[U-Boot] [PATCH] ppc4xx: Some more PMC405 coding-style cleanup
Signed-off-by: Stefan Roese sr@denx.de --- board/esd/pmc405/pmc405.c | 30 +++++++++++++++--------------- 1 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/board/esd/pmc405/pmc405.c b/board/esd/pmc405/pmc405.c index 10e7ce4..94caa6c 100644 --- a/board/esd/pmc405/pmc405.c +++ b/board/esd/pmc405/pmc405.c @@ -72,22 +72,22 @@ int board_early_init_f (void) /* * Setup GPIO pins */ - mtdcr(cntrl0, mfdcr(cntrl0) | ((CONFIG_SYS_FPGA_INIT | \ - CONFIG_SYS_FPGA_DONE | \ - CONFIG_SYS_XEREADY | \ - CONFIG_SYS_NONMONARCH | \ + mtdcr(cntrl0, mfdcr(cntrl0) | ((CONFIG_SYS_FPGA_INIT | + CONFIG_SYS_FPGA_DONE | + CONFIG_SYS_XEREADY | + CONFIG_SYS_NONMONARCH | CONFIG_SYS_REV1_2) << 5));
- if (!(in_be32((void*)GPIO0_IR) & CONFIG_SYS_REV1_2)) { + if (!(in_be32((void *)GPIO0_IR) & CONFIG_SYS_REV1_2)) { /* rev 1.2 boards */ - mtdcr(cntrl0, mfdcr(cntrl0) | ((CONFIG_SYS_INTA_FAKE | \ + mtdcr(cntrl0, mfdcr(cntrl0) | ((CONFIG_SYS_INTA_FAKE | CONFIG_SYS_SELF_RST) << 5)); }
- out_be32((void*)GPIO0_OR, CONFIG_SYS_VPEN); + out_be32((void *)GPIO0_OR, CONFIG_SYS_VPEN); /* setup for output */ - out_be32((void*)GPIO0_TCR, CONFIG_SYS_FPGA_PRG | CONFIG_SYS_FPGA_CLK | \ - CONFIG_SYS_FPGA_DATA | CONFIG_SYS_XEREADY | CONFIG_SYS_VPEN); + out_be32((void *)GPIO0_TCR, CONFIG_SYS_FPGA_PRG | CONFIG_SYS_FPGA_CLK | + CONFIG_SYS_FPGA_DATA | CONFIG_SYS_XEREADY | CONFIG_SYS_VPEN);
/* * - check if rev1_2 is low, then: @@ -104,15 +104,16 @@ int misc_init_r (void) gd->bd->bi_flashoffset = 0;
/* deassert EREADY# */ - out_be32((void*)GPIO0_OR, - in_be32((void*)GPIO0_OR) | CONFIG_SYS_XEREADY); + out_be32((void *)GPIO0_OR, + in_be32((void *)GPIO0_OR) | CONFIG_SYS_XEREADY); return (0); }
ushort pmc405_pci_subsys_deviceid(void) { ulong val; - val = in_be32((void*)GPIO0_IR); + + val = in_be32((void *)GPIO0_IR); if (!(val & CONFIG_SYS_REV1_2)) { /* low=rev1.2 */ /* check monarch# signal */ if (val & CONFIG_SYS_NONMONARCH) @@ -128,9 +129,8 @@ ushort pmc405_pci_subsys_deviceid(void) int checkboard (void) { ulong val; - char str[64]; - int i = getenv_r ("serial#", str, sizeof(str)); + int i = getenv_r("serial#", str, sizeof(str));
puts ("Board: ");
@@ -139,7 +139,7 @@ int checkboard (void) else puts(str);
- val = in_be32((void*)GPIO0_IR); + val = in_be32((void *)GPIO0_IR); if (!(val & CONFIG_SYS_REV1_2)) { /* low=rev1.2 */ puts(" rev1.2 ("); if (val & CONFIG_SYS_NONMONARCH) /* monarch# signal */
Thanks.
Acked-by: Matthias Fuchs matthias.fuchs@esd.eu
- if (!(in_be32((void *)GPIO0_IR) & CONFIG_SYS_REV1_2)) { /* rev 1.2 boards */
}mtdcr(cntrl0, mfdcr(cntrl0) | ((CONFIG_SYS_INTA_FAKE | CONFIG_SYS_SELF_RST) << 5));
- out_be32((void *)GPIO0_OR, CONFIG_SYS_VPEN); /* setup for output */
return (0);in_be32((void *)GPIO0_OR) | CONFIG_SYS_XEREADY);
- val = in_be32((void *)GPIO0_IR); if (!(val & CONFIG_SYS_REV1_2)) { /* low=rev1.2 */ /* check monarch# signal */ if (val & CONFIG_SYS_NONMONARCH)
- char str[64];
puts ("Board: ");
- val = in_be32((void *)GPIO0_IR); if (!(val & CONFIG_SYS_REV1_2)) { /* low=rev1.2 */ puts(" rev1.2 ("); if (val & CONFIG_SYS_NONMONARCH) /* monarch# signal */
Matthias Fuchs
Stefan Roese
