[U-Boot] [PATCH v2 0/3] ddr: vybrid: Support for vf610 built-in DDR3 memory calibration
This patch series provides code to perform read leveling - RDLVL, which is adjusting the DQS strobe in relation to the DQ signals so that the strobe edge is centered in the window of valid read data.
The code is based on Vybrid's Reference Manual's: "VFxxx Controller Reference Manual, Rev. 0, 10/2016", page 1600, 10.1.6.16.4.1 "Software Read Leveling in MC Evaluation Mode"
and uses clarification provided by following NXP's community thread: "Vybrid: About DDR leveling feature on DDRMC." https://community.nxp.com/thread/395323
It depends on a BITMAP rework patch: usb: composite: Move bitmap related operations to ./include/linux/bitmap.h http://patchwork.ozlabs.org/patch/1006448/
Changes in v2: - CR93_SWLVL_EXIT -> CR94_SWLVL_EXIT (EXIT is in CR94) - Add more defines to imx-regs.h (moved from *-calibration.h) - CR93_SWLVL_EXIT -> CR94_SWLVL_EXIT (EXIT is in CR94) - Update Kconfig information regarding DDRMC_VF610_CALIBRATION - Update ddrmc-vf610-calibration. comment - Update code after extending imx-regs.h - Remove not needed #ifdef
Lukasz Majewski (3): ddr: vybrid: Add DDRMC calibration related registers (DQS to DQ) ddr: vybrid: Provide code to perform on-boot calibration ddr: vybrid: Add calibration code to memory controler's (DDRMC) setup code
arch/arm/include/asm/arch-vf610/imx-regs.h | 14 +- arch/arm/mach-imx/Kconfig | 12 + arch/arm/mach-imx/Makefile | 1 + arch/arm/mach-imx/ddrmc-vf610-calibration.c | 342 ++++++++++++++++++++++++++++ arch/arm/mach-imx/ddrmc-vf610-calibration.h | 45 ++++ arch/arm/mach-imx/ddrmc-vf610.c | 5 + 6 files changed, 418 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-imx/ddrmc-vf610-calibration.c create mode 100644 arch/arm/mach-imx/ddrmc-vf610-calibration.h
This commit provides extra defines needed for DDR memory controller calibration (read leveling performing).
Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Stefan Agner stefan.agner@toradex.com
arch/arm/include/asm/arch-vf610/imx-regs.h | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-vf610/imx-regs.h b/arch/arm/include/asm/arch-vf610/imx-regs.h index 08ba8e94f8..e3209b0f56 100644 --- a/arch/arm/include/asm/arch-vf610/imx-regs.h +++ b/arch/arm/include/asm/arch-vf610/imx-regs.h @@ -206,15 +206,27 @@ #define DDRMC_CR88_TODTL_CMD(v) (((v) & 0x1f) << 16) #define DDRMC_CR89_AODT_RWSMCS(v) ((v) & 0xf) #define DDRMC_CR91_R2W_SMCSDL(v) (((v) & 0x7) << 16) +#define DDRMC_CR93_SW_LVL_MODE_OFF (8) +#define DDRMC_CR93_SW_LVL_MODE(v) (((v) & 0x3) << DDRMC_CR93_SW_LVL_MODE_OFF) +#define DDRMC_CR93_SWLVL_LOAD BIT(16) +#define DDRMC_CR93_SWLVL_START BIT(24) +#define DDRMC_CR94_SWLVL_EXIT BIT(0) +#define DDRMC_CR94_SWLVL_OP_DONE BIT(8) +#define DDRMC_CR94_SWLVL_RESP_0_OFF (24) +#define DDRMC_CR95_SWLVL_RESP_1_OFF (0) #define DDRMC_CR96_WLMRD(v) (((v) & 0x3f) << 8) #define DDRMC_CR96_WLDQSEN(v) ((v) & 0x3f) #define DDRMC_CR97_WRLVL_EN (1 << 24) #define DDRMC_CR98_WRLVL_DL_0(v) ((v) & 0xffff) #define DDRMC_CR99_WRLVL_DL_1(v) ((v) & 0xffff) +#define DDRMC_CR101_PHY_RDLVL_EDGE_OFF (24) +#define DDRMC_CR101_PHY_RDLVL_EDGE BIT(DDRMC_CR101_PHY_RDLVL_EDGE_OFF) #define DDRMC_CR102_RDLVL_GT_REGEN (1 << 16) #define DDRMC_CR102_RDLVL_REG_EN (1 << 8) -#define DDRMC_CR105_RDLVL_DL_0(v) (((v) & 0xff) << 8) +#define DDRMC_CR105_RDLVL_DL_0_OFF (8) +#define DDRMC_CR105_RDLVL_DL_0(v) (((v) & 0xff) << DDRMC_CR105_RDLVL_DL_0_OFF) #define DDRMC_CR106_RDLVL_GTDL_0(v) ((v) & 0xff) +#define DDRMC_CR110_RDLVL_DL_1_OFF (0) #define DDRMC_CR110_RDLVL_DL_1(v) ((v) & 0xff) #define DDRMC_CR110_RDLVL_GTDL_1(v) (((v) & 0xff) << 16) #define DDRMC_CR114_RDLVL_GTDL_2(v) (((v) & 0xffff) << 8)
This commit provides extra defines needed for DDR memory controller calibration (read leveling performing). Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Stefan Agner stefan.agner@toradex.com
Best regards, Stefano Babic
This patch provides the code to calibrate the DDR's DQS to DQ signals (RDLVL).
