[PATCH v2 0/7] binman: Show missing blob message when building U-Boot
binman currently support showing a helpful missing blob message, however only when the badly named --allow-missing flag is used.
This changes so that binman is invoked with the --allow-missing flag and the helpful message can be shown by default when building U-Boot.
Using the following:
make rockpro64-rk3399_defconfig make CROSS_COMPILE="aarch64-linux-gnu-"
Before this series a build fails with:
binman: Filename 'atf-bl31' not found in input path (...)
After this series a build fails with:
Image 'simple-bin' is missing external blobs and is non-functional: atf-bl31
/binman/simple-bin/fit/images/@atf-SEQ/atf-bl31 (atf-bl31): See the documentation for your board. You may need to build ARM Trusted Firmware and build with BL31=/path/to/bl31.bin
Image 'simple-bin' is missing optional external blobs but is still functional: tee-os
/binman/simple-bin/fit/images/@tee-SEQ/tee-os (tee-os): See the documentation for your board. You may need to build Open Portable Trusted Execution Environment (OP-TEE) and build with TEE=/path/to/tee.bin
Some images are invalid
Builds will continue to fail when there is missing blobs, and the use of BINMAN_ALLOW_MISSING=1 now only enables the --ignore-missing flag.
Changes in v2: - Drop merged patches. - Add patches to improve help text. - Add tests. - Collect r-b tags.
In v1 there was discussion regarding the name of binman --ignore-missing flag, see [1]. The flag is kept as-is in v2 and a rename or change of default behavior is something that someone can do in a follow up series.
The series is based on top of Simon's "binman: Simple templating feature and mkimage conversion" v5 series. This series can also be found at [2].
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230219220158.4160763-10-j... [2] https://github.com/Kwiboo/u-boot-rockchip/commits/binman-missing-v2
Jonas Karlman (7): binman: Update tee-os missing blob help text binman: Update missing optional external blob warning text binman: Report missing external blobs using error level binman: Override CheckOptional in fit entry binman: Fix blank line usage for invalid images warning text binman: Show filename in missing blob help message Makefile: Show binman missing blob message
Makefile | 2 +- tools/binman/control.py | 34 +++++++++++++++--------- tools/binman/etype/fit.py | 7 +++++ tools/binman/ftest.py | 11 +++++++- tools/binman/missing-blob-help | 2 +- tools/binman/test/264_tee_os_opt_fit.dts | 1 + 6 files changed, 41 insertions(+), 16 deletions(-)
Make it more clear that the missing external blob is optional in the printed warning message.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v2: - New patch
tools/binman/control.py | 2 +- tools/binman/ftest.py | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/binman/control.py b/tools/binman/control.py index 25e66814837d..3560cadba4c2 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -674,7 +674,7 @@ def ProcessImage(image, update_fdt, write_map, get_contents=True, image.CheckOptional(optional_list) if optional_list: tout.warning( - "Image '%s' is missing external blobs but is still functional: %s" % + "Image '%s' is missing optional external blobs but is still functional: %s" % (image.name, ' '.join([e.name for e in optional_list]))) _ShowHelpForMissingBlobs(optional_list)
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index e53181afb78a..152f800c676c 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -6330,7 +6330,7 @@ fdt fdtmap Extract the devicetree blob from the fdtmap err = stderr.getvalue() self.assertRegex( err, - "Image '.*' is missing external blobs but is still functional: missing") + "Image '.*' is missing optional external blobs but is still functional: missing")
def testSectionInner(self): """Test an inner section with a size"""
v2:
- New patch
-- 2.41.0
v2:
- New patch
Applied to u-boot-dm, thanks!
