[PATCH v2 0/3] Apple M1 power management controller support
This series adds support for the power management controller found on Apple SoCs based on the device tree bindings submitted to upstream Linux. This is needed to enable power domains for devices that haven't been enabled by earlier boot stages.
ChangeLog:
v2: - Drop unrelated changes from device tree update
Mark Kettenis (3): arm: dts: apple: Update Apple M1 device trees arm: dts: apple: Add u-boot,dm-pre-reloc properties power: domain: Add Apple pmgr driver
arch/arm/Kconfig | 3 + arch/arm/dts/Makefile | 5 +- arch/arm/dts/t8103-j274-u-boot.dtsi | 1 + arch/arm/dts/t8103-j274.dts | 122 +-- arch/arm/dts/t8103-j293-u-boot.dtsi | 1 + arch/arm/dts/t8103-j293.dts | 92 +-- arch/arm/dts/t8103-j313-u-boot.dtsi | 1 + arch/arm/dts/t8103-j313.dts | 57 ++ arch/arm/dts/t8103-j456-u-boot.dtsi | 1 + arch/arm/dts/t8103-j456.dts | 71 ++ arch/arm/dts/t8103-j457-u-boot.dtsi | 1 + arch/arm/dts/t8103-j457.dts | 59 ++ arch/arm/dts/t8103-jxxx.dtsi | 140 ++++ arch/arm/dts/t8103-pmgr.dtsi | 1136 +++++++++++++++++++++++++++ arch/arm/dts/t8103-u-boot.dtsi | 25 + arch/arm/dts/t8103.dtsi | 585 +++++++------- drivers/power/domain/Kconfig | 8 + drivers/power/domain/Makefile | 1 + drivers/power/domain/apple-pmgr.c | 113 +++ 19 files changed, 1994 insertions(+), 428 deletions(-) create mode 100644 arch/arm/dts/t8103-j274-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j293-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j313-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j313.dts create mode 100644 arch/arm/dts/t8103-j456-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j456.dts create mode 100644 arch/arm/dts/t8103-j457-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j457.dts create mode 100644 arch/arm/dts/t8103-jxxx.dtsi create mode 100644 arch/arm/dts/t8103-pmgr.dtsi create mode 100644 arch/arm/dts/t8103-u-boot.dtsi create mode 100644 drivers/power/domain/apple-pmgr.c
This synchronizes the device trees with those that are in the process of being upstreamed into Linux 5.16 or proposed for Linux 5.17. This includes device trees for machines that were still missing.
There are still some differences that will hopefully be resolved soon.
Signed-off-by: Mark Kettenis kettenis@openbsd.org --- arch/arm/dts/Makefile | 5 +- arch/arm/dts/t8103-j274.dts | 122 +--- arch/arm/dts/t8103-j293.dts | 92 +-- arch/arm/dts/t8103-j313.dts | 57 ++ arch/arm/dts/t8103-j456.dts | 71 +++ arch/arm/dts/t8103-j457.dts | 59 ++ arch/arm/dts/t8103-jxxx.dtsi | 140 +++++ arch/arm/dts/t8103-pmgr.dtsi | 1136 ++++++++++++++++++++++++++++++++++ arch/arm/dts/t8103.dtsi | 585 +++++++++-------- 9 files changed, 1839 insertions(+), 428 deletions(-) create mode 100644 arch/arm/dts/t8103-j313.dts create mode 100644 arch/arm/dts/t8103-j456.dts create mode 100644 arch/arm/dts/t8103-j457.dts create mode 100644 arch/arm/dts/t8103-jxxx.dtsi create mode 100644 arch/arm/dts/t8103-pmgr.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7f622fedbd..35872e1574 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -34,7 +34,10 @@ dtb-$(CONFIG_TARGET_A7Y17LTE) += exynos78x0-axy17lte.dtb
dtb-$(CONFIG_ARCH_APPLE) += \ t8103-j274.dtb \ - t8103-j293.dtb + t8103-j293.dtb \ + t8103-j313.dtb \ + t8103-j456.dtb \ + t8103-j457.dtb
dtb-$(CONFIG_ARCH_DAVINCI) += \ da850-evm.dtb \ diff --git a/arch/arm/dts/t8103-j274.dts b/arch/arm/dts/t8103-j274.dts index aef1ae29b6..2144768147 100644 --- a/arch/arm/dts/t8103-j274.dts +++ b/arch/arm/dts/t8103-j274.dts @@ -10,126 +10,48 @@ /dts-v1/;
#include "t8103.dtsi" +#include "t8103-jxxx.dtsi"
/ { compatible = "apple,j274", "apple,t8103", "apple,arm-platform"; model = "Apple Mac mini (M1, 2020)";
aliases { - serial0 = &serial0; - ethernet0 = ð0; - wifi0 = &wifi0; - }; - - chosen { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - stdout-path = "serial0"; - - framebuffer0: framebuffer@0 { - compatible = "apple,simple-framebuffer", "simple-framebuffer"; - reg = <0 0 0 0>; /* To be filled by loader */ - /* Format properties will be added by loader */ - status = "disabled"; - }; - }; - - memory@800000000 { - device_type = "memory"; - reg = <0x8 0 0x2 0>; /* To be filled by loader */ + ethernet0 = ðernet0; }; };
-&serial0 { - status = "okay"; -}; - -&pcie0_dart_0 { - status = "okay"; -}; +/* + * Provide labels for the USB type C ports. + */
-&pcie0_dart_1 { - status = "okay"; +&typec0 { + label = "USB-C Back-left"; };
-&pcie0_dart_2 { - status = "okay"; +&typec1 { + label = "USB-C Back-right"; };
-&pcie0 { - status = "okay"; - - pci0: pci@0,0 { - device_type = "pci"; - reg = <0x0 0x0 0x0 0x0 0x0>; - pwren-gpios = <&smc 13 0>; - reset-gpios = <&pinctrl_ap 152 0>; - max-link-speed = <2>; - - #address-cells = <3>; - #size-cells = <2>; - ranges; - }; - - pci1: pci@1,0 { - device_type = "pci"; - reg = <0x800 0x0 0x0 0x0 0x0>; - reset-gpios = <&pinctrl_ap 153 0>; - max-link-speed = <2>; - - #address-cells = <3>; - #size-cells = <2>; - ranges; - }; - - pci2: pci@2,0 { - device_type = "pci"; - reg = <0x1000 0x0 0x0 0x0 0x0>; - reset-gpios = <&pinctrl_ap 33 0>; - max-link-speed = <1>; +/* + * Force the bus number assignments so that we can declare some of the + * on-board devices and properties that are populated by the bootloader + * (such as MAC addresses). + */
- #address-cells = <3>; - #size-cells = <2>; - ranges; - }; +&port01 { + bus-range = <2 2>; };
-&pci0 { - wifi0: network@0,0 { - reg = <0x10000 0x0 0x0 0x0 0x0>; - local-mac-address = [00 00 00 00 00 00]; - }; -}; - -&pci2 { - eth0: ethernet@0,0 { +&port02 { + bus-range = <3 3>; + ethernet0: ethernet@0,0 { reg = <0x30000 0x0 0x0 0x0 0x0>; - local-mac-address = [00 00 00 00 00 00]; + /* To be filled by the loader */ + local-mac-address = [00 10 18 00 00 00]; }; };
-&dwc3_0_dart_0 { - status = "okay"; -}; - -&dwc3_0_dart_1 { - status = "okay"; -}; - -&dwc3_0 { - status = "okay"; -}; - -&dwc3_1_dart_0 { - status = "okay"; -}; - -&dwc3_1_dart_1 { - status = "okay"; -}; - -&dwc3_1 { +&i2c2 { status = "okay"; }; diff --git a/arch/arm/dts/t8103-j293.dts b/arch/arm/dts/t8103-j293.dts index 4a22596cf4..cf92ee53e0 100644 --- a/arch/arm/dts/t8103-j293.dts +++ b/arch/arm/dts/t8103-j293.dts @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ OR MIT /* - * Apple Macbook Pro (M1, 2020) + * Apple MacBook Pro (13-inch, M1, 2020) * * target-type: J293 * @@ -10,88 +10,56 @@ /dts-v1/;
/ { compatible = "apple,j293", "apple,t8103", "apple,arm-platform"; - model = "Apple Macbook Pro (M1, 2020)"; - - aliases { - serial0 = &serial0; - wifi0 = &wifi0; - }; - - chosen { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - stdout-path = "serial0"; - - framebuffer0: framebuffer@0 { - compatible = "apple,simple-framebuffer", "simple-framebuffer"; - reg = <0 0 0 0>; /* To be filled by loader */ - /* Format properties will be added by loader */ - status = "disabled"; - }; - }; - - memory@800000000 { - device_type = "memory"; - reg = <0x8 0 0x2 0>; /* To be filled by loader */ - }; + model = "Apple MacBook Pro (13-inch, M1, 2020)"; };
-&serial0 { - status = "okay"; -}; +/* + * Provide labels for the USB type C ports. + */
-&pcie0_dart_0 { - status = "okay"; +&typec0 { + label = "USB-C Left-back"; };
-&pcie0 { - status = "okay"; - - pci0: pci@0,0 { - device_type = "pci"; - reg = <0x0 0x0 0x0 0x0 0x0>; - pwren-gpios = <&smc 13 0>; - reset-gpios = <&pinctrl_ap 152 0>; - max-link-speed = <2>; - - #address-cells = <3>; - #size-cells = <2>; - ranges; - }; +&typec1 { + label = "USB-C Left-front"; };
-&pci0 { - wifi0: network@0,0 { - reg = <0x10000 0x0 0x0 0x0 0x0>; - local-mac-address = [00 00 00 00 00 00]; - }; -}; +/* + * Remove unused PCIe ports and disable the associated DARTs. + */
-&dwc3_0_dart_0 { - status = "okay"; +&pcie0_dart_1 { + status = "disabled"; };
-&dwc3_0_dart_1 { - status = "okay"; +&pcie0_dart_2 { + status = "disabled"; };
-&dwc3_0 { - status = "okay"; -}; +/delete-node/ &port01; +/delete-node/ &port02;
-&dwc3_1_dart_0 { +&i2c2 { status = "okay"; };
-&dwc3_1_dart_1 { +&i2c4 { status = "okay"; };
-&dwc3_1 { +&spi3 { status = "okay"; + + keyboard@0 { + compatible = "apple,keyboard"; + spi-max-frequency = <2000000>; + reg = <0>; + interrupts-extended = <&pinctrl_nub 13 IRQ_TYPE_LEVEL_LOW>; + spien-gpios = <&pinctrl_ap 195 GPIO_ACTIVE_HIGH>; + }; }; diff --git a/arch/arm/dts/t8103-j313.dts b/arch/arm/dts/t8103-j313.dts new file mode 100644 index 0000000000..c8574d81c8 --- /dev/null +++ b/arch/arm/dts/t8103-j313.dts @@ -0,0 +1,57 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Apple MacBook Air (M1, 2020) + * + * target-type: J313 + * + * Copyright The Asahi Linux Contributors + */ + +/dts-v1/; + +#include "t8103.dtsi" +#include "t8103-jxxx.dtsi" + +/ { + compatible = "apple,j313", "apple,t8103", "apple,arm-platform"; + model = "Apple MacBook Air (M1, 2020)"; +}; + +/* + * Provide labels for the USB type C ports. + */ + +&typec0 { + label = "USB-C Left-back"; +}; + +&typec1 { + label = "USB-C Left-front"; +}; + +/* + * Remove unused PCIe ports and disable the associated DARTs. + */ + +&pcie0_dart_1 { + status = "disabled"; +}; + +&pcie0_dart_2 { + status = "disabled"; +}; + +/delete-node/ &port01; +/delete-node/ &port02; + +&spi3 { + status = "okay"; + + keyboard@0 { + compatible = "apple,keyboard"; + spi-max-frequency = <2000000>; + reg = <0>; + interrupts-extended = <&pinctrl_nub 13 IRQ_TYPE_LEVEL_LOW>; + spien-gpios = <&pinctrl_ap 195 GPIO_ACTIVE_HIGH>; + }; +}; diff --git a/arch/arm/dts/t8103-j456.dts b/arch/arm/dts/t8103-j456.dts new file mode 100644 index 0000000000..9814c97cd9 --- /dev/null +++ b/arch/arm/dts/t8103-j456.dts @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Apple iMac (24-inch, 4x USB-C, M1, 2020) + * + * target-type: J456 + * + * Copyright The Asahi Linux Contributors + */ + +/dts-v1/; + +#include "t8103.dtsi" +#include "t8103-jxxx.dtsi" + +/ { + compatible = "apple,j456", "apple,t8103", "apple,arm-platform"; + model = "Apple iMac (24-inch, 4x USB-C, M1, 2020)"; + + aliases { + ethernet0 = ðernet0; + }; +}; + +&i2c0 { + hpm2: usb-pd@3b { + compatible = "apple,cd321x"; + reg = <0x3b>; + interrupt-parent = <&pinctrl_ap>; + interrupts = <106 IRQ_TYPE_LEVEL_LOW>; + interrupt-names = "irq"; + }; + + hpm3: usb-pd@3c { + compatible = "apple,cd321x"; + reg = <0x3c>; + interrupt-parent = <&pinctrl_ap>; + interrupts = <106 IRQ_TYPE_LEVEL_LOW>; + interrupt-names = "irq"; + }; +}; + +/* + * Provide labels for the USB type C ports. + */ + +&typec0 { + label = "USB-C Back-right"; +}; + +&typec1 { + label = "USB-C Back-right-middle"; +}; + +/* + * Force the bus number assignments so that we can declare some of the + * on-board devices and properties that are populated by the bootloader + * (such as MAC addresses). + */ + +&port01 { + bus-range = <2 2>; +}; + +&port02 { + bus-range = <3 3>; + ethernet0: ethernet@0,0 { + reg = <0x30000 0x0 0x0 0x0 0x0>; + /* To be filled by the loader */ + local-mac-address = [00 10 18 00 00 00]; + }; +}; diff --git a/arch/arm/dts/t8103-j457.dts b/arch/arm/dts/t8103-j457.dts new file mode 100644 index 0000000000..0f4cc64374 --- /dev/null +++ b/arch/arm/dts/t8103-j457.dts @@ -0,0 +1,59 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Apple iMac (24-inch, 2x USB-C, M1, 2020) + * + * target-type: J457 + * + * Copyright The Asahi Linux Contributors + */ + +/dts-v1/; + +#include "t8103.dtsi" +#include "t8103-jxxx.dtsi" + +/ { + compatible = "apple,j457", "apple,t8103", "apple,arm-platform"; + model = "Apple iMac (24-inch, 2x USB-C, M1, 2020)"; + + aliases { + ethernet0 = ðernet0; + }; +}; + +/* + * Provide labels for the USB type C ports. + */ + +&typec0 { + label = "USB-C Back-right"; +}; + +&typec1 { + label = "USB-C Back-left"; +}; + +/* + * Force the bus number assignments so that we can declare some of the + * on-board devices and properties that are populated by the bootloader + * (such as MAC addresses). + */ + +&port02 { + bus-range = <3 3>; + ethernet0: ethernet@0,0 { + reg = <0x30000 0x0 0x0 0x0 0x0>; + /* To be filled by the loader */ + local-mac-address = [00 10 18 00 00 00]; + }; +}; + +/* + * Remove unused PCIe port and disable the associated DART. + */ + +&pcie0_dart_1 { + status = "disabled"; +}; + +/delete-node/ &port01; diff --git a/arch/arm/dts/t8103-jxxx.dtsi b/arch/arm/dts/t8103-jxxx.dtsi new file mode 100644 index 0000000000..8478090b34 --- /dev/null +++ b/arch/arm/dts/t8103-jxxx.dtsi @@ -0,0 +1,140 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Apple M1 Mac mini, MacBook Air/Pro, iMac 24" (M1, 2020/2021) + * + * This file contains parts common to all Apple M1 devices using the t8103. + * + * target-type: J274, J293, J313, J456, J457 + * + * Copyright The Asahi Linux Contributors + */ + +#include <dt-bindings/spmi/spmi.h> + +/ { + aliases { + serial0 = &serial0; + serial2 = &serial2; + wifi0 = &wifi0; + }; + + chosen { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + stdout-path = "serial0"; + + framebuffer0: framebuffer@0 { + compatible = "apple,simple-framebuffer", "simple-framebuffer"; + reg = <0 0 0 0>; /* To be filled by loader */ + /* Format properties will be added by loader */ + status = "disabled"; + }; + }; + + memory@800000000 { + device_type = "memory"; + reg = <0x8 0 0x2 0>; /* To be filled by loader */ + }; +}; + +&serial0 { + status = "okay"; +}; + +&serial2 { + status = "okay"; +}; + +&i2c0 { + hpm0: usb-pd@38 { + compatible = "apple,cd321x"; + reg = <0x38>; + interrupt-parent = <&pinctrl_ap>; + interrupts = <106 IRQ_TYPE_LEVEL_LOW>; + interrupt-names = "irq"; + + typec0: connector { + compatible = "usb-c-connector"; + power-role = "dual"; + data-role = "dual"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + typec0_con_hs: endpoint { + remote-endpoint = <&typec0_usb_hs>; + }; + }; + }; + }; + }; + + hpm1: usb-pd@3f { + compatible = "apple,cd321x"; + reg = <0x3f>; + interrupt-parent = <&pinctrl_ap>; + interrupts = <106 IRQ_TYPE_LEVEL_LOW>; + interrupt-names = "irq"; + + typec1: connector { + compatible = "usb-c-connector"; + power-role = "dual"; + data-role = "dual"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + typec1_con_hs: endpoint { + remote-endpoint = <&typec1_usb_hs>; + }; + }; + }; + }; + }; +}; + +/* USB controllers */ +&dwc3_0 { + port { + typec0_usb_hs: endpoint { + remote-endpoint = <&typec0_con_hs>; + }; + }; +}; + +&dwc3_1 { + port { + typec1_usb_hs: endpoint { + remote-endpoint = <&typec1_con_hs>; + }; + }; +}; + +/* + * Force the bus number assignments so that we can declare some of the + * on-board devices and properties that are populated by the bootloader + * (such as MAC addresses). + */ +&port00 { + bus-range = <1 1>; + pwren-gpios = <&smc 13 0>; + wifi0: network@0,0 { + reg = <0x10000 0x0 0x0 0x0 0x0>; + local-mac-address = [00 00 00 00 00 00]; + }; +}; + +&spmi { + status = "okay"; + + pmu@f { + compatible = "apple,sera-pmu"; + reg = <0xf SPMI_USID>; + }; +}; diff --git a/arch/arm/dts/t8103-pmgr.dtsi b/arch/arm/dts/t8103-pmgr.dtsi new file mode 100644 index 0000000000..1310be74df --- /dev/null +++ b/arch/arm/dts/t8103-pmgr.dtsi @@ -0,0 +1,1136 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * PMGR Power domains for the Apple T8103 "M1" SoC + * + * Copyright The Asahi Linux Contributors + */ + + +&pmgr { + ps_sbr: power-controller@100 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x100 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "sbr"; + apple,always-on; /* Core device */ + }; + + ps_aic: power-controller@108 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x108 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "aic"; + apple,always-on; /* Core device */ + }; + + ps_dwi: power-controller@110 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x110 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dwi"; + apple,always-on; /* Core device */ + }; + + ps_soc_spmi0: power-controller@118 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x118 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "soc_spmi0"; + }; + + ps_soc_spmi1: power-controller@120 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x120 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "soc_spmi1"; + }; + + ps_soc_spmi2: power-controller@128 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x128 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "soc_spmi2"; + }; + + ps_gpio: power-controller@130 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x130 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "gpio"; + }; + + ps_pms_busif: power-controller@138 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x138 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "pms_busif"; + apple,always-on; /* Core device */ + }; + + ps_pms: power-controller@140 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x140 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "pms"; + apple,always-on; /* Core device */ + }; + + ps_pms_fpwm0: power-controller@148 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x148 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "pms_fpwm0"; + power-domains = <&ps_pms>; + }; + + ps_pms_fpwm1: power-controller@150 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x150 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "pms_fpwm1"; + power-domains = <&ps_pms>; + }; + + ps_pms_fpwm2: power-controller@158 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x158 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "pms_fpwm2"; + power-domains = <&ps_pms>; + }; + + ps_pms_fpwm3: power-controller@160 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x160 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "pms_fpwm3"; + power-domains = <&ps_pms>; + }; + + ps_pms_fpwm4: power-controller@168 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x168 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "pms_fpwm4"; + power-domains = <&ps_pms>; + }; + + ps_soc_dpe: power-controller@170 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x170 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "soc_dpe"; + apple,always-on; /* Core device */ + }; + + ps_pmgr_soc_ocla: power-controller@178 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x178 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "pmgr_soc_ocla"; + }; + + ps_ispsens0: power-controller@180 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x180 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "ispsens0"; + }; + + ps_ispsens1: power-controller@188 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x188 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "ispsens1"; + }; + + ps_ispsens2: power-controller@190 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x190 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "ispsens2"; + }; + + ps_ispsens3: power-controller@198 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x198 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "ispsens3"; + }; + + ps_pcie_ref: power-controller@1a0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1a0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "pcie_ref"; + }; + + ps_aft0: power-controller@1a8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1a8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "aft0"; + }; + + ps_devc0_ivdmc: power-controller@1b0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1b0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "devc0_ivdmc"; + }; + + ps_imx: power-controller@1b8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1b8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "imx"; + apple,always-on; /* Apple fabric, critical block */ + }; + + ps_sio_busif: power-controller@1c0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1c0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "sio_busif"; + }; + + ps_sio: power-controller@1c8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1c8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "sio"; + power-domains = <&ps_sio_busif>; + }; + + ps_sio_cpu: power-controller@1d0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1d0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "sio_cpu"; + power-domains = <&ps_sio>; + }; + + ps_fpwm0: power-controller@1d8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1d8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "fpwm0"; + }; + + ps_fpwm1: power-controller@1e0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1e0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "fpwm1"; + }; + + ps_fpwm2: power-controller@1e8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1e8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "fpwm2"; + }; + + ps_i2c0: power-controller@1f0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1f0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "i2c0"; + power-domains = <&ps_sio>; + }; + + ps_i2c1: power-controller@1f8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x1f8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "i2c1"; + power-domains = <&ps_sio>; + }; + + ps_i2c2: power-controller@200 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x200 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "i2c2"; + power-domains = <&ps_sio>; + }; + + ps_i2c3: power-controller@208 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x208 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "i2c3"; + power-domains = <&ps_sio>; + }; + + ps_i2c4: power-controller@210 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x210 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "i2c4"; + power-domains = <&ps_sio>; + }; + + ps_spi_p: power-controller@218 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x218 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "spi_p"; + power-domains = <&ps_sio>; + }; + + ps_uart_p: power-controller@220 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x220 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "uart_p"; + power-domains = <&ps_sio>; + }; + + ps_audio_p: power-controller@228 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x228 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "audio_p"; + power-domains = <&ps_sio>; + }; + + ps_sio_adma: power-controller@230 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x230 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "sio_adma"; + power-domains = <&ps_sio>, <&ps_pms>; + }; + + ps_aes: power-controller@238 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x238 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "aes"; + power-domains = <&ps_sio>; + }; + + ps_spi0: power-controller@240 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x240 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "spi0"; + power-domains = <&ps_sio>, <&ps_spi_p>; + }; + + ps_spi1: power-controller@248 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x248 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "spi1"; + power-domains = <&ps_sio>, <&ps_spi_p>; + }; + + ps_spi2: power-controller@250 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x250 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "spi2"; + power-domains = <&ps_sio>, <&ps_spi_p>; + }; + + ps_spi3: power-controller@258 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x258 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "spi3"; + power-domains = <&ps_sio>, <&ps_spi_p>; + }; + + ps_uart_n: power-controller@268 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x268 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "uart_n"; + power-domains = <&ps_uart_p>; + }; + + ps_uart0: power-controller@270 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x270 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "uart0"; + power-domains = <&ps_uart_p>; + }; + + ps_uart1: power-controller@278 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x278 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "uart1"; + power-domains = <&ps_uart_p>; + }; + + ps_uart2: power-controller@280 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x280 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "uart2"; + power-domains = <&ps_uart_p>; + }; + + ps_uart3: power-controller@288 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x288 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "uart3"; + power-domains = <&ps_uart_p>; + }; + + ps_uart4: power-controller@290 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x290 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "uart4"; + power-domains = <&ps_uart_p>; + }; + + ps_uart5: power-controller@298 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x298 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "uart5"; + power-domains = <&ps_uart_p>; + }; + + ps_uart6: power-controller@2a0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2a0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "uart6"; + power-domains = <&ps_uart_p>; + }; + + ps_uart7: power-controller@2a8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2a8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "uart7"; + power-domains = <&ps_uart_p>; + }; + + ps_uart8: power-controller@2b0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2b0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "uart8"; + power-domains = <&ps_uart_p>; + }; + + ps_mca0: power-controller@2b8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2b8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "mca0"; + power-domains = <&ps_audio_p>, <&ps_sio_adma>; + }; + + ps_mca1: power-controller@2c0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2c0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "mca1"; + power-domains = <&ps_audio_p>, <&ps_sio_adma>; + }; + + ps_mca2: power-controller@2c8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2c8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "mca2"; + power-domains = <&ps_audio_p>, <&ps_sio_adma>; + }; + + ps_mca3: power-controller@2d0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2d0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "mca3"; + power-domains = <&ps_audio_p>, <&ps_sio_adma>; + }; + + ps_mca4: power-controller@2d8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2d8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "mca4"; + power-domains = <&ps_audio_p>, <&ps_sio_adma>; + }; + + ps_mca5: power-controller@2e0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2e0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "mca5"; + power-domains = <&ps_audio_p>, <&ps_sio_adma>; + }; + + ps_dpa0: power-controller@2e8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2e8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dpa0"; + power-domains = <&ps_audio_p>; + }; + + ps_dpa1: power-controller@2f0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2f0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dpa1"; + power-domains = <&ps_audio_p>; + }; + + ps_mcc: power-controller@2f8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x2f8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "mcc"; + apple,always-on; /* Memory controller */ + }; + + ps_spi4: power-controller@260 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x260 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "spi4"; + power-domains = <&ps_sio>, <&ps_spi_p>; + }; + + ps_dcs0: power-controller@300 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x300 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dcs0"; + apple,always-on; /* LPDDR4 interface */ + }; + + ps_dcs1: power-controller@310 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x310 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dcs1"; + apple,always-on; /* LPDDR4 interface */ + }; + + ps_dcs2: power-controller@308 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x308 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dcs2"; + apple,always-on; /* LPDDR4 interface */ + }; + + ps_dcs3: power-controller@318 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x318 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dcs3"; + apple,always-on; /* LPDDR4 interface */ + }; + + ps_smx: power-controller@340 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x340 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "smx"; + apple,always-on; /* Apple fabric, critical block */ + }; + + ps_apcie: power-controller@348 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x348 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "apcie"; + power-domains = <&ps_imx>, <&ps_pcie_ref>; + }; + + ps_rmx: power-controller@350 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x350 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "rmx"; + /* Apple Fabric, display/image stuff: this can power down */ + }; + + ps_mmx: power-controller@358 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x358 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "mmx"; + /* Apple Fabric, media stuff: this can power down */ + }; + + ps_disp0_fe: power-controller@360 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x360 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "disp0_fe"; + power-domains = <&ps_rmx>; + apple,always-on; /* TODO: figure out if we can enable PM here */ + }; + + ps_dispext_fe: power-controller@368 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x368 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dispext_fe"; + power-domains = <&ps_rmx>; + }; + + ps_dispext_cpu0: power-controller@378 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x378 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dispext_cpu0"; + power-domains = <&ps_dispext_fe>; + }; + + ps_jpg: power-controller@3c0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x3c0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "jpg"; + power-domains = <&ps_mmx>; + }; + + ps_msr: power-controller@3c8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x3c8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "msr"; + power-domains = <&ps_mmx>; + }; + + ps_msr_ase_core: power-controller@3d0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x3d0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "msr_ase_core"; + }; + + ps_pmp: power-controller@3d8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x3d8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "pmp"; + }; + + ps_pms_sram: power-controller@3e0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x3e0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "pms_sram"; + }; + + ps_apcie_gp: power-controller@3e8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x3e8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "apcie_gp"; + power-domains = <&ps_apcie>; + }; + + ps_ans2: power-controller@3f0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x3f0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "ans2"; + /* + * The ADT makes ps_apcie_st depend on ps_ans2 instead, but this + * doesn't make much sense since ANS2 uses APCIE_ST. + */ + power-domains = <&ps_apcie_st>; + }; + + ps_gfx: power-controller@3f8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x3f8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "gfx"; + }; + + ps_dcs4: power-controller@320 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x320 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dcs4"; + apple,always-on; /* LPDDR4 interface */ + }; + + ps_dcs5: power-controller@330 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x330 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dcs5"; + apple,always-on; /* LPDDR4 interface */ + }; + + ps_dcs6: power-controller@328 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x328 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dcs6"; + apple,always-on; /* LPDDR4 interface */ + }; + + ps_dcs7: power-controller@338 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x338 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dcs7"; + apple,always-on; /* LPDDR4 interface */ + }; + + ps_dispdfr_fe: power-controller@3a8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x3a8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dispdfr_fe"; + power-domains = <&ps_rmx>; + }; + + ps_dispdfr_be: power-controller@3b0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x3b0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "dispdfr_be"; + power-domains = <&ps_dispdfr_fe>; + }; + + ps_mipi_dsi: power-controller@3b8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x3b8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "mipi_dsi"; + power-domains = <&ps_dispdfr_be>; + }; + + ps_isp_sys: power-controller@400 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x400 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "isp_sys"; + power-domains = <&ps_rmx>; + }; + + ps_venc_sys: power-controller@408 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x408 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "venc_sys"; + power-domains = <&ps_mmx>; + }; + + ps_avd_sys: power-controller@410 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x410 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "avd_sys"; + power-domains = <&ps_mmx>; + }; + + ps_apcie_st: power-controller@418 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x418 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "apcie_st"; + power-domains = <&ps_apcie>; + }; + + ps_ane_sys: power-controller@470 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x470 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "ane_sys"; + }; + + ps_atc0_common: power-controller@420 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x420 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc0_common"; + }; + + ps_atc0_pcie: power-controller@428 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x428 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc0_pcie"; + power-domains = <&ps_atc0_common>; + }; + + ps_atc0_cio: power-controller@430 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x430 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc0_cio"; + power-domains = <&ps_atc0_common>; + }; + + ps_atc0_cio_pcie: power-controller@438 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x438 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc0_cio_pcie"; + power-domains = <&ps_atc0_cio>; + }; + + ps_atc0_cio_usb: power-controller@440 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x440 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc0_cio_usb"; + power-domains = <&ps_atc0_cio>; + }; + + ps_atc1_common: power-controller@448 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x448 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc1_common"; + }; + + ps_atc1_pcie: power-controller@450 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x450 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc1_pcie"; + power-domains = <&ps_atc1_common>; + }; + + ps_atc1_cio: power-controller@458 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x458 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc1_cio"; + power-domains = <&ps_atc1_common>; + }; + + ps_atc1_cio_pcie: power-controller@460 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x460 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc1_cio_pcie"; + power-domains = <&ps_atc1_cio>; + }; + + ps_atc1_cio_usb: power-controller@468 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x468 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc1_cio_usb"; + power-domains = <&ps_atc1_cio>; + }; + + ps_sep: power-controller@c00 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0xc00 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "sep"; + apple,always-on; /* Locked on */ + }; + + ps_venc_dma: power-controller@8000 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x8000 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "venc_dma"; + power-domains = <&ps_venc_sys>; + }; + + ps_venc_pipe4: power-controller@8008 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x8008 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "venc_pipe4"; + power-domains = <&ps_venc_dma>; + }; + + ps_venc_pipe5: power-controller@8010 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x8010 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "venc_pipe5"; + power-domains = <&ps_venc_dma>; + }; + + ps_venc_me0: power-controller@8018 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x8018 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "venc_me0"; + power-domains = <&ps_venc_pipe4>, <&ps_venc_pipe5>; + }; + + ps_venc_me1: power-controller@8020 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x8020 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "venc_me1"; + power-domains = <&ps_venc_pipe4>, <&ps_venc_pipe5>; + }; + + ps_ane_sys_cpu: power-controller@c000 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0xc000 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "ane_sys_cpu"; + power-domains = <&ps_ane_sys>; + }; + + ps_disp0_cpu0: power-controller@10018 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x10018 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "disp0_cpu0"; + power-domains = <&ps_disp0_fe>; + apple,always-on; /* TODO: figure out if we can enable PM here */ + }; +}; + +&pmgr_mini { + ps_debug: power-controller@58 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x58 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "debug"; + apple,always-on; /* Core AON device */ + }; + + ps_nub_spmi0: power-controller@60 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x60 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "nub_spmi0"; + apple,always-on; /* Core AON device */ + }; + + ps_nub_aon: power-controller@70 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x70 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "nub_aon"; + apple,always-on; /* Core AON device */ + }; + + ps_nub_gpio: power-controller@80 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x80 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "nub_gpio"; + apple,always-on; /* Core AON device */ + }; + + ps_nub_fabric: power-controller@a8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0xa8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "nub_fabric"; + apple,always-on; /* Core