[U-Boot] [PATCH v4 0/5] Add support for Pinebook
This series adds support for the Pinebook, an allwinner A64 laptop produced by Pine64. It also syncs sun50i-a64.dtsi with linux, adds support for mmc delay calibration, R_I2C controller, and addresses the issue with activating video bridge when any of GPIOs is missing.
v2: - sync sun50i-a64.dtsi with linux instead of adding missing nodes - take sun50i-a64-pinebook.dts from linux - don't introduce new Kconfig for A64 MMC calibration - improve code in video bridge uclass to check for presensce of GPIO instead of ingoring EINVAL errors v3: - enable calibration for H6 as well - init ret variable in video_bridge_set_active() - fix order of dts files Makefile - split anx6345 binding into sun50i-a64-pinebook-u-boot.dts - drop speaker_amp node from pinebook dts - drop unnecessary options from defconfig v4: - sync device tree files with linux-next
Vasily Khoruzhick (5): mmc: sunxi: add support for automatic delay calibration dm: video: bridge: don't fail to activate bridge if reset or sleep GPIO is missing sunxi: DT: A64: update device tree files for Allwinner A64 SoC sun50i: A64: add support for R_I2C controller sunxi: DT: add support for Pinebook
arch/arm/dts/Makefile | 1 + arch/arm/dts/sun50i-a64-amarula-relic.dts | 168 +++++++++- arch/arm/dts/sun50i-a64-bananapi-m64.dts | 34 +- arch/arm/dts/sun50i-a64-nanopi-a64.dts | 89 +++++- arch/arm/dts/sun50i-a64-olinuxino.dts | 103 +++++- arch/arm/dts/sun50i-a64-orangepi-win.dts | 179 ++++++++++- arch/arm/dts/sun50i-a64-pine64.dts | 32 +- arch/arm/dts/sun50i-a64-pinebook-u-boot.dtsi | 15 + arch/arm/dts/sun50i-a64-pinebook.dts | 294 +++++++++++++++++ arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 32 +- arch/arm/dts/sun50i-a64-sopine.dtsi | 15 + arch/arm/dts/sun50i-a64.dtsi | 313 +++++++++++++++++-- arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/include/asm/arch-sunxi/mmc.h | 6 +- arch/arm/mach-sunxi/Kconfig | 1 + board/sunxi/board.c | 6 + configs/pinebook_defconfig | 22 ++ drivers/mmc/sunxi_mmc.c | 21 +- drivers/video/bridge/video-bridge-uclass.c | 16 +- 19 files changed, 1296 insertions(+), 52 deletions(-) create mode 100644 arch/arm/dts/sun50i-a64-pinebook-u-boot.dtsi create mode 100644 arch/arm/dts/sun50i-a64-pinebook.dts create mode 100644 configs/pinebook_defconfig
A64 and H6 support automatic delay calibration and Linux driver uses it instead of hardcoded delays. Add support for it to u-boot driver.
Fixes eMMC instability on Pinebook
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com Acked-by: Maxime Ripard maxime.ripard@bootlin.com Tested-by: Maxime Ripard maxime.ripard@bootlin.com Reviewed-by: Andre Przywara andre.przywara@arm.com Cc: Vagrant Cascadian vagrant@debian.org --- arch/arm/include/asm/arch-sunxi/mmc.h | 6 +++++- drivers/mmc/sunxi_mmc.c | 21 ++++++++++++++++++++- 2 files changed, 25 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/mmc.h b/arch/arm/include/asm/arch-sunxi/mmc.h index d98c53faaa..f2deafddd2 100644 --- a/arch/arm/include/asm/arch-sunxi/mmc.h +++ b/arch/arm/include/asm/arch-sunxi/mmc.h @@ -46,7 +46,9 @@ struct sunxi_mmc { u32 cbda; /* 0x94 */ u32 res2[26]; #if defined(CONFIG_SUNXI_GEN_SUN6I) || defined(CONFIG_MACH_SUN50I_H6) - u32 res3[64]; + u32 res3[17]; + u32 samp_dl; + u32 res4[46]; #endif u32 fifo; /* 0x100 / 0x200 FIFO access address */ }; @@ -130,5 +132,7 @@ struct sunxi_mmc { #define SUNXI_MMC_COMMON_CLK_GATE (1 << 16) #define SUNXI_MMC_COMMON_RESET (1 << 18)
+#define SUNXI_MMC_CAL_DL_SW_EN (0x1 << 7) + struct mmc *sunxi_mmc_init(int sdc_no); #endif /* _SUNXI_MMC_H */ diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 39f15eb423..147eb9b4d5 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -99,11 +99,16 @@ static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) { unsigned int pll, pll_hz, div, n, oclk_dly, sclk_dly; bool new_mode = false; + bool calibrate = false; u32 val = 0;
if (IS_ENABLED(CONFIG_MMC_SUNXI_HAS_NEW_MODE) && (priv->mmc_no == 2)) new_mode = true;
+#if defined(CONFIG_MACH_SUN50I) || defined(CONFIG_MACH_SUN50I_H6) + calibrate = true; +#endif + /* * The MMC clock has an extra /2 post-divider when operating in the new * mode. @@ -174,7 +179,11 @@ static int mmc_set_mod_clk(struct sunxi_mmc_priv *priv, unsigned int hz) val = CCM_MMC_CTRL_MODE_SEL_NEW; setbits_le32(&priv->reg->ntsr, SUNXI_MMC_NTSR_MODE_SEL_NEW); #endif - } else { + } else if (!calibrate) { + /* + * Use hardcoded delay values if controller doesn't support + * calibration + */ val = CCM_MMC_CTRL_OCLK_DLY(oclk_dly) | CCM_MMC_CTRL_SCLK_DLY(sclk_dly); } @@ -228,6 +237,16 @@ static int mmc_config_clock(struct sunxi_mmc_priv *priv, struct mmc *mmc) rval &= ~SUNXI_MMC_CLK_DIVIDER_MASK; writel(rval, &priv->reg->clkcr);
+#if defined(CONFIG_MACH_SUN50I) || defined(CONFIG_MACH_SUN50I_H6) + /* A64 supports calibration of delays on MMC controller and we + * have to set delay of zero before starting calibration. + * Allwinner BSP driver sets a delay only in the case of + * using HS400 which is not supported by mainline U-Boot or + * Linux at the moment + */ + writel(SUNXI_MMC_CAL_DL_SW_EN, &priv->reg->samp_dl); +#endif + /* Re-enable Clock */ rval |= SUNXI_MMC_CLK_ENABLE; writel(rval, &priv->reg->clkcr);
Both GPIOs are optional, so we shouldn't fail if any is missing. Without this fix reset is not deasserted if sleep GPIO is missing.