It is based on: VFxxx Controller Reference Manual, Rev. 0, 10/2016, page 1600 10.1.6.16.4.1 "Software Read Leveling in MC Evaluation Mode"
and NXP's community thread: "Vybrid: About DDR leveling feature on DDRMC." https://community.nxp.com/thread/395323
Changes in v2: - CR93_SWLVL_EXIT -> CR94_SWLVL_EXIT (EXIT is in CR94) - Update Kconfig information regarding DDRMC_VF610_CALIBRATION - Update ddrmc-vf610-calibration. comment - Update code after extending imx-regs.h
arch/arm/mach-imx/Kconfig | 12 + arch/arm/mach-imx/Makefile | 1 + arch/arm/mach-imx/ddrmc-vf610-calibration.c | 342 ++++++++++++++++++++++++++++ arch/arm/mach-imx/ddrmc-vf610-calibration.h | 45 ++++ 4 files changed, 400 insertions(+) create mode 100644 arch/arm/mach-imx/ddrmc-vf610-calibration.c create mode 100644 arch/arm/mach-imx/ddrmc-vf610-calibration.h
diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig index a1566cc2ad..8631fbd481 100644 --- a/arch/arm/mach-imx/Kconfig +++ b/arch/arm/mach-imx/Kconfig @@ -78,3 +78,15 @@ config NXP_BOARD_REVISION NXP boards based on i.MX6/7 contain the board revision information stored in the fuses. Select this option if you want to be able to retrieve the board revision information. + +config DDRMC_VF610_CALIBRATION + bool "Enable DDRMC (DDR3) on-chip calibration" + depends on ARCH_VF610 + help + Vybrid (vf610) SoC provides some on-chip facility to tune the DDR3 + memory parameters. Select this option if you want to calculate them + at boot time. + NOTE: + NXP does NOT recommend to perform this calibration at each boot. One + shall perform it on a new PCB and then use those values to program + the ddrmc_cr_setting on relevant board file. diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index 53d9e5f42b..4a07b1ea69 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -51,6 +51,7 @@ obj-$(CONFIG_SECURE_BOOT) += hab.o endif ifeq ($(SOC),$(filter $(SOC),vf610)) obj-y += ddrmc-vf610.o +obj-$(CONFIG_DDRMC_VF610_CALIBRATION) += ddrmc-vf610-calibration.o endif ifneq ($(CONFIG_SPL_BUILD),y) obj-$(CONFIG_CMD_BMODE) += cmd_bmode.o diff --git a/arch/arm/mach-imx/ddrmc-vf610-calibration.c b/arch/arm/mach-imx/ddrmc-vf610-calibration.c new file mode 100644 index 0000000000..f29de74c39 --- /dev/null +++ b/arch/arm/mach-imx/ddrmc-vf610-calibration.c @@ -0,0 +1,342 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ddrmc DDR3 calibration code for NXP's VF610 + * + * Copyright (C) 2018 DENX Software Engineering + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + */ +/* #define DEBUG */ +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <linux/bitmap.h> + +#include "ddrmc-vf610-calibration.h" + +/* + * Documents: + * + * [1] "Vybrid: About DDR leveling feature on DDRMC." + * https://community.nxp.com/thread/395323 + * + * [2] VFxxx Controller Reference Manual, Rev. 0, 10/2016 + * + * + * NOTE + * ==== + * + * NXP recommends setting 'fixed' parameters instead of performing