[U-Boot] [PATCH v2 00/16] efi: Enable basic sandbox support for EFI loader
A limitation of the EFI loader at present is that it does not build with sandbox. This makes it hard to write tests, since sandbox is used for most testing in U-Boot.
This series enables the EFI loader feature. It allows sandbox to build and run a trivial function which calls the EFI API to output a message.
Much work remains but this should serve as a basis for adding tests more easily for EFI loader.
This series sits on top of Heinrich's recent EFI test series. It is available at u-boot-dm/efi-working
Changes in v2: - Update return type of efi_smbios_register() to efi_status_t - Use return value of efi_install_configuration_table - Change return type of efi_init_obj_list() to efi_status_t - Update commit message to dropping libfdt_env.h - Update to use mapmem instead of a cast - Rebase to master
Simon Glass (16): efi: Update efi_smbios_register() to return error code efi: Move the init check inside efi_init_obj_list() efi: Add error checking for efi_init_obj_list() efi: Add a TODO to efi_init_obj_list() efi: Correct header order in efi_memory efi: sandbox: Adjust memory usage for sandbox sandbox: smbios: Update to support sandbox sandbox: Add a setjmp() implementation efi: sandbox: Add required linker sections efi: sandbox: Add distroboot support Define board_quiesce_devices() in a shared location Add a comment for board_quiesce_devices() efi: sandbox: Add relocation constants efi: Add a comment about duplicated ELF constants efi: sandbox: Enable EFI loader builder for sandbox efi: sandbox: Add a simple 'bootefi test' command
arch/arm/include/asm/u-boot-arm.h | 1 - arch/sandbox/cpu/cpu.c | 13 ++++++++ arch/sandbox/cpu/os.c | 17 +++++++++++ arch/sandbox/cpu/u-boot.lds | 29 ++++++++++++++++++ arch/sandbox/include/asm/setjmp.h | 21 +++++++++++++ arch/sandbox/lib/Makefile | 2 +- arch/sandbox/lib/sections.c | 12 ++++++++ arch/x86/include/asm/u-boot-x86.h | 1 - arch/x86/lib/bootm.c | 4 --- cmd/bootefi.c | 62 +++++++++++++++++++++++++++++++++++---- common/bootm.c | 4 +++ configs/sandbox_defconfig | 1 + include/bootm.h | 8 +++++ include/config_distro_bootcmd.h | 2 +- include/efi_loader.h | 12 +++++++- include/os.h | 21 +++++++++++++ lib/efi_loader/Kconfig | 12 +++++++- lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_memory.c | 36 +++++++++++++---------- lib/efi_loader/efi_runtime.c | 7 +++++ lib/efi_loader/efi_smbios.c | 7 +++-- lib/efi_loader/efi_test.c | 17 +++++++++++ lib/smbios.c | 38 ++++++++++++++++++------ 23 files changed, 284 insertions(+), 44 deletions(-) create mode 100644 arch/sandbox/include/asm/setjmp.h create mode 100644 arch/sandbox/lib/sections.c create mode 100644 lib/efi_loader/efi_test.c
This function can fail but gives no indication of failure. Update it to return an error when something goes wrong.
include/efi_loader.h | 9 ++++++++- lib/efi_loader/efi_smbios.c | 7 ++++--- 2 files changed, 12 insertions(+), 4 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index 1b92edbd77..35f8f84401 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -164,7 +164,14 @@ int efi_gop_register(void); /* Called by bootefi to make the network interface available */ int efi_net_register(void); /* Called by bootefi to make SMBIOS tables available */ -void efi_smbios_register(void); +/** + * efi_smbios_register() - write out SMBIOS tables + * + * Called by bootefi to make SMBIOS tables available + * + * @return 0 if OK, -ENOMEM if no memory is available for the tables + */ +efi_status_t efi_smbios_register(void);
struct efi_simple_file_system_protocol * efi_fs_from_path(struct efi_device_path *fp); diff --git a/lib/efi_loader/efi_smbios.c b/lib/efi_loader/efi_smbios.c index ac412e7362..67f71892ca 100644 --- a/lib/efi_loader/efi_smbios.c +++ b/lib/efi_loader/efi_smbios.c @@ -13,7 +13,7 @@
static const efi_guid_t smbios_guid = SMBIOS_TABLE_GUID;
-void efi_smbios_register(void) +efi_status_t efi_smbios_register(void) { /* Map within the low 32 bits, to allow for 32bit SMBIOS tables */ uint64_t dmi = 0xffffffff; @@ -22,11 +22,12 @@ void efi_smbios_register(void) int memtype = EFI_RUNTIME_SERVICES_DATA;
if (efi_allocate_pages(1, memtype, pages, &dmi) != EFI_SUCCESS) - return; + return EFI_OUT_OF_RESOURCES;
/* Generate SMBIOS tables */ write_smbios_table(dmi);
/* And expose them to our EFI payload */ - efi_install_configuration_table(&smbios_guid, (void*)(uintptr_t)dmi); + return efi_install_configuration_table(&smbios_guid, + (void *)(uintptr_t)dmi); }
Changes in v2:
- efi_smbios_register() - write out SMBIOS tables
- Called by bootefi to make SMBIOS tables available
- @return 0 if OK, -ENOMEM if no memory is available for the tables
Please, return the value returned from efi_allocate_pages(). The function has a lot of different failure modes.
return;
We should add a comment explaining why we do not use the return value of write_smbios_table(). My understanding is: write_smbios_table returns dmi rounded up to a multiple of 16. efi_allocate_pages returns a 4096 aligned address. So we do expect that the return value equals the parameter apssed to write_smbios_table().