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com Acked-by: Maxime Ripard maxime.ripard@bootlin.com Tested-by: Maxime Ripard maxime.ripard@bootlin.com Reviewed-by: Andre Przywara andre.przywara@arm.com Cc: Vagrant Cascadian vagrant@debian.org --- drivers/video/bridge/video-bridge-uclass.c | 16 +++++++++++----- 1 file changed, 11 insertions(+), 5 deletions(-)
diff --git a/drivers/video/bridge/video-bridge-uclass.c b/drivers/video/bridge/video-bridge-uclass.c index cd4959cc71..5fecb4cfd5 100644 --- a/drivers/video/bridge/video-bridge-uclass.c +++ b/drivers/video/bridge/video-bridge-uclass.c @@ -106,13 +106,19 @@ static int video_bridge_pre_probe(struct udevice *dev) int video_bridge_set_active(struct udevice *dev, bool active) { struct video_bridge_priv *uc_priv = dev_get_uclass_priv(dev); - int ret; + int ret = 0;
debug("%s: %d\n", __func__, active); - ret = dm_gpio_set_value(&uc_priv->sleep, !active); - if (ret) - return ret; - if (active) { + if (uc_priv->sleep.dev) { + ret = dm_gpio_set_value(&uc_priv->sleep, !active); + if (ret) + return ret; + } + + if (!active) + return 0; + + if (uc_priv->reset.dev) { ret = dm_gpio_set_value(&uc_priv->reset, true); if (ret) return ret;
Updates the device tree files from the linux-next tree, exactly Linux commit:
commit 8c60c36d0b8c (tag: next-20181019) Author: Stephen Rothwell sfr@canb.auug.org.au Date: Fri Oct 19 18:13:43 2018 +1100
Add linux-next specific files for 20181019
Signed-off-by: Stephen Rothwell sfr@canb.auug.org.au
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com Cc: Vagrant Cascadian vagrant@debian.org --- arch/arm/dts/sun50i-a64-amarula-relic.dts | 168 +++++++++- arch/arm/dts/sun50i-a64-bananapi-m64.dts | 34 +- arch/arm/dts/sun50i-a64-nanopi-a64.dts | 89 +++++- arch/arm/dts/sun50i-a64-olinuxino.dts | 103 +++++- arch/arm/dts/sun50i-a64-orangepi-win.dts | 179 ++++++++++- arch/arm/dts/sun50i-a64-pine64.dts | 32 +- arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 32 +- arch/arm/dts/sun50i-a64-sopine.dtsi | 15 + arch/arm/dts/sun50i-a64.dtsi | 313 +++++++++++++++++-- 9 files changed, 920 insertions(+), 45 deletions(-)
diff --git a/arch/arm/dts/sun50i-a64-amarula-relic.dts b/arch/arm/dts/sun50i-a64-amarula-relic.dts index f3b4e93ece..6cb2b7f0c8 100644 --- a/arch/arm/dts/sun50i-a64-amarula-relic.dts +++ b/arch/arm/dts/sun50i-a64-amarula-relic.dts @@ -22,11 +22,11 @@ stdout-path = "serial0:115200n8"; };
- reg_vcc3v3: vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; + wifi_pwrseq: wifi-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rtc 1>; + clock-names = "ext_clock"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* WL-PMU-EN: PL2 */ }; };
@@ -34,10 +34,34 @@ status = "okay"; };
+&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_dcdc1>; + /* + * Schematic shows both dldo4 and eldo1 connected for vcc-io-wifi, but + * dldo4 connection shows DNP(Do Not Populate) and eldo1 connected with + * 0Ohm register to vcc-io-wifi so eldo1 is used. + */ + vqmmc-supply = <®_eldo1>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&r_pio>; + interrupts = <0 3 IRQ_TYPE_LEVEL_LOW>; /* WL-WAKE-AP: PL3 */ + interrupt-names = "host-wake"; + }; +}; + &mmc2 { pinctrl-names = "default"; pinctrl-0 = <&mmc2_pins>; - vmmc-supply = <®_vcc3v3>; + vmmc-supply = <®_dcdc1>; bus-width = <8>; non-removable; cap-mmc-hw-reset; @@ -48,9 +72,138 @@ status = "okay"; };
+&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + x-powers,drive-vbus-en; /* set N_VBUSEN as output pin */ + }; +}; + +#include "axp803.dtsi" + +®_aldo1 { + regulator-always-on; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "avdd-csi"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1040000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-hdmi-dsi-sensor"; +}; + +®_dldo2 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-mipi"; +}; + +®_dldo3 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "dovdd-csi"; +}; + +®_dldo4 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi-io"; +}; + +®_drivevbus { + regulator-name = "usb0-vbus"; + status = "okay"; +}; + +®_eldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "cpvdd"; +}; + +®_eldo3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "dvdd-csi"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-1v2-hsic"; +}; + +/* + * The A64 chip cannot work without this regulator off, although + * it seems to be only driving the AR100 core. + * Maybe we don't still know well about CPUs domain. + */ +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; };
@@ -61,5 +214,6 @@
&usbphy { usb0_id_det-gpios = <&pio 7 9 GPIO_ACTIVE_HIGH>; /* PH9 */ + usb0_vbus-supply = <®_drivevbus>; status = "okay"; }; diff --git a/arch/arm/dts/sun50i-a64-bananapi-m64.dts b/arch/arm/dts/sun50i-a64-bananapi-m64.dts index 0716b14411..ef1c90401b 100644 --- a/arch/arm/dts/sun50i-a64-bananapi-m64.dts +++ b/arch/arm/dts/sun50i-a64-bananapi-m64.dts @@ -60,6 +60,17 @@ stdout-path = "serial0:115200n8"; };
+ hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + leds { compatible = "gpio-leds";
@@ -86,6 +97,10 @@ }; };
+&de { + status = "okay"; +}; + &ehci0 { status = "okay"; }; @@ -103,6 +118,17 @@ status = "okay"; };
