[U-Boot] [PATCH 0/4] riscv: sifive: fu540: Make GEM 10/100 Mbps work
At present the GEM ethernet on SiFive Unleashed board can only work in 1000 Mbps mode. With a 10/100 Mbps connection it just fails to do any network communication.
This adds a new GEMGXL clock driver to adjust the clock settings per the connection speed so that 10/100 Mbps works.
Bin Meng (4): clk: sifive: Add clock driver for GEMGXL MGMT dm: net: macb: Update macb_linkspd_cb() signature dm: net: macb: Implement link speed change callback sifive: fu540: Enable GEMGXL MGMT driver
board/sifive/fu540/Kconfig | 1 + drivers/clk/sifive/Kconfig | 7 +++++ drivers/clk/sifive/Makefile | 2 ++ drivers/clk/sifive/gemgxl-mgmt.c | 60 ++++++++++++++++++++++++++++++++++++++++ drivers/net/macb.c | 48 +++++++++++++++++++++++++++++++- 5 files changed, 117 insertions(+), 1 deletion(-) create mode 100644 drivers/clk/sifive/gemgxl-mgmt.c
This adds a clock driver to support the GEMGXL management IP block found in FU540 SoCs to control GEM TX clock operation mode for 10/100/1000 Mbps.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/clk/sifive/Kconfig | 7 +++++ drivers/clk/sifive/Makefile | 2 ++ drivers/clk/sifive/gemgxl-mgmt.c | 60 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 69 insertions(+) create mode 100644 drivers/clk/sifive/gemgxl-mgmt.c
diff --git a/drivers/clk/sifive/Kconfig b/drivers/clk/sifive/Kconfig index 81fc9f8..644881b 100644 --- a/drivers/clk/sifive/Kconfig +++ b/drivers/clk/sifive/Kconfig @@ -17,3 +17,10 @@ config CLK_SIFIVE_FU540_PRCI Supports the Power Reset Clock interface (PRCI) IP block found in FU540 SoCs. If this kernel is meant to run on a SiFive FU540 SoC, enable this driver. + +config CLK_SIFIVE_GEMGXL_MGMT + bool "GEMGXL management for SiFive FU540 SoCs" + depends on CLK_SIFIVE + help + Supports the GEMGXL management IP block found in FU540 SoCs to + control GEM TX clock operation mode for 10/100/1000 Mbps. diff --git a/drivers/clk/sifive/Makefile b/drivers/clk/sifive/Makefile index 1155e07..f8263e7 100644 --- a/drivers/clk/sifive/Makefile +++ b/drivers/clk/sifive/Makefile @@ -3,3 +3,5 @@ obj-$(CONFIG_CLK_ANALOGBITS_WRPLL_CLN28HPC) += wrpll-cln28hpc.o
obj-$(CONFIG_CLK_SIFIVE_FU540_PRCI) += fu540-prci.o + +obj-$(CONFIG_CLK_SIFIVE_GEMGXL_MGMT) += gemgxl-mgmt.o diff --git a/drivers/clk/sifive/gemgxl-mgmt.c b/drivers/clk/sifive/gemgxl-mgmt.c new file mode 100644 index 0000000..d989989 --- /dev/null +++ b/drivers/clk/sifive/gemgxl-mgmt.c @@ -0,0 +1,60 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019, Bin Meng bmeng.cn@gmail.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <asm/io.h> + +struct gemgxl_mgmt_regs { + __u32 tx_clk_sel; +}; + +struct gemgxl_mgmt_platdata { + struct gemgxl_mgmt_regs *regs; +}; + +static int gemgxl_mgmt_ofdata_to_platdata(struct udevice *dev) +{ + struct gemgxl_mgmt_platdata *plat = dev_get_platdata(dev); + + plat->regs = (struct gemgxl_mgmt_regs *)dev_read_addr(dev); + + return 0; +} + +static ulong gemgxl_mgmt_set_rate(struct clk *clk, ulong rate) +{ + struct gemgxl_mgmt_platdata *plat = dev_get_platdata(clk->dev); + + /* + * GEMGXL TX clock operation mode: + * + * 0 = GMII mode. Use 125 MHz gemgxlclk from PRCI in TX logic + * and output clock on GMII output signal GTX_CLK + * 1 = MII mode. Use MII input signal TX_CLK in TX logic + */ + writel(rate != 125000000, &plat->regs->tx_clk_sel); + + return 0; +} + +const struct clk_ops gemgxl_mgmt_ops = { + .set_rate = gemgxl_mgmt_set_rate, +}; + +static const struct udevice_id gemgxl_mgmt_match[] = { + { .compatible = "sifive,cadencegemgxlmgmt0", }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(gemgxl_mgmt) = { + .name = "gemgxl-mgmt", + .id = UCLASS_CLK, + .of_match = gemgxl_mgmt_match, + .ofdata_to_platdata = gemgxl_mgmt_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct gemgxl_mgmt_platdata), + .ops = &gemgxl_mgmt_ops, +};
