[PATCH 0/2] mkimage/rockchip: support packing optional second level boot-loader
When enabling back-to-bootrom, the bootrom would continue to load the second level boot-loader. And currently we are packing it by appending the generated image manually (with a predefined max size):
./firefly-rk3288/tools/mkimage -n rk3288 -T rksd -d \ firefly-rk3288/spl/u-boot-spl-dtb.bin out && \ cat firefly-rk3288/u-boot-dtb.bin >> out
This series add support of packing optional second level loader with mkimage tool: ./tools/mkimage -n rk3399 -T rksd -d \ rk3399_ddr_800MHz_v1.24.bin:rk3399_miniloader_v1.19.bin out
Jeffy Chen (2): rockchip: mkimage: support packing optional second level boot-loader doc: rockchip: document packing second level loader with mkimage
doc/README.rockchip | 11 +++ tools/imagetool.h | 1 + tools/mkimage.c | 8 ++ tools/rkcommon.c | 236 +++++++++++++++++++++++++++++++++++++++++++--------- tools/rkcommon.h | 18 ++-- tools/rksd.c | 35 +------- tools/rkspi.c | 42 ++++------ 7 files changed, 237 insertions(+), 114 deletions(-)
Support packing optional second level boot-loader:
$ ./tools/mkimage -n rk3399 -T rksd -d \ rk3399_ddr_800MHz_v1.24.bin:rk3399_miniloader_v1.19.bin out -v Adding Image rk3399_ddr_800MHz_v1.24.bin Size 116492(pad to 116736) Adding Image rk3399_miniloader_v1.19.bin Size 88060(pad to 88064) Image Type: Rockchip RK33 (SD/MMC) boot image Init Data Size: 116736 bytes Boot Data Size: 88064 bytes
Mainly parse init file and boot file from datafile option, copy them to the image, and padding each one to 2KB boundary.
Signed-off-by: Jeffy Chen jeffy.chen@rock-chips.com ---
tools/imagetool.h | 1 + tools/mkimage.c | 8 ++ tools/rkcommon.c | 236 +++++++++++++++++++++++++++++++++++++++++++++--------- tools/rkcommon.h | 18 ++--- tools/rksd.c | 35 +------- tools/rkspi.c | 42 ++++------ 6 files changed, 226 insertions(+), 114 deletions(-)
diff --git a/tools/imagetool.h b/tools/imagetool.h index 2689a4004a..e1c778b0df 100644 --- a/tools/imagetool.h +++ b/tools/imagetool.h @@ -253,6 +253,7 @@ void pbl_load_uboot(int fd, struct image_tool_params *mparams); int zynqmpbif_copy_image(int fd, struct image_tool_params *mparams); int imx8image_copy_image(int fd, struct image_tool_params *mparams); int imx8mimage_copy_image(int fd, struct image_tool_params *mparams); +int rockchip_copy_image(int fd, struct image_tool_params *mparams);
#define ___cat(a, b) a ## b #define __cat(a, b) ___cat(a, b) diff --git a/tools/mkimage.c b/tools/mkimage.c index 4217188310..5f51d2cc89 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -544,6 +544,14 @@ int main(int argc, char **argv) ret = imx8mimage_copy_image(ifd, ¶ms); if (ret) return ret; + } else if ((params.type == IH_TYPE_RKSD) || + (params.type == IH_TYPE_RKSPI)) { + /* Rockchip has special Image format */ + int ret; + + ret = rockchip_copy_image(ifd, ¶ms); + if (ret) + return ret; } else { copy_file(ifd, params.datafile, pad_len); } diff --git a/tools/rkcommon.c b/tools/rkcommon.c index 0d908daee8..1095aa3426 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -80,6 +80,24 @@ static struct spl_info spl_infos[] = { { "rv1108", "RK11", 0x1800, false }, };