Best regards
Heinrich
- return efi_install_configuration_table(&smbios_guid,
}(void *)(uintptr_t)dmi);
Hi Heinrich,
Changes in v2:
+efi_status_t efi_smbios_register(void); struct efi_simple_file_system_protocol * efi_fs_from_path(struct efi_device_path *fp); diff --git a/lib/efi_loader/efi_smbios.c b/lib/efi_loader/efi_smbios.c index ac412e7362..67f71892ca 100644 --- a/lib/efi_loader/efi_smbios.c +++ b/lib/efi_loader/efi_smbios.c @@ -13,7 +13,7 @@ static const efi_guid_t smbios_guid = SMBIOS_TABLE_GUID; -void efi_smbios_register(void) +efi_status_t efi_smbios_register(void) { /* Map within the low 32 bits, to allow for 32bit SMBIOS tables */ uint64_t dmi = 0xffffffff; @@ -22,11 +22,12 @@ void efi_smbios_register(void) int memtype = EFI_RUNTIME_SERVICES_DATA; if (efi_allocate_pages(1, memtype, pages, &dmi) != EFI_SUCCESS)
OK, will do. But looking at efi_allocate_pages() there is no documentation as to the return value.
return;
return EFI_OUT_OF_RESOURCES; /* Generate SMBIOS tables */ write_smbios_table(dmi);
OK will do.
Rather than having the caller check this variable and the callee set it, move all access to the variable inside the function. This reduces the logic needed to call efi_init_obj_list().
Signed-off-by: Simon Glass sjg@chromium.org Reviewed: Heinrich Schuchardt xypron.glpk@gmx.de ---
Changes in v2: None
cmd/bootefi.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 478bc116e2..17b26e6f4e 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -28,6 +28,8 @@ static struct efi_device_path *bootefi_device_path; /* Initialize and populate EFI object list */ static void efi_init_obj_list(void) { + if (efi_obj_list_initalized) + return; efi_obj_list_initalized = 1;
efi_console_register(); @@ -208,6 +210,9 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt, env_set("efi_8be4df61-93ca-11d2-aa0d-00e098032b8c_OsIndicationsSupported", "{ro,boot}(blob)0000000000000000");
+ /* Initialize and populate EFI object list */ + efi_init_obj_list(); + /* Call our payload! */ debug("%s:%d Jumping to 0x%lx\n", __func__, __LINE__, (long)entry);
@@ -310,6 +315,8 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* Initialize and populate EFI object list */ if (!efi_obj_list_initalized) efi_init_obj_list(); + loaded_image_info.device_handle = bootefi_device_path; + loaded_image_info.file_path = bootefi_image_path; return efi_selftest(&loaded_image_info, &systab); } else #endif
Changes in v2: None
return;
- /* Initialize and populate EFI object list */
- efi_init_obj_list();
If you add it here where do you remove the old call? We do not want to do the assignments twice.
- /* Call our payload! */ debug("%s:%d Jumping to 0x%lx\n", __func__, __LINE__, (long)entry);
Same.
Best regards
Heinrich
} else #endif
This function calls a function which can fail. Print a message in this case and abort the boot, rather than silently continuing to boot, which will certainly fail.
Changes in v2: - Change return type of efi_init_obj_list() to efi_status_t
cmd/bootefi.c | 32 +++++++++++++++++++++++++------- 1 file changed, 25 insertions(+), 7 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 17b26e6f4e..a2138f6075 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -25,11 +25,17 @@ static uint8_t efi_obj_list_initalized; static struct efi_device_path *bootefi_image_path; static struct efi_device_path *bootefi_device_path;
-/* Initialize and populate EFI object list */ -static void efi_init_obj_list(void) +/** + * efi_init_obj_list() - Initialize and populate EFI object list + * + * @return 0 if OK, -ve on error (in which case it prints a message) + */ +static efi_status_t efi_init_obj_list(void) { + efi_status_t ret; + if (efi_obj_list_initalized) - return; + return 0; efi_obj_list_initalized = 1;
efi_console_register(); @@ -43,12 +49,19 @@ static void efi_init_obj_list(void) efi_net_register(); #endif #ifdef CONFIG_GENERATE_SMBIOS_TABLE - efi_smbios_register(); + ret = efi_smbios_register(); + if (ret) + goto error; #endif
/* Initialize EFI runtime services */ efi_reset_system_init(); efi_get_time_init(); + + return EFI_SUCCESS; +error: + printf("Error: Cannot set up EFI object list (err=%d)\n", ret); + return ret; }
static void *copy_fdt(void *fdt) @@ -137,6 +150,7 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt, ulong fdt_pages, fdt_size, fdt_start, fdt_end; const efi_guid_t fdt_guid = EFI_FDT_GUID; bootm_headers_t img = { 0 }; + int ret;
/* * Special case for efi payload not loaded from disk, such as @@ -211,7 +225,9 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt, "{ro,boot}(blob)0000000000000000");
/* Initialize and populate EFI object list */ - efi_init_obj_list(); + ret = efi_init_obj_list(); + if (ret) + return ret;
/* Call our payload! */ debug("%s:%d Jumping to 0x%lx\n", __func__, __LINE__, (long)entry); @@ -313,10 +329,12 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) */ efi_save_gd(); /* Initialize and populate EFI object list */ - if (!efi_obj_list_initalized) - efi_init_obj_list(); + if (!efi_obj_list_initalized && efi_init_obj_list()) + return CMD_RET_FAILURE; + loaded_image_info.device_handle = bootefi_device_path; loaded_image_info.file_path = bootefi_image_path; + return efi_selftest(&loaded_image_info, &systab); } else #endif
Changes in v2:
- efi_init_obj_list() - Initialize and populate EFI object list
- @return 0 if OK, -ve on error (in which case it prints a message)
- efi_status_t ret;
- if (efi_obj_list_initalized)
return;
This function can also fail. Same is true for efi_gop_register.
- ret = efi_smbios_register();
- if (ret)
if (ret != EFI_SUCCESS)
goto error;
#endif
return EFI_SUCCESS;
+error:
- printf("Error: Cannot set up EFI object list (err=%d)\n", ret);
Now we have some objects initialized and others not. Before returning we should clean up. We should free all allocated objects.
