[U-Boot] [U-BOOT][PATCH 1/4] mflash : Change MG_BASE define to inline function
Signed-off-by: unsik Kim donari75@gmail.com --- drivers/block/mg_disk.c | 45 ++++++++++++++++++++++++--------------------- 1 files changed, 24 insertions(+), 21 deletions(-)
diff --git a/drivers/block/mg_disk.c b/drivers/block/mg_disk.c index bbfeeda..26b6a80 100644 --- a/drivers/block/mg_disk.c +++ b/drivers/block/mg_disk.c @@ -34,10 +34,13 @@
#define MG_RES_SEC ((CONFIG_MG_DISK_RES) << 1)
-#define MG_BASE (host.drv_data->base) - static struct mg_host host;
+static inline u32 mg_base(void) +{ + return host.drv_data->base; +} + static block_dev_desc_t mg_disk_dev = { .if_type = IF_TYPE_ATAPI, .part_type = PART_TYPE_UNKNOWN, @@ -122,7 +125,7 @@ static unsigned int mg_wait (u32 expect, u32 msec) reset_timer(); from = get_timer(0);
- status = readb(MG_BASE + MG_REG_STATUS); + status = readb(mg_base() + MG_REG_STATUS); do { cur = get_timer(from); if (status & MG_REG_STATUS_BIT_BUSY) { @@ -131,7 +134,7 @@ static unsigned int mg_wait (u32 expect, u32 msec) } else { /* Check the error condition! */ if (status & MG_REG_STATUS_BIT_ERROR) { - err = readb(MG_BASE + MG_REG_ERROR); + err = readb(mg_base() + MG_REG_ERROR); mg_dump_status("mg_wait", status, err); break; } @@ -144,7 +147,7 @@ static unsigned int mg_wait (u32 expect, u32 msec) if (status & MG_REG_STATUS_BIT_DATA_REQ) break; } - status = readb(MG_BASE + MG_REG_STATUS); + status = readb(mg_base() + MG_REG_STATUS); } while (cur < msec);
if (cur >= msec) @@ -160,15 +163,15 @@ static int mg_get_disk_id (void) u32 i, err, res; u16 *buff = (u16 *)iobuf;
- writeb(MG_CMD_ID, MG_BASE + MG_REG_COMMAND); + writeb(MG_CMD_ID, mg_base() + MG_REG_COMMAND); err = mg_wait(MG_REG_STATUS_BIT_DATA_REQ, 3000); if (err) return err;
for(i = 0; i < (MG_SECTOR_SIZE / sizeof(u32)) >> 1; i++) - buff[i] = readw(MG_BASE + MG_BUFF_OFFSET + i * 2); + buff[i] = readw(mg_base() + MG_BUFF_OFFSET + i * 2);
- writeb(MG_CMD_RD_CONF, MG_BASE + MG_REG_COMMAND); + writeb(MG_CMD_RD_CONF, mg_base() + MG_REG_COMMAND); err = mg_wait(MG_STAT_READY, 3000); if (err) return err; @@ -235,18 +238,18 @@ static int mg_disk_reset (void)
/* soft reset on */ writeb(MG_REG_CTRL_RESET | MG_REG_CTRL_INTR_DISABLE, - MG_BASE + MG_REG_DRV_CTRL); + mg_base() + MG_REG_DRV_CTRL); err = mg_wait(MG_REG_STATUS_BIT_BUSY, 3000); if(err) return err;
/* soft reset off */ - writeb(MG_REG_CTRL_INTR_DISABLE, MG_BASE + MG_REG_DRV_CTRL); + writeb(MG_REG_CTRL_INTR_DISABLE, mg_base() + MG_REG_DRV_CTRL); err = mg_wait(MG_STAT_READY, 3000); if(err) return err;
- init_status = readb(MG_BASE + MG_REG_STATUS) & 0xf; + init_status = readb(mg_base() + MG_REG_STATUS) & 0xf;
if (init_status == 0xf) return MG_ERR_INIT_STAT; @@ -265,13 +268,13 @@ static unsigned int mg_out(unsigned int sect_num, if (err) return err;
- writeb((u8)sect_cnt, MG_BASE + MG_REG_SECT_CNT); - writeb((u8)sect_num, MG_BASE + MG_REG_SECT_NUM); - writeb((u8)(sect_num >> 8), MG_BASE + MG_REG_CYL_LOW); - writeb((u8)(sect_num >> 16), MG_BASE + MG_REG_CYL_HIGH); + writeb((u8)sect_cnt, mg_base() + MG_REG_SECT_CNT); + writeb((u8)sect_num, mg_base() + MG_REG_SECT_NUM); + writeb((u8)(sect_num >> 8), mg_base() + MG_REG_CYL_LOW); + writeb((u8)(sect_num >> 16), mg_base() + MG_REG_CYL_HIGH); writeb((u8)((sect_num >> 24) | MG_REG_HEAD_LBA_MODE), - MG_BASE + MG_REG_DRV_HEAD); - writeb(cmd, MG_BASE + MG_REG_COMMAND); + mg_base() + MG_REG_DRV_HEAD); + writeb(cmd, mg_base() + MG_REG_COMMAND);
return err; } @@ -293,11 +296,11 @@ static unsigned int mg_do_read_sects(void *buff, u32 sect_num, u32 sect_cnt) /* TODO : u16 unaligned case */ for(j = 0; j < MG_SECTOR_SIZE >> 1; j++) { *(u16 *)buff_ptr = - readw(MG_BASE + MG_BUFF_OFFSET + (j << 1)); + readw(mg_base() + MG_BUFF_OFFSET + (j << 1)); buff_ptr += 2; }
MG_DBG("%u (0x%8.8x) sector read", sect_num + i, (sect_num + i) * MG_SECTOR_SIZE); @@ -426,11 +429,11 @@ static int mg_do_write_sects(void *buff, u32 sect_num, u32 sect_cnt) /* TODO : u16 unaligned case */ for(j = 0; j < MG_SECTOR_SIZE >> 1; j++) { writew(*(u16 *)buff_ptr, - MG_BASE + MG_BUFF_OFFSET + (j << 1)); + mg_base() + MG_BUFF_OFFSET + (j << 1)); buff_ptr += 2; }
- writeb(MG_CMD_WR_CONF, MG_BASE + MG_REG_COMMAND); + writeb(MG_CMD_WR_CONF, mg_base() + MG_REG_COMMAND);
MG_DBG("%u (0x%8.8x) sector write", sect_num + i, (sect_num + i) * MG_SECTOR_SIZE);
unsik Kim