+&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + &i2c1 { pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; @@ -151,7 +177,7 @@
&mmc2 { pinctrl-names = "default"; - pinctrl-0 = <&mmc2_pins>; + pinctrl-0 = <&mmc2_pins>, <&mmc2_ds_pin>; vmmc-supply = <®_dcdc1>; bus-width = <8>; non-removable; @@ -296,9 +322,13 @@ regulator-name = "vcc-rtc"; };
+&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; };
diff --git a/arch/arm/dts/sun50i-a64-nanopi-a64.dts b/arch/arm/dts/sun50i-a64-nanopi-a64.dts index e2dce48fa2..31884dbc88 100644 --- a/arch/arm/dts/sun50i-a64-nanopi-a64.dts +++ b/arch/arm/dts/sun50i-a64-nanopi-a64.dts @@ -51,12 +51,44 @@ compatible = "friendlyarm,nanopi-a64", "allwinner,sun50i-a64";
aliases { + ethernet0 = &emac; serial0 = &uart0; };
chosen { stdout-path = "serial0:115200n8"; }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + blue { + label = "nanopi-a64:blue:status"; + gpios = <&pio 3 24 GPIO_ACTIVE_LOW>; /* PD24 */ + }; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rtc 1>; + clock-names = "ext_clock"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ + }; +}; + +&de { + status = "okay"; };
&ehci0 { @@ -67,6 +99,26 @@ status = "okay"; };
+&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + phy-supply = <®_dcdc1>; + status = "okay"; +}; + +&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + /* i2c1 connected with gpio headers like pine64, bananapi */ &i2c1 { pinctrl-names = "default"; @@ -78,6 +130,13 @@ bias-pull-up; };
+&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <7>; + }; +}; + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; @@ -88,6 +147,24 @@ status = "okay"; };
+&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_dldo4>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + rtl8189etv: wifi@1 { + reg = <1>; + interrupt-parent = <&r_pio>; + interrupts = <0 3 IRQ_TYPE_LEVEL_LOW>; /* PL3 */ + interrupt-names = "host-wake"; + }; +}; + &ohci0 { status = "okay"; }; @@ -125,9 +202,9 @@
®_dcdc1 { regulator-always-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-name = "vcc-3v"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; };
®_dcdc2 { @@ -195,9 +272,13 @@ regulator-name = "vcc-rtc"; };
diff --git a/arch/arm/dts/sun50i-a64-olinuxino.dts b/arch/arm/dts/sun50i-a64-olinuxino.dts index 3b3081b10e..f7a4bccaa5 100644 --- a/arch/arm/dts/sun50i-a64-olinuxino.dts +++ b/arch/arm/dts/sun50i-a64-olinuxino.dts @@ -51,6 +51,7 @@ compatible = "olimex,a64-olinuxino", "allwinner,sun50i-a64";
@@ -58,12 +59,74 @@ stdout-path = "serial0:115200n8"; };
+ hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + reg_usb1_vbus: usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + enable-active-high; + gpio = <&pio 6 9 GPIO_ACTIVE_HIGH>; /* PG9 */ + status = "okay"; + }; + wifi_pwrseq: wifi_pwrseq { compatible = "mmc-pwrseq-simple"; reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ }; };
+&de { + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + phy-supply = <®_dcdc1>; + allwinner,tx-delay-ps = <600>; + status = "okay"; +}; + +&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; @@ -92,6 +155,14 @@ }; };
+&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + &r_rsb { status = "okay";
@@ -100,6 +171,7 @@ reg = <0x3a3>; interrupt-parent = <&r_intc>; interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + x-powers,drive-vbus-en; /* set N_VBUSEN as output pin */ }; };
@@ -142,10 +214,14 @@
+/* + * The board uses DDR3L DRAM chips. 1.36V is the closest to the nominal + * 1.35V that the PMIC can drive. + */ ®_dcdc5 { regulator-always-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; + regulator-min-microvolt = <1360000>; + regulator-max-microvolt = <1360000>; regulator-name = "vcc-ddr3"; };
@@ -180,6 +256,11 @@ regulator-name = "vcc-wifi-io"; };
+®_drivevbus { + regulator-name = "usb0-vbus"; + status = "okay"; +}; + ®_eldo1 { regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -214,8 +295,24 @@ regulator-name = "vcc-rtc"; };
+&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { status = "okay"; + usb0_id_det-gpios = <&pio 7 9 GPIO_ACTIVE_HIGH>; /* PH9 */ + usb0_vbus-supply = <®_drivevbus>; + usb1_vbus-supply = <®_usb1_vbus>; }; diff --git a/arch/arm/dts/sun50i-a64-orangepi-win.dts b/arch/arm/dts/sun50i-a64-orangepi-win.dts index bf42690a33..b0c64f7579 100644 --- a/arch/arm/dts/sun50i-a64-orangepi-win.dts +++ b/arch/arm/dts/sun50i-a64-orangepi-win.dts @@ -1,5 +1,6 @@ /* * Copyright (C) 2017 Jagan Teki jteki@openedev.com + * Copyright (C) 2017-2018 Samuel Holland samuel@sholland.org * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual @@ -51,23 +52,127 @@ compatible = "xunlong,orangepi-win", "allwinner,sun50i-a64";
aliases { + ethernet0 = &emac; serial0 = &uart0; + serial1 = &uart1; + serial2 = &uart2; + serial3 = &uart3; + serial4 = &uart4; };
chosen { stdout-path = "serial0:115200n8"; }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + status { + label = "orangepi:green:status"; + gpios = <&pio 7 11 GPIO_ACTIVE_HIGH>; /* PH11 */ + }; + }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + enable-active-high; + gpio = <&pio 3 14 GPIO_ACTIVE_HIGH>; /* PD14 */ + status = "okay"; + }; + + reg_usb1_vbus: usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + enable-active-high; + gpio = <&pio 3 7 GPIO_ACTIVE_HIGH>; /* PD7 */ + status = "okay"; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 8 GPIO_ACTIVE_LOW>; /* PL8 */ + }; +}; + +&de { + status = "okay"; +}; + +&ehci0 { + status = "okay"; };
