[U-Boot] [PATCH] net: phy: ti: Fix dp83867 RGMII_TXID interface path
There is code that is specifically for RGMII_TXID interface, but this will never get used because the code checks that the RGMII interface is RGMII_ID to RGMII_RXID; RGMII_TXID is after this.
To fix this and avoid similar problems in the future, use the phy_interface_is_rgmii helper function.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- This has _not_ been tested in any way, shape or form! It was picked up when converting PHY code to use the phy_interface_is_rgmii helper function. --- drivers/net/phy/ti.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/net/phy/ti.c b/drivers/net/phy/ti.c index c55dd97..5e2b2dd 100644 --- a/drivers/net/phy/ti.c +++ b/drivers/net/phy/ti.c @@ -246,8 +246,7 @@ static int dp83867_config(struct phy_device *phydev) phy_write(phydev, MDIO_DEVAD_NONE, MII_DP83867_BISCR, 0x0); }
- if ((phydev->interface >= PHY_INTERFACE_MODE_RGMII_ID) && - (phydev->interface <= PHY_INTERFACE_MODE_RGMII_RXID)) { + if (phy_interface_is_rgmii(phydev)) { val = phy_read_mmd_indirect(phydev, DP83867_RGMIICTL, DP83867_DEVADDR, phydev->addr);
Hi Phil,
On Fri, Dec 9, 2016 at 4:46 AM, Phil Edworthy phil.edworthy@renesas.com wrote:
Joe Hershberger
Joe Hershberger
Phil Edworthy