+/** + * struct spl_params - spl params parsed in check_params() + * + * @init_file: Init data file path + * @init_size: Aligned size of init data in bytes + * @boot_file: Boot data file path + * @boot_size: Aligned size of boot data in bytes + */ + +struct spl_params { + char *init_file; + uint32_t init_size; + char *boot_file; + uint32_t boot_size; +}; + +static struct spl_params spl_params = { 0 }; + static unsigned char rc4_key[16] = { 124, 78, 3, 4, 85, 5, 9, 7, 45, 44, 123, 56, 23, 13, 23, 17 @@ -99,12 +117,25 @@ static struct spl_info *rkcommon_get_spl_info(char *imagename) return NULL; }
-int rkcommon_check_params(struct image_tool_params *params) +static int rkcommon_get_aligned_size(struct image_tool_params *params, + const char *fname) { - int i; + int size;
- if (rkcommon_get_spl_info(params->imagename) != NULL) - return EXIT_SUCCESS; + size = imagetool_get_filesize(params, fname); + if (size < 0) + return -1; + + /* + * Pad to a 2KB alignment, as required for init/boot size by the ROM + * (see https://lists.denx.de/pipermail/u-boot/2017-May/293268.html) + */ + return ROUND(size, RK_SIZE_ALIGN); +} + +int rkcommon_check_params(struct image_tool_params *params) +{ + int i, spl_size;
/* * If this is a operation (list or extract), the don't require @@ -113,6 +144,41 @@ int rkcommon_check_params(struct image_tool_params *params) if (params->lflag || params->iflag) return EXIT_SUCCESS;
+ if (!rkcommon_get_spl_info(params->imagename)) + goto err_spl_info; + + spl_params.init_file = params->datafile; + + spl_params.boot_file = strchr(spl_params.init_file, ':'); + if (spl_params.boot_file) { + *spl_params.boot_file = '\0'; + spl_params.boot_file += 1; + } + + spl_params.init_size = + rkcommon_get_aligned_size(params, spl_params.init_file); + if (spl_params.init_size < 0) + return EXIT_FAILURE; + + /* Boot file is optional, and only for back-to-bootrom functionality. */ + if (spl_params.boot_file) { + spl_params.boot_size = + rkcommon_get_aligned_size(params, spl_params.boot_file); + if (spl_params.boot_size < 0) + return EXIT_FAILURE; + } + + spl_size = RK_SPL_HDR_START + spl_params.init_size; + if (spl_size > rkcommon_get_spl_size(params)) { + fprintf(stderr, + "Error: SPL image is too large (size %#x than %#x)\n", + spl_size, rkcommon_get_spl_size(params)); + return EXIT_FAILURE; + } + + return EXIT_SUCCESS; + +err_spl_info: fprintf(stderr, "ERROR: imagename (%s) is not supported!\n", params->imagename ? params->imagename : "NULL");
@@ -155,8 +221,7 @@ bool rkcommon_need_rc4_spl(struct image_tool_params *params) return info->spl_rc4; }
-static void rkcommon_set_header0(void *buf, uint file_size, - struct image_tool_params *params) +static void rkcommon_set_header0(void *buf, struct image_tool_params *params) { struct header0_info *hdr = buf;
@@ -164,16 +229,8 @@ static void rkcommon_set_header0(void *buf, uint file_size, hdr->signature = RK_SIGNATURE; hdr->disable_rc4 = !rkcommon_need_rc4_spl(params); hdr->init_offset = RK_INIT_OFFSET; + hdr->init_size = spl_params.init_size / RK_BLK_SIZE;