Best regards
Heinrich
return ret; }
int ret;
- Special case for efi payload not loaded from disk, such as
if (ret)
return ret;
- loaded_image_info.device_handle = bootefi_device_path; loaded_image_info.file_path = bootefi_image_path;
- return efi_selftest(&loaded_image_info, &systab); } else #endif
Hi Heinrich,
Changes in v2:
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 17b26e6f4e..a2138f6075 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -25,11 +25,17 @@ static uint8_t efi_obj_list_initalized; static struct efi_device_path *bootefi_image_path; static struct efi_device_path *bootefi_device_path; -/* Initialize and populate EFI object list */ -static void efi_init_obj_list(void) +/**
efi_status_t ret;
return;
return 0; efi_obj_list_initalized = 1; efi_console_register();
if (ret)
Please can we avoid this obfuscation? It really pains me to see what I consider to be stupidity in the code. Can we just agree that success is 0 in U-Boot/?
#endif /* Initialize EFI runtime services */ efi_reset_system_init(); efi_get_time_init();goto error;
return EFI_SUCCESS;
+error:
OK let me take another look at this.
Best regards
Heinrich
} static void *copy_fdt(void *fdt)return ret;
int ret; /* * Special case for efi payload not loaded from disk, such as
@@ -211,7 +225,9 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt, "{ro,boot}(blob)0000000000000000"); /* Initialize and populate EFI object list */
if (ret)
return ret; /* Call our payload! */ debug("%s:%d Jumping to 0x%lx\n", __func__, __LINE__,
#endifreturn efi_selftest(&loaded_image_info, &systab); } else
Changes in v2:
- efi_status_t ret;
return;
- if (ret)
goto error;
#endif
- return EFI_SUCCESS;
+error:
warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘efi_status_t {aka long unsigned int}’ [-Wformat=]
Please, use %lu.
Regards
Heinrich
- return ret;
int ret;
if (ret)
return ret;
#endif
This function repeats data structures provided by driver model. They are only created once so can be stale if the EFI loader is called twice (e.g. for testing or on boot failure).
Add a TODO to address this. It should be possible to attach EFI devices and data structures to driver-model devices and avoid having a parallel set of data structures.
Changes in v2: None
cmd/bootefi.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index a2138f6075..a4686f17f0 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -28,6 +28,10 @@ static struct efi_device_path *bootefi_device_path; /** * efi_init_obj_list() - Initialize and populate EFI object list * + * TODO(sjg@chromium.org): Move this to a dynamic list based on driver model, + * so that it does not need to be created before running EFI applications + * and updates when devices change. + * * @return 0 if OK, -ve on error (in which case it prints a message) */ static efi_status_t efi_init_obj_list(void)
The headers are not in the correct order. Fix this. Also drop libfdt_env.h since it is not needed.
Changes in v2: - Update commit message to dropping libfdt_env.h
lib/efi_loader/efi_memory.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index d47759e08e..e95896ca0a 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -8,12 +8,11 @@
#include <common.h> #include <efi_loader.h> +#include <inttypes.h> #include <malloc.h> +#include <watchdog.h> #include <asm/global_data.h> -#include <libfdt_env.h> #include <linux/list_sort.h> -#include <inttypes.h> -#include <watchdog.h>
DECLARE_GLOBAL_DATA_PTR;
What do you consider as correct order? Do you mean sorted alphabetically? Includes should be self sufficient and the correct execution be independent of the sequence.
Best regards
Heinrich
Changes in v2:
Hi Heinrich,
https://www.denx.de/wiki/U-Boot/CodingStyle
If we need libfdt we should include libfdt.h I think.
With sandbox the U-Boot code is not mapped into the sandbox memory range so does not need to be excluded when allocating EFI memory. Update the EFI memory init code to take account of that.
Also use mapmem instead of a cast to convert a memory address to a pointer.
Changes in v2: - Update to use mapmem instead of a cast
lib/efi_loader/efi_memory.c | 31 ++++++++++++++++++------------- 1 file changed, 18 insertions(+), 13 deletions(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index e95896ca0a..3ad58d8930 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -10,6 +10,7 @@ #include <efi_loader.h> #include <inttypes.h> #include <malloc.h> +#include <mapmem.h> #include <watchdog.h> #include <asm/global_data.h> #include <linux/list_sort.h> @@ -366,7 +367,7 @@ efi_status_t efi_allocate_pool(int pool_type, unsigned long size, r = efi_allocate_pages(0, pool_type, num_pages, &t);
if (r == EFI_SUCCESS) { - struct efi_pool_allocation *alloc = (void *)(uintptr_t)t; + struct efi_pool_allocation *alloc = map_sysmem(t, size); alloc->num_pages = num_pages; *buffer = alloc->data; } @@ -460,18 +461,22 @@ int efi_memory_init(void)
efi_add_known_memory();
- /* Add U-Boot */ - uboot_start = (gd->start_addr_sp - uboot_stack_size) & ~EFI_PAGE_MASK; - uboot_pages = (gd->ram_top - uboot_start) >> EFI_PAGE_SHIFT; - efi_add_memory_map(uboot_start, uboot_pages, EFI_LOADER_DATA, false); - - /* Add Runtime Services */ - runtime_start = (ulong)&__efi_runtime_start & ~EFI_PAGE_MASK; - runtime_end = (ulong)&__efi_runtime_stop; - runtime_end = (runtime_end + EFI_PAGE_MASK) & ~EFI_PAGE_MASK; - runtime_pages = (runtime_end - runtime_start) >> EFI_PAGE_SHIFT; - efi_add_memory_map(runtime_start, runtime_pages, - EFI_RUNTIME_SERVICES_CODE, false); + if (!IS_ENABLED(CONFIG_SANDBOX)) { + /* Add U-Boot */ + uboot_start = (gd->start_addr_sp - uboot_stack_size) & + ~EFI_PAGE_MASK; + uboot_pages = (gd->ram_top - uboot_start) >> EFI_PAGE_SHIFT; + efi_add_memory_map(uboot_start, uboot_pages, EFI_LOADER_DATA, + false); + + /* Add Runtime Services */ + runtime_start = (ulong)&__efi_runtime_start & ~EFI_PAGE_MASK; + runtime_end = (ulong)&__efi_runtime_stop; + runtime_end = (runtime_end + EFI_PAGE_MASK) & ~EFI_PAGE_MASK; + runtime_pages = (runtime_end - runtime_start) >> EFI_PAGE_SHIFT; + efi_add_memory_map(runtime_start, runtime_pages, + EFI_RUNTIME_SERVICES_CODE, false); + }
#ifdef CONFIG_EFI_LOADER_BOUNCE_BUFFER /* Request a 32bit 64MB bounce buffer region */
Changes in v2:
alloc->num_pages = num_pages; *buffer = alloc->data; }struct efi_pool_allocation *alloc = map_sysmem(t, size);
- /* Add U-Boot */
- if (!IS_ENABLED(CONFIG_SANDBOX)) {
/* Add U-Boot */
~EFI_PAGE_MASK;
false);
bootefi selftest shows an error. You should setup the EFI memory for CONFIG_SANDBOX=y too.
