan = dev_get_plat(dev); + + return setup_channel(dev, chan); +} + static int scmi_optee_probe(struct udevice *dev) { + struct scmi_optee_channel *chan = dev_get_plat(dev); struct channel_session sess; int ret;
/* Check OP-TEE service acknowledges the SCMI channel */ - ret = open_channel(dev, &sess); + ret = open_channel(dev, chan, &sess); if (!ret) close_channel(&sess);
@@ -335,6 +384,7 @@ static const struct udevice_id scmi_optee_ids[] = { };
static const struct scmi_agent_ops scmi_optee_ops = { + .of_get_channel = scmi_optee_get_channel, .process_msg = scmi_optee_process_msg, };
Update SCMI clock driver to get its assigned SCMI channel during initialization. This change allows SCMI clock protocol to use a dedicated channel when defined in the DT. The reference is saved in SCMI clock driver private data.
Cc: Lukasz Majewski lukma@denx.de Cc: Sean Anderson seanga2@gmail.com Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/clk/clk_scmi.c | 23 +++++++++++++++++------ 1 file changed, 17 insertions(+), 6 deletions(-)
diff --git a/drivers/clk/clk_scmi.c b/drivers/clk/clk_scmi.c index 0d0bb72eaf7..5cf7bd73df5 100644 --- a/drivers/clk/clk_scmi.c +++ b/drivers/clk/clk_scmi.c @@ -15,6 +15,7 @@
static int scmi_clk_get_num_clock(struct udevice *dev, size_t *num_clocks) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_clk_protocol_attr_out out; struct scmi_msg msg = { .protocol_id = SCMI_PROTOCOL_ID_CLOCK, @@ -24,7 +25,7 @@ static int scmi_clk_get_num_clock(struct udevice *dev, size_t *num_clocks) }; int ret;
- ret = devm_scmi_process_msg(dev, NULL, &msg); + ret = devm_scmi_process_msg(dev, *scmi_channel_ref, &msg); if (ret) return ret;
@@ -35,6 +36,7 @@ static int scmi_clk_get_num_clock(struct udevice *dev, size_t *num_clocks)
static int scmi_clk_get_attibute(struct udevice *dev, int clkid, char **name) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_clk_attribute_in in = { .clock_id = clkid, }; @@ -49,7 +51,7 @@ static int scmi_clk_get_attibute(struct udevice *dev, int clkid, char **name) }; int ret;
@@ -60,6 +62,7 @@ static int scmi_clk_get_attibute(struct udevice *dev, int clkid, char **name)
static int scmi_clk_gate(struct clk *clk, int enable) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(clk->dev); struct scmi_clk_state_in in = { .clock_id = clk->id, .attributes = enable, @@ -70,7 +73,7 @@ static int scmi_clk_gate(struct clk *clk, int enable) in, out); int ret;
- ret = devm_scmi_process_msg(clk->dev, NULL, &msg); + ret = devm_scmi_process_msg(clk->dev, *scmi_channel_ref, &msg); if (ret) return ret;
@@ -89,6 +92,7 @@ static int scmi_clk_disable(struct clk *clk)
static ulong scmi_clk_get_rate(struct clk *clk) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(clk->dev); struct scmi_clk_rate_get_in in = { .clock_id = clk->id, }; @@ -98,7 +102,7 @@ static ulong scmi_clk_get_rate(struct clk *clk) in, out); int ret;
- ret = devm_scmi_process_msg(clk->dev, NULL, &msg); + ret = devm_scmi_process_msg(clk->dev, *scmi_channel_ref, &msg); if (ret < 0) return ret;
@@ -111,6 +115,7 @@ static ulong scmi_clk_get_rate(struct clk *clk)
static ulong scmi_clk_set_rate(struct clk *clk, ulong rate) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(clk->dev); struct scmi_clk_rate_set_in in = { .clock_id = clk->id, .flags = SCMI_CLK_RATE_ROUND_CLOSEST, @@ -123,7 +128,7 @@ static ulong scmi_clk_set_rate(struct clk *clk, ulong rate) in, out); int ret;
@@ -136,10 +141,15 @@ static ulong scmi_clk_set_rate(struct clk *clk, ulong rate)
static int scmi_clk_probe(struct udevice *dev) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct clk *clk; size_t num_clocks, i; int ret;
+ ret = devm_scmi_of_get_channel(dev, scmi_channel_ref); + if (ret) + return ret; + if (!CONFIG_IS_ENABLED(CLK_CCF)) return 0;