- hdr->init_size = DIV_ROUND_UP(file_size, RK_BLK_SIZE); - /* - * The init_size has to be a multiple of 4 blocks (i.e. of 2K) - * or the BootROM will not boot the image. - * - * Note: To verify that this is not a legacy constraint, we - * rechecked this against the RK3399 BootROM. - */ - hdr->init_size = ROUND(hdr->init_size, 4); /* * init_boot_size needs to be set, as it is read by the BootROM * to determine the size of the next-stage bootloader (e.g. U-Boot @@ -182,20 +239,22 @@ static void rkcommon_set_header0(void *buf, uint file_size, * see https://lists.denx.de/pipermail/u-boot/2017-May/293267.html * for a more detailed explanation by Andy Yan */ - hdr->init_boot_size = hdr->init_size + RK_MAX_BOOT_SIZE / RK_BLK_SIZE; + if (spl_params.boot_file) + hdr->init_boot_size = + hdr->init_size + spl_params.boot_size / RK_BLK_SIZE; + else + hdr->init_boot_size = + hdr->init_size + RK_MAX_BOOT_SIZE / RK_BLK_SIZE;
rc4_encode(buf, RK_BLK_SIZE, rc4_key); }
-int rkcommon_set_header(void *buf, uint file_size, - struct image_tool_params *params) +void rkcommon_set_header(void *buf, struct stat *sbuf, int ifd, + struct image_tool_params *params) { struct header1_info *hdr = buf + RK_SPL_HDR_START;
- if (file_size > rkcommon_get_spl_size(params)) - return -ENOSPC; - - rkcommon_set_header0(buf, file_size, params); + rkcommon_set_header0(buf, params);
/* Set up the SPL name (i.e. copy spl_hdr over) */ memcpy(&hdr->magic, rkcommon_get_spl_hdr(params), RK_SPL_HDR_SIZE); @@ -203,8 +262,6 @@ int rkcommon_set_header(void *buf, uint file_size, if (rkcommon_need_rc4_spl(params)) rkcommon_rc4_encode_spl(buf, RK_SPL_HDR_START, params->file_size - RK_SPL_HDR_START); - - return 0; }
static inline unsigned rkcommon_offset_to_spi(unsigned offset) @@ -296,7 +353,7 @@ void rkcommon_print_header(const void *buf) struct header0_info header0; struct spl_info *spl_info; uint8_t image_type; - int ret; + int ret, boot_size;
ret = rkcommon_parse_header(buf, &header0, &spl_info);
@@ -314,7 +371,11 @@ void rkcommon_print_header(const void *buf) printf("Image Type: Rockchip %s (%s) boot image\n", spl_info->spl_hdr, (image_type == IH_TYPE_RKSD) ? "SD/MMC" : "SPI"); - printf("Data Size: %d bytes\n", header0.init_size * RK_BLK_SIZE); + printf("Init Data Size: %d bytes\n", header0.init_size * RK_BLK_SIZE); + + boot_size = (header0.init_boot_size - header0.init_size) * RK_BLK_SIZE; + if (boot_size != RK_MAX_BOOT_SIZE) + printf("Boot Data Size: %d bytes\n", boot_size); }
void rkcommon_rc4_encode_spl(void *buf, unsigned int offset, unsigned int size) @@ -331,12 +392,8 @@ void rkcommon_rc4_encode_spl(void *buf, unsigned int offset, unsigned int size) }
int rkcommon_vrec_header(struct image_tool_params *params, - struct image_type_params *tparams, - unsigned int alignment) + struct image_type_params *tparams) { - unsigned int unpadded_size; - unsigned int padded_size; - /* * The SPL image looks as follows: * @@ -362,19 +419,118 @@ int rkcommon_vrec_header(struct image_tool_params *params,
/* Allocate, clear and install the header */ tparams->hdr = malloc(tparams->header_size); - if (!tparams->hdr) - return -ENOMEM; + if (!tparams->hdr) { + fprintf(stderr, "%s: Can't alloc header: %s\n", + params->cmdname, strerror(errno)); + exit(EXIT_FAILURE); + } memset(tparams->hdr, 0, tparams->header_size);
