[U-Boot] [PATCH v6 0/3] arm64: rockchip: dts: Add rk3399 -u-boot.dtsi files
This series is a rework of v5 patch that send it in separate series[1]
All these changes are creating an initial rk3399-u-boot.dtsi and rk3399 board -u-boot.dtsi files and u-boot specific dts changes like - sdram dtsi - sdmmc, u-boot,dm-pre-reloc - spi1, u-boot,dm-pre-reloc
Changes for v6: - spilt the existing patch[1] into multiple patches and send as a separate series.
[1] https://patchwork.ozlabs.org/patch/1091720/
Any inputs? Jagan.
Jagan Teki (3): arm64: rockchip: dts: rk3399: Add board -u-boot.dtsi files arm64: rockchip: dts: Add initial rk3399-u-boot.dtsi file arm64: rockchip: dts: rk3399: Use rk3399-u-boot.dtsi
arch/arm/dts/rk3399-evb-u-boot.dtsi | 7 +++++++ arch/arm/dts/rk3399-evb.dts | 2 -- arch/arm/dts/rk3399-ficus-u-boot.dtsi | 6 ++++++ arch/arm/dts/rk3399-ficus.dts | 1 - arch/arm/dts/rk3399-firefly-u-boot.dtsi | 7 +++++++ arch/arm/dts/rk3399-firefly.dts | 2 -- arch/arm/dts/rk3399-gru-bob-u-boot.dtsi | 7 +++++++ arch/arm/dts/rk3399-gru-bob.dts | 1 - arch/arm/dts/rk3399-gru-u-boot.dtsi | 6 ++++++ arch/arm/dts/rk3399-gru.dtsi | 1 - arch/arm/dts/rk3399-puma-ddr1600.dts | 1 + arch/arm/dts/rk3399-puma.dtsi | 3 --- arch/arm/dts/rk3399-rock960-u-boot.dtsi | 6 ++++++ arch/arm/dts/rk3399-rock960.dts | 1 - arch/arm/dts/rk3399-u-boot.dtsi | 12 ++++++++++++ 15 files changed, 52 insertions(+), 11 deletions(-) create mode 100644 arch/arm/dts/rk3399-evb-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-ficus-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-firefly-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-gru-bob-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-gru-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-rock960-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-u-boot.dtsi
Devicetree files in RK3399 platform is synced from Linux, like other platforms does. Apart from these u-boot in rk3399 would also require some u-boot specific node like dmc.
dmc node has big chunk of DDR timing parameters which are specific to specific board, and maintained with rk3399-sdram*.dtsi.
So, create board specific -u-boot.dtsi files and move these sdram dtsi files accordingly. This would help of maintain u-boot specific changes separately without touching Linux dts(i) files which indeed easy for syncing from Linux between releases.
These board specific -u-boot.dtsi can be extendible to add more u-boot specific nodes or properties in future.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-evb-u-boot.dtsi | 6 ++++++ arch/arm/dts/rk3399-evb.dts | 1 - arch/arm/dts/rk3399-ficus-u-boot.dtsi | 6 ++++++ arch/arm/dts/rk3399-ficus.dts | 1 - arch/arm/dts/rk3399-firefly-u-boot.dtsi | 6 ++++++ arch/arm/dts/rk3399-firefly.dts | 1 - arch/arm/dts/rk3399-gru-bob-u-boot.dtsi | 6 ++++++ arch/arm/dts/rk3399-gru-bob.dts | 1 - arch/arm/dts/rk3399-rock960-u-boot.dtsi | 6 ++++++ arch/arm/dts/rk3399-rock960.dts | 1 - 10 files changed, 30 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/rk3399-evb-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-ficus-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-firefly-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-gru-bob-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-rock960-u-boot.dtsi
diff --git a/arch/arm/dts/rk3399-evb-u-boot.dtsi b/arch/arm/dts/rk3399-evb-u-boot.dtsi new file mode 100644 index 0000000000..7e2c57af22 --- /dev/null +++ b/arch/arm/dts/rk3399-evb-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-sdram-lpddr3-4GB-1600.dtsi" diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index ce004d0d18..2366e7ed3a 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -7,7 +7,6 @@ #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/pinctrl/rockchip.h> #include "rk3399.dtsi" -#include "rk3399-sdram-lpddr3-4GB-1600.dtsi"