Make it a little bit more clear that it is U-Boot that should be built with TEE=/path/to/tee.bin and not OP-TEE itself.
tools/binman/missing-blob-help | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/binman/missing-blob-help b/tools/binman/missing-blob-help index f013367ac36b..ab0023eb9fb5 100644 --- a/tools/binman/missing-blob-help +++ b/tools/binman/missing-blob-help @@ -43,7 +43,7 @@ for the external TPL binary is https://github.com/rockchip-linux/rkbin.
tee-os: See the documentation for your board. You may need to build Open Portable -Trusted Execution Environment (OP-TEE) with TEE=/path/to/tee.bin +Trusted Execution Environment (OP-TEE) and build with TEE=/path/to/tee.bin
opensbi: See the documentation for your board. The OpenSBI git repo is at
v2:
- New patch
v2:
- New patch
Print missing external blobs using error level and missing optional external blobs using warning level. Also change to only print the header line in color, red for missing and yellow for optional.
tools/binman/control.py | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/tools/binman/control.py b/tools/binman/control.py index 3560cadba4c2..e5682bf2d3db 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -112,12 +112,12 @@ def _ReadMissingBlobHelp(): _FinishTag(tag, msg, result) return result
-def _ShowBlobHelp(path, text): - tout.warning('\n%s:' % path) +def _ShowBlobHelp(level, path, text): + tout.do_output(level, '\n%s:' % path) for line in text.splitlines(): - tout.warning(' %s' % line) + tout.do_output(level, ' %s' % line)
-def _ShowHelpForMissingBlobs(missing_list): +def _ShowHelpForMissingBlobs(level, missing_list): """Show help for each missing blob to help the user take action
Args: @@ -134,7 +134,7 @@ def _ShowHelpForMissingBlobs(missing_list): # Show the first match help message for tag in tags: if tag in missing_blob_help: - _ShowBlobHelp(entry._node.path, missing_blob_help[tag]) + _ShowBlobHelp(level, entry._node.path, missing_blob_help[tag]) break
def GetEntryModules(include_testing=True): @@ -658,9 +658,9 @@ def ProcessImage(image, update_fdt, write_map, get_contents=True, missing_list = [] image.CheckMissing(missing_list) if missing_list: - tout.warning("Image '%s' is missing external blobs and is non-functional: %s" % - (image.name, ' '.join([e.name for e in missing_list]))) - _ShowHelpForMissingBlobs(missing_list) + tout.error("Image '%s' is missing external blobs and is non-functional: %s" % + (image.name, ' '.join([e.name for e in missing_list]))) + _ShowHelpForMissingBlobs(tout.ERROR, missing_list)
faked_list = [] image.CheckFakedBlobs(faked_list) @@ -676,7 +676,7 @@ def ProcessImage(image, update_fdt, write_map, get_contents=True, tout.warning( "Image '%s' is missing optional external blobs but is still functional: %s" % (image.name, ' '.join([e.name for e in optional_list]))) - _ShowHelpForMissingBlobs(optional_list) + _ShowHelpForMissingBlobs(tout.WARNING, optional_list)
missing_bintool_list = [] image.check_missing_bintools(missing_bintool_list)
v2:
- New patch
v2:
- New patch
Missing optional blobs was not reported for generated entries, e.g. tee-os on rockchip targets. Implement a CheckOptional to fix this.
After this the following can be shown:
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Simon Glass sjg@chromium.org --- v2: - Add test - Collect r-b tag
tools/binman/etype/fit.py | 7 +++++++ tools/binman/ftest.py | 7 +++++++ tools/binman/test/264_tee_os_opt_fit.dts | 1 + 3 files changed, 15 insertions(+)
diff --git a/tools/binman/etype/fit.py b/tools/binman/etype/fit.py index ef4d0667578d..2c14b15b03cd 100644 --- a/tools/binman/etype/fit.py +++ b/tools/binman/etype/fit.py @@ -842,6 +842,13 @@ class Entry_fit(Entry_section): for entry in self._priv_entries.values(): entry.CheckMissing(missing_list)
+ def CheckOptional(self, optional_list): + # We must use our private entry list for this since generator nodes + # which are removed from self._entries will otherwise not show up as + # optional + for entry in self._priv_entries.values(): + entry.CheckOptional(optional_list) + def CheckEntries(self): pass
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 152f800c676c..40ef6e5dce99 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -6298,6 +6298,13 @@ fdt fdtmap Extract the devicetree blob from the fdtmap fdt_util.fdt32_to_cpu(node.props['entry'].value)) self.assertEqual(U_BOOT_DATA, node.props['data'].bytes)
+ with test_util.capture_sys_output() as (stdout, stderr): + self.checkFitTee('264_tee_os_opt_fit.dts', '') + err = stderr.getvalue() + self.assertRegex( + err, + "Image '.*' is missing optional external blobs but is still functional: tee-os") + def testFitTeeOsOptionalFitBad(self): """Test an image with a FIT with an optional OP-TEE binary""" with self.assertRaises(ValueError) as exc: diff --git a/tools/binman/test/264_tee_os_opt_fit.dts b/tools/binman/test/264_tee_os_opt_fit.dts index ae44b433edf1..e9634d3ccdcd 100644 --- a/tools/binman/test/264_tee_os_opt_fit.dts +++ b/tools/binman/test/264_tee_os_opt_fit.dts @@ -25,6 +25,7 @@ fit,data;
tee-os { + optional; }; }; };
There is no blank line between last missing blob help message and the header line for optional blob help messages.
