[U-Boot] [PULL] u-boot-usb/master
Hello,
This has been in the usb tree for a while, but I'm hesitant to ask you for scheduling it into current release. On the other hand, I don't think this will cause any breakage.
The following changes since commit 58e22f8a15adec39d24d060180d76a4cbe86a04b:
fdt: send all dtc output to stderr (2012-07-09 09:05:24 +0200)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to a4dae631bfa848d8a0d1933583ed7e2f6a96cab3:
CONFIG: EXYNOS5: USB: Enable USB 2.0 on smdk5250 (2012-07-09 18:27:55 +0200)
---------------------------------------------------------------- Rajeshwari Shinde (7): USB: EXYNOS: Incorporate EHCI review comments EXYNOS5: Fix system register structure EXYNOS5: Add structure for PMU registers USB: EXYNOS: Set USB 2.0 HOST Link mode EXYNOS: Add power Enable/Disable for USB-EHCI EXYNOS5: USB: Fix incorrect USB base addresses CONFIG: EXYNOS5: USB: Enable USB 2.0 on smdk5250
arch/arm/cpu/armv7/exynos/power.c | 22 +++ arch/arm/cpu/armv7/exynos/system.c | 22 +++ arch/arm/include/asm/arch-exynos/cpu.h | 7 +- arch/arm/include/asm/arch-exynos/{ehci-s5p.h => ehci.h} | 10 +- arch/arm/include/asm/arch-exynos/power.h | 626 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/system.h | 4 + drivers/usb/host/Makefile | 2 +- drivers/usb/host/{ehci-s5p.c => ehci-exynos.c} | 26 ++- include/configs/smdk5250.h | 6 + 9 files changed, 708 insertions(+), 17 deletions(-) rename arch/arm/include/asm/arch-exynos/{ehci-s5p.h => ehci.h} (90%) rename drivers/usb/host/{ehci-s5p.c => ehci-exynos.c} (79%)
Best regards, Marek Vasut
Dear Marek Vasut,
In message 201207091843.31146.marex@denx.de you wrote:
Hello,
Applied, thanks.
Dear Marek, Vivek, Rajeshwari:
These patches break 5 ARM boards:
origen s5pc210_universal smdk5250 smdkv310 trats
For example:
Configuring for origen board... text data bss dec hex filename 158893 3880 205648 368421 59f25 /work/wd/tmp-arm/u-boot 2332 0 0 2332 91c /work/wd/tmp-arm/spl/u-boot-spl system.c: In function 'exynos5_set_usbhost_mode': system.c:32:15: warning: unused variable 'phy_cfg' [-Wunused-variable] system.c: In function 'exynos5_set_usbhost_mode': system.c:32:15: warning: unused variable 'phy_cfg' [-Wunused-variable]
Please fix.
Thanks.