Setting up 'ExitBootServices' Setting up 'ExitBootServices' succeeded lib/efi_selftest/efi_selftest.c(53): ERROR: GetMemoryMap did not return EFI_SUCCESS
Best regards
Heinrich
At present this code casts addresses to pointers so cannot be used with sandbox. Update it to use mapmem instead.
Changes in v2: None
lib/smbios.c | 38 +++++++++++++++++++++++++++++--------- 1 file changed, 29 insertions(+), 9 deletions(-)
diff --git a/lib/smbios.c b/lib/smbios.c index 8f19ad89c1..56481d448d 100644 --- a/lib/smbios.c +++ b/lib/smbios.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <mapmem.h> #include <smbios.h> #include <tables_csum.h> #include <version.h> @@ -75,9 +76,10 @@ static int smbios_string_table_len(char *start)
static int smbios_write_type0(ulong *current, int handle) { - struct smbios_type0 *t = (struct smbios_type0 *)*current; + struct smbios_type0 *t; int len = sizeof(struct smbios_type0);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type0)); fill_smbios_header(t, SMBIOS_BIOS_INFORMATION, len, handle); t->vendor = smbios_add_string(t->eos, "U-Boot"); @@ -104,16 +106,18 @@ static int smbios_write_type0(ulong *current, int handle)
len = t->length + smbios_string_table_len(t->eos); *current += len; + unmap_sysmem(t);
return len; }
static int smbios_write_type1(ulong *current, int handle) { - struct smbios_type1 *t = (struct smbios_type1 *)*current; + struct smbios_type1 *t; int len = sizeof(struct smbios_type1); char *serial_str = env_get("serial#");
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type1)); fill_smbios_header(t, SMBIOS_SYSTEM_INFORMATION, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -125,15 +129,17 @@ static int smbios_write_type1(ulong *current, int handle)
return len; }
static int smbios_write_type2(ulong *current, int handle) { - struct smbios_type2 *t = (struct smbios_type2 *)*current; + struct smbios_type2 *t; int len = sizeof(struct smbios_type2);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type2)); fill_smbios_header(t, SMBIOS_BOARD_INFORMATION, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -143,15 +149,17 @@ static int smbios_write_type2(ulong *current, int handle)
return len; }
static int smbios_write_type3(ulong *current, int handle) { - struct smbios_type3 *t = (struct smbios_type3 *)*current; + struct smbios_type3 *t; int len = sizeof(struct smbios_type3);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type3)); fill_smbios_header(t, SMBIOS_SYSTEM_ENCLOSURE, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -163,6 +171,7 @@ static int smbios_write_type3(ulong *current, int handle)
return len; } @@ -201,9 +210,10 @@ static void smbios_write_type4_dm(struct smbios_type4 *t)
static int smbios_write_type4(ulong *current, int handle) { - struct smbios_type4 *t = (struct smbios_type4 *)*current; + struct smbios_type4 *t; int len = sizeof(struct smbios_type4);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type4)); fill_smbios_header(t, SMBIOS_PROCESSOR_INFORMATION, len, handle); t->processor_type = SMBIOS_PROCESSOR_TYPE_CENTRAL; @@ -217,32 +227,37 @@ static int smbios_write_type4(ulong *current, int handle)
return len; }
static int smbios_write_type32(ulong *current, int handle) { - struct smbios_type32 *t = (struct smbios_type32 *)*current; + struct smbios_type32 *t; int len = sizeof(struct smbios_type32);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type32)); fill_smbios_header(t, SMBIOS_SYSTEM_BOOT_INFORMATION, len, handle);
return len; }
static int smbios_write_type127(ulong *current, int handle) { - struct smbios_type127 *t = (struct smbios_type127 *)*current; + struct smbios_type127 *t; int len = sizeof(struct smbios_type127);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type127)); fill_smbios_header(t, SMBIOS_END_OF_TABLE, len, handle);
return len; } @@ -271,7 +286,7 @@ ulong write_smbios_table(ulong addr) /* 16 byte align the table address */ addr = ALIGN(addr, 16);
- se = (struct smbios_entry *)(uintptr_t)addr; + se = map_sysmem(addr, sizeof(struct smbios_entry)); memset(se, 0, sizeof(struct smbios_entry));
addr += sizeof(struct smbios_entry); @@ -280,9 +295,13 @@ ulong write_smbios_table(ulong addr)
/* populate minimum required tables */ for (i = 0; i < ARRAY_SIZE(smbios_write_funcs); i++) { - int tmp = smbios_write_funcs[i]((ulong *)&addr, handle++); + ulong *ptr = map_sysmem(addr, 0); + int tmp; + + tmp = smbios_write_funcs[i](ptr, handle++); max_struct_size = max(max_struct_size, tmp); len += tmp; + unmap_sysmem(ptr); }
memcpy(se->anchor, "_SM_", 4); @@ -300,6 +319,7 @@ ulong write_smbios_table(ulong addr) isize = sizeof(struct smbios_entry) - SMBIOS_INTERMEDIATE_OFFSET; se->intermediate_checksum = table_compute_checksum(istart, isize); se->checksum = table_compute_checksum(se, sizeof(struct smbios_entry)); + unmap_sysmem(se);
return addr; }
Changes in v2: None
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
*current += len;
unmap_sysmem(t);
return len;
*current += len;
unmap_sysmem(t);
return len;
This replaces &addr by addr and breaks booting on ARM64.