/binman/simple-bin/fit/images/@atf-SEQ/atf-bl31: See the documentation for your board. You may need to build ARM Trusted Firmware and build with BL31=/path/to/bl31.bin Image 'simple-bin' is missing external blobs but is still functional: tee-os
/binman/simple-bin/fit/images/@tee-SEQ/tee-os: See the documentation for your board. You may need to build Open Portable Trusted Execution Environment (OP-TEE) and build with TEE=/path/to/tee.bin
With this a blank line is inserted to make the text more readable.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Simon Glass sjg@chromium.org --- v2: - Collect r-b tag
tools/binman/control.py | 13 +++++++------ 1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/tools/binman/control.py b/tools/binman/control.py index e5682bf2d3db..fe5d704c4048 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -113,9 +113,10 @@ def _ReadMissingBlobHelp(): return result
def _ShowBlobHelp(level, path, text): - tout.do_output(level, '\n%s:' % path) + tout.do_output(level, '%s:' % path) for line in text.splitlines(): tout.do_output(level, ' %s' % line) + tout.do_output(level, '')
def _ShowHelpForMissingBlobs(level, missing_list): """Show help for each missing blob to help the user take action @@ -658,7 +659,7 @@ def ProcessImage(image, update_fdt, write_map, get_contents=True, missing_list = [] image.CheckMissing(missing_list) if missing_list: - tout.error("Image '%s' is missing external blobs and is non-functional: %s" % + tout.error("Image '%s' is missing external blobs and is non-functional: %s\n" % (image.name, ' '.join([e.name for e in missing_list]))) _ShowHelpForMissingBlobs(tout.ERROR, missing_list)
@@ -666,7 +667,7 @@ def ProcessImage(image, update_fdt, write_map, get_contents=True, image.CheckFakedBlobs(faked_list) if faked_list: tout.warning( - "Image '%s' has faked external blobs and is non-functional: %s" % + "Image '%s' has faked external blobs and is non-functional: %s\n" % (image.name, ' '.join([os.path.basename(e.GetDefaultFilename()) for e in faked_list])))
@@ -674,7 +675,7 @@ def ProcessImage(image, update_fdt, write_map, get_contents=True, image.CheckOptional(optional_list) if optional_list: tout.warning( - "Image '%s' is missing optional external blobs but is still functional: %s" % + "Image '%s' is missing optional external blobs but is still functional: %s\n" % (image.name, ' '.join([e.name for e in optional_list]))) _ShowHelpForMissingBlobs(tout.WARNING, optional_list)
@@ -682,7 +683,7 @@ def ProcessImage(image, update_fdt, write_map, get_contents=True, image.check_missing_bintools(missing_bintool_list) if missing_bintool_list: tout.warning( - "Image '%s' has missing bintools and is non-functional: %s" % + "Image '%s' has missing bintools and is non-functional: %s\n" % (image.name, ' '.join([os.path.basename(bintool.name) for bintool in missing_bintool_list]))) return any([missing_list, faked_list, missing_bintool_list]) @@ -827,7 +828,7 @@ def Binman(args): # This can only be True if -M is provided, since otherwise binman # would have raised an error already if invalid: - msg = '\nSome images are invalid' + msg = 'Some images are invalid' if args.ignore_missing: tout.warning(msg) else:
Hi Jonas,
v2:
- Collect r-b tag
IMO you don't need to do this...just collect them and say 'no changes'.
