[U-Boot] [PATCH 9/9] [v3] rsa: Use checksum algorithms from struct hash_algo
Sorry. Resending as message bounced on uboot mailing list.
Hi Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Wednesday, December 24, 2014 6:20 AM To: Gupta Ruchika-R66431 Cc: U-Boot Mailing List; Sun York-R58495 Subject: Re: [PATCH 9/9] [v3] rsa: Use checksum algorithms from struct hash_algo
Hi Ruchika,
On 23 December 2014 at 04:32, Ruchika Gupta ruchika.gupta@freescale.com wrote:
Currently the hash functions used in RSA are called directly from the sha1 and sha256 libraries. Change the RSA checksum library to use the progressive hash API's registered with struct hash_algo. This will allow the checksum library to use the hardware accelerated progressive hash
API's once available.
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com CC: Simon Glass sjg@chromium.org
Changes in v3: Modified rsa-verify to check for return from checksum function
Changes in v2: Added generic function hash_calculate. Pass an additional argument as name of algorithm.
common/image-sig.c | 6 ++--- include/image.h | 5 ++-- include/u-boot/rsa-checksum.h | 7 +++--- lib/rsa/rsa-checksum.c | 53
lib/rsa/rsa-verify.c | 7 +++++- 5 files changed, 64 insertions(+), 14 deletions(-)
diff --git a/common/image-sig.c b/common/image-sig.c index 8601eda..2c9f0cd 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -38,7 +38,7 @@ struct checksum_algo checksum_algos[] = { #if IMAGE_ENABLE_SIGN EVP_sha1, #endif
sha1_calculate,
hash_calculate, padding_sha1_rsa2048, }, {
@@ -48,7 +48,7 @@ struct checksum_algo checksum_algos[] = { #if IMAGE_ENABLE_SIGN EVP_sha256, #endif
sha256_calculate,
hash_calculate, padding_sha256_rsa2048, }, {
@@ -58,7 +58,7 @@ struct checksum_algo checksum_algos[] = { #if IMAGE_ENABLE_SIGN EVP_sha256, #endif
sha256_calculate,
hash_calculate, padding_sha256_rsa4096, }
diff --git a/include/image.h b/include/image.h index af30d60..ec55f23 100644 --- a/include/image.h +++ b/include/image.h @@ -926,8 +926,9 @@ struct checksum_algo { #if IMAGE_ENABLE_SIGN const EVP_MD *(*calculate_sign)(void); #endif
void (*calculate)(const struct image_region region[],
int region_count, uint8_t *checksum);
int (*calculate)(const char *name,
int region_count, uint8_t *checksum); const uint8_t *rsa_padding;
diff --git a/include/u-boot/rsa-checksum.h b/include/u-boot/rsa-checksum.h index c996fb3..c546c80 100644 --- a/include/u-boot/rsa-checksum.h +++ b/include/u-boot/rsa-checksum.h @@ -16,9 +16,8 @@ extern const uint8_t padding_sha256_rsa4096[]; extern const uint8_t padding_sha256_rsa2048[]; extern const uint8_t padding_sha1_rsa2048[];
-void sha256_calculate(const struct image_region region[], int
region_count,
uint8_t *checksum);
-void sha1_calculate(const struct image_region region[], int region_count,
uint8_t *checksum);
+int hash_calculate(const char *name,
uint8_t *checksum);
This could use a function comment.
#endif diff --git a/lib/rsa/rsa-checksum.c b/lib/rsa/rsa-checksum.c index 8d8b59f..7f1909a 100644 --- a/lib/rsa/rsa-checksum.c +++ b/lib/rsa/rsa-checksum.c @@ -10,12 +10,13 @@ #include <asm/byteorder.h> #include <asm/errno.h> #include <asm/unaligned.h> +#include <hash.h> #else #include "fdt_host.h" -#endif -#include <u-boot/rsa.h> #include <u-boot/sha1.h> #include <u-boot/sha256.h> +#endif +#include <u-boot/rsa.h>
/* PKCS 1.5 paddings as described in the RSA PKCS#1 v2.1 standard. */
@@ -136,7 +137,33 @@ const uint8_t padding_sha256_rsa4096[RSA4096_BYTES -
SHA256_SUM_LEN] = {
0x03, 0x04, 0x02, 0x01, 0x05, 0x00, 0x04, 0x20 };
-void sha1_calculate(const struct image_region region[], int region_count, +#ifndef USE_HOSTCC +int hash_calculate(const char *name,
int region_count, uint8_t *checksum) {
struct hash_algo *algo;
int ret = 0;
void *ctx;
uint32_t i;
i = 0;
ret = hash_progressive_lookup_algo(name, &algo);
if (ret)
return ret;
algo->hash_init(algo, &ctx);
for (i = 0; i < region_count - 1; i++)
algo->hash_update(algo, ctx, region[i].data,
- region[i].size, 0);
algo->hash_update(algo, ctx, region[i].data, region[i].size, 1);
algo->hash_finish(algo, ctx, checksum, algo->digest_size);
+#else
The above looks good, but what is happening here? Why do you need to do something different for USE_HOSTCC?
The hash_algo struct is defined in common/hash.c which doesn’t get compiled for tools. That is why I did it differently for USE_HOSTCC
+int sha1_calculate(const struct image_region region[], int +region_count, uint8_t *checksum) { sha1_context ctx; @@ -147,9 +174,11 @@ void sha1_calculate(const struct image_region
for (i = 0; i < region_count; i++) sha1_update(&ctx, region[i].data, region[i].size); sha1_finish(&ctx, checksum);
-void sha256_calculate(const struct image_region region[], int region_count, +int sha256_calculate(const struct image_region region[], int +region_count, uint8_t *checksum) { sha256_context ctx; @@ -160,4 +189,20 @@ void sha256_calculate(const struct image_region
for (i = 0; i < region_count; i++) sha256_update(&ctx, region[i].data, region[i].size); sha256_finish(&ctx, checksum);
uint8_t *checksum)
if (!strcmp(name, "sha1"))
sha1_calculate(region, region_count, checksum);
if (!strcmp(name, "sha256"))
sha256_calculate(region, region_count, checksum);
+} +#endif diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index 27f10ef..0028304 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -188,7 +188,12 @@ int rsa_verify(struct image_sign_info *info, }
/* Calculate checksum with checksum-algorithm */
info->algo->checksum->calculate(region, region_count, hash);
ret = info->algo->checksum->calculate(info->algo->checksum->name,
if (ret < 0) {
debug("%s: Error in checksum calculation\n", __func__);
return -EINVAL;
} /* See if we must use a particular key */ if (info->required_keynode != -1) {
-- 1.8.1.4
Regards, Ruchika
Ruchika Gupta
