[PATCH v2] cmd: nand: Add support to print the manufacturer, model and size
Add support to nand info for printing the manufacturer,model and size. The manufacturer and model are printed only for ONFI flashes.
U-Boot> nand info
Device 0: nand0, sector size 256 KiB Manufacturer MACRONIX Model MX30LF4G28AD Device size 512 MiB Page size 4096 b OOB size 256 b Erase size 262144 b ecc strength 8 bits ecc step size 512 b subpagesize 4096 b options 0x00004200 bbt options 0x00028000
Signed-off-by: Mihai Sain mihai.sain@microchip.com
Changes in v2: -------------- * use #ifdef directive for ONFI flashes. * use unsigned int for chipsize. --- cmd/nand.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/cmd/nand.c b/cmd/nand.c index fe834c4ac5..5773246d64 100644 --- a/cmd/nand.c +++ b/cmd/nand.c @@ -418,6 +418,11 @@ static void nand_print_and_set_info(int idx) printf("%dx ", chip->numchips); printf("%s, sector size %u KiB\n", mtd->name, mtd->erasesize >> 10); +#ifdef CONFIG_SYS_NAND_ONFI_DETECTION + printf(" Manufacturer %s \n", chip->onfi_params.manufacturer); + printf(" Model %s \n", chip->onfi_params.model); +#endif + printf(" Device size %8u MiB\n", (unsigned int)(chip->chipsize >> 20)); printf(" Page size %8d b\n", mtd->writesize); printf(" OOB size %8d b\n", mtd->oobsize); printf(" Erase size %8d b\n", mtd->erasesize);
U-Boot> nand info
Changes in v2:
- use #ifdef directive for ONFI flashes.
- use unsigned int for chipsize.
- printf(" Manufacturer %s \n", chip->onfi_params.manufacturer);
- printf(" Model %s \n", chip->onfi_params.model);
- printf(" Device size %8u MiB\n", (unsigned int)(chip->chipsize >> 20)); printf(" Page size %8d b\n", mtd->writesize); printf(" OOB size %8d b\n", mtd->oobsize); printf(" Erase size %8d b\n", mtd->erasesize);
Can you refactor the logic out of the end of nand_detect as a separate function and use that instead? That will cover more cases (e.g. JEDEC).
--Sean
Mihai Sain
Sean Anderson