&ehci1 { status = "okay"; };
+&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + phy-supply = <®_gmac_3v3>; + status = "okay"; +}; + +&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; vmmc-supply = <®_dcdc1>; - cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_dldo2>; + vqmmc-supply = <®_dldo4>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; +}; + +&ohci0 { status = "okay"; };
@@ -89,9 +194,8 @@ #include "axp803.dtsi"
®_aldo1 { - regulator-always-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; regulator-name = "afvcc-csi"; };
@@ -163,12 +267,23 @@ regulator-name = "vcc-wifi-io"; };
+®_drivevbus { + regulator-name = "usb0-vbus"; + status = "okay"; +}; + ®_eldo1 { regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-name = "cpvdd"; };
+®_eldo3 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1800000>; + regulator-name = "dvdd-csi"; +}; + ®_fldo1 { regulator-min-microvolt = <1200000>; regulator-max-microvolt = <1200000>; @@ -191,13 +306,65 @@ regulator-name = "vcc-rtc"; };
+&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + +&spi0 { + status = "okay"; + + spi-flash@0 { + compatible = "mxicy,mx25l1606e", "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <80000000>; + m25p,fast-read; + status = "okay"; + }; +}; + +/* On debug connector */ &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; };
-&usbphy { +/* Bluetooth */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; + status = "okay"; +}; + +/* On Pi-2 connector, RTS/CTS optional */ +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + status = "disabled"; +}; + +/* On Pi-2 connector, RTS/CTS optional */ +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins>; + status = "disabled"; +}; + +/* On Pi-2 connector (labeled for SPI1), RTS/CTS optional */ +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&uart4_pins>; + status = "disabled"; +}; + +&usb_otg { + dr_mode = "otg"; status = "okay"; };
+&usbphy { + usb0_id_det-gpios = <&pio 7 9 GPIO_ACTIVE_HIGH>; /* PH9 */ + usb0_vbus-supply = <®_drivevbus>; + usb1_vbus-supply = <®_usb1_vbus>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-a64-pine64.dts b/arch/arm/dts/sun50i-a64-pine64.dts index a75825798a..c077b6c1f4 100644 --- a/arch/arm/dts/sun50i-a64-pine64.dts +++ b/arch/arm/dts/sun50i-a64-pine64.dts @@ -62,6 +62,21 @@ chosen { stdout-path = "serial0:115200n8"; }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; +}; + +&de { + status = "okay"; };
&ehci0 { @@ -82,6 +97,17 @@
+&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + &i2c1 { pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; @@ -229,6 +255,10 @@ regulator-name = "vcc-rtc"; };
+&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + /* On Euler connector */ &spdif { status = "disabled"; @@ -237,7 +267,7 @@ /* On Exp and Euler connectors */ &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; };
diff --git a/arch/arm/dts/sun50i-a64-sopine-baseboard.dts b/arch/arm/dts/sun50i-a64-sopine-baseboard.dts index abe179de35..53fcc9098d 100644 --- a/arch/arm/dts/sun50i-a64-sopine-baseboard.dts +++ b/arch/arm/dts/sun50i-a64-sopine-baseboard.dts @@ -61,6 +61,17 @@ stdout-path = "serial0:115200n8"; };
+ hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + reg_vcc1v8: vcc1v8 { compatible = "regulator-fixed"; regulator-name = "vcc1v8"; @@ -69,6 +80,10 @@ }; };
+&de { + status = "okay"; +}; + &ehci0 { status = "okay"; }; @@ -86,6 +101,17 @@ status = "okay"; };
+&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + &mdio { ext_rgmii_phy: ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; @@ -134,9 +160,13 @@ regulator-name = "vcc-wifi"; };
diff --git a/arch/arm/dts/sun50i-a64-sopine.dtsi b/arch/arm/dts/sun50i-a64-sopine.dtsi index 43418bd881..6723b8695e 100644 --- a/arch/arm/dts/sun50i-a64-sopine.dtsi +++ b/arch/arm/dts/sun50i-a64-sopine.dtsi @@ -45,6 +45,8 @@
#include "sun50i-a64.dtsi"
+#include <dt-bindings/gpio/gpio.h> + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; @@ -52,6 +54,7 @@ non-removable; disable-wp; bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ status = "okay"; };
@@ -66,6 +69,18 @@ }; };
+&spi0 { + status = "okay"; + + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <40000000>; + }; +}; + #include "axp803.dtsi"
®_aldo2 { diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index 7a083637c4..f3a66f8882 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -43,9 +43,12 @@ */
#include <dt-bindings/clock/sun50i-a64-ccu.h> +#include <dt-bindings/clock/sun8i-de2.h> #include <dt-bindings/clock/sun8i-r-ccu.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/reset/sun50i-a64-ccu.h> +#include <dt-bindings/reset/sun8i-de2.h> +#include <dt-bindings/reset/sun8i-r-ccu.h>
/ { interrupt-parent = <&gic>; @@ -57,17 +60,21 @@ #size-cells = <1>; ranges;