/* - * If someone passed in 0 for the alignment, we'd better handle - * it correctly... + * We need to store the original file-size (i.e. before padding), as + * imagetool does not set this during its adjustment of file_size. */ - if (!alignment) - alignment = 1; + params->orig_file_size = tparams->header_size + + spl_params.init_size + spl_params.boot_size; + + params->file_size = ROUND(params->orig_file_size, RK_SIZE_ALIGN); + + /* Ignoring pad len, since we are using our own copy_image() */ + return 0; +} + +static int pad_file(struct image_tool_params *params, int ifd, int pad) +{ + uint8_t zeros[4096]; + + memset(zeros, 0, sizeof(zeros)); + + while (pad > 0) { + int todo = sizeof(zeros); + + if (todo > pad) + todo = pad; + if (write(ifd, (char *)&zeros, todo) != todo) { + fprintf(stderr, "%s: Write error on %s: %s\n", + params->cmdname, params->imagefile, + strerror(errno)); + return -1; + } + pad -= todo; + } + + return 0; +} + +static int copy_file(struct image_tool_params *params, int ifd, + const char *file, int padded_size) +{ + int dfd; + struct stat sbuf; + unsigned char *ptr; + int size; + + if (params->vflag) + fprintf(stderr, "Adding Image %s\n", file); + + dfd = open(file, O_RDONLY | O_BINARY); + if (dfd < 0) { + fprintf(stderr, "%s: Can't open %s: %s\n", + params->cmdname, file, strerror(errno)); + return -1; + }
- unpadded_size = tparams->header_size + params->file_size; - padded_size = ROUND(unpadded_size, alignment); + if (fstat(dfd, &sbuf) < 0) { + fprintf(stderr, "%s: Can't stat %s: %s\n", + params->cmdname, file, strerror(errno)); + goto err_close; + } + + if (params->vflag) + fprintf(stderr, "Size %u(pad to %u)\n", + (int)sbuf.st_size, padded_size); + + ptr = mmap(0, sbuf.st_size, PROT_READ, MAP_SHARED, dfd, 0); + if (ptr == MAP_FAILED) { + fprintf(stderr, "%s: Can't read %s: %s\n", + params->cmdname, file, strerror(errno)); + goto err_munmap; + } + + size = sbuf.st_size; + if (write(ifd, ptr, size) != size) { + fprintf(stderr, "%s: Write error on %s: %s\n", + params->cmdname, params->imagefile, strerror(errno)); + goto err_munmap; + } + + munmap((void *)ptr, sbuf.st_size); + close(dfd); + return pad_file(params, ifd, padded_size - size); + +err_munmap: + munmap((void *)ptr, sbuf.st_size); +err_close: + close(dfd); + return -1; +} + +int rockchip_copy_image(int ifd, struct image_tool_params *params) +{ + int ret; + + ret = copy_file(params, ifd, spl_params.init_file, + spl_params.init_size); + if (ret) + return ret; + + if (spl_params.boot_file) { + ret = copy_file(params, ifd, spl_params.boot_file, + spl_params.boot_size); + if (ret) + return ret; + }
- return padded_size - unpadded_size; + return pad_file(params, ifd, + params->file_size - params->orig_file_size); } diff --git a/tools/rkcommon.h b/tools/rkcommon.h index 47f47a52aa..93518824a5 100644 --- a/tools/rkcommon.h +++ b/tools/rkcommon.h @@ -9,13 +9,11 @@
enum { RK_BLK_SIZE = 512, - RK_INIT_SIZE_ALIGN = 2048, + RK_SIZE_ALIGN = 2048, RK_INIT_OFFSET = 4, RK_MAX_BOOT_SIZE = 512 << 10, RK_SPL_HDR_START = RK_INIT_OFFSET * RK_BLK_SIZE, RK_SPL_HDR_SIZE = 4, - RK_SPL_START = RK_SPL_HDR_START + RK_SPL_HDR_SIZE, - RK_IMAGE_HEADER_LEN = RK_SPL_START, };
/** @@ -49,11 +47,9 @@ int rkcommon_get_spl_size(struct image_tool_params *params); * This sets up a 2KB header which can be interpreted by the Rockchip boot ROM. * * @buf: Pointer to header place (must be at least 2KB in size) - * @file_size: Size of the file we want the boot ROM to load, in bytes - * @return 0 if OK, -ENOSPC if too large */ -int rkcommon_set_header(void *buf, uint file_size, - struct image_tool_params *params); +void rkcommon_set_header(void *buf, struct stat *sbuf, int ifd, + struct image_tool_params *params);