AON device */ + }; + + ps_nub_sram: power-controller@b0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0xb0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "nub_sram"; + apple,always-on; /* Core AON device */ + }; + + ps_debug_usb: power-controller@b8 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0xb8 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "debug_usb"; + apple,always-on; /* Core AON device */ + power-domains = <&ps_debug>; + }; + + ps_debug_auth: power-controller@c0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0xc0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "debug_auth"; + apple,always-on; /* Core AON device */ + power-domains = <&ps_debug>; + }; + + ps_nub_spmi1: power-controller@68 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x68 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "nub_spmi1"; + apple,always-on; /* Core AON device */ + }; + + ps_msg: power-controller@78 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x78 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "msg"; + }; + + ps_atc0_usb_aon: power-controller@88 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x88 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc0_usb_aon"; + }; + + ps_atc1_usb_aon: power-controller@90 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x90 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc1_usb_aon"; + }; + + ps_atc0_usb: power-controller@98 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0x98 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc0_usb"; + power-domains = <&ps_atc0_usb_aon>, <&ps_atc0_common>; + }; + + ps_atc1_usb: power-controller@a0 { + compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; + reg = <0xa0 4>; + #power-domain-cells = <0>; + #reset-cells = <0>; + label = "atc1_usb"; + power-domains = <&ps_atc1_usb_aon>, <&ps_atc1_common>; + }; +}; diff --git a/arch/arm/dts/t8103.dtsi b/arch/arm/dts/t8103.dtsi index 03d8436fec..1f029cb8fd 100644 --- a/arch/arm/dts/t8103.dtsi +++ b/arch/arm/dts/t8103.dtsi @@ -11,7 +11,6 @@ #include <dt-bindings/interrupt-controller/apple-aic.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/pinctrl/apple.h> -#include <dt-bindings/spmi/spmi.h>
/ { compatible = "apple,t8103", "apple,arm-platform"; @@ -91,11 +90,11 @@ timer { compatible = "arm,armv8-timer"; interrupt-parent = <&aic>; - interrupt-names = "hyp-phys", "hyp-virt", "phys", "virt"; - interrupts = <AIC_FIQ AIC_TMR_HV_PHYS IRQ_TYPE_LEVEL_HIGH>, - <AIC_FIQ AIC_TMR_HV_VIRT IRQ_TYPE_LEVEL_HIGH>, - <AIC_FIQ AIC_TMR_GUEST_PHYS IRQ_TYPE_LEVEL_HIGH>, - <AIC_FIQ AIC_TMR_GUEST_VIRT IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "phys", "virt", "hyp-phys", "hyp-virt"; + interrupts = <AIC_FIQ AIC_TMR_GUEST_PHYS IRQ_TYPE_LEVEL_HIGH>, + <AIC_FIQ AIC_TMR_GUEST_VIRT IRQ_TYPE_LEVEL_HIGH>, + <AIC_FIQ AIC_TMR_HV_PHYS IRQ_TYPE_LEVEL_HIGH>, + <AIC_FIQ AIC_TMR_HV_VIRT IRQ_TYPE_LEVEL_HIGH>; };
clkref: clock-ref { @@ -111,18 +110,100 @@ #size-cells = <2>;
ranges; - dma-ranges; - dma-coherent; nonposted-mmio;
+ i2c0: i2c@235010000 { + compatible = "apple,t8103-i2c", "apple,i2c"; + reg = <0x2 0x35010000 0x0 0x4000>; + clocks = <&clkref>; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 627 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-0 = <&i2c0_pins>; + pinctrl-names = "default"; + #address-cells = <0x1>; + #size-cells = <0x0>; + power-domains = <&ps_i2c0>; + }; + + i2c1: i2c@235014000 { + compatible = "apple,t8103-i2c", "apple,i2c"; + reg = <0x2 0x35014000 0x0 0x4000>; + clocks = <&clkref>; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 628 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-0 = <&i2c1_pins>; + pinctrl-names = "default"; + #address-cells = <0x1>; + #size-cells = <0x0>; + power-domains = <&ps_i2c1>; + }; + + i2c2: i2c@235018000 { + compatible = "apple,t8103-i2c", "apple,i2c"; + reg = <0x2 0x35018000 0x0 0x4000>; + clocks = <&clkref>; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 629 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-0 = <&i2c2_pins>; + pinctrl-names = "default"; + #address-cells = <0x1>; + #size-cells = <0x0>; + power-domains = <&ps_i2c2>; + status = "disabled"; /* not used in all devices */ + }; + + i2c3: i2c@23501c000 { + compatible = "apple,t8103-i2c", "apple,i2c"; + reg = <0x2 0x3501c000 0x0 0x4000>; + clocks = <&clkref>; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 630 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-0 = <&i2c3_pins>; + pinctrl-names = "default"; + #address-cells = <0x1>; + #size-cells = <0x0>; + power-domains = <&ps_i2c3>; + }; + + i2c4: i2c@235020000 { + compatible = "apple,t8103-i2c", "apple,i2c"; + reg = <0x2 0x35020000 0x0 0x4000>; + clocks = <&clkref>; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 631 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-0 = <&i2c4_pins>; + pinctrl-names = "default"; + #address-cells = <0x1>; + #size-cells = <0x0>; + power-domains = <&ps_i2c4>; + status = "disabled"; /* only used in J293 */ + }; + + spi3: spi@23510c000 { + compatible = "apple,t8103-spi", "apple,spi"; + reg = <0x2 0x3510c000 0x0 0x4000>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkref>; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 617 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&ps_spi3>; + cs-gpios = <&pinctrl_ap 49 GPIO_ACTIVE_LOW>; + status = "disabled"; + }; + serial0: serial@235200000 { compatible = "apple,s5l-uart"; reg = <0x2 0x35200000 0x0 0x1000>; reg-io-width = <4>; interrupt-parent = <&aic>; interrupts = <AIC_IRQ 605 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clkref>, <&clkref>, <&clkref>; - clock-names = "uart", "clk_uart_baud0", "clk_uart_baud1"; + /* + * TODO: figure out the clocking properly, there may + * be a third selectable clock. + */ + clocks = <&clkref>, <&clkref>; + clock-names = "uart", "clk_uart_baud0"; power-domains = <&ps_uart0>; status = "disabled"; }; @@ -133,8 +214,8 @@ reg-io-width = <4>; interrupt-parent = <&aic>; interrupts = <AIC_IRQ 607 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clkref>, <&clkref>, <&clkref>; - clock-names = "uart", "clk_uart_baud0", "clk_uart_baud1"; + clocks = <&clkref>, <&clkref>; + clock-names = "uart", "clk_uart_baud0"; power-domains = <&ps_uart2>; status = "disabled"; }; @@ -144,131 +225,28 @@ #interrupt-cells = <3>; interrupt-controller; reg = <0x2 0x3b100000 0x0 0x8000>; + power-domains = <&ps_aic>; };
- pmgr: power-controller@23b700000 { + pmgr: power-management@23b700000 { compatible = "apple,t8103-pmgr", "apple,pmgr", "syscon", "simple-mfd"; #address-cells = <1>; - #size-cells = <0>; - - reg = <0x2 0x3b700000 0x0 0x14000>; - - ps_pcie_ref: power-controller@1a0 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x1a0>; - #power-domain-cells = <0>; - #reset-cells = <0>; - apple,domain-name = "pcie_ref"; - }; - - ps_imx: power-controller@1b8 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x1b8>; - #power-domain-cells = <0>; - #reset-cells = <0>; - apple,domain-name = "imx"; - apple,always-on; - }; - - ps_sio: power-controller@1c0 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x1c0>; - #power-domain-cells = <0>; - #reset-cells = <0>; - apple,domain-name = "sio"; - }; - - ps_uart_p: power-controller@220 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x220>; - #power-domain-cells = <0>; - #reset-cells = <0>; - power-domains = <&ps_sio>; - apple,domain-name = "uart_p"; - }; - - ps_uart0: power-controller@270 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x270>; - #power-domain-cells = <0>; - #reset-cells = <0>; - power-domains = <&ps_uart_p>; - apple,domain-name = "uart0"; - }; - - ps_uart1: power-controller@278 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x278>; - #power-domain-cells = <0>; - #reset-cells = <0>; - apple,domain-name = "uart1"; - power-domains = <&ps_uart_p>; - }; - - ps_uart2: power-controller@280 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x280>; - #power-domain-cells = <0>; - #reset-cells = <0>; - apple,domain-name = "uart2"; - power-domains = <&ps_uart_p>; - }; - - ps_uart3: power-controller@288 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x288>; - #power-domain-cells = <0>; - #reset-cells = <0>; - apple,domain-name = "uart3"; - power-domains = <&ps_uart_p>; - }; - - ps_apcie: power-controller@348 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x348>; - #power-domain-cells = <0>; - #reset-cells = <0>; - apple,domain-name = "apcie"; - power-domains = <&ps_imx>; - }; - - ps_apcie_gp: power-controller@3e8 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x3e8>; - #power-domain-cells = <0>; - #reset-cells = <0>; - apple,domain-name = "apcie_gp"; - power-domains = <&ps_apcie>; - }; - - ps_ans2: power-controller@3f0 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x3f0>; - #power-domain-cells = <0>; - #reset-cells = <0>; - apple,domain-name = "ans2"; - power-domains = <&ps_apcie_st>; - }; - - ps_apcie_st: power-controller@418 { - compatible = "apple,t8103-pmgr-pwrstate", "apple,pmgr-pwrstate"; - reg = <0x418>; - #power-domain-cells = <0>; - #reset-cells = <0>; - apple,domain-name = "apcie_st"; - power-domains = <&ps_apcie>; - }; + #size-cells = <1>; + reg = <0x2 0x3b700000 0 0x14000>; };
pinctrl_ap: pinctrl@23c100000 { compatible = "apple,t8103-pinctrl", "apple,pinctrl"; reg = <0x2 0x3c100000 0x0 0x100000>; + power-domains = <&ps_gpio>;
gpio-controller; #gpio-cells = <2>; gpio-ranges = <&pinctrl_ap 0 0 212>; + apple,npins = <212>;
interrupt-controller; + #interrupt-cells = <2>; interrupt-parent = <&aic>; interrupts = <AIC_IRQ 190 IRQ_TYPE_LEVEL_HIGH>, <AIC_IRQ 191 IRQ_TYPE_LEVEL_HIGH>, @@ -278,18 +256,55 @@ <AIC_IRQ 195 IRQ_TYPE_LEVEL_HIGH>, <AIC_IRQ 196 IRQ_TYPE_LEVEL_HIGH>;
- i2c0_pins: i2c0_pins { - pinmux = <APPLE_PINMUX(188, 1)>, - <APPLE_PINMUX(192, 1)>; + i2c0_pins: i2c0-pins { + pinmux = <APPLE_PINMUX(192, 1)>, + <APPLE_PINMUX(188, 1)>; + }; + + i2c1_pins: i2c1-pins { + pinmux = <APPLE_PINMUX(201, 1)>, + <APPLE_PINMUX(199, 1)>; + }; + + i2c2_pins: i2c2-pins { + pinmux = <APPLE_PINMUX(163, 1)>, + <APPLE_PINMUX(162, 1)>; + }; + + i2c3_pins: i2c3-pins { + pinmux = <APPLE_PINMUX(73, 1)>, + <APPLE_PINMUX(72, 1)>; + }; + + i2c4_pins: i2c4-pins { + pinmux = <APPLE_PINMUX(135, 1)>, + <APPLE_PINMUX(134, 1)>; };
pcie_pins: pcie-pins { pinmux = <APPLE_PINMUX(150, 1)>, - <APPLE_PINMUX(151, 1)>, + <APPLE_PINMUX(151, 1)>, <APPLE_PINMUX(32, 1)>; }; };
+ spmi: spmi@23d0d9300 { + compatible = "apple,t8103-spmi", "apple,spmi"; + reg = <0x2 0x3d0d9300 0x0 0x100>; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 343 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <2>; + #size-cells = <0>; + status = "disabled"; + }; + + pmgr_mini: power-management@23d280000 { + compatible = "apple,t8103-pmgr", "apple,pmgr", "syscon", "simple-mfd"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x2 0x3d280000 0 0x4000>; + }; + pinctrl_aop: pinctrl@24a820000 { compatible = "apple,t8103-pinctrl", "apple,pinctrl"; reg = <0x2 0x4a820000 0x0 0x4000>; @@ -297,8 +312,10 @@ gpio-controller; #gpio-cells = <2>; gpio-ranges = <&pinctrl_aop 0 0 42>; + apple,npins = <42>;
interrupt-controller; + #interrupt-cells = <2>; interrupt-parent = <&aic>; interrupts = <AIC_IRQ 268 IRQ_TYPE_LEVEL_HIGH>, <AIC_IRQ 269 IRQ_TYPE_LEVEL_HIGH>, @@ -312,12 +329,15 @@ pinctrl_nub: pinctrl@23d1f0000 { compatible = "apple,t8103-pinctrl", "apple,pinctrl"; reg = <0x2 0x3d1f0000 0x0 0x4000>; + power-domains = <&ps_nub_gpio>;
gpio-controller; #gpio-cells = <2>; gpio-ranges = <&pinctrl_nub 0 0 23>; + apple,npins = <23>;
interrupt-controller; + #interrupt-cells = <2>; interrupt-parent = <&aic>; interrupts = <AIC_IRQ 330 IRQ_TYPE_LEVEL_HIGH>, <AIC_IRQ 331 IRQ_TYPE_LEVEL_HIGH>, @@ -343,8 +363,10 @@ gpio-controller; #gpio-cells = <2>; gpio-ranges = <&pinctrl_smc 0 0 16>; + apple,npins = <16>;
interrupt-controller; + #interrupt-cells = <2>; interrupt-parent = <&aic>; interrupts = <AIC_IRQ 391 IRQ_TYPE_LEVEL_HIGH>, <AIC_IRQ 392 IRQ_TYPE_LEVEL_HIGH>, @@ -355,100 +377,124 @@ <AIC_IRQ 397 IRQ_TYPE_LEVEL_HIGH>; };
- i2c0: i2c@20a110000 { - compatible = "apple,i2c-v0"; - reg = <0x2 0x35010000 0x0 0x4000>; + smc_mbox: mbox@23e408000 { + compatible = "apple,t8103-asc-mailbox"; + reg = <0x2 0x3e408000 0x0 0x4000>; interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 627 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clkref>; - pinctrl-0 = <&i2c0_pins>; - pinctrl-names = "default"; - #address-cells = <0x1>; - #size-cells = <0x0>; + interrupts = <AIC_IRQ 400 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 401 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 402 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 403 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "send-empty", "send-not-empty", + "recv-empty", "recv-not-empty"; + #mbox-cells = <0>; + };
