[U-Boot] [PATCH v3 0/3] Moving Uartlite to DM
This patch series depends on microblaze cleanup series. All these patches will be available in git://git.denx.de/u-boot-microblaze.git also with patches which I am going to send now.
Thanks, Michal
Changes in v3: - Use BIT macros - Fix logic in pending() for output direction - Add static inline to _debug_uart_init
Changes in v2: - Remove unneeded headers - Use get_dev_addr instead of fdtdec_get_addr - Use platdata instead of private data - Add opb compatible string to be in sync with Linux - Add binding documentation - Add needed header from the first patch - Remove WATCHDOG_RESET call - Extend commit description
Michal Simek (3): serial: uartlite: Move driver to DM serial: uartlite: Add support for debug console serial: uartlite: Add uartlite to Kconfig
arch/microblaze/Kconfig | 1 + board/xilinx/microblaze-generic/xparameters.h | 4 - configs/microblaze-generic_defconfig | 3 + .../serial/xilinx_uartlite.txt | 13 ++ doc/driver-model/serial-howto.txt | 1 - drivers/serial/Kconfig | 14 ++ drivers/serial/serial_xuartlite.c | 194 +++++++++------------ include/configs/microblaze-generic.h | 7 +- 8 files changed, 119 insertions(+), 118 deletions(-) create mode 100644 doc/device-tree-bindings/serial/xilinx_uartlite.txt
Enable SPL DM too.
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Thomas Chou thomas@wytron.com.tw ---
arch/microblaze/Kconfig | 1 + configs/microblaze-generic_defconfig | 2 + .../serial/xilinx_uartlite.txt | 13 ++ doc/driver-model/serial-howto.txt | 1 - drivers/serial/serial_xuartlite.c | 176 ++++++++------------- 5 files changed, 81 insertions(+), 112 deletions(-) create mode 100644 doc/device-tree-bindings/serial/xilinx_uartlite.txt
diff --git a/arch/microblaze/Kconfig b/arch/microblaze/Kconfig index 604f6815af5b..30ea484f48aa 100644 --- a/arch/microblaze/Kconfig +++ b/arch/microblaze/Kconfig @@ -13,6 +13,7 @@ config TARGET_MICROBLAZE_GENERIC select SUPPORT_SPL select OF_CONTROL select DM + select DM_SERIAL
endchoice
diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 54aa3ef3d26f..5df080b6a87c 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -1,9 +1,11 @@ CONFIG_MICROBLAZE=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_DM=y CONFIG_TARGET_MICROBLAZE_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="microblaze-generic" CONFIG_SPL=y CONFIG_SYS_PROMPT="U-Boot-mONStR> " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y diff --git a/doc/device-tree-bindings/serial/xilinx_uartlite.txt b/doc/device-tree-bindings/serial/xilinx_uartlite.txt new file mode 100644 index 000000000000..d15753c8c380 --- /dev/null +++ b/doc/device-tree-bindings/serial/xilinx_uartlite.txt @@ -0,0 +1,13 @@ +Binding for Xilinx Uartlite Controller + +Required properties: +- compatible : should be "xlnx,xps-uartlite-1.00.a", or "xlnx,opb-uartlite-1.00.b" +- reg: Should contain UART controller registers location and length. +- interrupts: Should contain UART controller interrupts. + +Example: + serial@40600000 { + compatible = "xlnx,xps-uartlite-1.00.a"; + interrupts = <1 0>; + reg = <0x40600000 0x10000>; + }; diff --git a/doc/driver-model/serial-howto.txt b/doc/driver-model/serial-howto.txt index 76ad629ef9cb..381a2a084562 100644 --- a/doc/driver-model/serial-howto.txt +++ b/doc/driver-model/serial-howto.txt @@ -18,7 +18,6 @@ is time for maintainers to start converting over the remaining serial drivers: serial_pxa.c serial_s3c24x0.c serial_sa1100.c - serial_xuartlite.c usbtty.c