/** * rkcommon_verify_header() - verify the header for a Rockchip boot image @@ -102,14 +98,10 @@ void rkcommon_rc4_encode_spl(void *buf, unsigned int offset, unsigned int size); * @params: Pointer to the tool params structure * @tparams: Pointer tot the image type structure (for setting * the header and header_size) - * @alignment: Alignment (a power of two) that the image should be - * padded to (e.g. 512 if we want to align with SD/MMC - * blocksizes or 2048 for the SPI format) * - * @return bytes of padding required/added (does not include the header_size) + * @return 0 (always) */ int rkcommon_vrec_header(struct image_tool_params *params, - struct image_type_params *tparams, - unsigned int alignment); + struct image_type_params *tparams);
#endif diff --git a/tools/rksd.c b/tools/rksd.c index 24411d863a..7d46a1b07b 100644 --- a/tools/rksd.c +++ b/tools/rksd.c @@ -12,27 +12,6 @@ #include "mkimage.h" #include "rkcommon.h"
-static void rksd_set_header(void *buf, struct stat *sbuf, int ifd, - struct image_tool_params *params) -{ - unsigned int size; - int ret; - - /* - * We need to calculate this using 'RK_SPL_HDR_START' and not using - * 'tparams->header_size', as the additional byte inserted when - * 'is_boot0' is true counts towards the payload (and not towards the - * header). - */ - size = params->file_size - RK_SPL_HDR_START; - ret = rkcommon_set_header(buf, size, params); - if (ret) { - /* TODO(sjg@chromium.org): This method should return an error */ - printf("Warning: SPL image is too large (size %#x) and will " - "not boot\n", size); - } -} - static int rksd_check_image_type(uint8_t type) { if (type == IH_TYPE_RKSD) @@ -41,16 +20,6 @@ static int rksd_check_image_type(uint8_t type) return EXIT_FAILURE; }
-static int rksd_vrec_header(struct image_tool_params *params, - struct image_type_params *tparams) -{ - /* - * Pad to a 2KB alignment, as required for init_size by the ROM - * (see https://lists.denx.de/pipermail/u-boot/2017-May/293268.html) - */ - return rkcommon_vrec_header(params, tparams, RK_INIT_SIZE_ALIGN); -} - /* * rk_sd parameters */ @@ -62,9 +31,9 @@ U_BOOT_IMAGE_TYPE( rkcommon_check_params, rkcommon_verify_header, rkcommon_print_header, - rksd_set_header, + rkcommon_set_header, NULL, rksd_check_image_type, NULL, - rksd_vrec_header + rkcommon_vrec_header ); diff --git a/tools/rkspi.c b/tools/rkspi.c index faa18fcd18..f2530f7bde 100644 --- a/tools/rkspi.c +++ b/tools/rkspi.c @@ -21,22 +21,20 @@ static void rkspi_set_header(void *buf, struct stat *sbuf, int ifd, { int sector; unsigned int size; - int ret;
size = params->orig_file_size; - ret = rkcommon_set_header(buf, size, params); - debug("size %x\n", size); - if (ret) { - /* TODO(sjg@chromium.org): This method should return an error */ - printf("Warning: SPL image is too large (size %#x) and will " - "not boot\n", size); - } + + rkcommon_set_header(buf, sbuf, ifd, params);
/* * Spread the image out so we only use the first 2KB of each 4KB * region. This is a feature of the SPI format required by the Rockchip * boot ROM. Its rationale is unknown. */ + if (params->vflag) + fprintf(stderr, "Spreading spi image from %u to %u\n", + size, params->file_size); + for (sector = size / RKSPI_SECT_LEN - 1; sector >= 0; sector--) { debug("sector %u\n", sector); memmove(buf + sector * RKSPI_SECT_LEN * 2, @@ -56,35 +54,23 @@ static int rkspi_check_image_type(uint8_t type) }