@@ -186,5 +196,6 @@ U_BOOT_DRIVER(scmi_clock) = { .name = "scmi_clk", .id = UCLASS_CLK, .ops = &scmi_clk_ops, - .probe = &scmi_clk_probe, + .probe = scmi_clk_probe, + .priv_auto = sizeof(struct scmi_channel *), };
- struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_clk_protocol_attr_out out; struct scmi_msg msg = { .protocol_id = SCMI_PROTOCOL_ID_CLOCK,
- ret = devm_scmi_process_msg(dev, *scmi_channel_ref, &msg); if (ret) return ret;
- struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_clk_attribute_in in = { .clock_id = clkid, };
- struct scmi_channel **scmi_channel_ref = dev_get_priv(clk->dev); struct scmi_clk_state_in in = { .clock_id = clk->id, .attributes = enable,
- ret = devm_scmi_process_msg(clk->dev, *scmi_channel_ref, &msg); if (ret) return ret;
- struct scmi_channel **scmi_channel_ref = dev_get_priv(clk->dev); struct scmi_clk_rate_get_in in = { .clock_id = clk->id, };
- ret = devm_scmi_process_msg(clk->dev, *scmi_channel_ref, &msg); if (ret < 0) return ret;
- struct scmi_channel **scmi_channel_ref = dev_get_priv(clk->dev); struct scmi_clk_rate_set_in in = { .clock_id = clk->id, .flags = SCMI_CLK_RATE_ROUND_CLOSEST,
if (ret)
return ret;
- .probe = scmi_clk_probe,
- .priv_auto = sizeof(struct scmi_channel *),
Please create a priv struct to hold this. E.g.
/** * struct scmi_clk_priv - Private data for SCMI clocks * @channel: ... */ struct scmi_clk_priv { struct scmi_channel *channel; };
This will allow for easier refactoring if it is necessary to add additional per-device data in the future.
--Sean
Update SCMI reset controller driver to get its assigned SCMI channel during initialization. This change allows SCMI reset domain protocol to use a dedicated channel when defined in the DT. The reference is saved in SCMI reset controller driver private data.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/reset/reset-scmi.c | 15 +++++++++++++-- 1 file changed, 13 insertions(+), 2 deletions(-)
diff --git a/drivers/reset/reset-scmi.c b/drivers/reset/reset-scmi.c index 30b26ec9d31..6101bd2a1e8 100644 --- a/drivers/reset/reset-scmi.c +++ b/drivers/reset/reset-scmi.c @@ -15,6 +15,7 @@
static int scmi_reset_set_level(struct reset_ctl *rst, bool assert_not_deassert) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(rst->dev); struct scmi_rd_reset_in in = { .domain_id = rst->id, .flags = assert_not_deassert ? SCMI_RD_RESET_FLAG_ASSERT : 0, @@ -26,7 +27,7 @@ static int scmi_reset_set_level(struct reset_ctl *rst, bool assert_not_deassert) in, out); int ret;
- ret = devm_scmi_process_msg(rst->dev, NULL, &msg); + ret = devm_scmi_process_msg(rst->dev, *scmi_channel_ref, &msg); if (ret) return ret;
@@ -45,6 +46,7 @@ static int scmi_reset_deassert(struct reset_ctl *rst)
static int scmi_reset_request(struct reset_ctl *rst) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(rst->dev); struct scmi_rd_attr_in in = { .domain_id = rst->id, }; @@ -58,7 +60,7 @@ static int scmi_reset_request(struct reset_ctl *rst) * We don't really care about the attribute, just check * the reset domain exists. */ - ret = devm_scmi_process_msg(rst->dev, NULL, &msg); + ret = devm_scmi_process_msg(rst->dev, *scmi_channel_ref, &msg); if (ret) return ret;
@@ -71,8 +73,17 @@ static const struct reset_ops scmi_reset_domain_ops = { .rst_deassert = scmi_reset_deassert, };
+static int scmi_reset_probe(struct udevice *dev) +{ + struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); + + return devm_scmi_of_get_channel(dev, scmi_channel_ref); +} + U_BOOT_DRIVER(scmi_reset_domain) = { .name = "scmi_reset_domain", .id = UCLASS_RESET, .ops = &scmi_reset_domain_ops, + .probe = scmi_reset_probe, + .priv_auto = sizeof(struct scmi_channel *), };
Update SCMI regulator controller driver to get its assigned SCMI channel during initialization. This change allows SCMI voltage domain protocol to use a dedicated channel when defined in the DT. The reference is saved in SCMI regulator controller driver private data.
