Re: [U-Boot] [PATCH] cmd_mem: Decode the mtest start and end values from fdt
Dear Jagannadha Sutradharudu Teki,
In message ff1257d2-b332-477f-915d-0851e5ef944f@CO9EHSMHS030.ehs.local you wrote:
I think the entire change are not good as it touches the environment concept, Can you suggest any better way we could do or it may not be possible/require the mem test values alter though devicetree.
May I ask _why_ you would want to do this in the first place?
It does not seem to make sense to me.
Please also note that "mtest" is basicly useless. Totally useless, to be honest. It performs plain read / write cycles, and unless you have very basic memory issues this will always work - if you have such, these get detected when running get_ram_size().
"mtest" was once added as an explicit requirement of a customer to meet some formal specification requests. It is a ZERO practical use.
If you want to do memory testing, then use the memory test functions of the POST framework. OK, these will not exercise any burst mode accesses either, but they are at least a bit more useful.