Did you mean: ulong *ptr = map_sysmem((phys_addr_t)&addr, 0);
The coding would get much easier to maintain if the map_sysmem() function would be eliminated from U-Boot.
Why don't you simply use the address range that mmap() has provided? This would avoid double book keeping.
Regards
Heinrich
int tmp;
unmap_sysmem(ptr);
unmap_sysmem(se);
return addr;
Hi Heinrich,
Changes in v2: None
unmap_sysmem(t); return len;
t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type32)); fill_smbios_header(t, SMBIOS_SYSTEM_BOOT_INFORMATION, len, handle); *current += len;
t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type127)); fill_smbios_header(t, SMBIOS_END_OF_TABLE, len, handle); *current += len;
se = map_sysmem(addr, sizeof(struct smbios_entry)); memset(se, 0, sizeof(struct smbios_entry)); addr += sizeof(struct smbios_entry);
No, actually I don't think this is really needed at all since the version is done by the functions it calls.
It is on my mind. But the address is used in U-Boot (e.g. in scripts). Every other board has a defined and known SDRAM start address, and I think it is best that sandbox has this too. It is also a good marker of the conversion between an address and a pointer. IMO using a cast is a bit ad-hoc.
Add an implementation of setjmp() and longjmp() which rely on the underlying host C library. Since we cannot know how large the jump buffer needs to be, pick something that should be suitable and check it at runtime. At present we need access to the underlying struct as well.
Changes in v2: None
arch/sandbox/cpu/cpu.c | 13 +++++++++++++ arch/sandbox/cpu/os.c | 17 +++++++++++++++++ arch/sandbox/include/asm/setjmp.h | 21 +++++++++++++++++++++ include/os.h | 21 +++++++++++++++++++++ 4 files changed, 72 insertions(+) create mode 100644 arch/sandbox/include/asm/setjmp.h
diff --git a/arch/sandbox/cpu/cpu.c b/arch/sandbox/cpu/cpu.c index 66c3a6a88a..8b397c7168 100644 --- a/arch/sandbox/cpu/cpu.c +++ b/arch/sandbox/cpu/cpu.c @@ -9,6 +9,7 @@ #include <libfdt.h> #include <os.h> #include <asm/io.h> +#include <asm/setjmp.h> #include <asm/state.h> #include <dm/root.h>
@@ -164,3 +165,15 @@ ulong timer_get_boot_us(void)
return (count - base_count) / 1000; } + +int setjmp(jmp_buf jmp) +{ + return os_setjmp((ulong *)jmp, sizeof(jmp)); +} + +void longjmp(jmp_buf jmp, int ret) +{ + os_longjmp((ulong *)jmp, ret); + while (1) + ; +} diff --git a/arch/sandbox/cpu/os.c b/arch/sandbox/cpu/os.c index c524957b6c..e9200192c6 100644 --- a/arch/sandbox/cpu/os.c +++ b/arch/sandbox/cpu/os.c @@ -7,6 +7,7 @@ #include <errno.h> #include <fcntl.h> #include <getopt.h> +#include <setjmp.h> #include <stdio.h> #include <stdint.h> #include <stdlib.h> @@ -617,3 +618,19 @@ void os_localtime(struct rtc_time *rt) rt->tm_yday = tm->tm_yday; rt->tm_isdst = tm->tm_isdst; } + +int os_setjmp(ulong *jmp, int size) +{ + if (size < sizeof(jmp_buf)) { + printf("setjmp: jmpbuf is too small (%d bytes, need %d)\n", + size, sizeof(jmp_buf)); + return -ENOSPC; + } + + return setjmp((struct __jmp_buf_tag *)jmp); +} + +void os_longjmp(ulong *jmp, int ret) +{ + longjmp((struct __jmp_buf_tag *)jmp, ret); +} diff --git a/arch/sandbox/include/asm/setjmp.h b/arch/sandbox/include/asm/setjmp.h new file mode 100644 index 0000000000..e25f50107c --- /dev/null +++ b/arch/sandbox/include/asm/setjmp.h @@ -0,0 +1,21 @@ +/* + * (C) Copyright 2016 + * Alexander Graf agraf@suse.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _SETJMP_H_ +#define _SETJMP_H_ 1 + +struct jmp_buf_data { + /* We're not sure how long this should be */ + ulong data[32]; +}; + +typedef struct jmp_buf_data jmp_buf[1]; + +int setjmp(jmp_buf jmp); +__noreturn void longjmp(jmp_buf jmp, int ret); + +#endif /* _SETJMP_H_ */ diff --git a/include/os.h b/include/os.h index 2bf4bdb1b8..ad1836ac9f 100644 --- a/include/os.h +++ b/include/os.h @@ -310,4 +310,25 @@ int os_spl_to_uboot(const char *fname); */ void os_localtime(struct rtc_time *rt);
+/** + * os_setjmp() - Call setjmp() + * + * Call the host system's setjmp() function. + * + * @jmp: Buffer to store current execution state + * @size: Size of buffer + * @return normal setjmp() value if OK, -ENOSPC if @size is too small + */ +int os_setjmp(ulong *jmp, int size); + +/** + * os_longjmp() - Call longjmp() + * + * Call the host system's longjmp() function. + * + * @jmp: Buffer where previous execution state was stored + * @ret: Value to pass to longjmp() + */ +void os_longjmp(ulong *jmp, int ret); + #endif
Changes in v2: None
- return os_setjmp((ulong *)jmp, sizeof(jmp));
This produces a warning: ‘sizeof’ on array function parameter ‘jmp’ will return size of ‘struct jmp_buf_data *’ [-Wsizeof-array-argument]
Did you mean sizeof(struct jmp_buf_data)?
- os_longjmp((ulong *)jmp, ret);
- while (1)
- if (size < sizeof(jmp_buf)) {
size, sizeof(struct jmp_buf_data));
Shouldn't this be sizeof(*jmp_buf)?
return -ENOSPC;
- return setjmp((struct __jmp_buf_tag *)jmp);
- longjmp((struct __jmp_buf_tag *)jmp, ret);
- (C) Copyright 2016
- Alexander Graf agraf@suse.de
- /* We're not sure how long this should be */
- ulong data[32];
Isn't this buffer is too short?
sizeof(jmp_buf) =============== amd64: 200 bytes arm64: 392 bytes armhf: 392 bytes
Please, check the alignment. On Windows amd64 a jump buffer must be 16 byte aligned.