Hi Bin,
- bool "GEMGXL management for SiFive FU540 SoCs"
- depends on CLK_SIFIVE
- help
- Copyright (C) 2019, Bin Meng bmeng.cn@gmail.com
- __u32 tx_clk_sel;
- struct gemgxl_mgmt_regs *regs;
- struct gemgxl_mgmt_platdata *plat = dev_get_platdata(dev);
- plat->regs = (struct gemgxl_mgmt_regs *)dev_read_addr(dev);
- struct gemgxl_mgmt_platdata *plat = dev_get_platdata(clk->dev);
- writel(rate != 125000000, &plat->regs->tx_clk_sel);
- .set_rate = gemgxl_mgmt_set_rate,
- { .compatible = "sifive,cadencegemgxlmgmt0", },
- { /* sentinel */ }
- .name = "gemgxl-mgmt",
nit: should the driver maybe be named sifive-gemgxl-mgmt to indicate that it is a SiFive-specific driver?
Looks good otherwise!
Reviewed-by: Lukas Auer lukas.auer@aisec.fraunhofer.de Tested-by: Lukas Auer lukas.auer@aisec.fraunhofer.de
Thanks, Lukas
- .id = UCLASS_CLK,
- .of_match = gemgxl_mgmt_match,
- .ofdata_to_platdata = gemgxl_mgmt_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct gemgxl_mgmt_platdata),
- .ops = &gemgxl_mgmt_ops,
Hi Lukas,
On Mon, May 20, 2019 at 7:26 PM Auer, Lukas lukas.auer@aisec.fraunhofer.de wrote:
Hi Bin,
help
__u32 tx_clk_sel;
{ /* sentinel */ }
Will rename the driver in v2.
Regards, Bin
This updates DM version macb_linkspd_cb() signature for future expansion, eg: adding an implementation for link speed changes.
drivers/net/macb.c | 22 +++++++++++++++++++++- 1 file changed, 21 insertions(+), 1 deletion(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 7261416..b7f404e 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -488,15 +488,23 @@ static int macb_phy_find(struct macb_device *macb, const char *name)
/** * macb_linkspd_cb - Linkspeed change callback function - * @regs: Base Register of MACB devices + * @dev/@regs: MACB udevice (DM version) or + * Base Register of MACB devices (non-DM version) * @speed: Linkspeed * Returns 0 when operation success and negative errno number * when operation failed. */ +#ifdef CONFIG_DM_ETH +int __weak macb_linkspd_cb(struct udevice *dev, unsigned int speed) +{ + return 0; +} +#else int __weak macb_linkspd_cb(void *regs, unsigned int speed) { return 0; } +#endif
#ifdef CONFIG_DM_ETH static int macb_phy_init(struct udevice *dev, const char *name) @@ -589,7 +597,11 @@ static int macb_phy_init(struct macb_device *macb, const char *name)
macb_writel(macb, NCFGR, ncfgr);
+#ifdef CONFIG_DM_ETH + ret = macb_linkspd_cb(dev, _1000BASET); +#else ret = macb_linkspd_cb(macb->regs, _1000BASET); +#endif if (ret) return ret;
@@ -614,9 +626,17 @@ static int macb_phy_init(struct macb_device *macb, const char *name) ncfgr &= ~(MACB_BIT(SPD) | MACB_BIT(FD) | GEM_BIT(GBE)); if (speed) { ncfgr |= MACB_BIT(SPD); +#ifdef CONFIG_DM_ETH + ret = macb_linkspd_cb(dev, _100BASET); +#else ret = macb_linkspd_cb(macb->regs, _100BASET); +#endif } else { +#ifdef CONFIG_DM_ETH + ret = macb_linkspd_cb(dev, _10BASET); +#else ret = macb_linkspd_cb(macb->regs, _10BASET); +#endif }
if (ret)
At present the link speed change callback is a nop. According to macb device tree bindings, an optional "tx_clk" is used to clock the ethernet controller's TX_CLK under different link speed.