You should complete this by the end of January 2016. diff --git a/drivers/serial/serial_xuartlite.c b/drivers/serial/serial_xuartlite.c index 988438e75471..157e14dedc4f 100644 --- a/drivers/serial/serial_xuartlite.c +++ b/drivers/serial/serial_xuartlite.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2008-2011 Michal Simek monstr@monstr.eu + * (C) Copyright 2008 - 2015 Michal Simek monstr@monstr.eu * Clean driver and add xilinx constant from header file * * (C) Copyright 2004 Atmark Techno, Inc. @@ -10,13 +10,17 @@
#include <config.h> #include <common.h> +#include <dm.h> #include <asm/io.h> #include <linux/compiler.h> #include <serial.h>
-#define SR_TX_FIFO_FULL 0x08 /* transmit FIFO full */ -#define SR_RX_FIFO_VALID_DATA 0x01 /* data in receive FIFO */ -#define SR_RX_FIFO_FULL 0x02 /* receive FIFO full */ +DECLARE_GLOBAL_DATA_PTR; + +#define SR_TX_FIFO_FULL BIT(3) /* transmit FIFO full */ +#define SR_TX_FIFO_EMPTY BIT(2) /* transmit FIFO empty */ +#define SR_RX_FIFO_VALID_DATA BIT(0) /* data in receive FIFO */ +#define SR_RX_FIFO_FULL BIT(1) /* receive FIFO full */
#define ULITE_CONTROL_RST_TX 0x01 #define ULITE_CONTROL_RST_RX 0x02 @@ -28,135 +32,85 @@ struct uartlite { unsigned int control; };
-static struct uartlite *userial_ports[4] = { -#ifdef XILINX_UARTLITE_BASEADDR - [0] = (struct uartlite *)XILINX_UARTLITE_BASEADDR, -#endif -#ifdef XILINX_UARTLITE_BASEADDR1 - [1] = (struct uartlite *)XILINX_UARTLITE_BASEADDR1, -#endif -#ifdef XILINX_UARTLITE_BASEADDR2 - [2] = (struct uartlite *)XILINX_UARTLITE_BASEADDR2, -#endif -#ifdef XILINX_UARTLITE_BASEADDR3 - [3] = (struct uartlite *)XILINX_UARTLITE_BASEADDR3 -#endif +struct uartlite_platdata { + struct uartlite *regs; };
-static void uartlite_serial_putc(const char c, const int port) +static int uartlite_serial_putc(struct udevice *dev, const char ch) { - struct uartlite *regs = userial_ports[port]; + struct uartlite_platdata *plat = dev_get_platdata(dev); + struct uartlite *regs = plat->regs;
- if (c == '\n') - uartlite_serial_putc('\r', port); + if (in_be32(®s->status) & SR_TX_FIFO_FULL) + return -EAGAIN;
- while (in_be32(®s->status) & SR_TX_FIFO_FULL) - ; - out_be32(®s->tx_fifo, c & 0xff); -} + out_be32(®s->tx_fifo, ch & 0xff);
-static void uartlite_serial_puts(const char *s, const int port) -{ - while (*s) - uartlite_serial_putc(*s++, port); + return 0; }
-static int uartlite_serial_getc(const int port) +static int uartlite_serial_getc(struct udevice *dev) { - struct uartlite *regs = userial_ports[port]; + struct uartlite_platdata *plat = dev_get_platdata(dev); + struct uartlite *regs = plat->regs; + + if (!(in_be32(®s->status) & SR_RX_FIFO_VALID_DATA)) + return -EAGAIN;
- while (!(in_be32(®s->status) & SR_RX_FIFO_VALID_DATA)) - ; return in_be32(®s->rx_fifo) & 0xff; }
-static int uartlite_serial_tstc(const int port) +static int uartlite_serial_pending(struct udevice *dev, bool input) { - struct uartlite *regs = userial_ports[port]; + struct uartlite_platdata *plat = dev_get_platdata(dev); + struct uartlite *regs = plat->regs;
- return in_be32(®s->status) & SR_RX_FIFO_VALID_DATA; + if (input) + return in_be32(®s->status) & SR_RX_FIFO_VALID_DATA; + + return !(in_be32(®s->status) & SR_TX_FIFO_EMPTY); }
-static int uartlite_serial_init(const int port) +static int uartlite_serial_probe(struct udevice *dev) { - struct uartlite *regs = userial_ports[port]; - - if (regs) { - out_be32(®s->control, 0); - out_be32(®s->control, - ULITE_CONTROL_RST_RX | ULITE_CONTROL_RST_TX); - in_be32(®s->control); - return 0; - } + struct uartlite_platdata *plat = dev_get_platdata(dev); + struct uartlite *regs = plat->regs;
- return -1; -} + out_be32(®s->control, 0); + out_be32(®s->control, ULITE_CONTROL_RST_RX | ULITE_CONTROL_RST_TX); + in_be32(®s->control);