Cc: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/power/regulator/scmi_regulator.c | 20 +++++++++++++++----- 1 file changed, 15 insertions(+), 5 deletions(-)
diff --git a/drivers/power/regulator/scmi_regulator.c b/drivers/power/regulator/scmi_regulator.c index 3325ddaf23b..e0343e913f4 100644 --- a/drivers/power/regulator/scmi_regulator.c +++ b/drivers/power/regulator/scmi_regulator.c @@ -27,6 +27,7 @@ struct scmi_regulator_platdata {
static int scmi_voltd_set_enable(struct udevice *dev, bool enable) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_regulator_platdata *pdata = dev_get_plat(dev); struct scmi_voltd_config_set_in in = { .domain_id = pdata->domain_id, @@ -38,7 +39,7 @@ static int scmi_voltd_set_enable(struct udevice *dev, bool enable) in, out); int ret;
@@ -51,6 +52,7 @@ static int scmi_voltd_set_enable(struct udevice *dev, bool enable)
static int scmi_voltd_get_enable(struct udevice *dev) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_regulator_platdata *pdata = dev_get_plat(dev); struct scmi_voltd_config_get_in in = { .domain_id = pdata->domain_id, @@ -61,7 +63,7 @@ static int scmi_voltd_get_enable(struct udevice *dev) in, out); int ret;
- ret = devm_scmi_process_msg(dev, NULL, &msg); + ret = devm_scmi_process_msg(dev, *scmi_channel_ref, &msg); if (ret < 0) return ret;
@@ -74,6 +76,7 @@ static int scmi_voltd_get_enable(struct udevice *dev)
static int scmi_voltd_set_voltage_level(struct udevice *dev, int uV) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_regulator_platdata *pdata = dev_get_plat(dev); struct scmi_voltd_level_set_in in = { .domain_id = pdata->domain_id, @@ -85,7 +88,7 @@ static int scmi_voltd_set_voltage_level(struct udevice *dev, int uV) in, out); int ret;
@@ -94,6 +97,7 @@ static int scmi_voltd_set_voltage_level(struct udevice *dev, int uV)
static int scmi_voltd_get_voltage_level(struct udevice *dev) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_regulator_platdata *pdata = dev_get_plat(dev); struct scmi_voltd_level_get_in in = { .domain_id = pdata->domain_id, @@ -104,7 +108,7 @@ static int scmi_voltd_get_voltage_level(struct udevice *dev) in, out); int ret;
@@ -131,6 +135,7 @@ static int scmi_regulator_of_to_plat(struct udevice *dev)
static int scmi_regulator_probe(struct udevice *dev) { + struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_regulator_platdata *pdata = dev_get_plat(dev); struct scmi_voltd_attr_in in = { 0 }; struct scmi_voltd_attr_out out = { 0 }; @@ -144,10 +149,14 @@ static int scmi_regulator_probe(struct udevice *dev) }; int ret;
+ ret = devm_scmi_of_get_channel(dev->parent, scmi_channel_ref); + if (ret) + return ret; + /* Check voltage domain is known from SCMI server */ in.domain_id = pdata->domain_id;
- ret = devm_scmi_process_msg(dev, NULL, &scmi_msg); + ret = devm_scmi_process_msg(dev, *scmi_channel_ref, &scmi_msg); if (ret) { dev_err(dev, "Failed to query voltage domain %u: %d\n", pdata->domain_id, ret); @@ -171,6 +180,7 @@ U_BOOT_DRIVER(scmi_regulator) = { .probe = scmi_regulator_probe, .of_to_plat = scmi_regulator_of_to_plat, .plat_auto = sizeof(struct scmi_regulator_platdata), + .priv_auto = sizeof(struct scmi_channel *), };
static int scmi_regulator_bind(struct udevice *dev)
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_regulator_platdata *pdata = dev_get_plat(dev); struct scmi_voltd_config_set_in in = { .domain_id = pdata->domain_id,
- struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_regulator_platdata *pdata = dev_get_plat(dev); struct scmi_voltd_config_get_in in = { .domain_id = pdata->domain_id,
- ret = devm_scmi_process_msg(dev, *scmi_channel_ref, &msg); if (ret < 0) return ret;
- struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_regulator_platdata *pdata = dev_get_plat(dev); struct scmi_voltd_level_set_in in = { .domain_id = pdata->domain_id,
- struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_regulator_platdata *pdata = dev_get_plat(dev); struct scmi_voltd_level_get_in in = { .domain_id = pdata->domain_id,
- struct scmi_channel **scmi_channel_ref = dev_get_priv(dev); struct scmi_regulator_platdata *pdata = dev_get_plat(dev); struct scmi_voltd_attr_in in = { 0 }; struct scmi_voltd_attr_out out = { 0 };
- ret = devm_scmi_of_get_channel(dev->parent, scmi_channel_ref);
- if (ret)
return ret;
- /* Check voltage domain is known from SCMI server */ in.domain_id = pdata->domain_id;
- ret = devm_scmi_process_msg(dev, *scmi_channel_ref, &scmi_msg); if (ret) { dev_err(dev, "Failed to query voltage domain %u: %d\n", pdata->domain_id, ret);
Simplify scmi_voltd_set_enable() exit sequence.
