[GIT PULL] xilinx patches for v2020.10-rc3
Hi Tom,
here are patches I have collected so far. CI loops looks fine. https://travis-ci.org/github/michalsimek/u-boot/builds/719527417 https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze/-/pipelines/4451
The most of that patches targets xilinx platforms with two exceptions. i2c partitions handling and second two mmc patches which I found independently of Faiz. Peng didn't reply to me that's why I pick them up.
Thanks, Michal
The following changes since commit ba989cf1cac82f10efc749aaf2aaff1694894e71:
Merge tag 'uniphier-v2020.10-2' of https://gitlab.denx.de/u-boot/custodians/u-boot-uniphier (2020-08-18 21:28:49 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-microblaze.git tags/xilinx-for-v2020.10-rc3
for you to fetch changes up to 29af2ac48c8f910cc2efc8099323f9d619fb2bd5:
clk: versal: Move pm_query_id out of clock driver (2020-08-20 10:57:46 +0200)
---------------------------------------------------------------- Xilinx changes for v2020.10-rc3
- Fix fdtfile variable setup - Fix bootm_*/fdt_high/initrd_high variables handling - Fix Kconfig dependencies for Xilinx drivers - Fix booting u-boot from lowest memory - Fix firmware payload argument count for Versal - Fix dfu configurations - Fix mio_bank property handling - Fix and align code around ID detection - Start to use ENV_VARS_UBOOT_RUNTIME_CONFIG - Simplify logic around reading MAC from eeprom - Decrease malloc length for zynqmp mini qspi - Enable preboot for ZynqMP and Versal
i2c: - Fix i2c eeprom partitions handling
mmc: - Fix logic around HS mode enabling and use proper functions
---------------------------------------------------------------- Ashok Reddy Soma (1): arm64: zynqmp: Reduce malloc memory for mini QSPI configuration
Faiz Abbas (1): mmc: sdhci: Enable high speed conditional on the corresponding bit
Ibai Erkiaga (7): versal: fix versal PM ret payload size xilinx: zynqmp: synchronize firmware call return payload xilinx: zynqmp: merge firmware calls for EL2 and EL3 xilinx: zynqmp: get chip ID using firmware driver xilinx: zynqmp: get chip ID at EL3 xilinx: zynqmp: remove chip_id function xilinx: zynqmp: fix incorrect map not align with IPI HW
Igor Lantsman (1): arm64: zynqmp: Fix set_fdtfile() not to break u-boots DTB
Michal Simek (20): xilinx: Setup bootm variables xilinx: kconfig: Change Kconfig dependencies for Xilinx drivers xilinx: Enable preboot feature for ZynqMP and Versal lib: fdt: Introduce fdtdec_setup_mem_size_base_lowest() lib: fdt: Convert fdtdes_setup_mem..() to livetree API xilinx: versal: Use lowest memory for U-Boot xilinx: Align dfu ram with booti command xilinx: zynqmp: Enable DFU tftp support i2c: eeprom: Use reg property instead of offset and size xilinx: Fix xlnx,mio_bank property mmc: zynq: Fix default value for xlnx,mio-bank xilinx: versal: Enable i2c misc eeprom driver xilinx: Add support for ENV_VARS_UBOOT_RUNTIME_CONFIG xilinx: Change logic around zynq_board_read_rom_ethaddr() xilinx: common: Get rid of fdt_high variable xilinx: common: Get rid of initrd_high variable setup xilinx: common: Check return value from variable setup xilinx: common: Change bootm_size variable setting mmc: sdhci: Use upper/lower_32_bits macros clk: versal: Move pm_query_id out of clock driver
T Karthik Reddy (1): xilinx: versal: Add new versal loadpdi command
arch/arm/Kconfig | 4 ++++ arch/arm/dts/avnet-ultrazedev-cc-v1.0-ultrazedev-som-v1.0.dts | 2 +- arch/arm/dts/avnet-ultrazedev-som-v1.0.dtsi | 2 +- arch/arm/dts/imx53-ppd-uboot.dtsi | 12 ++++++------ arch/arm/dts/imx6q-bx50v3-uboot.dtsi | 10 +++++----- arch/arm/dts/versal-mini-emmc0.dts | 2 +- arch/arm/dts/versal-mini-emmc1.dts | 2 +- arch/arm/dts/zynqmp-e-a2197-00-revA.dts | 2 +- arch/arm/dts/zynqmp-g-a2197-00-revA.dts | 2 +- arch/arm/dts/zynqmp-m-a2197-01-revA.dts | 4 ++-- arch/arm/dts/zynqmp-m-a2197-02-revA.dts | 4 ++-- arch/arm/dts/zynqmp-m-a2197-03-revA.dts | 4 ++-- arch/arm/dts/zynqmp-p-a2197-00-revA.dts | 4 ++-- arch/arm/dts/zynqmp-topic-miamimp-xilinx-xdp-v1r1.dts | 4 ++-- arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 4 ++-- arch/arm/dts/zynqmp-zcu100-revC.dts | 4 ++-- arch/arm/dts/zynqmp-zcu102-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu104-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu104-revC.dts | 2 +- arch/arm/dts/zynqmp-zcu106-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu111-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu1275-revB.dts | 2 +- arch/arm/dts/zynqmp-zcu1285-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu208-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu216-revA.dts | 2 +- arch/arm/mach-versal/include/mach/sys_proto.h | 2 -- arch/arm/mach-zynqmp/include/mach/sys_proto.h | 3 --- arch/sandbox/dts/test.dts | 13 +++++++++++++ board/xilinx/common/board.c | 21 +++++++++++++-------- board/xilinx/versal/Kconfig | 14 ++++++++++++++ board/xilinx/versal/Makefile | 1 + board/xilinx/versal/board.c | 5 ++++- board/xilinx/versal/cmds.c | 105 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/xilinx/zynq/board.c | 9 +++++++++ board/xilinx/zynqmp/zynqmp.c | 116 +++++++++++++++++++++++++++++++++++++++++--------------------------------------------------------------------------- configs/sandbox_defconfig | 1 + configs/xilinx_versal_virt_defconfig | 4 ++++ configs/xilinx_zynqmp_virt_defconfig | 2 ++ drivers/clk/clk_versal.c | 17 ----------------- drivers/firmware/firmware-zynqmp.c | 84 +++++++++++++++++++++++++++++++++++++++++++----------------------------------------- drivers/fpga/versalpl.c | 2 +- drivers/gpio/Kconfig | 4 ++-- drivers/i2c/Kconfig | 2 +- drivers/mailbox/zynqmp-ipi.c | 14 ++++++++++---- drivers/misc/i2c_eeprom.c | 15 ++++++++------- drivers/mmc/Kconfig | 1 - drivers/mmc/sdhci.c | 13 ++++++++----- drivers/mmc/zynq_sdhci.c | 2 +- drivers/net/Kconfig | 6 +++--- include/configs/xilinx_versal.h | 3 +-- include/configs/xilinx_zynqmp.h | 11 +++++++---- include/configs/xilinx_zynqmp_mini_qspi.h | 2 +- include/configs/zynq-common.h | 1 - include/fdtdec.h | 17 +++++++++++++++++ include/zynqmp_firmware.h | 26 ++++++++++++++++++++++++++ lib/fdtdec.c | 90 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++--------------------- test/dm/bootcount.c | 8 ++++++++ 57 files changed, 457 insertions(+), 241 deletions(-) create mode 100644 board/xilinx/versal/Kconfig create mode 100644 board/xilinx/versal/cmds.c
On Thu, Aug 20, 2020 at 04:30:12PM +0200, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Michal Simek
