[PATCH 0/3] arm: bcmbca: move bcm68360 support under CONFIG_ARCH_BCMBCA
BCM68360 is a variant for the main PON chip BCM6856 which is part of the Broadcom BCA (Broadband Carrier Access origin) chipset family. BCM68360 was originally added by Philippe before Broadcom started to upstream the support for BCMBCA SoCs. The ARM based Broadband SoC family is now supported under the unified ARCH_BCMBCA config. This patch series migrate the BCM68360 support under the config of ARCH_BCMBCA and BCM6856.
This patch series need to apply on top of my previous patch series [1].
[1] https://lists.denx.de/pipermail/u-boot/2022-August/491581.html
William Zhang (3): arm: bcmbca: add bcm6856 SoC support under CONFIG_ARCH_BCMBCA arm: bcmbca: remove bcm68360 support under CONFIG_ARCH_BCM68360 arm: bcmbca: make bcm68360 driver depending on CONFIG_BCM6856
MAINTAINERS | 1 + arch/arm/Kconfig | 7 - arch/arm/dts/Makefile | 6 +- arch/arm/dts/bcm68360.dtsi | 217 ------------------- arch/arm/dts/bcm6856.dtsi | 252 +++++++++++++++++++++++ arch/arm/dts/bcm968360bg.dts | 6 +- arch/arm/dts/bcm96856.dts | 30 +++ arch/arm/mach-bcmbca/Kconfig | 8 + arch/arm/mach-bcmbca/Makefile | 1 + arch/arm/mach-bcmbca/bcm6856/Kconfig | 17 ++ arch/arm/mach-bcmbca/bcm6856/Makefile | 5 + arch/arm/mach-bcmbca/bcm6856/mmu_table.c | 32 +++ board/broadcom/bcm968360bg/Kconfig | 17 -- board/broadcom/bcm968360bg/MAINTAINERS | 6 - board/broadcom/bcm968360bg/Makefile | 3 - board/broadcom/bcm968360bg/bcm968360bg.c | 62 ------ board/broadcom/bcmbca/Kconfig | 7 + configs/bcm968360bg_ram_defconfig | 10 +- configs/bcm96856_defconfig | 23 +++ drivers/gpio/Kconfig | 2 +- drivers/led/Kconfig | 2 +- drivers/mtd/nand/raw/Kconfig | 2 +- drivers/spi/Kconfig | 2 +- drivers/watchdog/Kconfig | 2 +- include/configs/bcm96856.h | 15 ++ include/configs/broadcom_bcm968360bg.h | 32 --- 26 files changed, 407 insertions(+), 360 deletions(-) delete mode 100644 arch/arm/dts/bcm68360.dtsi create mode 100644 arch/arm/dts/bcm6856.dtsi create mode 100644 arch/arm/dts/bcm96856.dts create mode 100644 arch/arm/mach-bcmbca/bcm6856/Kconfig create mode 100644 arch/arm/mach-bcmbca/bcm6856/Makefile create mode 100644 arch/arm/mach-bcmbca/bcm6856/mmu_table.c delete mode 100644 board/broadcom/bcm968360bg/Kconfig delete mode 100644 board/broadcom/bcm968360bg/MAINTAINERS delete mode 100644 board/broadcom/bcm968360bg/Makefile delete mode 100644 board/broadcom/bcm968360bg/bcm968360bg.c create mode 100644 configs/bcm96856_defconfig create mode 100644 include/configs/bcm96856.h delete mode 100644 include/configs/broadcom_bcm968360bg.h
William Zhang