- hpm0: hpm@38 { - compatible = "ti,tps6598x"; - reg = <0x38>; - }; + smc: smc@23e050000 { + compatible = "apple,smc-m1"; + reg = <0x2 0x3e050000 0x0 0x4000>, + <0x2 0x3e400000 0x0 0x4000>; + reg-names = "smc", "coproc"; + mboxes = <&smc_mbox>; + gpio-controller; + #gpio-cells = <2>; + gpio-13 = <0x00800000>; + };
- hpm1: hpm@3f { - compatible = "ti,tps6598x"; - reg = <0x3f>; - }; - }; + dwc3_0_dart_0: iommu@382f00000 { + compatible = "apple,t8103-dart"; + reg = <0x3 0x82f00000 0x0 0x4000>; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 781 IRQ_TYPE_LEVEL_HIGH>; + #iommu-cells = <1>; + power-domains = <&ps_atc0_usb>; + };
- ans_mbox: mbox@277400000 { - compatible = "apple,iop-mailbox-m1"; - reg = <0x2 0x77400000 0x0 0x20000>; + dwc3_0_dart_1: iommu@382f80000 { + compatible = "apple,t8103-dart"; + reg = <0x3 0x82f80000 0x0 0x4000>; interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 583 IRQ_TYPE_LEVEL_HIGH>, - <AIC_IRQ 586 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&ps_ans2>; - #mbox-cells = <1>; - endpoints = <32>; + interrupts = <AIC_IRQ 781 IRQ_TYPE_LEVEL_HIGH>; + #iommu-cells = <1>; + power-domains = <&ps_atc0_usb>; };
- ans@27bcc0000 { - compatible = "apple,nvme-m1"; - reg = <0x2 0x7bcc0000 0x0 0x40000>, - <0x2 0x7bc50000 0x0 0x4000>; + dwc3_0: usb@382280000 { + compatible = "apple,t8103-dwc3", "apple,dwc3", "snps,dwc3"; + reg = <0x3 0x82280000 0x0 0x100000>; interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 590 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&ps_apcie_st>; - mboxes = <&ans_mbox 32>; + interrupts = <AIC_IRQ 777 IRQ_TYPE_LEVEL_HIGH>; + usb-role-switch; + role-switch-default-mode = "host"; + iommus = <&dwc3_0_dart_0 0>, <&dwc3_0_dart_1 1>; + power-domains = <&ps_atc0_usb>; };
- pcie0_dart_0: iommu@681008000 { - compatible = "apple,t8103-dart", "apple,dart-m1"; - reg = <0x6 0x81008000 0x0 0x4000>; + dwc3_1_dart_0: iommu@502f00000 { + compatible = "apple,t8103-dart"; + reg = <0x5 0x02f00000 0x0 0x4000>; interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 696 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <AIC_IRQ 861 IRQ_TYPE_LEVEL_HIGH>; #iommu-cells = <1>; - status = "disabled"; + power-domains = <&ps_atc1_usb>; };
- pcie0_dart_1: iommu@682008000 { - compatible = "apple,t8103-dart", "apple,dart-m1"; - reg = <0x6 0x82008000 0x0 0x4000>; + dwc3_1_dart_1: iommu@502f80000 { + compatible = "apple,t8103-dart"; + reg = <0x5 0x02f80000 0x0 0x4000>; interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 699 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <AIC_IRQ 861 IRQ_TYPE_LEVEL_HIGH>; #iommu-cells = <1>; - status = "disabled"; + power-domains = <&ps_atc1_usb>; };
- pcie0_dart_2: iommu@683008000 { - compatible = "apple,t8103-dart", "apple,dart-m1"; - reg = <0x6 0x83008000 0x0 0x4000>; + dwc3_1: usb@b02280000 { + compatible = "apple,t8103-dwc3", "apple,dwc3", "snps,dwc3"; + reg = <0x5 0x02280000 0x0 0x100000>; interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 702 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <AIC_IRQ 857 IRQ_TYPE_LEVEL_HIGH>; + usb-role-switch; + role-switch-default-mode = "host"; + iommus = <&dwc3_1_dart_0 0>, <&dwc3_1_dart_1 1>; + power-domains = <&ps_atc1_usb>; + }; + + pcie0_dart_0: dart@681008000 { + compatible = "apple,t8103-dart"; + reg = <0x6 0x81008000 0x0 0x4000>; #iommu-cells = <1>; - status = "disabled"; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 696 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&ps_apcie_gp>; };
- smc_mbox: mbox@23e400000 { - compatible = "apple,iop-mailbox-m1"; - reg = <0x2 0x3e400000 0x0 0x20000>; - #mbox-cells = <1>; - endpoints = <32>; + pcie0_dart_1: dart@682008000 { + compatible = "apple,t8103-dart"; + reg = <0x6 0x82008000 0x0 0x4000>; + #iommu-cells = <1>; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 699 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&ps_apcie_gp>; };
- smc: smc@23e050000 { - compatible = "apple,smc-m1"; - reg = <0x2 0x3e050000 0x0 0x4000>; - mboxes = <&smc_mbox 32>; - gpio-controller; - #gpio-cells = <2>; - gpio-13 = <0x00800000>; + pcie0_dart_2: dart@683008000 { + compatible = "apple,t8103-dart"; + reg = <0x6 0x83008000 0x0 0x4000>; + #iommu-cells = <1>; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 702 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&ps_apcie_gp>; };
pcie0: pcie@690000000 { compatible = "apple,t8103-pcie", "apple,pcie"; + device_type = "pci";
reg = <0x6 0x90000000 0x0 0x1000000>, - <0x6 0x80000000 0x0 0x4000>, - <0x6 0x81000000 0x0 0x8000>, - <0x6 0x82000000 0x0 0x8000>, - <0x6 0x83000000 0x0 0x8000>; + <0x6 0x80000000 0x0 0x100000>, + <0x6 0x81000000 0x0 0x4000>, + <0x6 0x82000000 0x0 0x4000>, + <0x6 0x83000000 0x0 0x4000>; reg-names = "config", "rc", "port0", "port1", "port2";
interrupt-parent = <&aic>; @@ -460,6 +506,7 @@ msi-parent = <&pcie0>; msi-ranges = <&aic AIC_IRQ 704 IRQ_TYPE_EDGE_RISING 32>;
+ iommu-map = <0x100 &pcie0_dart_0 1 1>, <0x200 &pcie0_dart_1 1 1>, <0x300 &pcie0_dart_2 1 1>; @@ -468,96 +515,104 @@ bus-range = <0 3>; #address-cells = <3>; #size-cells = <2>; - ranges = <0x43000000 0x6 0xa0000000 0x6 0xa0000000 - 0x0 0x20000000>, - <0x02000000 0x0 0xc0000000 0x6 0xc0000000 - 0x0 0x40000000>; + ranges = <0x43000000 0x6 0xa0000000 0x6 0xa0000000 0x0 0x20000000>, + <0x02000000 0x0 0xc0000000 0x6 0xc0000000 0x0 0x40000000>;
- power-domains = <&ps_apcie>, <&ps_apcie_gp>, <&ps_pcie_ref>; + power-domains = <&ps_apcie_gp>; pinctrl-0 = <&pcie_pins>; pinctrl-names = "default";
- device_type = "pci"; - status = "disabled"; - }; + port00: pci@0,0 { + device_type = "pci"; + reg = <0x0 0x0 0x0 0x0 0x0>; + reset-gpios = <&pinctrl_ap 152 GPIO_ACTIVE_LOW>; + max-link-speed = <2>;
- dwc3_0_dart_0: iommu@382f00000 { - compatible = "apple,t8103-dart"; - reg = <0x3 0x82f00000 0x0 0x4000>; - interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 781 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; + #address-cells = <3>; + #size-cells = <2>; + ranges;
- dwc3_0_dart_1: iommu@382f80000 { - compatible = "apple,t8103-dart"; - reg = <0x3 0x82f80000 0x0 0x4000>; - interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 781 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; + interrupt-controller; + #interrupt-cells = <1>;
- dwc3_0: usb@382280000{ - compatible = "snps,dwc3"; - reg = <0x3 0x82280000 0x0 0x100000>; - interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 777 IRQ_TYPE_LEVEL_HIGH>; - dr_mode = "host"; - iommus = <&dwc3_0_dart_0 0>, <&dwc3_0_dart_1 1>; - status = "disabled"; - }; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &port00 0 0 0 0>, + <0 0 0 2 &port00 0 0 0 1>, + <0 0 0 3 &port00 0 0 0 2>, + <0 0 0 4 &port00 0 0 0 3>; + };
- dwc3_1_dart_0: iommu@502f00000 { - compatible = "apple,t8103-dart"; - reg = <0x5 0x02f00000 0x0 0x4000>; - interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 861 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; + port01: pci@1,0 { + device_type = "pci"; + reg = <0x800 0x0 0x0 0x0 0x0>; + reset-gpios = <&pinctrl_ap 153 GPIO_ACTIVE_LOW>; + max-link-speed = <2>;
- dwc3_1_dart_1: iommu@502f80000 { - compatible = "apple,t8103-dart"; - reg = <0x5 0x02f80000 0x0 0x4000>; - interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 861 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - status = "disabled"; - }; + #address-cells = <3>; + #size-cells = <2>; + ranges;
- dwc3_1: usb@502280000{ - compatible = "snps,dwc3"; - reg = <0x5 0x02280000 0x0 0x100000>; - interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 857 IRQ_TYPE_LEVEL_HIGH>; - dr_mode = "host"; - iommus = <&dwc3_1_dart_0 0>, <&dwc3_1_dart_1 1>; - status = "disabled"; - }; + interrupt-controller; + #interrupt-cells = <1>;
- spi@23510c000 { - compatible = "apple,t8103-spi", "apple,spi"; - reg = <0x2 0x3510c000 0x0 0x4000>; - interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 617 IRQ_TYPE_LEVEL_HIGH>; - cs-gpios = <&pinctrl_ap 49 GPIO_ACTIVE_HIGH>; - }; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &port01 0 0 0 0>, + <0 0 0 2 &port01 0 0 0 1>, + <0 0 0 3 &port01 0 0 0 2>, + <0 0 0 4 &port01 0 0 0 3>; + };
- spmi@23d0d8000 { - compatible = "apple,t8103-spmi", "apple,spmi"; - reg = <0x2 0x3d0d9300 0x0 0x100>; - interrupt-parent = <&aic>; - interrupts = <AIC_IRQ 343 IRQ_TYPE_LEVEL_HIGH>; + port02: pci@2,0 { + device_type = "pci"; + reg = <0x1000 0x0 0x0 0x0 0x0>; + reset-gpios = <&pinctrl_ap 33 GPIO_ACTIVE_LOW>; + max-link-speed = <1>;
- #address-cells = <2>; - #size-cells = <0>; + #address-cells = <3>; + #size-cells = <2>; + ranges;
- pmu@f { - compatible = "apple,sera-pmu"; - reg = <0xf SPMI_USID>; + interrupt-controller; + #interrupt-cells = <1>; + + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &port02 0 0 0 0>, + <0 0 0 2 &port02 0 0 0 1>, + <0 0 0 3 &port02 0 0 0 2>, + <0 0 0 4 &port02 0 0 0 3>; }; }; + ans: mbox@277408000 { + compatible = "apple,t8103-asc-mailbox"; + reg = <0x2 0x77408000 0x0 0x4000>; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 583 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 584 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 585 IRQ_TYPE_LEVEL_HIGH>, + <AIC_IRQ 586 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "send-empty", "send-not-empty", + "recv-empty", "recv-not-empty"; + #mbox-cells = <0>; + power-domains = <&ps_ans2>; + }; + + sart: sart@27bc50000 { + compatible = "apple,t8103-sart"; + reg = <0x2 0x7bc50000 0x0 0x10000>; + power-domains = <&ps_ans2>; + }; + + ans2: nvme@27bcc0000 { + compatible = "apple,t8103-ans-nvme", "apple,nvme-m1"; + reg = <0x2 0x7bcc0000 0x0 0x40000>, <0x2 0x77400000 0x0 0x4000>; + reg-names = "nvme", "coproc"; + interrupt-parent = <&aic>; + interrupts = <AIC_IRQ 590 IRQ_TYPE_LEVEL_HIGH>; + mboxes = <&ans>; + apple,sart = <&sart>; + power-domains = <&ps_ans2>; + }; }; }; + +#include "t8103-pmgr.dtsi"
On 12/24/21 6:34 AM, Mark Kettenis wrote:
This synchronizes the device trees with those that are in the process of being upstreamed into Linux 5.16 or proposed for Linux 5.17. This includes device trees for machines that were still missing.
There are still some differences that will hopefully be resolved soon.
Signed-off-by: Mark Kettenis kettenis@openbsd.org
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
arch/arm/dts/Makefile | 5 +- arch/arm/dts/t8103-j274.dts | 122 +--- arch/arm/dts/t8103-j293.dts | 92 +-- arch/arm/dts/t8103-j313.dts | 57 ++ arch/arm/dts/t8103-j456.dts | 71 +++ arch/arm/dts/t8103-j457.dts | 59 ++ arch/arm/dts/t8103-jxxx.dtsi | 140 +++++ arch/arm/dts/t8103-pmgr.dtsi | 1136 ++++++++++++++++++++++++++++++++++ arch/arm/dts/t8103.dtsi | 585 +++++++++-------- 9 files changed, 1839 insertions(+), 428 deletions(-) create mode 100644 arch/arm/dts/t8103-j313.dts create mode 100644 arch/arm/dts/t8103-j456.dts create mode 100644 arch/arm/dts/t8103-j457.dts create mode 100644 arch/arm/dts/t8103-jxxx.dtsi create mode 100644 arch/arm/dts/t8103-pmgr.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7f622fedbd..35872e1574 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -34,7 +34,10 @@ dtb-$(CONFIG_TARGET_A7Y17LTE) += exynos78x0-axy17lte.dtb
dtb-$(CONFIG_ARCH_APPLE) += \ t8103-j274.dtb \
- t8103-j293.dtb
- t8103-j293.dtb \
- t8103-j313.dtb \
- t8103-j456.dtb \
- t8103-j457.dtb
dtb-$(CONFIG_ARCH_DAVINCI) += \ da850-evm.dtb \ diff --git a/arch/arm/dts/t8103-j274.dts b/arch/arm/dts/t8103-j274.dts index aef1ae29b6..2144768147 100644 --- a/arch/arm/dts/t8103-j274.dts +++ b/arch/arm/dts/t8103-j274.dts @@ -10,126 +10,48 @@ /dts-v1/;
/ { compatible = "apple,j274", "apple,t8103", "apple,arm-platform"; model = "Apple Mac mini (M1, 2020)";
aliases {
serial0 = &serial0;
ethernet0 = ð0;
wifi0 = &wifi0;
- chosen {
#size-cells = <2>;
ranges;
- memory@800000000 {
};ethernet0 = ðernet0;
-&serial0 {
- status = "okay";
-&pcie0_dart_0 {
- status = "okay";
- Provide labels for the USB type C ports.
-&pcie0_dart_1 {
- status = "okay";
+&typec0 {
- label = "USB-C Back-left";
-&pcie0_dart_2 {
- status = "okay";
+&typec1 {
- label = "USB-C Back-right";
-&pcie0 {
- status = "okay";
- pci0: pci@0,0 {
reset-gpios = <&pinctrl_ap 152 0>;
#size-cells = <2>;
ranges;
- pci1: pci@1,0 {
reset-gpios = <&pinctrl_ap 153 0>;
#size-cells = <2>;
ranges;
- pci2: pci@2,0 {
reset-gpios = <&pinctrl_ap 33 0>;
- Force the bus number assignments so that we can declare some of the
- on-board devices and properties that are populated by the bootloader
- (such as MAC addresses).
