[U-Boot] [PATCH] ARM: DTS: Resync am3517-evm.dts with Linux 4.20
The DTS file for the AM3517 had the incorrect CD polarity. Resync with the fixed DTS file from Linux.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/am3517-evm-ui.dtsi b/arch/arm/dts/am3517-evm-ui.dtsi new file mode 100644 index 0000000000..e841918c1c --- /dev/null +++ b/arch/arm/dts/am3517-evm-ui.dtsi @@ -0,0 +1,220 @@ +/* + * Copyright (C) 2018 Logic PD, Inc - http://www.logicpd.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#include <dt-bindings/input/input.h> + +/ { + codec1 { + compatible = "simple-audio-card"; + simple-audio-card,name = "tlv320aic23-hifi"; + + simple-audio-card,widgets = + "Microphone", "Mic In", + "Line", "Line In", + "Line", "Line Out"; + + simple-audio-card,routing = + "Line Out", "LOUT", + "Line Out", "ROUT", + "LLINEIN", "Line In", + "RLINEIN", "Line In", + "MICIN", "Mic In"; + + simple-audio-card,format = "i2s"; + simple-audio-card,bitclock-master = <&sound_master>; + simple-audio-card,frame-master = <&sound_master>; + + simple-audio-card,cpu { + sound-dai = <&mcbsp1>; + }; + + sound_master: simple-audio-card,codec { + sound-dai = <&tlv320aic23_1>; + system-clock-frequency = <12000000>; + }; + }; + + codec2 { + compatible = "simple-audio-card"; + simple-audio-card,name = "tlv320aic23-hifi"; + + simple-audio-card,widgets = + "Microphone", "Mic In", + "Line", "Line In", + "Line", "Line Out"; + + simple-audio-card,routing = + "Line Out", "LOUT", + "Line Out", "ROUT", + "LLINEIN", "Line In", + "RLINEIN", "Line In", + "MICIN", "Mic In"; + + simple-audio-card,format = "i2s"; + simple-audio-card,bitclock-master = <&sound_master2>; + simple-audio-card,frame-master = <&sound_master2>; + + simple-audio-card,cpu { + sound-dai = <&mcbsp2>; + }; + + sound_master2: simple-audio-card,codec { + sound-dai = <&tlv320aic23_2>; + system-clock-frequency = <12000000>; + }; + }; + + expander-keys { + compatible = "gpio-keys-polled"; + poll-interval = <100>; + + record { + label = "Record"; + /* linux,code = <BTN_0>; */ + gpios = <&tca6416_2 15 GPIO_ACTIVE_LOW>; + }; + + play { + label = "Play"; + linux,code = <KEY_PLAY>; + gpios = <&tca6416_2 14 GPIO_ACTIVE_LOW>; + }; + + Stop { + label = "Stop"; + linux,code = <KEY_STOP>; + gpios = <&tca6416_2 13 GPIO_ACTIVE_LOW>; + }; + + fwd { + label = "FWD"; + linux,code = <KEY_FASTFORWARD>; + gpios = <&tca6416_2 12 GPIO_ACTIVE_LOW>; + }; + + rwd { + label = "RWD"; + linux,code = <KEY_REWIND>; + gpios = <&tca6416_2 11 GPIO_ACTIVE_LOW>; + }; + + shift { + label = "Shift"; + linux,code = <KEY_LEFTSHIFT>; + gpios = <&tca6416_2 10 GPIO_ACTIVE_LOW>; + }; + + Mode { + label = "Mode"; + linux,code = <BTN_MODE>; + gpios = <&tca6416_2 9 GPIO_ACTIVE_LOW>; + }; + + Menu { + label = "Menu"; + linux,code = <KEY_MENU>; + gpios = <&tca6416_2 8 GPIO_ACTIVE_LOW>; + }; + + Up { + label = "Up"; + linux,code = <KEY_UP>; + gpios = <&tca6416_2 7 GPIO_ACTIVE_LOW>; + }; + + Down { + label = "Down"; + linux,code = <KEY_DOWN>; + gpios = <&tca6416_2 6 GPIO_ACTIVE_LOW>; + }; + }; +}; + +&i2c2 { + /* Audio codecs */ + tlv320aic23_1: codec@1a { + compatible = "ti,tlv320aic23"; + reg = <0x1a>; + #sound-dai-cells= <0>; + status = "okay"; + }; + + tlv320aic23_2: codec@1b { + compatible = "ti,tlv320aic23"; + reg = <0x1b>; + #sound-dai-cells= <0>; + status = "okay"; + }; +}; + +&i2c3 { + /* Audio codecs */ + tlv320aic23_3: codec@1a { + compatible = "ti,tlv320aic23"; + reg = <0x1a>; + #sound-dai-cells= <0>; + status = "okay"; + }; + + /* GPIO Expanders */ + tca6416_2: gpio@20 { + compatible = "ti,tca6416"; + reg = <0x20>; + gpio-controller; + #gpio-cells = <2>; + vcc-supply = <&vdd_io_reg>; + }; + + tca6416_3: gpio@21 { + compatible = "ti,tca6416"; + reg = <0x21>; + gpio-controller; + #gpio-cells = <2>; + vcc-supply = <&vdd_io_reg>; + }; + + /* TVP5146 Analog Video decoder input */ + tvp5146@5c { + compatible = "ti,tvp5146m2"; + reg = <0x5c>; + }; +}; + +&mcbsp1 { + status = "ok"; + #sound-dai-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&mcbsp1_pins>; +}; + +&mcbsp2 { + status = "ok"; + #sound-dai-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&mcbsp2_pins>; +}; + +&omap3_pmx_core { + mcbsp1_pins: pinmux_mcbsp1_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x2190, PIN_OUTPUT | MUX_MODE0) /* mcbsp1_dx.mcbsp1_dx */ + OMAP3_CORE1_IOPAD(0x2192, PIN_INPUT | MUX_MODE0) /* mcbsp1_dx.mcbsp1_dr */ + OMAP3_CORE1_IOPAD(0x2196, PIN_INPUT | MUX_MODE0) /* mcbsp_clks.mcbsp1_fsx */ + OMAP3_CORE1_IOPAD(0x2198, PIN_INPUT | MUX_MODE0) /* mcbsp1_clkx.mcbsp1_clkx */ + >; + }; + + mcbsp2_pins: pinmux_mcbsp2_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x213c, PIN_INPUT | MUX_MODE0) /* mcbsp2_fsx.mcbsp2_fsx */ + OMAP3_CORE1_IOPAD(0x213e, PIN_INPUT | MUX_MODE0) /* mcbsp2_clkx.mcbsp2_clkx */ + OMAP3_CORE1_IOPAD(0x2140, PIN_INPUT | MUX_MODE0) /* mcbsp2_dr.mcbsp2.dr */ + OMAP3_CORE1_IOPAD(0x2142, PIN_OUTPUT | MUX_MODE0) /* mcbsp2_dx.mcbsp2_dx */ + >; + }; +}; diff --git a/arch/arm/dts/am3517-evm.dts b/arch/arm/dts/am3517-evm.dts index 1d158cfda1..1e2bb68231 100644 --- a/arch/arm/dts/am3517-evm.dts +++ b/arch/arm/dts/am3517-evm.dts @@ -9,6 +9,7 @@
#include "am3517.dtsi" #include "am3517-som.dtsi" +#include "am3517-evm-ui.dtsi" #include <dt-bindings/input/input.h>
/ { @@ -227,7 +228,7 @@ vmmc-supply = <&vmmc_fixed>; bus-width = <4>; wp-gpios = <&gpio4 30 GPIO_ACTIVE_HIGH>; /* gpio_126 */ - cd-gpios = <&gpio4 31 GPIO_ACTIVE_HIGH>; /* gpio_127 */ + cd-gpios = <&gpio4 31 GPIO_ACTIVE_LOW>; /* gpio_127 */ };
&mmc3 { diff --git a/arch/arm/dts/am3517-som.dtsi b/arch/arm/dts/am3517-som.dtsi index dae6e458e5..b1c988eed8 100644 --- a/arch/arm/dts/am3517-som.dtsi +++ b/arch/arm/dts/am3517-som.dtsi @@ -163,7 +163,7 @@ compatible = "ti,wl1271"; reg = <2>; interrupt-parent = <&gpio6>; - interrupts = <10 IRQ_TYPE_LEVEL_HIGH>; /* gpio_170 */ + interrupts = <10 IRQ_TYPE_EDGE_RISING>; /* gpio_170 */ ref-clock-frequency = <26000000>; tcxo-clock-frequency = <26000000>; };
Adam Ford