-/* - * The pipeline mixer0-lcd0 depends on clock CLK_MIXER0 from DE2 CCU. - * However there is no support for this clock on A64 yet, so we depend - * on the upstream clocks here to keep them (and thus CLK_MIXER0) up. - */ simplefb_lcd: framebuffer-lcd { compatible = "allwinner,simple-framebuffer", "simple-framebuffer"; allwinner,pipeline = "mixer0-lcd0"; clocks = <&ccu CLK_TCON0>, - <&ccu CLK_DE>, <&ccu CLK_BUS_DE>; + <&display_clocks CLK_MIXER0>; + status = "disabled"; + }; + + simplefb_hdmi: framebuffer-hdmi { + compatible = "allwinner,simple-framebuffer", + "simple-framebuffer"; + allwinner,pipeline = "mixer1-lcd1-hdmi"; + clocks = <&display_clocks CLK_MIXER1>, + <&ccu CLK_TCON1>, <&ccu CLK_HDMI>; status = "disabled"; }; }; @@ -81,6 +88,7 @@ device_type = "cpu"; reg = <0>; enable-method = "psci"; + next-level-cache = <&L2>; };
cpu1: cpu@1 { @@ -88,6 +96,7 @@ device_type = "cpu"; reg = <1>; enable-method = "psci"; + next-level-cache = <&L2>; };
cpu2: cpu@2 { @@ -95,6 +104,7 @@ device_type = "cpu"; reg = <2>; enable-method = "psci"; + next-level-cache = <&L2>; };
cpu3: cpu@3 { @@ -102,7 +112,20 @@ device_type = "cpu"; reg = <3>; enable-method = "psci"; + next-level-cache = <&L2>; }; + + L2: l2-cache { + compatible = "cache"; + cache-level = <2>; + }; + }; + + de: display-engine { + compatible = "allwinner,sun50i-a64-display-engine"; + allwinner,pipelines = <&mixer0>, + <&mixer1>; + status = "disabled"; };
osc24M: osc24M_clk { @@ -168,10 +191,92 @@ #size-cells = <1>; ranges;
+ de2@1000000 { + compatible = "allwinner,sun50i-a64-de2"; + reg = <0x1000000 0x400000>; + allwinner,sram = <&de2_sram 1>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1000000 0x400000>; + + display_clocks: clock@0 { + compatible = "allwinner,sun50i-a64-de2-clk"; + reg = <0x0 0x100000>; + clocks = <&ccu CLK_DE>, + <&ccu CLK_BUS_DE>; + clock-names = "mod", + "bus"; + resets = <&ccu RST_BUS_DE>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + mixer0: mixer@100000 { + compatible = "allwinner,sun50i-a64-de2-mixer-0"; + reg = <0x100000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER0>, + <&display_clocks CLK_MIXER0>; + clock-names = "bus", + "mod"; + resets = <&display_clocks RST_MIXER0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer0_out: port@1 { + reg = <1>; + + mixer0_out_tcon0: endpoint { + remote-endpoint = <&tcon0_in_mixer0>; + }; + }; + }; + }; + + mixer1: mixer@200000 { + compatible = "allwinner,sun50i-a64-de2-mixer-1"; + reg = <0x200000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER1>, + <&display_clocks CLK_MIXER1>; + clock-names = "bus", + "mod"; + resets = <&display_clocks RST_MIXER1>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer1_out: port@1 { + reg = <1>; + + mixer1_out_tcon1: endpoint { + remote-endpoint = <&tcon1_in_mixer1>; + }; + }; + }; + }; + }; + syscon: syscon@1c00000 { - compatible = "allwinner,sun50i-a64-system-controller", - "syscon"; + compatible = "allwinner,sun50i-a64-system-control"; reg = <0x01c00000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + sram_c: sram@18000 { + compatible = "mmio-sram"; + reg = <0x00018000 0x28000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x00018000 0x28000>; + + de2_sram: sram-section@0 { + compatible = "allwinner,sun50i-a64-sram-c"; + reg = <0x0000 0x28000>; + }; + }; };
dma: dma-controller@1c02000 { @@ -185,6 +290,75 @@ #dma-cells = <1>; };
+ tcon0: lcd-controller@1c0c000 { + compatible = "allwinner,sun50i-a64-tcon-lcd", + "allwinner,sun8i-a83t-tcon-lcd"; + reg = <0x01c0c000 0x1000>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON0>, <&ccu CLK_TCON0>; + clock-names = "ahb", "tcon-ch0"; + clock-output-names = "tcon-pixel-clock"; + resets = <&ccu RST_BUS_TCON0>, <&ccu RST_BUS_LVDS>; + reset-names = "lcd", "lvds"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon0_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + tcon0_in_mixer0: endpoint@0 { + reg = <0>; + remote-endpoint = <&mixer0_out_tcon0>; + }; + }; + + tcon0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + }; + }; + }; + + tcon1: lcd-controller@1c0d000 { + compatible = "allwinner,sun50i-a64-tcon-tv", + "allwinner,sun8i-a83t-tcon-tv"; + reg = <0x01c0d000 0x1000>; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON1>, <&ccu CLK_TCON1>; + clock-names = "ahb", "tcon-ch1"; + resets = <&ccu RST_BUS_TCON1>; + reset-names = "lcd"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon1_in: port@0 { + reg = <0>; + + tcon1_in_mixer1: endpoint { + remote-endpoint = <&mixer1_out_tcon1>; + }; + }; + + tcon1_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + tcon1_out_hdmi: endpoint@1 { + reg = <1>; + remote-endpoint = <&hdmi_in_tcon1>; + }; + }; + }; + }; + mmc0: mmc@1c0f000 { compatible = "allwinner,sun50i-a64-mmc"; reg = <0x01c0f000 0x1000>; @@ -227,6 +401,11 @@ #size-cells = <0>; };
+ sid: eeprom@1c14000 { + compatible = "allwinner,sun50i-a64-sid"; + reg = <0x1c14000 0x400>; + }; + usb_otg: usb@1c19000 { compatible = "allwinner,sun8i-a33-musb"; reg = <0x01c19000 0x0400>; @@ -356,7 +535,7 @@ };
mmc2_pins: mmc2-pins { - pins = "PC1", "PC5", "PC6", "PC8", "PC9", + pins = "PC5", "PC6", "PC8", "PC9", "PC10","PC11", "PC12", "PC13", "PC14", "PC15", "PC16"; function = "mmc2"; @@ -364,6 +543,18 @@ bias-pull-up; };