#size-cells = <2>;
ranges;
+&port01 {
- bus-range = <2 2>;
-&pci0 {
- wifi0: network@0,0 {
-&pci2 {
- eth0: ethernet@0,0 {
+&port02 {
- bus-range = <3 3>;
- ethernet0: ethernet@0,0 { reg = <0x30000 0x0 0x0 0x0 0x0>;
};local-mac-address = [00 10 18 00 00 00];
-&dwc3_0_dart_0 {
- status = "okay";
-&dwc3_0_dart_1 {
- status = "okay";
-&dwc3_0 {
- status = "okay";
-&dwc3_1_dart_0 {
- status = "okay";
-&dwc3_1_dart_1 {
- status = "okay";
-&dwc3_1 { +&i2c2 { status = "okay"; }; diff --git a/arch/arm/dts/t8103-j293.dts b/arch/arm/dts/t8103-j293.dts index 4a22596cf4..cf92ee53e0 100644 --- a/arch/arm/dts/t8103-j293.dts +++ b/arch/arm/dts/t8103-j293.dts @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ OR MIT /*
- Apple Macbook Pro (M1, 2020)
- Apple MacBook Pro (13-inch, M1, 2020)
- target-type: J293
@@ -10,88 +10,56 @@ /dts-v1/;
/ { compatible = "apple,j293", "apple,t8103", "apple,arm-platform";
- model = "Apple Macbook Pro (M1, 2020)";
- aliases {
serial0 = &serial0;
wifi0 = &wifi0;
- chosen {
#size-cells = <2>;
ranges;
- model = "Apple MacBook Pro (13-inch, M1, 2020)";
-&serial0 {
- status = "okay";
-&pcie0_dart_0 {
- status = "okay";
+&typec0 {
- label = "USB-C Left-back";
-&pcie0 {
- status = "okay";
- pci0: pci@0,0 {
#size-cells = <2>;
ranges;
+&typec1 {
- label = "USB-C Left-front";
-&pci0 {
- Remove unused PCIe ports and disable the associated DARTs.
-&dwc3_0_dart_0 {
- status = "okay";
+&pcie0_dart_1 {
-&dwc3_0_dart_1 {
- status = "okay";
+&pcie0_dart_2 {
-&dwc3_0 {
- status = "okay";
-}; +/delete-node/ &port01; +/delete-node/ &port02;
-&dwc3_1_dart_0 { +&i2c2 { status = "okay"; };
-&dwc3_1_dart_1 { +&i2c4 { status = "okay"; };
-&dwc3_1 { +&spi3 { status = "okay";
- keyboard@0 {
compatible = "apple,keyboard";
spi-max-frequency = <2000000>;
reg = <0>;
interrupts-extended = <&pinctrl_nub 13 IRQ_TYPE_LEVEL_LOW>;
spien-gpios = <&pinctrl_ap 195 GPIO_ACTIVE_HIGH>;
}; diff --git a/arch/arm/dts/t8103-j313.dts b/arch/arm/dts/t8103-j313.dts new file mode 100644 index 0000000000..c8574d81c8 --- /dev/null +++ b/arch/arm/dts/t8103-j313.dts @@ -0,0 +1,57 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/*
- Apple MacBook Air (M1, 2020)
- target-type: J313
- Copyright The Asahi Linux Contributors
+/dts-v1/;
- compatible = "apple,j313", "apple,t8103", "apple,arm-platform";
- model = "Apple MacBook Air (M1, 2020)";
+&typec0 {
+&typec1 {
+&pcie0_dart_1 {
+&pcie0_dart_2 {
+&spi3 {
- status = "okay";
- keyboard@0 {
reg = <0>;
+}; diff --git a/arch/arm/dts/t8103-j456.dts b/arch/arm/dts/t8103-j456.dts new file mode 100644 index 0000000000..9814c97cd9 --- /dev/null +++ b/arch/arm/dts/t8103-j456.dts @@ -0,0 +1,71 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/*
- Apple iMac (24-inch, 4x USB-C, M1, 2020)
- target-type: J456
+/dts-v1/;
- compatible = "apple,j456", "apple,t8103", "apple,arm-platform";
- model = "Apple iMac (24-inch, 4x USB-C, M1, 2020)";
- aliases {
+&i2c0 {
- hpm2: usb-pd@3b {
reg = <0x3b>;
- hpm3: usb-pd@3c {
reg = <0x3c>;
+&typec0 {
+&typec1 {
- label = "USB-C Back-right-middle";
+&port01 {
+&port02 {
+}; diff --git a/arch/arm/dts/t8103-j457.dts b/arch/arm/dts/t8103-j457.dts new file mode 100644 index 0000000000..0f4cc64374 --- /dev/null +++ b/arch/arm/dts/t8103-j457.dts @@ -0,0 +1,59 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/*
- Apple iMac (24-inch, 2x USB-C, M1, 2020)
- target-type: J457
+/dts-v1/;
+#include "t8103.dtsi" +#include "t8103-jxxx.dtsi"
- compatible = "apple,j457", "apple,t8103", "apple,arm-platform";
- model = "Apple iMac (24-inch, 2x USB-C, M1, 2020)";
- aliases {
+&typec0 {
+&typec1 {
+&port02 {
- Remove unused PCIe port and disable the associated DART.
+&pcie0_dart_1 {
- Apple M1 Mac mini, MacBook Air/Pro, iMac 24" (M1, 2020/2021)
- This file contains parts common to all Apple M1 devices using the t8103.
- target-type: J274, J293, J313, J456, J457
- aliases {
serial0 = &serial0;
serial2 = &serial2;
wifi0 = &wifi0;
- chosen {
#size-cells = <2>;
ranges;
+&serial0 {
- status = "okay";
+&serial2 {
- status = "okay";
+&i2c0 {
- hpm0: usb-pd@38 {
reg = <0x38>;
typec0: connector {
data-role = "dual";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
- hpm1: usb-pd@3f {
reg = <0x3f>;
typec1: connector {
data-role = "dual";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
- port {
+&dwc3_1 {
- port {
+&port00 {
- bus-range = <1 1>;
- pwren-gpios = <&smc 13 0>;
+&spmi {
- status = "okay";
- pmu@f {
- PMGR Power domains for the Apple T8103 "M1" SoC
+&pmgr {
- ps_sbr: power-controller@100 {
reg = <0x100 4>;
#reset-cells = <0>;
label = "sbr";
- ps_aic: power-controller@108 {
reg = <0x108 4>;
#reset-cells = <0>;
label = "aic";
- ps_dwi: power-controller@110 {
reg = <0x110 4>;
#reset-cells = <0>;
label = "dwi";
- ps_soc_spmi0: power-controller@118 {
reg = <0x118 4>;
#reset-cells = <0>;
- ps_soc_spmi1: power-controller@120 {
reg = <0x120 4>;
#reset-cells = <0>;
- ps_soc_spmi2: power-controller@128 {
reg = <0x128 4>;
#reset-cells = <0>;
- ps_gpio: power-controller@130 {
reg = <0x130 4>;
#reset-cells = <0>;
label = "gpio";
- ps_pms_busif: power-controller@138 {
reg = <0x138 4>;
#reset-cells = <0>;
- ps_pms: power-controller@140 {
reg = <0x140 4>;
#reset-cells = <0>;
label = "pms";
- ps_pms_fpwm0: power-controller@148 {
reg = <0x148 4>;
#reset-cells = <0>;
- ps_pms_fpwm1: power-controller@150 {
reg = <0x150 4>;
#reset-cells = <0>;
- ps_pms_fpwm2: power-controller@158 {
reg = <0x158 4>;
#reset-cells = <0>;
- ps_pms_fpwm3: power-controller@160 {
reg = <0x160 4>;
#reset-cells = <0>;
- ps_pms_fpwm4: power-controller@168 {
reg = <0x168 4>;
#reset-cells = <0>;
- ps_soc_dpe: power-controller@170 {
reg = <0x170 4>;
#reset-cells = <0>;
label = "soc_dpe";
- ps_pmgr_soc_ocla: power-controller@178 {
reg = <0x178 4>;
#reset-cells = <0>;
- ps_ispsens0: power-controller@180 {
reg = <0x180 4>;
#reset-cells = <0>;
label = "ispsens0";
- ps_ispsens1: power-controller@188 {
reg = <0x188 4>;
#reset-cells = <0>;
label = "ispsens1";
- ps_ispsens2: power-controller@190 {
reg = <0x190 4>;
#reset-cells = <0>;
label = "ispsens2";
- ps_ispsens3: power-controller@198 {
reg = <0x198 4>;
#reset-cells = <0>;
label = "ispsens3";
reg = <0x1a0 4>;
#reset-cells = <0>;
label = "pcie_ref";
- ps_aft0: power-controller@1a8 {
reg = <0x1a8 4>;
#reset-cells = <0>;
label = "aft0";
- ps_devc0_ivdmc: power-controller@1b0 {
reg = <0x1b0 4>;
#reset-cells = <0>;
reg = <0x1b8 4>;
#reset-cells = <0>;
label = "imx";
- ps_sio_busif: power-controller@1c0 {
reg = <0x1c0 4>;
#reset-cells = <0>;
- ps_sio: power-controller@1c8 {
reg = <0x1c8 4>;
#reset-cells = <0>;
label = "sio";
- ps_sio_cpu: power-controller@1d0 {
reg = <0x1d0 4>;
#reset-cells = <0>;
label = "sio_cpu";
- ps_fpwm0: power-controller@1d8 {
reg = <0x1d8 4>;
#reset-cells = <0>;
label = "fpwm0";
- ps_fpwm1: power-controller@1e0 {
reg = <0x1e0 4>;
#reset-cells = <0>;
label = "fpwm1";
- ps_fpwm2: power-controller@1e8 {
reg = <0x1e8 4>;
#reset-cells = <0>;
label = "fpwm2";
- ps_i2c0: power-controller@1f0 {
reg = <0x1f0 4>;
#reset-cells = <0>;
label = "i2c0";
- ps_i2c1: power-controller@1f8 {
reg = <0x1f8 4>;
#reset-cells = <0>;
label = "i2c1";
- ps_i2c2: power-controller@200 {
reg = <0x200 4>;
#reset-cells = <0>;
label = "i2c2";
- ps_i2c3: power-controller@208 {
reg = <0x208 4>;
#reset-cells = <0>;
label = "i2c3";
- ps_i2c4: power-controller@210 {
reg = <0x210 4>;
#reset-cells = <0>;
label = "i2c4";
- ps_spi_p: power-controller@218 {
reg = <0x218 4>;
#reset-cells = <0>;
label = "spi_p";
reg = <0x220 4>;
#reset-cells = <0>;
label = "uart_p";
- ps_audio_p: power-controller@228 {
reg = <0x228 4>;
#reset-cells = <0>;
label = "audio_p";
- ps_sio_adma: power-controller@230 {
reg = <0x230 4>;
#reset-cells = <0>;
label = "sio_adma";
- ps_aes: power-controller@238 {
reg = <0x238 4>;
#reset-cells = <0>;
label = "aes";
- ps_spi0: power-controller@240 {
reg = <0x240 4>;
#reset-cells = <0>;
label = "spi0";
- ps_spi1: power-controller@248 {
reg = <0x248 4>;
#reset-cells = <0>;
label = "spi1";
- ps_spi2: power-controller@250 {
reg = <0x250 4>;
#reset-cells = <0>;
label = "spi2";
- ps_spi3: power-controller@258 {
reg = <0x258 4>;
#reset-cells = <0>;
label = "spi3";
- ps_uart_n: power-controller@268 {
reg = <0x268 4>;
#reset-cells = <0>;
label = "uart_n";
reg = <0x270 4>;
#reset-cells = <0>;
label = "uart0";
reg = <0x278 4>;
#reset-cells = <0>;
label = "uart1";
reg = <0x280 4>;
#reset-cells = <0>;
label = "uart2";
reg = <0x288 4>;
#reset-cells = <0>;
label = "uart3";
- ps_uart4: power-controller@290 {
reg = <0x290 4>;
#reset-cells = <0>;
label = "uart4";
- ps_uart5: power-controller@298 {
reg = <0x298 4>;
#reset-cells = <0>;
label = "uart5";
- ps_uart6: power-controller@2a0 {
reg = <0x2a0 4>;
#reset-cells = <0>;
label = "uart6";
- ps_uart7: power-controller@2a8 {
reg = <0x2a8 4>;
#reset-cells = <0>;
label = "uart7";
- ps_uart8: power-controller@2b0 {
reg = <0x2b0 4>;
#reset-cells = <0>;
label = "uart8";
