rpi: Compute Module 5 doesn't autoboot without debug UART
I'm working on getting a compute module working with Yocto using U-Boot as bootloader, which mostly works thanks to previous work to get RPi 5 working. However I'm running into a strange issue: if I turn on the CM5 without the debug UART (which requires soldering a header onto the CM5) attached, the Pi doesn't boot beyond showing the submarine splash screen, if I boot it with the console attached it autoboots correctly. If I attach the UART after the boot halted and press enter I get a U-Boot console, and giving the boot command boots it normally. And setting bootdelay=-2 in the env allows it to correctly boot.
Which leads me to believe there is perhaps a spurious input registered by U-Boot which interrupts autobooting.
Is there a command that allows me to extract why U-Boot didn't continue autobooting?
And anyone have a hint how this could perhaps be fixed in a more elegant way (allowing interruptable autoboot).
The hardware I'm testing on is the CM5 devkit, I needed to make small changes to yocto to get it working: https://github.com/agherzan/meta-raspberrypi/pull/1397
No changes were needed in U-Boot to get it to boot
Thanks,
Gijs
Hi Gijs,
I see the same thing. I wonder if we need to be able to silently disable the UART. I made a few attempts at [1] and [2]. Tom specifically mentioned the rpi at [3].
At least for the case where I saw it in my lab, the board continued to boot OK, even though no console output appeared on the display. I haven't actually made time to investigate this though.
[1] https://patchwork.ozlabs.org/project/uboot/patch/20231101180447.99361-1-sjg@... [2] https://patchwork.ozlabs.org/project/uboot/list/?series=433605 [3] https://patchwork.ozlabs.org/project/uboot/cover/20241120153554.860710-1-sjg...
I don't think this is unique to the CM5, I've seen it on other RPi models, I have a RPi4 8Gb model that exhibits the same behavior, yet other RPi4s I have don't exhibit the behavious. In the case of the 8Gb I have a USB serial TTL on it, it boots if the USB is plugged in, doesn't if not. I have other v4s, both with and without the TTL and they boot fine, I've never been able to get to the bottom of why.
I'm working on getting a compute module working with Yocto using U-Boot as bootloader, which mostly works thanks to previous work to get RPi 5 working. However I'm running into a strange issue: if I turn on the CM5 without the debug UART (which requires soldering a header onto the CM5) attached, the Pi doesn't boot beyond showing the submarine splash screen, if I boot it with the console attached it autoboots correctly. If I attach the UART after the boot halted and press enter I get a U-Boot console, and giving the boot command boots it normally. And setting bootdelay=-2 in the env allows it to correctly boot. Which leads me to believe there is perhaps a spurious input registered by U-Boot which interrupts autobooting. Is there a command that allows me to extract why U-Boot didn't continue autobooting? And anyone have a hint how this could perhaps be fixed in a more elegant way (allowing interruptable autoboot). The hardware I'm testing on is the CM5 devkit, I needed to make small changes to yocto to get it working: https://github.com/agherzan/meta-raspberrypi/pull/1397
Can you try by setting the bootdelay to -2? That did fix it for me, though autoboot is no longer interruptable.
As stated, I suspect my CM5 is generating spurious signals on the debug uart when it's not connected. Is there a config option that changes autoboot interruption to only happen on a specific key combination? i.e. control+c ? That might fix it sufficiently for me.
Gijs
Hi Gijs,
On 1/2/25 3:07 PM, Gijs Peskens wrote:
[You don't often get email from gijs.peskens@munisense.com. Learn why this is important at https://aka.ms/LearnAboutSenderIdentification ]
The hardware I'm testing on is the CM5 devkit, I needed to make small changes to yocto to get it working: https://eur02.safelinks.protection.outlook.com/? url=https%3A%2F%2Fgithub.com%2Fagherzan%2Fmeta- raspberrypi%2Fpull%2F1397&data=05%7C02%7Cquentin.schulz%40cherry.de%7C7761da6784444fc601c708dd2b36dc7d%7C5e0e1b5221b54e7b83bb514ec460677e%7C0%7C0%7C638714236816045296%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=lvd6ywVVIfRlzcOYxKoMBrimT20rumG9hWD3VWZDkbE%3D&reserved=0
I'm wondering if this couldn't be fixed by configuring the pinconf of the UART pins so that a floating line is in a stable state? e.g. a small pull-up/pull-down? Is this possible with the way UART generally works (i.e. is this going to work whether a console is connected or not?).
You are looking for AUTOBOOT_KEYED I believe.
Cheers, Quentin
Gijs Peskens
Peter Robinson
Quentin Schulz
