[U-Boot] [PATCH 1/2] libfdt: fdt_address_cells() and fdt_size_cells()
Add internal fdt_cells() to avoid copy and paste. Fix typo in fdt_size_cells() documentation comment.
This is based in upstream commit: c12b2b0 ("libfdt: fdt_address_cells() and fdt_size_cells()") but misses the test cases, as we don't implement them in u-boot.
Signed-off-by: Matthias Brugger mbrugger@suse.com --- scripts/dtc/libfdt/fdt_addresses.c | 35 +++++++++++------------------- scripts/dtc/libfdt/libfdt.h | 2 +- 2 files changed, 14 insertions(+), 23 deletions(-)
diff --git a/scripts/dtc/libfdt/fdt_addresses.c b/scripts/dtc/libfdt/fdt_addresses.c index eff4dbcc72..49537b578d 100644 --- a/scripts/dtc/libfdt/fdt_addresses.c +++ b/scripts/dtc/libfdt/fdt_addresses.c @@ -1,6 +1,7 @@ /* * libfdt - Flat Device Tree manipulation * Copyright (C) 2014 David Gibson david@gibson.dropbear.id.au + * Copyright (C) 2018 embedded brains GmbH * * libfdt is dual licensed: you can use it either under the terms of * the GPL, or the BSD license, at your option. @@ -55,42 +56,32 @@
#include "libfdt_internal.h"
-int fdt_address_cells(const void *fdt, int nodeoffset) +static int fdt_cells(const void *fdt, int nodeoffset, const char *name) { - const fdt32_t *ac; + const fdt32_t *c; int val; int len;
- ac = fdt_getprop(fdt, nodeoffset, "#address-cells", &len); - if (!ac) + c = fdt_getprop(fdt, nodeoffset, name, &len); + if (!c) return 2;
- if (len != sizeof(*ac)) + if (len != sizeof(*c)) return -FDT_ERR_BADNCELLS;
- val = fdt32_to_cpu(*ac); + val = fdt32_to_cpu(*c); if ((val <= 0) || (val > FDT_MAX_NCELLS)) return -FDT_ERR_BADNCELLS;
return val; }
-int fdt_size_cells(const void *fdt, int nodeoffset) +int fdt_address_cells(const void *fdt, int nodeoffset) { - const fdt32_t *sc; - int val; - int len; - - sc = fdt_getprop(fdt, nodeoffset, "#size-cells", &len); - if (!sc) - return 2; - - if (len != sizeof(*sc)) - return -FDT_ERR_BADNCELLS; - - val = fdt32_to_cpu(*sc); - if ((val < 0) || (val > FDT_MAX_NCELLS)) - return -FDT_ERR_BADNCELLS; + return fdt_cells(fdt, nodeoffset, "#address-cells"); +}
- return val; +int fdt_size_cells(const void *fdt, int nodeoffset) +{ + return fdt_cells(fdt, nodeoffset, "#size-cells"); } diff --git a/scripts/dtc/libfdt/libfdt.h b/scripts/dtc/libfdt/libfdt.h index cf86ddba88..66f01fec53 100644 --- a/scripts/dtc/libfdt/libfdt.h +++ b/scripts/dtc/libfdt/libfdt.h @@ -1109,7 +1109,7 @@ int fdt_address_cells(const void *fdt, int nodeoffset); * * returns: * 0 <= n < FDT_MAX_NCELLS, on success - * 2, if the node has no #address-cells property + * 2, if the node has no #size-cells property * -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid * #size-cells property * -FDT_ERR_BADMAGIC,
According to the device tree specification, the default value for was not present.
This patch also makes fdt_address_cells() and fdt_size_cells() conform to the behaviour documented in libfdt.h. The defaults are only returned if fdt_getprop() returns -FDT_ERR_NOTFOUND, otherwise the actual error is returned.
This is based on upstream commit: aa7254d ("libfdt: return correct value if #size-cells property is not present") but misses the test case part, as we don't implement them in u-boot.