/ { model = "Rockchip RK3399 Evaluation Board"; diff --git a/arch/arm/dts/rk3399-ficus-u-boot.dtsi b/arch/arm/dts/rk3399-ficus-u-boot.dtsi new file mode 100644 index 0000000000..eab86bdb30 --- /dev/null +++ b/arch/arm/dts/rk3399-ficus-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-sdram-ddr3-1600.dtsi" diff --git a/arch/arm/dts/rk3399-ficus.dts b/arch/arm/dts/rk3399-ficus.dts index 4af0e4e383..4b2dd82b67 100644 --- a/arch/arm/dts/rk3399-ficus.dts +++ b/arch/arm/dts/rk3399-ficus.dts @@ -8,7 +8,6 @@
/dts-v1/; #include "rk3399-rock960.dtsi" -#include "rk3399-sdram-ddr3-1600.dtsi"
/ { model = "96boards RK3399 Ficus"; diff --git a/arch/arm/dts/rk3399-firefly-u-boot.dtsi b/arch/arm/dts/rk3399-firefly-u-boot.dtsi new file mode 100644 index 0000000000..eab86bdb30 --- /dev/null +++ b/arch/arm/dts/rk3399-firefly-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-sdram-ddr3-1600.dtsi" diff --git a/arch/arm/dts/rk3399-firefly.dts b/arch/arm/dts/rk3399-firefly.dts index f90e7e88db..5d52319393 100644 --- a/arch/arm/dts/rk3399-firefly.dts +++ b/arch/arm/dts/rk3399-firefly.dts @@ -7,7 +7,6 @@ #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/pinctrl/rockchip.h> #include "rk3399.dtsi" -#include "rk3399-sdram-ddr3-1600.dtsi"
/ { model = "Firefly-RK3399 Board"; diff --git a/arch/arm/dts/rk3399-gru-bob-u-boot.dtsi b/arch/arm/dts/rk3399-gru-bob-u-boot.dtsi new file mode 100644 index 0000000000..9edb8cf841 --- /dev/null +++ b/arch/arm/dts/rk3399-gru-bob-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-sdram-lpddr3-samsung-4GB-1866.dtsi" diff --git a/arch/arm/dts/rk3399-gru-bob.dts b/arch/arm/dts/rk3399-gru-bob.dts index 0e3d91fc28..1ee0dc0d9f 100644 --- a/arch/arm/dts/rk3399-gru-bob.dts +++ b/arch/arm/dts/rk3399-gru-bob.dts @@ -7,7 +7,6 @@
/dts-v1/; #include "rk3399-gru-chromebook.dtsi" -#include "rk3399-sdram-lpddr3-samsung-4GB-1866.dtsi"
/ { model = "Google Bob"; diff --git a/arch/arm/dts/rk3399-rock960-u-boot.dtsi b/arch/arm/dts/rk3399-rock960-u-boot.dtsi new file mode 100644 index 0000000000..5256f6d3f2 --- /dev/null +++ b/arch/arm/dts/rk3399-rock960-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-sdram-lpddr3-2GB-1600.dtsi" diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts index 25c58b4261..7e06bc97e5 100644 --- a/arch/arm/dts/rk3399-rock960.dts +++ b/arch/arm/dts/rk3399-rock960.dts @@ -5,7 +5,6 @@
/dts-v1/; #include "rk3399-rock960.dtsi" -#include "rk3399-sdram-lpddr3-2GB-1600.dtsi"
/ { model = "96boards Rock960";
U-Boot always managed to use Linux devicetree files with respective bindings, but on the other hand u-boot also has it's own u-boot specific nodes or properties example u-boot,dm-pre-reloc which is required for SPL_OF_CONTROL to allocate particular node.
It is always better to maintain these u-boot specific nodes and properties into seperate dts files. This would help to sync the devicetrees directly from Linux.
This patch is adding initial rk3399-u-boot.dtsi and move sdmmc, spi1 u-boot,dm-pre-reloc properties into it so-that the subsequent rk3399 boards can include the same on their board dtsi files.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-u-boot.dtsi | 12 ++++++++++++ 1 file changed, 12 insertions(+) create mode 100644 arch/arm/dts/rk3399-u-boot.dtsi
diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi new file mode 100644 index 0000000000..0786c1193a --- /dev/null +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +&sdmmc { + u-boot,dm-pre-reloc; +}; + +&spi1 { + u-boot,dm-pre-reloc; +};
Now we have - board specific -u-boot.dtsi files for board specific u-boot dts changes. - soc specific rk3399-u-boot.dtsi for soc specific u-boot dts changes.