-/* Multi serial device functions */ -#define DECLARE_ESERIAL_FUNCTIONS(port) \ - static int userial##port##_init(void) \ - { return uartlite_serial_init(port); } \ - static void userial##port##_setbrg(void) {} \ - static int userial##port##_getc(void) \ - { return uartlite_serial_getc(port); } \ - static int userial##port##_tstc(void) \ - { return uartlite_serial_tstc(port); } \ - static void userial##port##_putc(const char c) \ - { uartlite_serial_putc(c, port); } \ - static void userial##port##_puts(const char *s) \ - { uartlite_serial_puts(s, port); } - -/* Serial device descriptor */ -#define INIT_ESERIAL_STRUCTURE(port, __name) { \ - .name = __name, \ - .start = userial##port##_init, \ - .stop = NULL, \ - .setbrg = userial##port##_setbrg, \ - .getc = userial##port##_getc, \ - .tstc = userial##port##_tstc, \ - .putc = userial##port##_putc, \ - .puts = userial##port##_puts, \ + return 0; }
-DECLARE_ESERIAL_FUNCTIONS(0); -struct serial_device uartlite_serial0_device = - INIT_ESERIAL_STRUCTURE(0, "ttyUL0"); -DECLARE_ESERIAL_FUNCTIONS(1); -struct serial_device uartlite_serial1_device = - INIT_ESERIAL_STRUCTURE(1, "ttyUL1"); -DECLARE_ESERIAL_FUNCTIONS(2); -struct serial_device uartlite_serial2_device = - INIT_ESERIAL_STRUCTURE(2, "ttyUL2"); -DECLARE_ESERIAL_FUNCTIONS(3); -struct serial_device uartlite_serial3_device = - INIT_ESERIAL_STRUCTURE(3, "ttyUL3"); - -__weak struct serial_device *default_serial_console(void) +static int uartlite_serial_ofdata_to_platdata(struct udevice *dev) { - if (userial_ports[0]) - return &uartlite_serial0_device; - if (userial_ports[1]) - return &uartlite_serial1_device; - if (userial_ports[2]) - return &uartlite_serial2_device; - if (userial_ports[3]) - return &uartlite_serial3_device; - - return NULL; -} + struct uartlite_platdata *plat = dev_get_platdata(dev);
-void uartlite_serial_initialize(void) -{ -#ifdef XILINX_UARTLITE_BASEADDR - serial_register(&uartlite_serial0_device); -#endif /* XILINX_UARTLITE_BASEADDR */ -#ifdef XILINX_UARTLITE_BASEADDR1 - serial_register(&uartlite_serial1_device); -#endif /* XILINX_UARTLITE_BASEADDR1 */ -#ifdef XILINX_UARTLITE_BASEADDR2 - serial_register(&uartlite_serial2_device); -#endif /* XILINX_UARTLITE_BASEADDR2 */ -#ifdef XILINX_UARTLITE_BASEADDR3 - serial_register(&uartlite_serial3_device); -#endif /* XILINX_UARTLITE_BASEADDR3 */ + plat->regs = (struct uartlite *)dev_get_addr(dev); + + return 0; } + +static const struct dm_serial_ops uartlite_serial_ops = { + .putc = uartlite_serial_putc, + .pending = uartlite_serial_pending, + .getc = uartlite_serial_getc, +}; + +static const struct udevice_id uartlite_serial_ids[] = { + { .compatible = "xlnx,opb-uartlite-1.00.b", }, + { .compatible = "xlnx,xps-uartlite-1.00.a" }, + { } +}; + +U_BOOT_DRIVER(serial_uartlite) = { + .name = "serial_uartlite", + .id = UCLASS_SERIAL, + .of_match = uartlite_serial_ids, + .ofdata_to_platdata = uartlite_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct uartlite_platdata), + .probe = uartlite_serial_probe, + .ops = &uartlite_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Add support for debug console.
Changes in v3: - Add static inline to _debug_uart_init
Changes in v2: - Add needed header from the first patch - Remove WATCHDOG_RESET call - Extend commit description
drivers/serial/Kconfig | 7 +++++++ drivers/serial/serial_xuartlite.c | 26 ++++++++++++++++++++++++++ 2 files changed, 33 insertions(+)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 1fc287ee98ec..f1e221799b81 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -92,6 +92,13 @@ config DEBUG_UART_S5P will need to provide parameters to make this work. The driver will be available until the real driver-model serial is running.