In 10/100 MII mode, transmit logic must be clocked from a free running clock generated by the external PHY. In gigabit GMII mode, the controller, not the external PHY, must generate the 125 MHz transmit clock towards the PHY.
drivers/net/macb.c | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index b7f404e..7d86fa1 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -497,6 +497,32 @@ static int macb_phy_find(struct macb_device *macb, const char *name) #ifdef CONFIG_DM_ETH int __weak macb_linkspd_cb(struct udevice *dev, unsigned int speed) { +#ifdef CONFIG_CLK + struct clk tx_clk; + ulong rate; + int ret; + + ret = clk_get_by_name(dev, "tx_clk", &tx_clk); + if (ret) + return 0; + + switch (speed) { + case _10BASET: + rate = 2500000; + break; + case _100BASET: + rate = 25000000; + break; + case _1000BASET: + default: + rate = 125000000; + break; + } + + if (tx_clk.dev) + clk_set_rate(&tx_clk, rate); +#endif + return 0; } #else
Hi Bin,
- struct clk tx_clk;
- ulong rate;
- int ret;
- ret = clk_get_by_name(dev, "tx_clk", &tx_clk);
- if (ret)
Can you return errors in ret here?
- switch (speed) {
- case _10BASET:
rate = 2500000;
break;
- case _100BASET:
rate = 25000000;
break;
- case _1000BASET:
- default:
rate = 125000000;
break;
The Linux driver simply returns in the default case, without changing tx_clk. I am wondering if we should do the same in U-Boot?
- if (tx_clk.dev)
Can you also check the return value of clk_set_rate() here?
Thanks, Lukas
} #else
Hi Lukas,
On Mon, May 20, 2019 at 7:29 PM Auer, Lukas lukas.auer@aisec.fraunhofer.de wrote:
Hi Bin,
struct clk tx_clk;
ulong rate;
int ret;
if (ret)
No, we should ignore DT that does not contain the "tx_clk" source hence cannot return error here. I will add a comment in v2.
switch (speed) {
case _10BASET:
rate = 2500000;
break;
case _100BASET:
rate = 25000000;
break;
case _1000BASET:
default:
rate = 125000000;
break;
Sure.
if (tx_clk.dev)
Will add the return value check in v2.
Regards, Bin
Enable the new GEMGXL MGMT driver so that GEM 10/100 Mbps works now.
board/sifive/fu540/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index f464379..8eb5e30 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -28,6 +28,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply CMD_PING imply CLK_SIFIVE imply CLK_SIFIVE_FU540_PRCI + imply CLK_SIFIVE_GEMGXL_MGMT imply DOS_PARTITION imply EFI_PARTITION imply IP_DYN
Thanks for the patch series. I tested it successfully on a SiFive HiFive Unleashed board at 10, 100, and 1000 Mbps link speeds. Without the patch series, ethernet at 10 and 100 Mbps link speeds did not work.
Auer, Lukas
Bin Meng