- ps_mca0: power-controller@2b8 {
reg = <0x2b8 4>;
#reset-cells = <0>;
label = "mca0";
- ps_mca1: power-controller@2c0 {
reg = <0x2c0 4>;
#reset-cells = <0>;
label = "mca1";
- ps_mca2: power-controller@2c8 {
reg = <0x2c8 4>;
#reset-cells = <0>;
label = "mca2";
- ps_mca3: power-controller@2d0 {
reg = <0x2d0 4>;
#reset-cells = <0>;
label = "mca3";
- ps_mca4: power-controller@2d8 {
reg = <0x2d8 4>;
#reset-cells = <0>;
label = "mca4";
- ps_mca5: power-controller@2e0 {
reg = <0x2e0 4>;
#reset-cells = <0>;
label = "mca5";
- ps_dpa0: power-controller@2e8 {
reg = <0x2e8 4>;
#reset-cells = <0>;
label = "dpa0";
- ps_dpa1: power-controller@2f0 {
reg = <0x2f0 4>;
#reset-cells = <0>;
label = "dpa1";
- ps_mcc: power-controller@2f8 {
reg = <0x2f8 4>;
#reset-cells = <0>;
label = "mcc";
- ps_spi4: power-controller@260 {
reg = <0x260 4>;
#reset-cells = <0>;
label = "spi4";
- ps_dcs0: power-controller@300 {
reg = <0x300 4>;
#reset-cells = <0>;
label = "dcs0";
- ps_dcs1: power-controller@310 {
reg = <0x310 4>;
#reset-cells = <0>;
label = "dcs1";
- ps_dcs2: power-controller@308 {
reg = <0x308 4>;
#reset-cells = <0>;
label = "dcs2";
- ps_dcs3: power-controller@318 {
reg = <0x318 4>;
#reset-cells = <0>;
label = "dcs3";
- ps_smx: power-controller@340 {
reg = <0x340 4>;
#reset-cells = <0>;
label = "smx";
reg = <0x348 4>;
#reset-cells = <0>;
label = "apcie";
- ps_rmx: power-controller@350 {
reg = <0x350 4>;
#reset-cells = <0>;
label = "rmx";
- ps_mmx: power-controller@358 {
reg = <0x358 4>;
#reset-cells = <0>;
label = "mmx";
- ps_disp0_fe: power-controller@360 {
reg = <0x360 4>;
#reset-cells = <0>;
label = "disp0_fe";
- ps_dispext_fe: power-controller@368 {
reg = <0x368 4>;
#reset-cells = <0>;
- ps_dispext_cpu0: power-controller@378 {
reg = <0x378 4>;
#reset-cells = <0>;
- ps_jpg: power-controller@3c0 {
reg = <0x3c0 4>;
#reset-cells = <0>;
label = "jpg";
- ps_msr: power-controller@3c8 {
reg = <0x3c8 4>;
#reset-cells = <0>;
label = "msr";
- ps_msr_ase_core: power-controller@3d0 {
reg = <0x3d0 4>;
#reset-cells = <0>;
- ps_pmp: power-controller@3d8 {
reg = <0x3d8 4>;
#reset-cells = <0>;
label = "pmp";
- ps_pms_sram: power-controller@3e0 {
reg = <0x3e0 4>;
#reset-cells = <0>;
label = "pms_sram";
reg = <0x3e8 4>;
#reset-cells = <0>;
label = "apcie_gp";
reg = <0x3f0 4>;
#reset-cells = <0>;
label = "ans2";
- ps_gfx: power-controller@3f8 {
reg = <0x3f8 4>;
#reset-cells = <0>;
label = "gfx";
- ps_dcs4: power-controller@320 {
reg = <0x320 4>;
#reset-cells = <0>;
label = "dcs4";
- ps_dcs5: power-controller@330 {
reg = <0x330 4>;
#reset-cells = <0>;
label = "dcs5";
- ps_dcs6: power-controller@328 {
reg = <0x328 4>;
#reset-cells = <0>;
label = "dcs6";
- ps_dcs7: power-controller@338 {
reg = <0x338 4>;
#reset-cells = <0>;
label = "dcs7";
- ps_dispdfr_fe: power-controller@3a8 {
reg = <0x3a8 4>;
#reset-cells = <0>;
- ps_dispdfr_be: power-controller@3b0 {
reg = <0x3b0 4>;
#reset-cells = <0>;
- ps_mipi_dsi: power-controller@3b8 {
reg = <0x3b8 4>;
#reset-cells = <0>;
label = "mipi_dsi";
- ps_isp_sys: power-controller@400 {
reg = <0x400 4>;
#reset-cells = <0>;
label = "isp_sys";
- ps_venc_sys: power-controller@408 {
reg = <0x408 4>;
#reset-cells = <0>;
label = "venc_sys";
- ps_avd_sys: power-controller@410 {
reg = <0x410 4>;
#reset-cells = <0>;
label = "avd_sys";
reg = <0x418 4>;
#reset-cells = <0>;
label = "apcie_st";
- ps_ane_sys: power-controller@470 {
reg = <0x470 4>;
#reset-cells = <0>;
label = "ane_sys";
- ps_atc0_common: power-controller@420 {
reg = <0x420 4>;
#reset-cells = <0>;
- ps_atc0_pcie: power-controller@428 {
reg = <0x428 4>;
#reset-cells = <0>;
- ps_atc0_cio: power-controller@430 {
reg = <0x430 4>;
#reset-cells = <0>;
label = "atc0_cio";
- ps_atc0_cio_pcie: power-controller@438 {
reg = <0x438 4>;
#reset-cells = <0>;
- ps_atc0_cio_usb: power-controller@440 {
reg = <0x440 4>;
#reset-cells = <0>;
- ps_atc1_common: power-controller@448 {
reg = <0x448 4>;
#reset-cells = <0>;
- ps_atc1_pcie: power-controller@450 {
reg = <0x450 4>;
#reset-cells = <0>;
- ps_atc1_cio: power-controller@458 {
reg = <0x458 4>;
#reset-cells = <0>;
label = "atc1_cio";
- ps_atc1_cio_pcie: power-controller@460 {
reg = <0x460 4>;
#reset-cells = <0>;
- ps_atc1_cio_usb: power-controller@468 {
reg = <0x468 4>;
#reset-cells = <0>;
- ps_sep: power-controller@c00 {
reg = <0xc00 4>;
#reset-cells = <0>;
label = "sep";
- ps_venc_dma: power-controller@8000 {
reg = <0x8000 4>;
#reset-cells = <0>;
label = "venc_dma";
- ps_venc_pipe4: power-controller@8008 {
reg = <0x8008 4>;
#reset-cells = <0>;
- ps_venc_pipe5: power-controller@8010 {
reg = <0x8010 4>;
#reset-cells = <0>;
- ps_venc_me0: power-controller@8018 {
reg = <0x8018 4>;
#reset-cells = <0>;
label = "venc_me0";
- ps_venc_me1: power-controller@8020 {
reg = <0x8020 4>;
#reset-cells = <0>;
label = "venc_me1";
- ps_ane_sys_cpu: power-controller@c000 {
reg = <0xc000 4>;
#reset-cells = <0>;
- ps_disp0_cpu0: power-controller@10018 {
reg = <0x10018 4>;
#reset-cells = <0>;
+&pmgr_mini {
- ps_debug: power-controller@58 {
reg = <0x58 4>;
#reset-cells = <0>;
label = "debug";
- ps_nub_spmi0: power-controller@60 {
reg = <0x60 4>;
#reset-cells = <0>;
- ps_nub_aon: power-controller@70 {
reg = <0x70 4>;
#reset-cells = <0>;
label = "nub_aon";
- ps_nub_gpio: power-controller@80 {
reg = <0x80 4>;
#reset-cells = <0>;
label = "nub_gpio";
- ps_nub_fabric: power-controller@a8 {
reg = <0xa8 4>;
#reset-cells = <0>;
- ps_nub_sram: power-controller@b0 {
reg = <0xb0 4>;
#reset-cells = <0>;
label = "nub_sram";
- ps_debug_usb: power-controller@b8 {
reg = <0xb8 4>;
#reset-cells = <0>;
- ps_debug_auth: power-controller@c0 {
reg = <0xc0 4>;
#reset-cells = <0>;
- ps_nub_spmi1: power-controller@68 {
reg = <0x68 4>;
#reset-cells = <0>;
- ps_msg: power-controller@78 {
reg = <0x78 4>;
#reset-cells = <0>;
label = "msg";
- ps_atc0_usb_aon: power-controller@88 {
reg = <0x88 4>;
#reset-cells = <0>;
- ps_atc1_usb_aon: power-controller@90 {
reg = <0x90 4>;
#reset-cells = <0>;
- ps_atc0_usb: power-controller@98 {
reg = <0x98 4>;
#reset-cells = <0>;
label = "atc0_usb";
- ps_atc1_usb: power-controller@a0 {
reg = <0xa0 4>;
#reset-cells = <0>;
label = "atc1_usb";
clkref: clock-ref {
ranges;
dma-ranges;
nonposted-mmio;dma-coherent;
clocks = <&clkref>;
clocks = <&clkref>;
clocks = <&clkref>;
clocks = <&clkref>;
clocks = <&clkref>;
#size-cells = <0>;
clocks = <&clkref>;
- serial0: serial@235200000 { compatible = "apple,s5l-uart"; reg = <0x2 0x35200000 0x0 0x1000>; reg-io-width = <4>; interrupt-parent = <&aic>; interrupts = <AIC_IRQ 605 IRQ_TYPE_LEVEL_HIGH>;
};clock-names = "uart", "clk_uart_baud0"; power-domains = <&ps_uart0>; status = "disabled";
};clock-names = "uart", "clk_uart_baud0"; power-domains = <&ps_uart2>; status = "disabled";
};power-domains = <&ps_aic>;
#size-cells = <0>;
reg = <0x1a0>;
#reset-cells = <0>;
reg = <0x1b8>;
#reset-cells = <0>;
apple,always-on;
reg = <0x1c0>;
#reset-cells = <0>;
reg = <0x220>;
#reset-cells = <0>;
reg = <0x270>;
#reset-cells = <0>;
reg = <0x278>;
#reset-cells = <0>;
reg = <0x280>;
#reset-cells = <0>;
reg = <0x288>;
#reset-cells = <0>;
reg = <0x348>;
#reset-cells = <0>;
reg = <0x3e8>;
#reset-cells = <0>;
reg = <0x3f0>;
#reset-cells = <0>;
reg = <0x418>;
#reset-cells = <0>;
#size-cells = <1>;
power-domains = <&ps_gpio>; gpio-controller; #gpio-cells = <2>; gpio-ranges = <&pinctrl_ap 0 0 212>;
apple,npins = <212>; interrupt-controller;
<APPLE_PINMUX(134, 1)>; }; pcie_pins: pcie-pins { pinmux = <APPLE_PINMUX(150, 1)>,
#size-cells = <0>;
#size-cells = <1>;
apple,npins = <42>; interrupt-controller;
power-domains = <&ps_nub_gpio>; gpio-controller; #gpio-cells = <2>; gpio-ranges = <&pinctrl_nub 0 0 23>;
apple,npins = <23>; interrupt-controller;
apple,npins = <16>; interrupt-controller;
clocks = <&clkref>;
#mbox-cells = <0>;
hpm0: hpm@38 {
reg = <0x38>;
gpio-controller;
#gpio-cells = <2>;
hpm1: hpm@3f {
reg = <0x3f>;
#iommu-cells = <1>;
#mbox-cells = <1>;
endpoints = <32>;
#iommu-cells = <1>;
};power-domains = <&ps_atc0_usb>;
ans@27bcc0000 {
usb-role-switch;
};power-domains = <&ps_atc1_usb>;
usb-role-switch;
};power-domains = <&ps_apcie_gp>;
#mbox-cells = <1>;
endpoints = <32>;
#iommu-cells = <1>;
gpio-controller;
#gpio-cells = <2>;
#iommu-cells = <1>;
device_type = "pci"; reg = <0x6 0x90000000 0x0 0x1000000>,
<0x6 0x83000000 0x0 0x4000>; reg-names = "config", "rc", "port0", "port1", "port2"; interrupt-parent = <&aic>;
0x0 0x20000000>,
0x0 0x40000000>;
port00: pci@0,0 {
#iommu-cells = <1>;
#size-cells = <2>;
ranges;
#iommu-cells = <1>;
dr_mode = "host";
#iommu-cells = <1>;
port01: pci@1,0 {
#iommu-cells = <1>;
#size-cells = <2>;
ranges;
dr_mode = "host";
spi@23510c000 {
spmi@23d0d8000 {
port02: pci@2,0 {
#size-cells = <0>;
#size-cells = <2>;
ranges;
pmu@f {
};<0 0 0 4 &port02 0 0 0 3>; };
#mbox-cells = <0>;
mboxes = <&ans>;
These are necessary to make sure the power domains needed for the serial console are availble in the pre-relocation phase.
