[U-Boot] [PATCH v2] arm: kirkwood: lsxl: add note about sata in README
The boot commands have changed in the environment. Add a note about the incompatible change and how resolve the issue in the board's README.
Signed-off-by: Michael Walle michael@walle.cc ---
changes since v2: - whoops wrong mail address for author and sob-tag, sorry about that
Happy holidays
board/buffalo/lsxl/README | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/board/buffalo/lsxl/README b/board/buffalo/lsxl/README index ef5ed42880..fffb1ce8ec 100644 --- a/board/buffalo/lsxl/README +++ b/board/buffalo/lsxl/README @@ -8,6 +8,16 @@ the LS-XHL PCB has two SDRAM chips. Both have a Kirkwood CPU (Marvell bootloader and its environment. The linux kernel and the initial ramdisk are loaded from the hard disk.
+Important! Changes since v2019.07 +--------------------------------- +In u-boot v2019.07 the driver for the SATA port was changed to a new +one. This means that the old "ide" command and block interface is not +supported anymore. More important, the boot commands have changed. You have +to overwrite the boot commands in your envionment with the new ones: + + env default -f bootcmd_legacy + env default -f bootcmd_hdd + saveenv
Rescue Mode -----------
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
Michael Walle
Stefan Roese