+config DEBUG_UART_UARTLITE + bool "Xilinx Uartlite" + help + Select this to enable a debug UART using the serial_uartlite driver. + You will need to provide parameters to make this work. The driver will + be available until the real driver-model serial is running. + config DEBUG_UART_ZYNQ bool "Xilinx Zynq" help diff --git a/drivers/serial/serial_xuartlite.c b/drivers/serial/serial_xuartlite.c index 157e14dedc4f..a2e930392571 100644 --- a/drivers/serial/serial_xuartlite.c +++ b/drivers/serial/serial_xuartlite.c @@ -114,3 +114,29 @@ U_BOOT_DRIVER(serial_uartlite) = { .ops = &uartlite_serial_ops, .flags = DM_FLAG_PRE_RELOC, }; + +#ifdef CONFIG_DEBUG_UART_UARTLITE + +#include <debug_uart.h> + +static inline void _debug_uart_init(void) +{ + struct uartlite *regs = (struct uartlite *)CONFIG_DEBUG_UART_BASE; + + out_be32(®s->control, 0); + out_be32(®s->control, ULITE_CONTROL_RST_RX | ULITE_CONTROL_RST_TX); + in_be32(®s->control); +} + +static inline void _debug_uart_putc(int ch) +{ + struct uartlite *regs = (struct uartlite *)CONFIG_DEBUG_UART_BASE; + + while (in_be32(®s->status) & SR_TX_FIFO_FULL) + ; + + out_be32(®s->tx_fifo, ch & 0xff); +} + +DEBUG_UART_FUNCS +#endif
- Move config option out of board file. - Remove uartlite address from config file
board/xilinx/microblaze-generic/xparameters.h | 4 ---- configs/microblaze-generic_defconfig | 1 + drivers/serial/Kconfig | 7 +++++++ include/configs/microblaze-generic.h | 7 +------ 4 files changed, 9 insertions(+), 10 deletions(-)
diff --git a/board/xilinx/microblaze-generic/xparameters.h b/board/xilinx/microblaze-generic/xparameters.h index 8ba146cb88db..11b3c9a4846e 100644 --- a/board/xilinx/microblaze-generic/xparameters.h +++ b/board/xilinx/microblaze-generic/xparameters.h @@ -28,10 +28,6 @@ #define XILINX_TIMER_BASEADDR 0x41c00000 #define XILINX_TIMER_IRQ 0
-/* Uart pheriphery is RS232_Uart */ -#define XILINX_UARTLITE_BASEADDR 0x40600000 -#define XILINX_UARTLITE_BAUDRATE 115200 - /* IIC pheriphery is IIC_EEPROM */ #define XILINX_IIC_0_BASEADDR 0x40800000 #define XILINX_IIC_0_FREQ 100000 diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 5df080b6a87c..9a7bb915466f 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -9,3 +9,4 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_XILINX_UARTLITE=y diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index f1e221799b81..ddf49ba9cef3 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -230,4 +230,11 @@ config UNIPHIER_SERIAL If you have a UniPhier based board and want to use the on-chip serial ports, say Y to this option. If unsure, say N.
+config XILINX_UARTLITE + bool "Xilinx Uarlite support" + depends on DM_SERIAL && (MICROBLAZE || ARCH_ZYNQ || ARCH_ZYNQMP) + help + If you have a Xilinx based board and want to use the uartlite + serial ports, say Y to this option. If unsure, say N. + endmenu diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 10ac8328b8ff..6e3c80b14350 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -37,10 +37,7 @@ # define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400}
-#ifdef XILINX_UARTLITE_BASEADDR -# define CONFIG_XILINX_UARTLITE -# define CONFIG_SERIAL_BASE XILINX_UARTLITE_BASEADDR -#elif XILINX_UART16550_BASEADDR +#if XILINX_UART16550_BASEADDR # define CONFIG_SYS_NS16550_SERIAL # if defined(__MICROBLAZEEL__) # define CONFIG_SYS_NS16550_REG_SIZE -4 @@ -51,8 +48,6 @@ # define CONFIG_SYS_NS16550_COM1 \ ((XILINX_UART16550_BASEADDR & ~0xF) + 0x1000) # define CONFIG_SYS_NS16550_CLK XILINX_UART16550_CLOCK_HZ -#else -# error Undefined uart #endif
/* setting reset address */
Michal Simek