Signed-off-by: Matthias Brugger mbrugger@suse.com --- scripts/dtc/libfdt/fdt_addresses.c | 16 +++++++++++++--- scripts/dtc/libfdt/libfdt.h | 2 +- 2 files changed, 14 insertions(+), 4 deletions(-)
diff --git a/scripts/dtc/libfdt/fdt_addresses.c b/scripts/dtc/libfdt/fdt_addresses.c index 49537b578d..f13a87dfa0 100644 --- a/scripts/dtc/libfdt/fdt_addresses.c +++ b/scripts/dtc/libfdt/fdt_addresses.c @@ -64,7 +64,7 @@ static int fdt_cells(const void *fdt, int nodeoffset, const char *name)
c = fdt_getprop(fdt, nodeoffset, name, &len); if (!c) - return 2; + return len;
if (len != sizeof(*c)) return -FDT_ERR_BADNCELLS; @@ -78,10 +78,20 @@ static int fdt_cells(const void *fdt, int nodeoffset, const char *name)
int fdt_address_cells(const void *fdt, int nodeoffset) { - return fdt_cells(fdt, nodeoffset, "#address-cells"); + int val; + + val = fdt_cells(fdt, nodeoffset, "#address-cells"); + if (val == -FDT_ERR_NOTFOUND) + return 2; + return val; }
int fdt_size_cells(const void *fdt, int nodeoffset) { - return fdt_cells(fdt, nodeoffset, "#size-cells"); + int val; + + val = fdt_cells(fdt, nodeoffset, "#size-cells"); + if (val == -FDT_ERR_NOTFOUND) + return 1; + return val; } diff --git a/scripts/dtc/libfdt/libfdt.h b/scripts/dtc/libfdt/libfdt.h index 66f01fec53..5c778b115b 100644 --- a/scripts/dtc/libfdt/libfdt.h +++ b/scripts/dtc/libfdt/libfdt.h @@ -1109,7 +1109,7 @@ int fdt_address_cells(const void *fdt, int nodeoffset); * * returns: * 0 <= n < FDT_MAX_NCELLS, on success - * 2, if the node has no #size-cells property + * 1, if the node has no #size-cells property * -FDT_ERR_BADNCELLS, if the node has a badly formatted or invalid * #size-cells property * -FDT_ERR_BADMAGIC,
Hi all,
After running these two patches through the CI [1] I realized that three test are failing: test/py sandbox test/py sandbox with clang test/py sandbox_flattree
All three fail dm_test_fdt_translation() in the case "No translation for busses with #size-cells == 0" [2].
Can anybody with more insight in the test infrastructure and the sandbox architecture help me to identify if this is a) a bug in the sandbox b) a bug in our test c) a bug in my patch
I write this because I'm pretty sure that it is not option c), as we just stick to the specs here.
Regards, Matthias
[1] https://travis-ci.org/mbgg/u-boot/builds/565955218 [2] https://github.com/u-boot/u-boot/blob/master/test/dm/test-fdt.c#L511
return 2;
return len;
- int val;
- val = fdt_cells(fdt, nodeoffset, "#address-cells");
- if (val == -FDT_ERR_NOTFOUND)
return 2;
- return val;
- int val;
- val = fdt_cells(fdt, nodeoffset, "#size-cells");
return 1;
- return val;
- returns:
- 0 <= n < FDT_MAX_NCELLS, on success
- -FDT_ERR_BADMAGIC,
+Stephen Warren
Hi Matthias,
On Thu, 1 Aug 2019 at 05:42, Matthias Brugger matthias.bgg@gmail.com wrote:
Hi all,
Can you check the test and see? It might well be that the test is wrong.
I hope we don't have tet code relying on this.
Regards, SImon
Hi all,
On 13/08/2019 11:34, Simon Glass wrote:
+Stephen Warren
Hi Matthias,
Hi all,
I think I found the error. I missed a commit in libftd which fixes the issue. I'll send a v2 soon.
Thanks, Matthias
U-Boot
I suppose we could implement them but the idea is to keep the code synced with upstream so it is unnecessary. I've sent a code-size series to help with that.
Matthias Brugger
Matthias Brugger