'patman status' is your friend.
Hi Jonas,
v2:
- Collect r-b tag
Show the filename next to the node path in missing blob help messages, also show a generic missing blob message when there was no help message for the help tag.
tools/binman/control.py | 13 ++++++++++--- tools/binman/ftest.py | 2 ++ 2 files changed, 12 insertions(+), 3 deletions(-)
diff --git a/tools/binman/control.py b/tools/binman/control.py index fe5d704c4048..048d74a0b786 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -112,8 +112,8 @@ def _ReadMissingBlobHelp(): _FinishTag(tag, msg, result) return result
-def _ShowBlobHelp(level, path, text): - tout.do_output(level, '%s:' % path) +def _ShowBlobHelp(level, path, text, fname): + tout.do_output(level, '%s (%s):' % (path, fname)) for line in text.splitlines(): tout.do_output(level, ' %s' % line) tout.do_output(level, '') @@ -133,10 +133,17 @@ def _ShowHelpForMissingBlobs(level, missing_list): tags = entry.GetHelpTags()
# Show the first match help message + shown_help = False for tag in tags: if tag in missing_blob_help: - _ShowBlobHelp(level, entry._node.path, missing_blob_help[tag]) + _ShowBlobHelp(level, entry._node.path, missing_blob_help[tag], + entry.GetDefaultFilename()) + shown_help = True break + # Or a generic help message + if not shown_help: + _ShowBlobHelp(level, entry._node.path, "Missing blob", + entry.GetDefaultFilename())
def GetEntryModules(include_testing=True): """Get a set of entry class implementations diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 40ef6e5dce99..b2f78d3d0adb 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -3781,6 +3781,7 @@ class TestFunctional(unittest.TestCase): allow_missing=True) self.assertEqual(103, ret) err = stderr.getvalue() + self.assertIn('(missing-file)', err) self.assertRegex(err, "Image 'image'.*missing.*: blob-ext") self.assertIn('Some images are invalid', err)
@@ -3791,6 +3792,7 @@ class TestFunctional(unittest.TestCase): allow_missing=True, ignore_missing=True) self.assertEqual(0, ret) err = stderr.getvalue() + self.assertIn('(missing-file)', err) self.assertRegex(err, "Image 'image'.*missing.*: blob-ext") self.assertIn('Some images are invalid', err)
When binman is invoked during a build of U-Boot and an external blob is missing, the user is usually presented with a generic file not found in input path message.
Invoke binman with --allow-missing so that binman can show relevant missing blob help messages. Build continue to fail with missing blobs unless BINMAN_ALLOW_MISSING=1 is used, same as before.
This changes the following error message during a normal build:
to the following:
Image 'itb' is missing external blobs and is non-functional: atf-blob
/binman/itb/fit/images/atf/atf-blob (bl31.bin): See the documentation for your board. You may need to build ARM Trusted Firmware and build with BL31=/path/to/bl31.bin
Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 87f9fc786e8c..7850c171a042 100644 --- a/Makefile +++ b/Makefile @@ -1334,7 +1334,7 @@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ --toolpath $(objtree)/tools \ $(if $(BINMAN_VERBOSE),-v$(BINMAN_VERBOSE)) \ build -u -d u-boot.dtb -O . -m \ - $(if $(BINMAN_ALLOW_MISSING),--allow-missing --ignore-missing) \ + --allow-missing $(if $(BINMAN_ALLOW_MISSING),--ignore-missing) \ -I . -I $(srctree) -I $(srctree)/board/$(BOARDDIR) \ -I arch/$(ARCH)/dts -a of-list=$(CONFIG_OF_LIST) \ $(foreach f,$(BINMAN_INDIRS),-I $(f)) \
to the following:
Jonas Karlman
