[PATCH] arm: dts: k3-j721e: ddr: Update to 0.2 version of DDR config tool
Update the ddr settings to use the DDR reg config tool rev 0.2.0. This reduces the aging count(in DDRSS_CTL_274_DATA reg) to 15 in-order to avoid DSS underflow errors.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Kevin Scholz k-scholz@ti.com --- arch/arm/dts/k3-j721e-ddr-evm-lp4-3733.dtsi | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/k3-j721e-ddr-evm-lp4-3733.dtsi b/arch/arm/dts/k3-j721e-ddr-evm-lp4-3733.dtsi index 135b6193a9..5ac32a0ffa 100644 --- a/arch/arm/dts/k3-j721e-ddr-evm-lp4-3733.dtsi +++ b/arch/arm/dts/k3-j721e-ddr-evm-lp4-3733.dtsi @@ -1,8 +1,8 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ - * This file was generated by the AM752x_DRA82x_TDA4x_DDRSS_RegConfigTool, Revision: 0.1.0 - * This file was generated on 09/06/2019 + * This file was generated by the AM752x_DRA82x_TDA4x_DDRSS_RegConfigTool, Revision: 0.2.0 + * This file was generated on 10/09/2019 */
#define DDRSS_PLL_FHS_CNT 10 @@ -283,7 +283,7 @@ #define DDRSS_CTL_271_DATA 0x1FFF1000 #define DDRSS_CTL_272_DATA 0x01FF0000 #define DDRSS_CTL_273_DATA 0x000101FF -#define DDRSS_CTL_274_DATA 0xFFFF0B00 +#define DDRSS_CTL_274_DATA 0x0FFF0B00 #define DDRSS_CTL_275_DATA 0x01010001 #define DDRSS_CTL_276_DATA 0x01010101 #define DDRSS_CTL_277_DATA 0x01180101
Lokesh Vutla