+ mmc2_ds_pin: mmc2-ds-pin { + pins = "PC1"; + function = "mmc2"; + drive-strength = <30>; + bias-pull-up; + }; + + pwm_pin: pwm_pin { + pins = "PD22"; + function = "pwm"; + }; + rmii_pins: rmii_pins { pins = "PD10", "PD11", "PD13", "PD14", "PD17", "PD18", "PD19", "PD20", "PD22", "PD23"; @@ -394,7 +585,7 @@ function = "spi1"; };
- uart0_pins_a: uart0 { + uart0_pb_pins: uart0-pb-pins { pins = "PB8", "PB9"; function = "uart0"; }; @@ -474,15 +665,6 @@ status = "disabled"; };
- pwm: pwm@1c21400 { - compatible = "allwinner,sun50i-a64-pwm", - "allwinner,sun5i-a13-pwm"; - reg = <0x01c21400 0x8>; - clocks = <&osc24M>; - #pwm-cells = <3>; - status = "disabled"; - }; - uart0: serial@1c28000 { compatible = "snps,dw-apb-uart"; reg = <0x01c28000 0x400>; @@ -617,8 +799,6 @@ clocks = <&ccu CLK_BUS_EMAC>; clock-names = "stmmaceth"; status = "disabled"; - #address-cells = <1>; - #size-cells = <0>;
mdio: mdio { compatible = "snps,dwmac-mdio"; @@ -638,11 +818,69 @@ #interrupt-cells = <3>; };
+ pwm: pwm@1c21400 { + compatible = "allwinner,sun50i-a64-pwm", + "allwinner,sun5i-a13-pwm"; + reg = <0x01c21400 0x400>; + clocks = <&osc24M>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm_pin>; + #pwm-cells = <3>; + status = "disabled"; + }; + + hdmi: hdmi@1ee0000 { + compatible = "allwinner,sun50i-a64-dw-hdmi", + "allwinner,sun8i-a83t-dw-hdmi"; + reg = <0x01ee0000 0x10000>; + reg-io-width = <1>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_HDMI>, <&ccu CLK_HDMI_DDC>, + <&ccu CLK_HDMI>; + clock-names = "iahb", "isfr", "tmds"; + resets = <&ccu RST_BUS_HDMI1>; + reset-names = "ctrl"; + phys = <&hdmi_phy>; + phy-names = "hdmi-phy"; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + hdmi_in: port@0 { + reg = <0>; + + hdmi_in_tcon1: endpoint { + remote-endpoint = <&tcon1_out_hdmi>; + }; + }; + + hdmi_out: port@1 { + reg = <1>; + }; + }; + }; + + hdmi_phy: hdmi-phy@1ef0000 { + compatible = "allwinner,sun50i-a64-hdmi-phy"; + reg = <0x01ef0000 0x10000>; + clocks = <&ccu CLK_BUS_HDMI>, <&ccu CLK_HDMI_DDC>, + <&ccu 7>; + clock-names = "bus", "mod", "pll-0"; + resets = <&ccu RST_BUS_HDMI0>; + reset-names = "phy"; + #phy-cells = <0>; + }; + rtc: rtc@1f00000 { compatible = "allwinner,sun6i-a31-rtc"; reg = <0x01f00000 0x54>; interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + clock-output-names = "rtc-osc32k", "rtc-osc32k-out"; + clocks = <&osc32k>; + #clock-cells = <1>; };
r_intc: interrupt-controller@1f00c00 { @@ -664,6 +902,29 @@ #reset-cells = <1>; };
+ r_i2c: i2c@1f02400 { + compatible = "allwinner,sun50i-a64-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x01f02400 0x400>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu CLK_APB0_I2C>; + resets = <&r_ccu RST_APB0_I2C>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + r_pwm: pwm@1f03800 { + compatible = "allwinner,sun50i-a64-pwm", + "allwinner,sun5i-a13-pwm"; + reg = <0x01f03800 0x400>; + clocks = <&osc24M>; + pinctrl-names = "default"; + pinctrl-0 = <&r_pwm_pin>; + #pwm-cells = <3>; + status = "disabled"; + }; + r_pio: pinctrl@1f02c00 { compatible = "allwinner,sun50i-a64-r-pinctrl"; reg = <0x01f02c00 0x400>; @@ -675,6 +936,16 @@ interrupt-controller; #interrupt-cells = <3>;
+ r_i2c_pl89_pins: r-i2c-pl89-pins { + pins = "PL8", "PL9"; + function = "s_i2c"; + }; + + r_pwm_pin: pwm { + pins = "PL10"; + function = "s_pwm"; + }; + r_rsb_pins: rsb { pins = "PL0", "PL1"; function = "s_rsb";
Allwinner A64 has a I2C controller, which is in the R_ MMIO zone and has two groups of pinmuxes on PL bank, so it's called R_I2C.
Add support for this I2C controller and the pinmux which doesn't conflict with RSB.
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com Acked-by: Maxime Ripard maxime.ripard@bootlin.com Tested-by: Maxime Ripard maxime.ripard@bootlin.com Cc: Vagrant Cascadian vagrant@debian.org --- arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/mach-sunxi/Kconfig | 1 + board/sunxi/board.c | 6 ++++++ 3 files changed, 8 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index 6a5eafc3d3..2daf23f6f5 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -211,6 +211,7 @@ enum sunxi_gpio_number { #define SUN8I_H3_GPL_R_TWI 2 #define SUN8I_A23_GPL_R_TWI 3 #define SUN8I_GPL_R_UART 2 +#define SUN50I_GPL_R_TWI 2
#define SUN9I_GPN_R_RSB 3
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 686f38fec4..7ba429c744 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -272,6 +272,7 @@ config MACH_SUN50I select ARM64 select DM_I2C select PHY_SUN4I_USB + select SUN6I_PRCM select SUNXI_DE2 select SUNXI_GEN_SUN6I select SUPPORT_SPL diff --git a/board/sunxi/board.c b/board/sunxi/board.c index d1d7f9f400..90f8bc0a6e 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -168,10 +168,16 @@ void i2c_init_board(void) #endif
#ifdef CONFIG_R_I2C_ENABLE +#ifdef CONFIG_MACH_SUN50I + clock_twi_onoff(5, 1); + sunxi_gpio_set_cfgpin(SUNXI_GPL(8), SUN50I_GPL_R_TWI); + sunxi_gpio_set_cfgpin(SUNXI_GPL(9), SUN50I_GPL_R_TWI); +#else clock_twi_onoff(5, 1); sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_H3_GPL_R_TWI); sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_H3_GPL_R_TWI); #endif +#endif }
#if defined(CONFIG_ENV_IS_IN_MMC) && defined(CONFIG_ENV_IS_IN_FAT)
Pinebook is a laptop produced by Pine64, with USB-connected keyboard, USB-connected touchpad and an eDP LCD panel connected via a RGB-eDP bridge from Analogix.