Signed-off-by: Mark Kettenis kettenis@openbsd.org --- arch/arm/dts/t8103-j274-u-boot.dtsi | 1 + arch/arm/dts/t8103-j293-u-boot.dtsi | 1 + arch/arm/dts/t8103-j313-u-boot.dtsi | 1 + arch/arm/dts/t8103-j456-u-boot.dtsi | 1 + arch/arm/dts/t8103-j457-u-boot.dtsi | 1 + arch/arm/dts/t8103-u-boot.dtsi | 25 +++++++++++++++++++++++++ 6 files changed, 30 insertions(+) create mode 100644 arch/arm/dts/t8103-j274-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j293-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j313-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j456-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-j457-u-boot.dtsi create mode 100644 arch/arm/dts/t8103-u-boot.dtsi
diff --git a/arch/arm/dts/t8103-j274-u-boot.dtsi b/arch/arm/dts/t8103-j274-u-boot.dtsi new file mode 100644 index 0000000000..6c8dd5a56f --- /dev/null +++ b/arch/arm/dts/t8103-j274-u-boot.dtsi @@ -0,0 +1 @@ +#include "t8103-u-boot.dtsi" diff --git a/arch/arm/dts/t8103-j293-u-boot.dtsi b/arch/arm/dts/t8103-j293-u-boot.dtsi new file mode 100644 index 0000000000..6c8dd5a56f --- /dev/null +++ b/arch/arm/dts/t8103-j293-u-boot.dtsi @@ -0,0 +1 @@ +#include "t8103-u-boot.dtsi" diff --git a/arch/arm/dts/t8103-j313-u-boot.dtsi b/arch/arm/dts/t8103-j313-u-boot.dtsi new file mode 100644 index 0000000000..6c8dd5a56f --- /dev/null +++ b/arch/arm/dts/t8103-j313-u-boot.dtsi @@ -0,0 +1 @@ +#include "t8103-u-boot.dtsi" diff --git a/arch/arm/dts/t8103-j456-u-boot.dtsi b/arch/arm/dts/t8103-j456-u-boot.dtsi new file mode 100644 index 0000000000..6c8dd5a56f --- /dev/null +++ b/arch/arm/dts/t8103-j456-u-boot.dtsi @@ -0,0 +1 @@ +#include "t8103-u-boot.dtsi" diff --git a/arch/arm/dts/t8103-j457-u-boot.dtsi b/arch/arm/dts/t8103-j457-u-boot.dtsi new file mode 100644 index 0000000000..6c8dd5a56f --- /dev/null +++ b/arch/arm/dts/t8103-j457-u-boot.dtsi @@ -0,0 +1 @@ +#include "t8103-u-boot.dtsi" diff --git a/arch/arm/dts/t8103-u-boot.dtsi b/arch/arm/dts/t8103-u-boot.dtsi new file mode 100644 index 0000000000..43f552979d --- /dev/null +++ b/arch/arm/dts/t8103-u-boot.dtsi @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT + +&serial0 { + u-boot,dm-pre-reloc; +}; + +&pmgr { + u-boot,dm-pre-reloc; +}; + +&ps_sio_busif { + u-boot,dm-pre-reloc; +}; + +&ps_sio { + u-boot,dm-pre-reloc; +}; + +&ps_uart_p { + u-boot,dm-pre-reloc; +}; + +&ps_uart0 { + u-boot,dm-pre-reloc; +};
+&serial0 {
- u-boot,dm-pre-reloc;
+&pmgr {
+&ps_sio_busif {
+&ps_sio {
+&ps_uart_p {
+&ps_uart0 {
You should not need the empty files, not sure what is happening there.
This driver supports power domains for the power management controller found on Apple SoCs.
Signed-off-by: Mark Kettenis kettenis@openbsd.org --- arch/arm/Kconfig | 3 + drivers/power/domain/Kconfig | 8 +++ drivers/power/domain/Makefile | 1 + drivers/power/domain/apple-pmgr.c | 113 ++++++++++++++++++++++++++++++ 4 files changed, 125 insertions(+) create mode 100644 drivers/power/domain/apple-pmgr.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 59e031de04..40d3f66acb 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -938,6 +938,9 @@ config ARCH_APPLE select OF_BOARD select PINCTRL select POSITION_INDEPENDENT + select POWER_DOMAIN + select REGMAP + select SYSCON select SYSRESET select SYSRESET_WATCHDOG select SYSRESET_WATCHDOG_AUTO diff --git a/drivers/power/domain/Kconfig b/drivers/power/domain/Kconfig index 99b3f9ae71..6ef7a3b3a7 100644 --- a/drivers/power/domain/Kconfig +++ b/drivers/power/domain/Kconfig @@ -9,6 +9,14 @@ config POWER_DOMAIN domains). This may be used to save power. This API provides the means to control such power management hardware.
+config APPLE_PMGR_POWER_DOMAIN + bool "Enable the Apple PMGR power domain driver" + depends on POWER_DOMAIN + default y if ARCH_APPLE + help + Enable support for manipulating the Apple M1 power domains via + MMIO mapped registers. + config BCM6328_POWER_DOMAIN bool "Enable the BCM6328 power domain driver" depends on POWER_DOMAIN && ARCH_BMIPS diff --git a/drivers/power/domain/Makefile b/drivers/power/domain/Makefile index 3d1e5f073c..530ae35671 100644 --- a/drivers/power/domain/Makefile +++ b/drivers/power/domain/Makefile @@ -4,6 +4,7 @@ #
obj-$(CONFIG_$(SPL_)POWER_DOMAIN) += power-domain-uclass.o +obj-$(CONFIG_APPLE_PMGR_POWER_DOMAIN) += apple-pmgr.o obj-$(CONFIG_BCM6328_POWER_DOMAIN) += bcm6328-power-domain.o obj-$(CONFIG_IMX8_POWER_DOMAIN) += imx8-power-domain-legacy.o imx8-power-domain.o obj-$(CONFIG_IMX8M_POWER_DOMAIN) += imx8m-power-domain.o diff --git a/drivers/power/domain/apple-pmgr.c b/drivers/power/domain/apple-pmgr.c new file mode 100644 index 0000000000..08a30c8ebf --- /dev/null +++ b/drivers/power/domain/apple-pmgr.c @@ -0,0 +1,113 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 Mark Kettenis kettenis@openbsd.org + */ + +#include <common.h> +#include <asm/io.h> +#include <dm.h> +#include <linux/err.h> +#include <linux/bitfield.h> +#include <power-domain-uclass.h> +#include <regmap.h> +#include <syscon.h> + +#define APPLE_PMGR_PS_TARGET GENMASK(3, 0) +#define APPLE_PMGR_PS_ACTUAL GENMASK(7, 4) + +#define APPLE_PMGR_PS_ACTIVE 0xf +#define APPLE_PMGR_PS_PWRGATE 0x0 + +#define APPLE_PMGR_PS_SET_TIMEOUT 100 + +struct apple_pmgr_priv { + struct regmap *regmap; + u32 offset; +}; + +static int apple_pmgr_request(struct power_domain *power_domain) +{ + return 0; +} + +static int apple_pmgr_rfree(struct power_domain *power_domain) +{ + return 0; +} + +static int apple_pmgr_ps_set(struct power_domain *power_domain, u32 pstate) +{ + struct apple_pmgr_priv *priv = dev_get_priv(power_domain->dev); + uint reg; + + regmap_update_bits(priv->regmap, priv->offset, APPLE_PMGR_PS_TARGET, + FIELD_PREP(APPLE_PMGR_PS_TARGET, pstate)); + + return regmap_read_poll_timeout( + priv->regmap, priv->offset, reg, + (FIELD_GET(APPLE_PMGR_PS_ACTUAL, reg) == pstate), 1, + APPLE_PMGR_PS_SET_TIMEOUT); +} + +static int apple_pmgr_on(struct power_domain *power_domain) +{ + return apple_pmgr_ps_set(power_domain, APPLE_PMGR_PS_ACTIVE); +} + +static int apple_pmgr_off(struct power_domain *power_domain) +{ + return 0; +} + +static int apple_pmgr_of_xlate(struct power_domain *power_domain, + struct ofnode_phandle_args *args) +{ + if (args->args_count != 0) { + debug("Invalid args_count: %d\n", args->args_count); + return -EINVAL; + } + + return 0; +} + +static const struct udevice_id apple_pmgr_ids[] = { + { .compatible = "apple,pmgr-pwrstate" }, + { /* sentinel */ } +}; + +static int apple_pmgr_probe(struct udevice *dev) +{ + struct apple_pmgr_priv *priv = dev_get_priv(dev); + int ret; + + ret = dev_power_domain_on(dev); + if (ret) + return ret; + + priv->regmap = syscon_get_regmap(dev->parent); + if (IS_ERR(priv->regmap)) + return PTR_ERR(priv->regmap); + + ret = dev_read_u32(dev, "reg", &priv->offset); + if (ret < 0) + return ret; + + return 0; +} + +struct power_domain_ops apple_pmgr_ops = { + .request = apple_pmgr_request, + .rfree = apple_pmgr_rfree, + .on = apple_pmgr_on, + .off = apple_pmgr_off, + .of_xlate = apple_pmgr_of_xlate, +}; + +U_BOOT_DRIVER(apple_pmgr) = { + .name = "apple_pmgr", + .id = UCLASS_POWER_DOMAIN, + .of_match = apple_pmgr_ids, + .ops = &apple_pmgr_ops, + .probe = apple_pmgr_probe, + .priv_auto = sizeof(struct apple_pmgr_priv), +};
- select POWER_DOMAIN
- select REGMAP
- select SYSCON select SYSRESET select SYSRESET_WATCHDOG select SYSRESET_WATCHDOG_AUTO
- bool "Enable the Apple PMGR power domain driver"
- depends on POWER_DOMAIN
- default y if ARCH_APPLE
- help
- Copyright (C) 2021 Mark Kettenis kettenis@openbsd.org
- struct regmap *regmap;
- u32 offset;
- struct apple_pmgr_priv *priv = dev_get_priv(power_domain->dev);
- uint reg;
- regmap_update_bits(priv->regmap, priv->offset, APPLE_PMGR_PS_TARGET,
- return regmap_read_poll_timeout(
- return apple_pmgr_ps_set(power_domain, APPLE_PMGR_PS_ACTIVE);
- if (args->args_count != 0) {
return -EINVAL;
- { .compatible = "apple,pmgr-pwrstate" },
- { /* sentinel */ }
- struct apple_pmgr_priv *priv = dev_get_priv(dev);
- int ret;
- ret = dev_power_domain_on(dev);
- if (ret)
return ret;
- priv->regmap = syscon_get_regmap(dev->parent);
- if (IS_ERR(priv->regmap))
- ret = dev_read_u32(dev, "reg", &priv->offset);
- if (ret < 0)
return ret;
- .request = apple_pmgr_request,
- .rfree = apple_pmgr_rfree,
- .on = apple_pmgr_on,
- .off = apple_pmgr_off,
- .of_xlate = apple_pmgr_of_xlate,
- .name = "apple_pmgr",
- .id = UCLASS_POWER_DOMAIN,
- .of_match = apple_pmgr_ids,
- .ops = &apple_pmgr_ops,
- .probe = apple_pmgr_probe,
- .priv_auto = sizeof(struct apple_pmgr_priv),
Hi Mark,
nits below
select POWER_DOMAIN
select REGMAP
help
Needs more detail here, perhaps a pointer to docs, or something about what the driver supports.
TIMEOUT_MS ? _US ?
u32 offset;
Needs comment for struct
uint reg;
s/ != 0//
return -EINVAL;
{ /* sentinel */ }
int ret;
if (ret)
return ret;
if (ret < 0)
return ret;
2.34.1
From: Simon Glass sjg@chromium.org Date: Tue, 28 Dec 2021 01:34:16 -0700
Hi Mark,
nits below
select POWER_DOMAIN
select REGMAP
help
Struggling to come up with more. The "via MMIO mapped registers" is already a bit silly. There are no docs. And the one line already indicates what the driver supports. Do you want me to add a sentence that says the same thing but in different words?
TIMEOUT_MS ? _US ?
_US
u32 offset;
Really? I mean, I can add a "Device private data" comment, but that's pretty much implied by the _priv and the vast majority of the drivers don't do such a thing.
uint reg;
s/ != 0//
!= 0 seems better here since that is the value we're checking for.
return -EINVAL;
{ /* sentinel */ }
int ret;
if (ret)
return ret;
if (ret < 0)
return ret;
2.34.1
Hi Mark,
Hi Mark,
nits below
select POWER_DOMAIN
select REGMAP
help
What is PMGR?
What power domains does the driver support? All of them or just a subset?
TIMEOUT_MS ? _US ?
_US
u32 offset;
What is offset?
uint reg;
s/ != 0//
It can't be negative though.
From: Simon Glass sjg@chromium.org Date: Wed, 29 Dec 2021 06:36:24 -0700
Hi Mark,
Hi Mark,
nits below
select POWER_DOMAIN
select REGMAP
help
What is PMGR?
Power ManaGeR? Who knows? It is wat Apple seems to call this thing.
Again, we don't know. It supports the power domains we know about.
This is revers-engineered and most of the naming comes from hints dropped by Apple in their version of the device tree and/or the macOS driver names. The more we say here, the more likely it is wrong.
TIMEOUT_MS ? _US ?
_US
u32 offset;
What is offset?
The offset into the register map for this particular power domain. Adding a comment feels like stating the obvious to me. But if you feel it needs one, I can add it.
uint reg;
s/ != 0//
Hi Mark,
Hi Mark,
Hi Mark,
nits below
select POWER_DOMAIN
select REGMAP
help
What is PMGR?
TIMEOUT_MS ? _US ?
_US
u32 offset;
What is offset?
Yes please.
Re the other things, just do your best. We often have docs problems, so Apple is not unique here.
Jaehoon Chung
Mark Kettenis
Mark Kettenis
