[U-Boot] [PATCH] fastboot: Replace literal 32 with PART_NAME_LEN
Where we have to compute partition names, rather than using a hardcoded 32 for the partition name length, replace with PART_NAME_LEN.
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com ---
drivers/fastboot/fb_mmc.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/fastboot/fb_mmc.c b/drivers/fastboot/fb_mmc.c index 4c1c7fd2cd8d..3cebedcd5a92 100644 --- a/drivers/fastboot/fb_mmc.c +++ b/drivers/fastboot/fb_mmc.c @@ -31,13 +31,13 @@ static int part_get_info_by_name_or_alias(struct blk_desc *dev_desc,
ret = part_get_info_by_name(dev_desc, name, info); if (ret < 0) { - /* strlen("fastboot_partition_alias_") + 32(part_name) + 1 */ - char env_alias_name[25 + 32 + 1]; + /* strlen("fastboot_partition_alias_") + PART_NAME_LEN + 1 */ + char env_alias_name[25 + PART_NAME_LEN + 1]; char *aliased_part_name;
/* check for alias */ strcpy(env_alias_name, "fastboot_partition_alias_"); - strncat(env_alias_name, name, 32); + strncat(env_alias_name, name, PART_NAME_LEN); aliased_part_name = env_get(env_alias_name); if (aliased_part_name != NULL) ret = part_get_info_by_name(dev_desc,
Running `md5sum drivers/fastboot/fb_mmc.o` before and after the change returns the same result, so this is expectedly a non-functional change.
In addition, `git grep -w 32 -- drivers/fastboot/` reveals no other occurrences of the magic number, except in below line where it stands for something unrelated to partition name length: drivers/fastboot/fb_command.c: char cmdbuf[32];
Reviewed-by: Eugeniu Rosca rosca.eugeniu@gmail.com
Alex Kiernan
Eugeniu Rosca