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com Acked-by: Maxime Ripard maxime.ripard@bootlin.com Tested-by: Maxime Ripard maxime.ripard@bootlin.com Cc: Vagrant Cascadian vagrant@debian.org --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun50i-a64-pinebook-u-boot.dtsi | 15 + arch/arm/dts/sun50i-a64-pinebook.dts | 294 +++++++++++++++++++ configs/pinebook_defconfig | 22 ++ 4 files changed, 332 insertions(+) create mode 100644 arch/arm/dts/sun50i-a64-pinebook-u-boot.dtsi create mode 100644 arch/arm/dts/sun50i-a64-pinebook.dts create mode 100644 configs/pinebook_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0de6234eec..94ec15a8ac 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -405,6 +405,7 @@ dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-orangepi-win.dtb \ sun50i-a64-pine64-plus.dtb \ sun50i-a64-pine64.dtb \ + sun50i-a64-pinebook.dtb \ sun50i-a64-sopine-baseboard.dtb dtb-$(CONFIG_MACH_SUN9I) += \ sun9i-a80-optimus.dtb \ diff --git a/arch/arm/dts/sun50i-a64-pinebook-u-boot.dtsi b/arch/arm/dts/sun50i-a64-pinebook-u-boot.dtsi new file mode 100644 index 0000000000..a99b7171d0 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-pinebook-u-boot.dtsi @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2018 Vasily Khoruzhick anarsoul@gmail.com + * + */ + +/* The ANX6345 eDP-bridge is on r_i2c */ +&r_i2c { + anx6345: edp-bridge@38 { + compatible = "analogix,anx6345"; + reg = <0x38>; + reset-gpios = <&pio 3 24 GPIO_ACTIVE_LOW>; /* PD24 */ + status = "okay"; + }; +}; diff --git a/arch/arm/dts/sun50i-a64-pinebook.dts b/arch/arm/dts/sun50i-a64-pinebook.dts new file mode 100644 index 0000000000..ec537c5297 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-pinebook.dts @@ -0,0 +1,294 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.xyz + * Copyright (C) 2018 Vasily Khoruzhick anarsoul@gmail.com + * + */ + +/dts-v1/; + +#include "sun50i-a64.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pwm/pwm.h> + +/ { + model = "Pinebook"; + compatible = "pine64,pinebook", "allwinner,sun50i-a64"; + + aliases { + serial0 = &uart0; + ethernet0 = &rtl8723cs; + }; + + vdd_bl: regulator@0 { + compatible = "regulator-fixed"; + regulator-name = "bl-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&pio 7 6 GPIO_ACTIVE_HIGH>; /* PH6 */ + enable-active-high; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + pwms = <&pwm 0 50000 0>; + brightness-levels = <0 5 10 15 20 30 40 55 70 85 100>; + default-brightness-level = <2>; + enable-gpios = <&pio 3 23 GPIO_ACTIVE_HIGH>; /* PD23 */ + power-supply = <&vdd_bl>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + + framebuffer-lcd { + panel-supply = <®_dc1sw>; + dvdd25-supply = <®_dldo2>; + dvdd12-supply = <®_fldo1>; + }; + }; + + gpio_keys { + compatible = "gpio-keys"; + + lid_switch { + label = "Lid Switch"; + gpios = <&r_pio 0 12 GPIO_ACTIVE_LOW>; /* PL12 */ + linux,input-type = <EV_SW>; + linux,code = <SW_LID>; + linux,can-disable; + wakeup-source; + }; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ + }; +}; + +&ehci0 { + phys = <&usbphy 0>; + phy-names = "usb"; + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_dcdc1>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_dldo4>; + vqmmc-supply = <®_eldo1>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + rtl8723cs: wifi@1 { + reg = <1>; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>, <&mmc2_ds_pin>; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_eldo1>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + mmc-hs200-1_8v; + status = "okay"; +}; + +&ohci0 { + phys = <&usbphy 0>; + phy-names = "usb"; + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&pwm { + status = "okay"; +}; + +&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +/* The ANX6345 eDP-bridge is on r_i2c */ +&r_i2c { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&r_i2c_pl89_pins>; + status = "okay"; +}; + +#include "axp803.dtsi" + +®_aldo1 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "vcc-csi"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <2700000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dc1sw { + regulator-name = "vcc-lcd"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-hdmi"; +}; + +®_dldo2 { + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-name = "vcc-edp"; +}; + +®_dldo3 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "avdd-csi"; +}; + +®_dldo4 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi"; +}; + +®_eldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "cpvdd"; +}; + +®_eldo3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vdd-1v8-csi"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-1v2-hsic"; +}; + +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_ldo_io0 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-usb"; + status = "okay"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + +&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "host"; +}; + +&usbphy { + usb0_vbus-supply = <®_ldo_io0>; + usb1_vbus-supply = <®_ldo_io0>; + status = "okay"; +}; diff --git a/configs/pinebook_defconfig b/configs/pinebook_defconfig new file mode 100644 index 0000000000..5294dbd2eb --- /dev/null +++ b/configs/pinebook_defconfig @@ -0,0 +1,22 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN50I=y +CONFIG_SUNXI_DRAM_LPDDR3_STOCK=y +CONFIG_DRAM_CLK=552 +CONFIG_DRAM_ZQ=3881949 +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_R_I2C_ENABLE=y +# CONFIG_CMD_FLASH is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pinebook" +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_PWM=y +CONFIG_PWM_SUNXI=y +CONFIG_USB_EHCI_HCD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +# CONFIG_USB_GADGET is not set +CONFIG_VIDEO_BRIDGE=y +CONFIG_VIDEO_BRIDGE_ANALOGIX_ANX6345=y
Hi!
- sun50i-a64-pinebook.dtb \ sun50i-a64-sopine-baseboard.dtb
- Copyright (C) 2018 Vasily Khoruzhick anarsoul@gmail.com
- anx6345: edp-bridge@38 {
reg = <0x38>;
status = "okay";
Maybe I missed something but I don't see when this dtsi file is used or included.