Cc: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/power/regulator/scmi_regulator.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/power/regulator/scmi_regulator.c b/drivers/power/regulator/scmi_regulator.c index e0343e913f4..6affa457991 100644 --- a/drivers/power/regulator/scmi_regulator.c +++ b/drivers/power/regulator/scmi_regulator.c @@ -43,11 +43,7 @@ static int scmi_voltd_set_enable(struct udevice *dev, bool enable) if (ret) return ret;
- ret = scmi_to_linux_errno(out.status); - if (ret) - return ret; - - return ret; + return scmi_to_linux_errno(out.status); }
- if (ret)
return ret;
- return ret;
- return scmi_to_linux_errno(out.status);
Updates .process_msg operators of the SCMI transport drivers that supports multi-channel to use it now that drivers do provide the reference through channel argument. These are the mailbox agent, the optee agent and the smccc agent.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/firmware/scmi/mailbox_agent.c | 6 +----- drivers/firmware/scmi/optee_agent.c | 5 +---- drivers/firmware/scmi/smccc_agent.c | 6 +----- 3 files changed, 3 insertions(+), 14 deletions(-)
diff --git a/drivers/firmware/scmi/mailbox_agent.c b/drivers/firmware/scmi/mailbox_agent.c index e63b67c5ee8..3efdab9e723 100644 --- a/drivers/firmware/scmi/mailbox_agent.c +++ b/drivers/firmware/scmi/mailbox_agent.c @@ -43,13 +43,9 @@ static int scmi_mbox_process_msg(struct udevice *dev, struct scmi_channel *channel, struct scmi_msg *msg) { - struct scmi_mbox_channel *chan = dev_get_plat(dev); + struct scmi_mbox_channel *chan = &channel->ref; int ret;
- /* Support SCMI drivers upgraded to of_get_channel operator */ - if (channel) - chan = &channel->ref; - ret = scmi_write_msg_to_smt(dev, &chan->smt, msg); if (ret) return ret; diff --git a/drivers/firmware/scmi/optee_agent.c b/drivers/firmware/scmi/optee_agent.c index da5c2ec9754..2b2b8c1670a 100644 --- a/drivers/firmware/scmi/optee_agent.c +++ b/drivers/firmware/scmi/optee_agent.c @@ -278,13 +278,10 @@ static int scmi_optee_process_msg(struct udevice *dev, struct scmi_channel *channel, struct scmi_msg *msg) { + struct scmi_optee_channel *chan = &channel->ref; struct channel_session sess = { }; int ret;
- /* Support SCMI drivers upgraded to of_get_channel operator */ - if (channel) - chan = &channel->ref; - ret = open_channel(dev, chan, &sess); if (ret) return ret; diff --git a/drivers/firmware/scmi/smccc_agent.c b/drivers/firmware/scmi/smccc_agent.c index 73a7e0a844a..bc2eb67335b 100644 --- a/drivers/firmware/scmi/smccc_agent.c +++ b/drivers/firmware/scmi/smccc_agent.c @@ -42,14 +42,10 @@ static int scmi_smccc_process_msg(struct udevice *dev, struct scmi_channel *channel, struct scmi_msg *msg) { - struct scmi_smccc_channel *chan = dev_get_plat(dev); + struct scmi_smccc_channel *chan = &channel->ref; struct arm_smccc_res res; int ret;
Etienne Carriere
Jaehoon Chung
Sean Anderson