So, include the rk3399-u-boot-dtsi on respective board -u-boot.dtsi and drop the properties which are globally available in rk3399-u-boot.dtsi
Right now rk3399-u-boot.dtsi has sdmmc, spi1 u-boot,dm-pre-reloc property and more properties and nodes can be move further based on the requirements.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-evb-u-boot.dtsi | 1 + arch/arm/dts/rk3399-evb.dts | 1 - arch/arm/dts/rk3399-firefly-u-boot.dtsi | 1 + arch/arm/dts/rk3399-firefly.dts | 1 - arch/arm/dts/rk3399-gru-bob-u-boot.dtsi | 1 + arch/arm/dts/rk3399-gru-u-boot.dtsi | 6 ++++++ arch/arm/dts/rk3399-gru.dtsi | 1 - arch/arm/dts/rk3399-puma-ddr1600.dts | 1 + arch/arm/dts/rk3399-puma.dtsi | 3 --- 9 files changed, 10 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/rk3399-gru-u-boot.dtsi
diff --git a/arch/arm/dts/rk3399-evb-u-boot.dtsi b/arch/arm/dts/rk3399-evb-u-boot.dtsi index 7e2c57af22..20910e744b 100644 --- a/arch/arm/dts/rk3399-evb-u-boot.dtsi +++ b/arch/arm/dts/rk3399-evb-u-boot.dtsi @@ -3,4 +3,5 @@ * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com */
+#include "rk3399-u-boot.dtsi" #include "rk3399-sdram-lpddr3-4GB-1600.dtsi" diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts index 2366e7ed3a..a506e8da37 100644 --- a/arch/arm/dts/rk3399-evb.dts +++ b/arch/arm/dts/rk3399-evb.dts @@ -154,7 +154,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; bus-width = <4>; status = "okay"; }; diff --git a/arch/arm/dts/rk3399-firefly-u-boot.dtsi b/arch/arm/dts/rk3399-firefly-u-boot.dtsi index eab86bdb30..67b63a8352 100644 --- a/arch/arm/dts/rk3399-firefly-u-boot.dtsi +++ b/arch/arm/dts/rk3399-firefly-u-boot.dtsi @@ -3,4 +3,5 @@ * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com */
+#include "rk3399-u-boot.dtsi" #include "rk3399-sdram-ddr3-1600.dtsi" diff --git a/arch/arm/dts/rk3399-firefly.dts b/arch/arm/dts/rk3399-firefly.dts index 5d52319393..a4cb64f8bd 100644 --- a/arch/arm/dts/rk3399-firefly.dts +++ b/arch/arm/dts/rk3399-firefly.dts @@ -591,7 +591,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; bus-width = <4>; status = "okay"; }; diff --git a/arch/arm/dts/rk3399-gru-bob-u-boot.dtsi b/arch/arm/dts/rk3399-gru-bob-u-boot.dtsi index 9edb8cf841..726f396f32 100644 --- a/arch/arm/dts/rk3399-gru-bob-u-boot.dtsi +++ b/arch/arm/dts/rk3399-gru-bob-u-boot.dtsi @@ -3,4 +3,5 @@ * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com */
+#include "rk3399-gru-u-boot.dtsi" #include "rk3399-sdram-lpddr3-samsung-4GB-1866.dtsi" diff --git a/arch/arm/dts/rk3399-gru-u-boot.dtsi b/arch/arm/dts/rk3399-gru-u-boot.dtsi new file mode 100644 index 0000000000..7bddc3acdb --- /dev/null +++ b/arch/arm/dts/rk3399-gru-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-u-boot.dtsi" diff --git a/arch/arm/dts/rk3399-gru.dtsi b/arch/arm/dts/rk3399-gru.dtsi index df19263acc..8b3d90fdc6 100644 --- a/arch/arm/dts/rk3399-gru.dtsi +++ b/arch/arm/dts/rk3399-gru.dtsi @@ -545,7 +545,6 @@ ap_i2c_audio: &i2c8 {
&spi1 { status = "okay"; - u-boot,dm-pre-reloc;
pinctrl-names = "default", "sleep"; pinctrl-1 = <&spi1_sleep>; diff --git a/arch/arm/dts/rk3399-puma-ddr1600.dts b/arch/arm/dts/rk3399-puma-ddr1600.dts index 337e0eabb4..42763f82d0 100644 --- a/arch/arm/dts/rk3399-puma-ddr1600.dts +++ b/arch/arm/dts/rk3399-puma-ddr1600.dts @@ -6,5 +6,6 @@ /dts-v1/;
#include "rk3399-puma.dtsi" +#include "rk3399-u-boot.dtsi" #include "rk3399-sdram-ddr3-1600.dtsi"
diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi index 8304f67192..2712ab6826 100644 --- a/arch/arm/dts/rk3399-puma.dtsi +++ b/arch/arm/dts/rk3399-puma.dtsi @@ -492,7 +492,6 @@ };
&sdmmc { - u-boot,dm-pre-reloc; clock-frequency = <150000000>; max-frequency = <40000000>; supports-sd; @@ -648,8 +647,6 @@
&spi1 { - u-boot,dm-pre-reloc; - status = "okay";
#address-cells = <1>;
- sdram dtsi
For the whole series: Reviewed-by: Paul Kocialkowski paul.kocialkowski@bootlin.com
Cheers,
Paul
Changes for v6:
Any inputs? Jagan.
Jagan Teki
Paul Kocialkowski