- Copyright (C) 2017 Icenowy Zheng icenowy@aosc.xyz
+/dts-v1/;
- model = "Pinebook";
- compatible = "pine64,pinebook", "allwinner,sun50i-a64";
- aliases {
serial0 = &uart0;
- vdd_bl: regulator@0 {
enable-active-high;
- backlight: backlight {
- chosen {
framebuffer-lcd {
- gpio_keys {
lid_switch {
linux,can-disable;
wakeup-source;
- wifi_pwrseq: wifi_pwrseq {
+&ehci0 {
- phys = <&usbphy 0>;
- phy-names = "usb";
- status = "okay";
+&ehci1 {
- status = "okay";
+&mmc0 {
- pinctrl-names = "default";
- pinctrl-0 = <&mmc0_pins>;
- vmmc-supply = <®_dcdc1>;
- disable-wp;
- bus-width = <4>;
- status = "okay";
+&mmc1 {
- pinctrl-0 = <&mmc1_pins>;
- vmmc-supply = <®_dldo4>;
- vqmmc-supply = <®_eldo1>;
- mmc-pwrseq = <&wifi_pwrseq>;
- bus-width = <4>;
- non-removable;
- status = "okay";
- rtl8723cs: wifi@1 {
reg = <1>;
+&mmc2 {
- pinctrl-0 = <&mmc2_pins>, <&mmc2_ds_pin>;
- bus-width = <8>;
- non-removable;
- cap-mmc-hw-reset;
- mmc-hs200-1_8v;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci1 {
- status = "okay";
+&pwm {
- status = "okay";
+&r_rsb {
- status = "okay";
- axp803: pmic@3a3 {
reg = <0x3a3>;
- clock-frequency = <100000>;
- pinctrl-0 = <&r_i2c_pl89_pins>;
- status = "okay";
+®_aldo1 {
- regulator-min-microvolt = <2800000>;
- regulator-max-microvolt = <2800000>;
- regulator-name = "vcc-csi";
+®_aldo2 {
- regulator-name = "vcc-pl";
+®_aldo3 {
- regulator-min-microvolt = <2700000>;
- regulator-name = "vcc-pll-avcc";
+®_dc1sw {
- regulator-name = "vcc-lcd";
+®_dcdc1 {
- regulator-name = "vcc-3v3";
+®_dcdc2 {
- regulator-min-microvolt = <1000000>;
- regulator-max-microvolt = <1300000>;
- regulator-name = "vdd-cpux";
+®_dcdc5 {
- regulator-min-microvolt = <1200000>;
- regulator-max-microvolt = <1200000>;
- regulator-name = "vcc-dram";
+®_dcdc6 {
- regulator-min-microvolt = <1100000>;
- regulator-max-microvolt = <1100000>;
- regulator-name = "vdd-sys";
+®_dldo1 {
- regulator-name = "vcc-hdmi";
+®_dldo2 {
- regulator-min-microvolt = <2500000>;
- regulator-max-microvolt = <2500000>;
- regulator-name = "vcc-edp";
+®_dldo3 {
- regulator-name = "avdd-csi";
+®_dldo4 {
- regulator-name = "vcc-wifi";
+®_eldo1 {
- regulator-max-microvolt = <1800000>;
- regulator-name = "cpvdd";
+®_eldo3 {
- regulator-name = "vdd-1v8-csi";
+®_fldo1 {
- regulator-name = "vcc-1v2-hsic";
+®_fldo2 {
- regulator-name = "vdd-cpus";
+®_ldo_io0 {
- regulator-name = "vcc-usb";
- status = "okay";
+®_rtc_ldo {
- regulator-name = "vcc-rtc";
+&simplefb_hdmi {
- vcc-hdmi-supply = <®_dldo1>;
+&uart0 {
- pinctrl-0 = <&uart0_pb_pins>;
- status = "okay";
+&usb_otg {
- dr_mode = "host";
+&usbphy {
- usb0_vbus-supply = <®_ldo_io0>;
- usb1_vbus-supply = <®_ldo_io0>;
- status = "okay";
On Mon, 29 Oct 2018 16:29:43 +0100 Loic Devulder ldevulder@suse.de wrote:
Hi!
reg = <0x38>;
status = "okay";
Yeah, that's some non-obvious U-Boot build magic: Whenever there is a file which has "-u-boot.dtsi" appended to certain .dts filename stubs, U-Boot includes this file when building the .dtb. This is supposed to be used to add U-Boot specific DT nodes or properties to some otherwise unchanged (read: Linux mainline) DTs. Check scripts/Makefile.lib and search for u-boot.dtsi for the source.
Cheers, Andre.
Tested series applied to u-boot 2018.11-rc3 on pinebook, both with reboot and cold boot.
Thanks for all the work on it!
Tested-by: Vagrant Cascadian vagrant@debian.org
-- 2.19.1
I have tested the series on my pinebook on top of git commit 99431c1c21685fe63d46b6eac995b78ce9adce0a
I am not sure if video is expected to work or not, in my case it does not work.
U-Boot SPL 2018.11-rc3-00027-g77a46c3a3c (Nov 03 2018 - 13:42:47 -0500) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v1.6(release): NOTICE: BL31: Built : 09:10:17, Sep 23 2018 NOTICE: BL31: Detected Allwinner A64/H64/R18 SoC (1689) NOTICE: BL31: STUB PMIC setup code called
U-Boot 2018.11-rc3-00027-g77a46c3a3c (Nov 03 2018 - 13:42:47 -0500) Allwinner Technology
CPU: Allwinner A64 (SUN50I) Model: Pinebook DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... *** Warning - bad CRC, using default environment
Warning: HDMI PHY init timeout! Warning: HDMI PHY init timeout! In: serial Out: serial Err: serial
u-boot however works fine and the system is able to boot and the correct dtb is loaded.
Tested-by: Dennis Gilmore dennis@ausil.us
-- 2.19.1
Video is supposed to work, but you need ATF from Andre to enable LCD power:
https://github.com/apritzel/arm-trusted-firmware/
-- 2.19.1
You need "allwinner" branch from this repo.
-- 2.19.1
I deliberately switched the standard branch away, since everything is merged in mainline ATF now (including PMIC support). I will post U-Boot patches to change the instructions soon, but just use the master branch from the official repo (and report back any issues!): https://github.com/ARM-Software/arm-trusted-firmware.git
You might need the latest DT in U-Boot (patches are queued, AFAIK) to let ATF know about your PMIC requirements.
Cheers, Andre
-- 2.19.1
Thanks, I just tested it - and my patches work fine with ATF from official repo.
Cheers, Andre
El sáb, 03-11-2018 a las 17:12 -0700, Vasily Khoruzhick escribió:
On Sat, Nov 3, 2018 at 2:15 PM André Przywara <andre.przywara@arm.com
I deliberately switched the standard branch away, since everything is merged in mainline ATF now (including PMIC support). I will post U- Boot patches to change the instructions soon, but just use the master branch from the official repo (and report back any issues!): https://github.com/ARM-Software/arm-trusted-firmware.git
I have just tested with ATF from the official repo and it all works.
Thanks
Dennis
participants (6)
Andre Przywara
André Przywara
Dennis Gilmore
Loic Devulder
Vagrant Cascadian
Vasily Khoruzhick