/* - * The SPI payload needs to be padded out to make space for odd half-sector - * layout used in flash (i.e. only the first 2K of each 4K sector is used). + * The SPI payload needs to make space for odd half-sector layout used in flash + * (i.e. only the first 2K of each 4K sector is used). */ static int rkspi_vrec_header(struct image_tool_params *params, struct image_type_params *tparams) { - int padding = rkcommon_vrec_header(params, tparams, RK_INIT_SIZE_ALIGN); - /* - * The file size has not been adjusted at this point (our caller will - * eventually add the header/padding to the file_size), so we need to - * add up the header_size, file_size and padding ourselves. - */ - int padded_size = tparams->header_size + params->file_size + padding; - - /* - * We need to store the original file-size (i.e. before padding), as - * imagetool does not set this during its adjustment of file_size. - */ - params->orig_file_size = padded_size; + rkcommon_vrec_header(params, tparams);
/* * Converting to the SPI format (i.e. splitting each 4K page into two * 2K subpages and then padding these 2K pages up to take a complete - * 4K sector again) will will double the image size. - * - * Thus we return the padded_size as an additional padding requirement - * (be sure to add this to the padding returned from the common code). + * 4K sector again) which will double the image size. */ - return padded_size + padding; + params->file_size = ROUND(params->file_size, RKSPI_SECT_LEN) << 1; + + /* Ignoring pad len, since we are using our own copy_image() */ + return 0; }
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
int ret;
if (ret)
} else { copy_file(ifd, params.datafile, pad_len); }return ret;
- struct spl_params - spl params parsed in check_params()
- @init_file: Init data file path
- @init_size: Aligned size of init data in bytes
- @boot_file: Boot data file path
- @boot_size: Aligned size of boot data in bytes
- char *init_file;
- uint32_t init_size;
- char *boot_file;
- uint32_t boot_size;
- static unsigned char rc4_key[16] = { 124, 78, 3, 4, 85, 5, 9, 7, 45, 44, 123, 56, 23, 13, 23, 17
{const char *fname)
- int i;
- int size;
- size = imagetool_get_filesize(params, fname);
- if (size < 0)
return -1;
- return ROUND(size, RK_SIZE_ALIGN);
int i, spl_size;
- If this is a operation (list or extract), the don't require
- if (!rkcommon_get_spl_info(params->imagename))
goto err_spl_info;
- spl_params.init_file = params->datafile;
- spl_params.boot_file = strchr(spl_params.init_file, ':');
- if (spl_params.boot_file) {
- spl_params.init_size =
- if (spl_params.init_size < 0)
- /* Boot file is optional, and only for back-to-bootrom functionality. */
- spl_size = RK_SPL_HDR_START + spl_params.init_size;
- if (spl_size > rkcommon_get_spl_size(params)) {
fprintf(stderr,
- hdr->init_size = spl_params.init_size / RK_BLK_SIZE;
- init_boot_size needs to be set, as it is read by the BootROM
- to determine the size of the next-stage bootloader (e.g. U-Boot
else
{ struct header1_info *hdr = buf + RK_SPL_HDR_START;struct image_tool_params *params)
return -ENOSPC;
return 0; }
- int ret;
int ret, boot_size;
{struct image_type_params *tparams)
- The SPL image looks as follows:
return -ENOMEM;
exit(EXIT_FAILURE);
* it correctly...
*/* imagetool does not set this during its adjustment of file_size.
