[U-Boot] [PATCH] net: designware: use 'phy_connect' instead of open coded
Using 'phy_connect' instead of 'phy_find_by_mask' and 'phy_connect_dev' both deduplicates code and adds support for 'fixed-link'.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
drivers/net/designware.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 2c5d9560c5..e08f459cf4 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -480,18 +480,16 @@ static int _dw_free_pkt(struct dw_eth_dev *priv) static int dw_phy_init(struct dw_eth_dev *priv, void *dev) { struct phy_device *phydev; - int mask = 0xffffffff, ret; + int phy_addr = -1, ret;
#ifdef CONFIG_PHY_ADDR - mask = 1 << CONFIG_PHY_ADDR; + phy_addr = CONFIG_PHY_ADDR; #endif
- phydev = phy_find_by_mask(priv->bus, mask, priv->interface); + phydev = phy_connect(priv->bus, phy_addr, dev, priv->interface); if (!phydev) return -ENODEV;
- phy_connect_dev(phydev, dev); - phydev->supported &= PHY_GBIT_FEATURES; if (priv->max_speed) { ret = phy_set_supported(phydev, priv->max_speed);
On Mon, Jul 15, 2019 at 2:53 PM Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Hi Simon,
https://patchwork.ozlabs.org/patch/1132238/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Joe Hershberger
Simon Goldschmidt
