[PATCH] mmc: hi6220-dwmmc: handle clocks and resets if CONFIG_CLK and CONFIG_DM_RESET enabled
This can avoid hardcoding a clock rate in driver. Also can enable the clocks and deassert the resets if the pre-bootloader does not do this for us.
Currently only enabled for Hi3798MV200.
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- drivers/mmc/hi6220_dw_mmc.c | 61 ++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 60 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/hi6220_dw_mmc.c b/drivers/mmc/hi6220_dw_mmc.c index 71962cd47e..a4b8072976 100644 --- a/drivers/mmc/hi6220_dw_mmc.c +++ b/drivers/mmc/hi6220_dw_mmc.c @@ -5,15 +5,24 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> #include <dwmmc.h> #include <errno.h> #include <fdtdec.h> #include <malloc.h> +#include <reset.h> #include <asm/global_data.h> +#include <dm/device_compat.h>
DECLARE_GLOBAL_DATA_PTR;
+enum hi6220_dwmmc_clk_type { + HI6220_DWMMC_CLK_BIU, + HI6220_DWMMC_CLK_CIU, + HI6220_DWMMC_CLK_CNT, +}; + struct hi6220_dwmmc_plat { struct mmc_config cfg; struct mmc mmc; @@ -21,6 +30,8 @@ struct hi6220_dwmmc_plat {
struct hi6220_dwmmc_priv_data { struct dwmci_host host; + struct clk *clks[HI6220_DWMMC_CLK_CNT]; + struct reset_ctl_bulk rsts; };
struct hisi_mmc_data { @@ -32,7 +43,29 @@ static int hi6220_dwmmc_of_to_plat(struct udevice *dev) { struct hi6220_dwmmc_priv_data *priv = dev_get_priv(dev); struct dwmci_host *host = &priv->host; + int ret;
+ if (CONFIG_IS_ENABLED(CLK) && CONFIG_IS_ENABLED(DM_RESET)) { + priv->clks[HI6220_DWMMC_CLK_BIU] = devm_clk_get(dev, "biu"); + if (IS_ERR(priv->clks[HI6220_DWMMC_CLK_BIU])) { + ret = PTR_ERR(priv->clks[HI6220_DWMMC_CLK_BIU]); + dev_err(dev, "Failed to get BIU clock(ret = %d).\n", ret); + return log_msg_ret("clk", ret); + } + + priv->clks[HI6220_DWMMC_CLK_CIU] = devm_clk_get(dev, "ciu"); + if (IS_ERR(priv->clks[HI6220_DWMMC_CLK_CIU])) { + ret = PTR_ERR(priv->clks[HI6220_DWMMC_CLK_CIU]); + dev_err(dev, "Failed to get CIU clock(ret = %d).\n", ret); + return log_msg_ret("clk", ret); + } + + ret = reset_get_bulk(dev, &priv->rsts); + if (ret) { + dev_err(dev, "Failed to get resets(ret = %d)", ret); + return log_msg_ret("rst", ret); + } + } host->name = dev->name; host->ioaddr = dev_read_addr_ptr(dev); host->buswidth = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), @@ -56,11 +89,37 @@ static int hi6220_dwmmc_probe(struct udevice *dev) struct hi6220_dwmmc_priv_data *priv = dev_get_priv(dev); struct dwmci_host *host = &priv->host; struct hisi_mmc_data *mmc_data; + int ret;
mmc_data = (struct hisi_mmc_data *)dev_get_driver_data(dev);
- /* Use default bus speed due to absence of clk driver */ host->bus_hz = mmc_data->clock; + if (CONFIG_IS_ENABLED(CLK) && CONFIG_IS_ENABLED(DM_RESET)) { + ret = clk_prepare_enable(priv->clks[HI6220_DWMMC_CLK_BIU]); + if (ret) { + dev_err(dev, "Failed to enable biu clock(ret = %d).\n", ret); + return log_msg_ret("clk", ret); + } + + ret = clk_prepare_enable(priv->clks[HI6220_DWMMC_CLK_CIU]); + if (ret) { + dev_err(dev, "Failed to enable ciu clock(ret = %d).\n", ret); + return log_msg_ret("clk", ret); + } + + ret = reset_deassert_bulk(&priv->rsts); + if (ret) { + dev_err(dev, "Failed to deassert resets(ret = %d).\n", ret); + return log_msg_ret("rst", ret); + } + + host->bus_hz = clk_get_rate(priv->clks[HI6220_DWMMC_CLK_CIU]); + if (host->bus_hz <= 0) { + dev_err(dev, "Failed to get ciu clock rate(ret = %d).\n", ret); + return log_msg_ret("clk", ret); + } + } + dev_dbg(dev, "bus clock rate: %d.\n", host->bus_hz);
dwmci_setup_cfg(&plat->cfg, host, host->bus_hz, 400000); host->mmc = &plat->mmc;
--- base-commit: f7cca7ccc5117eaafcc2bde91ad1bed6fee7cfc3 change-id: 20240119-mmc-9cf7f3455cb4
Yang Xiwen via B4 Relay