Best regards
Heinrich
- os_setjmp() - Call setjmp()
- Call the host system's setjmp() function.
- @jmp: Buffer to store current execution state
- @size: Size of buffer
- @return normal setjmp() value if OK, -ENOSPC if @size is too small
- os_longjmp() - Call longjmp()
- Call the host system's longjmp() function.
- @jmp: Buffer where previous execution state was stored
- @ret: Value to pass to longjmp()
#endif
The EFI loader code requires certain linker sections to exist. Add these for sandbox so that the EFI loader code will link.
Changes in v2: None
arch/sandbox/cpu/u-boot.lds | 29 +++++++++++++++++++++++++++++ arch/sandbox/lib/Makefile | 2 +- arch/sandbox/lib/sections.c | 12 ++++++++++++ 3 files changed, 42 insertions(+), 1 deletion(-) create mode 100644 arch/sandbox/lib/sections.c
diff --git a/arch/sandbox/cpu/u-boot.lds b/arch/sandbox/cpu/u-boot.lds index 7e92b4ac66..38a74bcaf4 100644 --- a/arch/sandbox/cpu/u-boot.lds +++ b/arch/sandbox/cpu/u-boot.lds @@ -19,6 +19,35 @@ SECTIONS __u_boot_sandbox_option_end = .;
__bss_start = .; + + .__efi_runtime_start : { + *(.__efi_runtime_start) + } + + .efi_runtime : { + *(efi_runtime_text) + *(efi_runtime_data) + } + + .__efi_runtime_stop : { + *(.__efi_runtime_stop) + } + + .efi_runtime_rel_start : + { + *(.__efi_runtime_rel_start) + } + + .efi_runtime_rel : { + *(.relefi_runtime_text) + *(.relefi_runtime_data) + } + + .efi_runtime_rel_stop : + { + *(.__efi_runtime_rel_stop) + } + }
INSERT BEFORE .data; diff --git a/arch/sandbox/lib/Makefile b/arch/sandbox/lib/Makefile index 2e7802feac..d2171579b7 100644 --- a/arch/sandbox/lib/Makefile +++ b/arch/sandbox/lib/Makefile @@ -7,7 +7,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += interrupts.o +obj-y += interrupts.o sections.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_PCI) += pci_io.o endif diff --git a/arch/sandbox/lib/sections.c b/arch/sandbox/lib/sections.c new file mode 100644 index 0000000000..6455e0f088 --- /dev/null +++ b/arch/sandbox/lib/sections.c @@ -0,0 +1,12 @@ +/* + * Copyright 2013 Albert ARIBAUD albert.u.boot@aribaud.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +char __efi_runtime_start[0] __attribute__((section(".__efi_runtime_start"))); +char __efi_runtime_stop[0] __attribute__((section(".__efi_runtime_stop"))); +char __efi_runtime_rel_start[0] + __attribute__((section(".__efi_runtime_rel_start"))); +char __efi_runtime_rel_stop[0] + __attribute__((section(".__efi_runtime_rel_stop")));
With sandbox these values depend on the host system. Let's assume that it is x86_64 for now.
Changes in v2: None
include/config_distro_bootcmd.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 5c469a23fa..6772d2d404 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -242,7 +242,7 @@ #elif defined(CONFIG_ARM) #define BOOTENV_EFI_PXE_ARCH "0xa" #define BOOTENV_EFI_PXE_VCI "PXEClient:Arch:00010:UNDI:003000" -#elif defined(CONFIG_X86) +#elif defined(CONFIG_X86) || defined(CONFIG_SANDBOX) /* Always assume we're running 64bit */ #define BOOTENV_EFI_PXE_ARCH "0x7" #define BOOTENV_EFI_PXE_VCI "PXEClient:Arch:00007:UNDI:003000"
How would you run this on a Pinebook (arm64)?
Shouldn't we strive to make sandbox work on any architecture?
Best regards
Heinrich
Changes in v2: None
Hi Heinrich,
Yes that would be good.
But I think getting it going on x86 is a good first step and will cover the vast majority of use cases (e.g. for travis-ci testing).
This undocumented function relies on arch-specific code to declare a nop weak version. Add the weak function in common code instead to avoid having to duplicate the same function in each arch.
Changes in v2: None
arch/arm/include/asm/u-boot-arm.h | 1 - arch/x86/include/asm/u-boot-x86.h | 1 - arch/x86/lib/bootm.c | 4 ---- common/bootm.c | 4 ++++ include/bootm.h | 2 ++ 5 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/u-boot-arm.h b/arch/arm/include/asm/u-boot-arm.h index ef4fca68ee..73ccf41f8c 100644 --- a/arch/arm/include/asm/u-boot-arm.h +++ b/arch/arm/include/asm/u-boot-arm.h @@ -38,7 +38,6 @@ int arch_early_init_r(void);
/* board/.../... */ int board_init(void); -void board_quiesce_devices(void);
/* cpu/.../interrupt.c */ int arch_interrupt_init (void); diff --git a/arch/x86/include/asm/u-boot-x86.h b/arch/x86/include/asm/u-boot-x86.h index 187fe5fd8c..d2e1426042 100644 --- a/arch/x86/include/asm/u-boot-x86.h +++ b/arch/x86/include/asm/u-boot-x86.h @@ -85,7 +85,6 @@ static inline __attribute__((no_instrument_function)) uint64_t rdtsc(void) /* board/... */ void timer_set_tsc_base(uint64_t new_base); uint64_t timer_get_tsc(void); -void board_quiesce_devices(void);
void quick_ram_check(void);
diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index e548cdbed5..60ae043f24 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -33,10 +33,6 @@ int arch_fixup_fdt(void *blob) return 0; }
-__weak void board_quiesce_devices(void) -{ -} - void bootm_announce_and_cleanup(void) { printf("\nStarting kernel ...\n\n"); diff --git a/common/bootm.c b/common/bootm.c index 9493a306cd..9fba0472ac 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -47,6 +47,10 @@ static const void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], bootm_headers_t *images, ulong *os_data, ulong *os_len);
+__weak void board_quiesce_devices(void) +{ +} + #ifdef CONFIG_LMB static void boot_start_lmb(bootm_headers_t *images) { diff --git a/include/bootm.h b/include/bootm.h index 49813772ce..76b6ab42e6 100644 --- a/include/bootm.h +++ b/include/bootm.h @@ -73,4 +73,6 @@ int bootm_decomp_image(int comp, ulong load, ulong image_start, int type, void *load_buf, void *image_buf, ulong image_len, uint unc_len, ulong *load_end);
+void board_quiesce_devices(void); + #endif
Undocumented code is unsatisfactory. Please, add a comment to the function.
