[U-Boot] [PATCH] Davinci: NAND enable ECC even when not in NAND boot mode
On Davinci platforms, the default NAND device is enabled (for ECC) in low level boot code when NAND boot mode is used. If booting in another mode, NAND ECC is not enabled. The driver should make sure ECC is enabled regardless of boot mode if NAND is configured in U-Boot.
Signed-off-by: Nick Thompson nick.thompson@ge.com --- Applies to: u-boot-ti
This patch depends on "[PATCH v2] Davinci: Configurable NAND chip selects" posted on Nov 19, 2009.
drivers/mtd/nand/davinci_nand.c | 2 ++ include/asm-arm/arch-davinci/emif_defs.h | 3 +-- 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/davinci_nand.c b/drivers/mtd/nand/davinci_nand.c index 1ad802a..90e038e 100644 --- a/drivers/mtd/nand/davinci_nand.c +++ b/drivers/mtd/nand/davinci_nand.c @@ -87,6 +87,7 @@ static void nand_davinci_enable_hwecc(struct mtd_info *mtd, int mode) (void)readl(&(emif_regs->NANDFECC[CONFIG_SYS_NAND_CS - 2]));
val = readl(&emif_regs->NANDFCR); + val |= DAVINCI_NANDFCR_NAND_ENABLE(CONFIG_SYS_NAND_CS); val |= DAVINCI_NANDFCR_1BIT_ECC_START(CONFIG_SYS_NAND_CS); writel(val, &emif_regs->NANDFCR); } @@ -219,6 +220,7 @@ static void nand_davinci_4bit_enable_hwecc(struct mtd_info *mtd, int mode) */ val = readl(&emif_regs->NANDFCR); val &= ~DAVINCI_NANDFCR_4BIT_ECC_SEL_MASK; + val |= DAVINCI_NANDFCR_NAND_ENABLE(CONFIG_SYS_NAND_CS); val |= DAVINCI_NANDFCR_4BIT_ECC_SEL(CONFIG_SYS_NAND_CS); val |= DAVINCI_NANDFCR_4BIT_ECC_START; writel(val, &emif_regs->NANDFCR); diff --git a/include/asm-arm/arch-davinci/emif_defs.h b/include/asm-arm/arch-davinci/emif_defs.h index d67292f..8fd4e01 100644 --- a/include/asm-arm/arch-davinci/emif_defs.h +++ b/include/asm-arm/arch-davinci/emif_defs.h @@ -66,11 +66,10 @@ typedef struct {
typedef emif_registers *emifregs;
+#define DAVINCI_NANDFCR_NAND_ENABLE(n) (1 << (n-2)) #define DAVINCI_NANDFCR_4BIT_ECC_SEL_MASK (3 << 4) #define DAVINCI_NANDFCR_4BIT_ECC_SEL(n) ((n-2) << 4) - #define DAVINCI_NANDFCR_1BIT_ECC_START(n) (1 << (8 + (n-2))) - #define DAVINCI_NANDFCR_4BIT_ECC_START (1 << 12) #define DAVINCI_NANDFCR_4BIT_CALC_START (1 << 13)
Acked-by: Scott Wood scottwood@freescale.com
-Scott
Nick Thompson
Scott Wood