- if (!alignment)
alignment = 1;
- params->orig_file_size = tparams->header_size +
- params->file_size = ROUND(params->orig_file_size, RK_SIZE_ALIGN);
- /* Ignoring pad len, since we are using our own copy_image() */
- uint8_t zeros[4096];
- memset(zeros, 0, sizeof(zeros));
- while (pad > 0) {
if (todo > pad)
todo = pad;
strerror(errno));
return -1;
pad -= todo;
- int dfd;
- struct stat sbuf;
- unsigned char *ptr;
- int size;
- if (params->vflag)
- dfd = open(file, O_RDONLY | O_BINARY);
- if (dfd < 0) {
return -1;
- if (fstat(dfd, &sbuf) < 0) {
goto err_close;
- ptr = mmap(0, sbuf.st_size, PROT_READ, MAP_SHARED, dfd, 0);
- if (ptr == MAP_FAILED) {
goto err_munmap;
- size = sbuf.st_size;
- if (write(ifd, ptr, size) != size) {
goto err_munmap;
- munmap((void *)ptr, sbuf.st_size);
- close(dfd);
- return pad_file(params, ifd, padded_size - size);
+err_munmap:
+err_close:
- close(dfd);
- return -1;
- int ret;
- ret = copy_file(params, ifd, spl_params.init_file,
- if (ret)
return ret;
if (ret)
return ret;
}params->file_size - params->orig_file_size);
- RK_SIZE_ALIGN = 2048, RK_INIT_OFFSET = 4, RK_MAX_BOOT_SIZE = 512 << 10, RK_SPL_HDR_START = RK_INIT_OFFSET * RK_BLK_SIZE, RK_SPL_HDR_SIZE = 4,
- This sets up a 2KB header which can be interpreted by the Rockchip boot ROM.
- @buf: Pointer to header place (must be at least 2KB in size)
- @file_size: Size of the file we want the boot ROM to load, in bytes
- @return 0 if OK, -ENOSPC if too large
- rkcommon_verify_header() - verify the header for a Rockchip boot image
- @params: Pointer to the tool params structure
- @tparams: Pointer tot the image type structure (for setting
- @alignment: Alignment (a power of two) that the image should be
- @return bytes of padding required/added (does not include the header_size)
- @return 0 (always)
#endif
- int ret;
* header).
- if (ret) {
- rk_sd parameters
- rksd_set_header,
- rkcommon_set_header, NULL, rksd_check_image_type, NULL,
- rksd_vrec_header
- rkcommon_vrec_header );
int ret;
if (ret) {
- Spread the image out so we only use the first 2KB of each 4KB
- region. This is a feature of the SPI format required by the Rockchip
- boot ROM. Its rationale is unknown.
if (params->vflag)
- The SPI payload needs to be padded out to make space for odd half-sector
- layout used in flash (i.e. only the first 2K of each 4K sector is used).
- The SPI payload needs to make space for odd half-sector layout used in flash
- (i.e. only the first 2K of each 4K sector is used).
- Converting to the SPI format (i.e. splitting each 4K page into two
- 2K subpages and then padding these 2K pages up to take a complete
*/* 4K sector again) which will double the image size.
return 0; }
Add documentation about packing optional second level boot-loader with mkimage tool.
doc/README.rockchip | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/doc/README.rockchip b/doc/README.rockchip index 67c14006a3..39dc9c5e9f 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -341,6 +341,12 @@ You can create the image via the following operations: cat firefly-rk3288/u-boot-dtb.bin >> out && \ sudo dd if=out of=/dev/sdc seek=64
+Or: + ./firefly-rk3288/tools/mkimage -n rk3288 -T rksd -d \ + firefly-rk3288/spl/u-boot-spl-dtb.bin:firefly-rk3288/u-boot-dtb.bin \ + out && \ + sudo dd if=out of=/dev/sdc seek=64 + If you have an HDMI cable attached you should see a video console.
For evb_rk3036 board: @@ -348,6 +354,11 @@ For evb_rk3036 board: cat evb-rk3036/u-boot-dtb.bin >> out && \ sudo dd if=out of=/dev/sdc seek=64
+Or: + ./evb-rk3036/tools/mkimage -n rk3036 -T rksd -d \ + evb-rk3036/spl/u-boot-spl.bin:evb-rk3036/u-boot-dtb.bin out && \ + sudo dd if=out of=/dev/sdc seek=64 + Note: rk3036 SDMMC and debug uart use the same iomux, so if you boot from SD, the debug uart must be disabled
Jeffy Chen
Kever Yang