Best regards
Heinrich
Changes in v2: None
- #ifdef CONFIG_LMB static void boot_start_lmb(bootm_headers_t *images) {
- #endif
Sorry I missed you put that in a separate patch (12/16).
BR
Best regards
Heinrich
Changes in v2: None
diff --git a/arch/arm/include/asm/u-boot-arm.h b/arch/arm/include/asm/u-boot-arm.h index ef4fca68ee..73ccf41f8c 100644 --- a/arch/arm/include/asm/u-boot-arm.h +++ b/arch/arm/include/asm/u-boot-arm.h @@ -38,7 +38,6 @@ int arch_early_init_r(void); /* board/.../... */ int board_init(void); -void board_quiesce_devices(void); /* cpu/.../interrupt.c */ int arch_interrupt_init (void); diff --git a/arch/x86/include/asm/u-boot-x86.h b/arch/x86/include/asm/u-boot-x86.h index 187fe5fd8c..d2e1426042 100644 --- a/arch/x86/include/asm/u-boot-x86.h +++ b/arch/x86/include/asm/u-boot-x86.h @@ -85,7 +85,6 @@ static inline __attribute__((no_instrument_function)) uint64_t rdtsc(void) /* board/... */ void timer_set_tsc_base(uint64_t new_base); uint64_t timer_get_tsc(void); -void board_quiesce_devices(void); void quick_ram_check(void); diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index e548cdbed5..60ae043f24 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -33,10 +33,6 @@ int arch_fixup_fdt(void *blob) return 0; } -__weak void board_quiesce_devices(void) -{ -}
void bootm_announce_and_cleanup(void) { printf("\nStarting kernel ...\n\n"); diff --git a/common/bootm.c b/common/bootm.c index 9493a306cd..9fba0472ac 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -47,6 +47,10 @@ static const void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], bootm_headers_t *images, ulong *os_data, ulong *os_len); +__weak void board_quiesce_devices(void) +{ +}
#ifdef CONFIG_LMB static void boot_start_lmb(bootm_headers_t *images) { diff --git a/include/bootm.h b/include/bootm.h index 49813772ce..76b6ab42e6 100644 --- a/include/bootm.h +++ b/include/bootm.h @@ -73,4 +73,6 @@ int bootm_decomp_image(int comp, ulong load, ulong image_start, int type, void *load_buf, void *image_buf, ulong image_len, uint unc_len, ulong *load_end); +void board_quiesce_devices(void);
#endif
This exported function should have a comment describing what it does. Also it should really be removed in favour of device_remove(), which handles this sort of thing now. Add a comment with a TODO.
Changes in v2: None
include/bootm.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/bootm.h b/include/bootm.h index 76b6ab42e6..caf331f54b 100644 --- a/include/bootm.h +++ b/include/bootm.h @@ -73,6 +73,12 @@ int bootm_decomp_image(int comp, ulong load, ulong image_start, int type, void *load_buf, void *image_buf, ulong image_len, uint unc_len, ulong *load_end);
+/* + * boards should define this to disable devices when EFI exits from boot + * services. + * + * TODO(sjg@chromium.org>): Update this to use driver model's device_remove(). + */ void board_quiesce_devices(void);
#endif
Add these so that we can build the EFI loader for sandbox. The values are for x86_64 so potentially bogus. But we don't support relocation within sandbox anyway.
Changes in v2: None
lib/efi_loader/efi_runtime.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index 8104e08c46..468dc12565 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -48,6 +48,9 @@ static efi_status_t __efi_runtime EFIAPI efi_invalid_parameter(void); #include <asm/elf.h> #define R_RELATIVE R_386_RELATIVE #define R_MASK 0xffULL +#elif defined(CONFIG_SANDBOX) +#define R_RELATIVE 8 +#define R_MASK 0xffffffffULL #else #error Need to add relocation awareness #endif
These constants are defined in arch-specific code but redefined here. Add a TODO to clean this up.
Changes in v2: None
lib/efi_loader/efi_runtime.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index 468dc12565..8313e9c4e0 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -37,6 +37,10 @@ static efi_status_t __efi_runtime EFIAPI efi_invalid_parameter(void); #define EFI_CACHELINE_SIZE 128 #endif
+/* + * TODO(sjg@chromium.org): These defines and structs should come from the elf. + * header for each arch (or a generic header) rather than being repeated here. + */ #if defined(CONFIG_ARM64) #define R_RELATIVE 1027 #define R_MASK 0xffffffffULL
This allows this feature to build within sandbox. This is for testing purposes only since it is not possible for sandbox to load native code.
Changes in v2: None
lib/efi_loader/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index d2b6327119..dee0a96a98 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -1,6 +1,6 @@ config EFI_LOADER bool "Support running EFI Applications in U-Boot" - depends on (ARM || X86) && OF_LIBFDT + depends on (ARM || X86 || SANDBOX) && OF_LIBFDT default y help Select this option if you want to run EFI applications (like grub2)
This jumps to test code which can call directly into the EFI support. It does not need a separate image so it is easy to write tests with it.
