[PATCH] rk3399: Add four clocks to clock driver needed by framebuffer
This patch adds the four clock gates
- ACLK_VOP0 - ACLK_VOP1 - HCLK_VOP0 - HCLK_VOP1
to the rockchip rk3399 clock drivers.
These clock gates were referenced by arch/arm/dts/rk3399.dtsi for vopb and vopl.
The driver drivers/video/rockchip/rk3399_vop.c won't get probed without these clocks and the framebuffer does not work. --- drivers/clk/rockchip/clk_rk3399.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 865b80cc0f..a3628d4a4c 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -923,6 +923,11 @@ static ulong rk3399_clk_get_rate(struct clk *clk) case DCLK_VOP0: case DCLK_VOP1: break; + case ACLK_VOP0: + case ACLK_VOP1: + case HCLK_VOP0: + case HCLK_VOP1: + break; case PCLK_EFUSE1024NS: break; case SCLK_SARADC: @@ -994,6 +999,12 @@ static ulong rk3399_clk_set_rate(struct clk *clk, ulong rate) case DCLK_VOP1: ret = rk3399_vop_set_clk(priv->cru, clk->id, rate); break; + case ACLK_VOP0: + case ACLK_VOP1: + case HCLK_VOP0: + case HCLK_VOP1: + /* clock gates are enabled by default */ + break; case SCLK_DDRCLK: ret = rk3399_ddr_set_clk(priv->cru, rate); break;
- ACLK_VOP0
- ACLK_VOP1
- HCLK_VOP0
- HCLK_VOP1
This needs at least a Signed-off-by: line
case ACLK_VOP0:
case ACLK_VOP1:
case HCLK_VOP0:
case HCLK_VOP1:
case ACLK_VOP0:
case ACLK_VOP1:
case HCLK_VOP0:
case HCLK_VOP1:
-- 2.25.1
- ACLK_VOP0
- ACLK_VOP1
- HCLK_VOP0
- HCLK_VOP1
Right, I simply forgot it. However, there was a more complete patch set previously posted by Jagan Teki on January, 23.
Wolfram
Peter Robinson
Wolfram Joost
