[U-Boot] AT91RM9200 U-Boot can not load initrd from flash
Hello
I've a board quite similar to AT91RM9200DK. I've compiled U-Boot 1.1.2 and 1.3.4 for it and both work fine with images loaded via tftp. When I try to boot same images from flash I got kernel running fine until this: ... No filesystem could mount root, tried: ext2 cramfs vfat romfs Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(1,0)
Seems like initrd is not copied to RAM by U-Boot. The u-boot environment is: setenv ipaddr 192.168.1.1 setenv serverip 192.168.1.10 setenv bootargs 'root=/dev/ram rw initrd=20a00000,500000 ramdisk_size=8192 console=ttyS0,115200 mem=32M mtdparts=phys_mapped_flash:64K(boot),64K(uboot),2944K(kernel),4608K(initrd),256K(settings),-(unused)' setenv bootcmd "bootm 10020000 10300000"
The images are: U-Boot> imls Legacy Image at 10020000: Image Name: K_2009-01-12_13:47:42 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2443456 Bytes = 2.3 MB Load Address: 20008000 Entry Point: 20008000 Verifying Checksum ... OK Legacy Image at 10300000: Image Name: FS_2009-01-12_14:13:24 Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3446369 Bytes = 3.3 MB Load Address: 20a00000 Entry Point: 20a00000 Verifying Checksum ... OK
What am I missing?
-- Dmitry K.
Dear Dmitry,
Yes, that's a know limitation (or call it feature, or bug, as you like) of the ARM kernel.
No, of course it is not copied. Why should we copy the compressed image to ram? That's just a waste of CPU cycles. The kernel can read it from flash as well.
Patches for this problem were submitted a few times since kenrel version 2.4.17 or so, and posted and re-posted again and again here on the ML. Search the archives for details.
What am I missing?
You're running on ARM...
I've searched here: http://www.nabble.com/Uboot---Users-f553.html and found same questions and no answers.
I have u-boot-1.1.1 which is able to load my images from flash, but is available only in binary. This makes me think that problem is in u-boot, but this message: http://www.nabble.com/Re%3A-Re%3A-Problem-with-bootm-command-p484325.html says that kernel is unable to handle ramdisk in flash, while it should.
I don't understand if I should patch kernel or U-Boot. Can anyone clarify this and advise me keywords to find appropriate patch?
Dear Dmitry Koroban,
To be more precise: Patches to the Linux kernel have been submitted...
Maybe gmane has a better search interface...
It's a Linux kernel problem, not an U-Boot issue.
As a work around, you can load the image to RAM in U-Boot...
I've searched archive using gmane but found only links to cvs whis is no longer used. This question seems to be asked frequently, so why don't you add it to FAQ along with link to patches to prevent further questions?
Thank you
-- Dmitry K.
Dmitry K
Dmitry Koroban