For now the test just outputs a message. To try it:
./sandbox/u-boot -c "bootefi test" U-Boot 2017.09-00204-g696c9855fe (Sep 17 2017 - 16:43:53 -0600)
DRAM: 128 MiB MMC: Using default environment
In: serial Out: serial Err: serial SCSI: Net: No ethernet found. IDE: Bus 0: not available Found 0 disks Hello, world! Test passed
Changes in v2: - Rebase to master
cmd/bootefi.c | 25 +++++++++++++++++++++++-- configs/sandbox_defconfig | 1 + include/efi_loader.h | 3 +++ lib/efi_loader/Kconfig | 10 ++++++++++ lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_test.c | 17 +++++++++++++++++ 6 files changed, 55 insertions(+), 2 deletions(-) create mode 100644 lib/efi_loader/efi_test.c
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index a4686f17f0..a77d8b256e 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -148,13 +148,11 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt, struct efi_object loaded_image_info_obj = {}; struct efi_device_path *memdp = NULL; ulong ret; - ulong (*entry)(void *image_handle, struct efi_system_table *st) asmlinkage; ulong fdt_pages, fdt_size, fdt_start, fdt_end; const efi_guid_t fdt_guid = EFI_FDT_GUID; bootm_headers_t img = { 0 }; - int ret;
/* * Special case for efi payload not loaded from disk, such as @@ -318,6 +316,29 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) memcpy((char *)addr, __efi_helloworld_begin, size); } else #endif + if (IS_ENABLED(CONFIG_BOOTEFI_TEST) && !strcmp(argv[1], "test")) { + int ret; + + /* Initialize and populate EFI object list */ + if (efi_init_obj_list()) + return CMD_RET_FAILURE; + + struct efi_loaded_image loaded_image_info = {}; + struct efi_object loaded_image_info_obj = {}; + + efi_setup_loaded_image(&loaded_image_info, + &loaded_image_info_obj, + bootefi_device_path, bootefi_image_path); + + ret = efi_test(&loaded_image_info, &systab); + if (ret) { + printf("Test failed: err=%d\n", ret); + return CMD_RET_FAILURE; + } + printf("Test passed\n"); + + return 0; + } #ifdef CONFIG_CMD_BOOTEFI_SELFTEST if (!strcmp(argv[1], "selftest")) { struct efi_loaded_image loaded_image_info = {}; diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 08eec8ecc6..ccf142c51d 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -194,3 +194,4 @@ CONFIG_UT_TIME=y CONFIG_UT_DM=y CONFIG_UT_ENV=y CONFIG_UT_OVERLAY=y +CONFIG_CMD_BOOTEFI_SELFTEST=y diff --git a/include/efi_loader.h b/include/efi_loader.h index 35f8f84401..90018fbe9e 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -335,6 +335,9 @@ efi_status_t EFIAPI efi_set_variable(s16 *variable_name, void *efi_bootmgr_load(struct efi_device_path **device_path, struct efi_device_path **file_path);
+/* Perform EFI tests */ +int efi_test(efi_handle_t image_handle, struct efi_system_table *systab); + #else /* defined(EFI_LOADER) && !defined(CONFIG_SPL_BUILD) */
/* Without CONFIG_EFI_LOADER we don't have a runtime section, stub it out */ diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index dee0a96a98..659b2b18f4 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -16,3 +16,13 @@ config EFI_LOADER_BOUNCE_BUFFER Some hardware does not support DMA to full 64bit addresses. For this hardware we can create a bounce buffer so that payloads don't have to worry about platform details. + +config BOOTEFI_TEST + bool "Provide a test for the EFI loader" + depends on EFI_LOADER && SANDBOX + default y + help + Provides a test of the EFI loader functionality accessed via the + command line ('bootefi test'). This runs within U-Boot so does not + need a separate EFI application to work. It aims to include coverage + of all EFI code which can be accessed within sandbox. diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index ddb978f650..14ef85cc67 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -23,3 +23,4 @@ obj-$(CONFIG_DM_VIDEO) += efi_gop.o obj-$(CONFIG_PARTITIONS) += efi_disk.o obj-$(CONFIG_NET) += efi_net.o obj-$(CONFIG_GENERATE_SMBIOS_TABLE) += efi_smbios.o +obj-$(CONFIG_BOOTEFI_TEST) += efi_test.o diff --git a/lib/efi_loader/efi_test.c b/lib/efi_loader/efi_test.c new file mode 100644 index 0000000000..3fdce78b05 --- /dev/null +++ b/lib/efi_loader/efi_test.c @@ -0,0 +1,17 @@ +/* + * Copyright (c) 2017, Google Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <efi_api.h> + +int efi_test(efi_handle_t image_handle, struct efi_system_table *systable) +{ + struct efi_simple_text_output_protocol *con_out = systable->con_out; + + con_out->output_string(con_out, L"Hello, world!\n"); + + return 0; +}
Hello Simon,
why do we need "bootefi test"? What do you plan to do here which we cannot do in "bootefi selftest? I think we should unify both.
Best regards
Heinrich
Changes in v2:
Rebase to master
int ret;
- if (IS_ENABLED(CONFIG_BOOTEFI_TEST) && !strcmp(argv[1], "test")) {
int ret;
if (ret) {
- } #ifdef CONFIG_CMD_BOOTEFI_SELFTEST if (!strcmp(argv[1], "selftest")) { struct efi_loaded_image loaded_image_info = {};
- bool "Provide a test for the EFI loader"
- depends on EFI_LOADER && SANDBOX
- default y
- help
- Copyright (c) 2017, Google Inc. All rights reserved.
- struct efi_simple_text_output_protocol *con_out = systable->con_out;
- con_out->output_string(con_out, L"Hello, world!\n");
Hi Heinrich,
Hello Simon,
It runs the hello world test directly without going through a separate app.
This is just a starting point, to get EFI running on sandbox. Of course after that we can do more work to make it run the proper tests.
On 12/04/2017 11:07 PM, Simon Glass wrote:
Hi Heinrich,
Hello Simon,
bootefi selftest does not run a separate app either but stays in the same executable.
Regards
Heinrich
Hi Heinrich,
Hi Heinrich,
Hello Simon,
I still see some value in having a simple test. The existing one seems to require a U-Boot reboot...?