the + * training at each boot. + * + * Use those functions to determine those values on new HW, read the + * calculated value from registers and add them to the board specific + * struct ddrmc_cr_setting. + * + * SW leveling supported operations - CR93[SW_LVL_MODE]: + * + * - 0x0 (b'00) - No leveling + * + * - 0x1 (b'01) - WRLVL_DL_X - It is not recommended to perform this tuning + * on HW designs utilizing non-flyback topology + * (Single DDR3 with x16). + * Instead the WRLVL_DL_0/1 fields shall be set + * based on trace length differences from their + * layout. + * Mismatches up to 25% or tCK (clock period) are + * allowed, so the value in the filed doesn’t have + * to be very accurate. + * + * - 0x2 (b'10) - RDLVL_DL_0/1 - refers to adjusting the DQS strobe in relation + * to the DQ signals so that the strobe edge is + * centered in the window of valid read data. + * + * - 0x3 (b'11) - RDLVL_GTDL_0/1 - refers to the delay the PHY uses to un-gate + * the Read DQS strobe pad from the time that the + * PHY enables the pad to input the strobe signal. + * + */ +static int ddr_cal_get_first_edge_index(unsigned long *bmap, enum edge e, + int samples, int start, int max) +{ + int i, ret = -1; + + /* + * We look only for the first value (and filter out + * some wrong data) + */ + switch (e) { + case RISING_EDGE: + for (i = start; i <= max - samples; i++) { + if (test_bit(i, bmap)) { + if (!test_bit(i - 1, bmap) && + test_bit(i + 1, bmap) && + test_bit(i + 2, bmap) && + test_bit(i + 3, bmap)) { + return i; + } + } + } + break; + case FALLING_EDGE: + for (i = start; i <= max - samples; i++) { + if (!test_bit(i, bmap)) { + if (test_bit(i - 1, bmap) && + test_bit(i - 2, bmap) && + test_bit(i - 3, bmap)) { + return i; + } + } + } + } + + return ret; +} + +static void bitmap_print(unsigned long *bmap, int max) +{ + int i; + + debug("BITMAP [0x%p]:\n", bmap); + for (i = 0; i <= max; i++) { + debug("%d ", test_bit(i, bmap) ? 1 : 0); + if (i && (i % 32) == (32 - 1)) + debug("\n"); + } + debug("\n"); +} + +#define sw_leveling_op_done \ + while (!(readl(&ddrmr->cr[94]) & DDRMC_CR94_SWLVL_OP_DONE)) + +#define sw_leveling_load_value \ + do { clrsetbits_le32(&ddrmr->cr[93], DDRMC_CR93_SWLVL_LOAD, \ + DDRMC_CR93_SWLVL_LOAD); } while (0) + +#define sw_leveling_start \ + do { clrsetbits_le32(&ddrmr->cr[93], DDRMC_CR93_SWLVL_START, \ + DDRMC_CR93_SWLVL_START); } while (0) + +#define sw_leveling_exit \ + do { clrsetbits_le32(&ddrmr->cr[94], DDRMC_CR94_SWLVL_EXIT, \ + DDRMC_CR94_SWLVL_EXIT); } while (0) + +/* + * RDLVL_DL calibration: + * + * NXP is _NOT_ recommending performing the leveling at each + * boot. Instead - one shall run this procedure on new boards + * and then use hardcoded values. + * + */ +static int ddrmc_cal_dqs_to_dq(struct ddrmr_regs *ddrmr) +{ + DECLARE_BITMAP(rdlvl_rsp, DDRMC_DQS_DQ_MAX_DELAY + 1); + int rdlvl_dl_0_min = -1, rdlvl_dl_0_max = -1; + int rdlvl_dl_1_min = -1, rdlvl_dl_1_max = -1; + int rdlvl_dl_0, rdlvl_dl_1; + u8 swlvl_rsp; + u32 tmp; + int i; + + /* Read defaults */ + u16 rdlvl_dl_0_def = + (readl(&ddrmr->cr[105]) >> DDRMC_CR105_RDLVL_DL_0_OFF) & 0xFFFF; + u16 rdlvl_dl_1_def = readl(&ddrmr->cr[110]) & 0xFFFF; + + debug("\nRDLVL: ======================\n"); + debug("RDLVL: DQS to DQ (RDLVL)\n"); + + debug("RDLVL: RDLVL_DL_0_DFL:\t 0x%x\n", rdlvl_dl_0_def); + debug("RDLVL: RDLVL_DL_1_DFL:\t 0x%x\n", rdlvl_dl_1_def); + + /* + * Set/Read setup for calibration + * + * Values necessary for leveling from Vybrid RM [2] - page 1600 + */ + writel(0x40703030, &ddrmr->cr[144]); + writel(0x40, &ddrmr->cr[145]); + writel(0x40, &ddrmr->cr[146]); + + tmp = readl(&ddrmr->cr[144]); + debug("RDLVL: PHY_RDLVL_RES:\t 0x%x\n", (tmp >> 24) & 0xFF);// set 0x40 + debug("RDLVL: PHY_RDLV_LOAD:\t 0x%x\n", (tmp >> 16) & 0xFF);// set 0x70 + debug("RDLVL: PHY_RDLV_DLL:\t 0x%x\n", (tmp >> 8) & 0xFF); // set 0x30 + debug("RDLVL: PHY_RDLV_EN:\t 0x%x\n", tmp & 0xFF); //set 0x30 + + tmp = readl(&ddrmr->cr[145]); + debug("RDLVL: PHY_RDLV_RR:\t 0x%x\n", tmp & 0x3FF); //set 0x40 + + tmp = readl(&ddrmr->cr[146]); + debug("RDLVL: PHY_RDLV_RESP:\t 0x%x\n", tmp); //set 0x40 + + /* + * Program/read the leveling edge RDLVL_EDGE = 0 + * + * 0x00 is the correct output on SWLVL_RSP_X + * If by any chance 1s are visible -> wrong number read + */ + clrbits_le32(&ddrmr->cr[101], DDRMC_CR101_PHY_RDLVL_EDGE); + + tmp = readl(&ddrmr->cr[101]); + debug("RDLVL: PHY_RDLVL_EDGE:\t 0x%x\n", + (tmp >> DDRMC_CR101_PHY_RDLVL_EDGE_OFF) & 0x1); //set 0 + + /* Program Leveling mode - CR93[SW_LVL_MODE] to ’b10 */ + clrsetbits_le32(&ddrmr->cr[93], DDRMC_CR93_SW_LVL_MODE(0x3), + DDRMC_CR93_SW_LVL_MODE(0x2)); + tmp = readl(&ddrmr->cr[93]); + debug("RDLVL: SW_LVL_MODE:\t 0x%x\n", + (tmp >> DDRMC_CR93_SW_LVL_MODE_OFF) & 0x3); + + /* Start procedure - CR93[SWLVL_START] to ’b1 */ + sw_leveling_start; + + /* Poll CR94[SWLVL_OP_DONE] */ + sw_leveling_op_done; + + /* + * Program delays for RDLVL_DL_0 + * + * The procedure is to increase the delay values from 0 to 0xFF + * and read the response from the DDRMC + */ + debug("\nRDLVL: ---> RDLVL_DL_0\n"); + bitmap_zero(rdlvl_rsp, DDRMC_DQS_DQ_MAX_DELAY + 1); + + for (i = 0; i <= DDRMC_DQS_DQ_MAX_DELAY; i++) { + clrsetbits_le32(&ddrmr->cr[105], + 0xFFFF << DDRMC_CR105_RDLVL_DL_0_OFF, + i << DDRMC_CR105_RDLVL_DL_0_OFF); + + /* Load values CR93[SWLVL_LOAD] to ’b1 */ + sw_leveling_load_value; + + /* Poll CR94[SWLVL_OP_DONE] */ + sw_leveling_op_done; + + /* + * Read Responses - SWLVL_RESP_0 + * + * The 0x00 (correct response when PHY_RDLVL_EDGE = 0) + * -> 1 in the bit vector + */ + swlvl_rsp = (readl(&ddrmr->cr[94]) >> + DDRMC_CR94_SWLVL_RESP_0_OFF) & 0xF; + if (swlvl_rsp == 0) + generic_set_bit(i, rdlvl_rsp); + } + + bitmap_print(rdlvl_rsp, DDRMC_DQS_DQ_MAX_DELAY); + + /* + * First test for rising edge 0x0 -> 0x1 in bitmap + */ + rdlvl_dl_0_min = ddr_cal_get_first_edge_index(rdlvl_rsp, RISING_EDGE, + N_SAMPLES, N_SAMPLES, + DDRMC_DQS_DQ_MAX_DELAY); + + /* + * Secondly test for falling edge 0x1 -> 0x0 in bitmap + */ + rdlvl_dl_0_max = ddr_cal_get_first_edge_index(rdlvl_rsp, FALLING_EDGE, + N_SAMPLES, rdlvl_dl_0_min, + DDRMC_DQS_DQ_MAX_DELAY); + + debug("RDLVL: DL_0 min: %d [0x%x] DL_0 max: %d [0x%x]\n", + rdlvl_dl_0_min, rdlvl_dl_0_min, rdlvl_dl_0_max, rdlvl_dl_0_max); + rdlvl_dl_0 = (rdlvl_dl_0_max - rdlvl_dl_0_min) / 2; + + if (rdlvl_dl_0_max == -1 || rdlvl_dl_0_min == -1 || rdlvl_dl_0 <= 0) { + debug("RDLVL: The DQS to DQ delay cannot be found!\n"); + debug("RDLVL: Using default - slice 0: %d!\n", rdlvl_dl_0_def); + rdlvl_dl_0 = rdlvl_dl_0_def; + } + + debug("\nRDLVL: ---> RDLVL_DL_1\n"); + bitmap_zero(rdlvl_rsp, DDRMC_DQS_DQ_MAX_DELAY + 1); + + for (i = 0; i <= DDRMC_DQS_DQ_MAX_DELAY; i++) { + clrsetbits_le32(&ddrmr->cr[110], + 0xFFFF << DDRMC_CR110_RDLVL_DL_1_OFF, + i << DDRMC_CR110_RDLVL_DL_1_OFF); + + /* Load values CR93[SWLVL_LOAD] to ’b1 */ + sw_leveling_load_value; + + /* Poll CR94[SWLVL_OP_DONE] */ + sw_leveling_op_done; + + /* + * Read Responses - SWLVL_RESP_1 + * + * The 0x00 (correct response when PHY_RDLVL_EDGE = 0) + * -> 1 in the bit vector + */ + swlvl_rsp = (readl(&ddrmr->cr[95]) >> + DDRMC_CR95_SWLVL_RESP_1_OFF) & 0xF; + if (swlvl_rsp == 0) + generic_set_bit(i, rdlvl_rsp); + } + + bitmap_print(rdlvl_rsp, DDRMC_DQS_DQ_MAX_DELAY); + + /* + * First test for rising edge 0x0 -> 0x1 in bitmap + */ + rdlvl_dl_1_min = ddr_cal_get_first_edge_index(rdlvl_rsp, RISING_EDGE, + N_SAMPLES, N_SAMPLES, + DDRMC_DQS_DQ_MAX_DELAY); + + /* + * Secondly test for falling edge 0x1 -> 0x0 in bitmap + */ + rdlvl_dl_1_max = ddr_cal_get_first_edge_index(rdlvl_rsp, FALLING_EDGE, + N_SAMPLES, rdlvl_dl_1_min, + DDRMC_DQS_DQ_MAX_DELAY); + + debug("RDLVL: DL_1 min: %d [0x%x] DL_1 max: %d [0x%x]\n", + rdlvl_dl_1_min, rdlvl_dl_1_min, rdlvl_dl_1_max, rdlvl_dl_1_max); + rdlvl_dl_1 = (rdlvl_dl_1_max - rdlvl_dl_1_min) / 2; + + if (rdlvl_dl_1_max == -1 || rdlvl_dl_1_min == -1 || rdlvl_dl_1 <= 0) { + debug("RDLVL: The DQS to DQ delay cannot be found!\n"); + debug("RDLVL: Using default - slice 1: %d!\n", rdlvl_dl_1_def); + rdlvl_dl_1 = rdlvl_dl_1_def; + } + + debug("RDLVL: CALIBRATED: rdlvl_dl_0: 0x%x\t rdlvl_dl_1: 0x%x\n", + rdlvl_dl_0, rdlvl_dl_1); + + /* Write new delay values */ + writel(DDRMC_CR105_RDLVL_DL_0(rdlvl_dl_0), &ddrmr->cr[105]); + writel(DDRMC_CR110_RDLVL_DL_1(rdlvl_dl_1), &ddrmr->cr[110]); + + sw_leveling_load_value; + sw_leveling_op_done; + + /* Exit procedure - CR94[SWLVL_EXIT] to ’b1 */ + sw_leveling_exit; + + /* Poll CR94[SWLVL_OP_DONE] */ + sw_leveling_op_done; + + return 0; +} + +/* + * WRLVL_DL calibration: + * + * For non-flyback memory architecture - where one have a single DDR3 x16 + * memory - it is NOT necessary to perform "Write Leveling" + * [3] 'Vybrid DDR3 write leveling' https://community.nxp.com/thread/429362 + * + */ + +int ddrmc_calibration(struct ddrmr_regs *ddrmr) +{ + ddrmc_cal_dqs_to_dq(ddrmr); + + return 0; +} diff --git a/arch/arm/mach-imx/ddrmc-vf610-calibration.h b/arch/arm/mach-imx/ddrmc-vf610-calibration.h new file mode 100644 index 0000000000..e82e217ab3 --- /dev/null +++ b/arch/arm/mach-imx/ddrmc-vf610-calibration.h @@ -0,0 +1,45 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * ddrmc DDR3 calibration code for NXP's VF610 + * + * Copyright (C) 2018 DENX Software Engineering + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + * + */ + +#ifndef __DDRMC_VF610_CALIBRATOIN_H_ +#define __DDRMC_VF610_CALIBRATOIN_H_ + +/* + * Number of "samples" in the calibration bitmap + * to be considered during calibration. + */ +#define N_SAMPLES 3 + +/* + * Constants to indicate if we are looking for a rising or + * falling edge in the calibration bitmap + */ +enum edge { + FALLING_EDGE = 1, + RISING_EDGE +}; + +/* + * The max number of delay elements when DQS to DQ setting + */ +#define DDRMC_DQS_DQ_MAX_DELAY 0xFF + +/** + * ddrmc_calibration - Vybrid's (VF610) DDR3 calibration code + * + * This function is calculating proper memory controller values + * during run time. + * + * @param ddrmr_regs - memory controller registers + * + * @return 0 on success, otherwise error code + */ +int ddrmc_calibration(struct ddrmr_regs *ddrmr); + +#endif /* __DDRMC_VF610_CALIBRATOIN_H_ */
This patch provides the code to calibrate the DDR's DQS to DQ signals (RDLVL). It is based on: VFxxx Controller Reference Manual, Rev. 0, 10/2016, page 1600 10.1.6.16.4.1 "Software Read Leveling in MC Evaluation Mode" and NXP's community thread: "Vybrid: About DDR leveling feature on DDRMC." https://community.nxp.com/thread/395323 Signed-off-by: Lukasz Majewski lukma@denx.de
This patch extends the vf610 DDR memory controller code to support SW leveling.
Changes in v2: - Remove not needed #ifdef
arch/arm/mach-imx/ddrmc-vf610.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/mach-imx/ddrmc-vf610.c b/arch/arm/mach-imx/ddrmc-vf610.c index ea6a49e0fa..2f59ec907f 100644 --- a/arch/arm/mach-imx/ddrmc-vf610.c +++ b/arch/arm/mach-imx/ddrmc-vf610.c @@ -10,6 +10,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/iomux-vf610.h> #include <asm/arch/ddrmc-vf610.h> +#include "ddrmc-vf610-calibration.h"
void ddrmc_setup_iomux(const iomux_v3_cfg_t *pads, int pads_count) { @@ -233,4 +234,8 @@ void ddrmc_ctrl_init_ddr3(struct ddr3_jedec_timings const *timings,
while (!(readl(&ddrmr->cr[80]) & 0x100)) udelay(10); + +#ifdef CONFIG_DDRMC_VF610_CALIBRATION + ddrmc_calibration(ddrmr); +#endif }
This patch extends the vf610 DDR memory controller code to support SW leveling. Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Stefan Agner stefan.agner@toradex.com
Hi Fabio, Stefano,
The above patch has found its way to main line, so there is no obstacles to pull this code.
Moreover, some Stefan's patches: [U-Boot,v1,0/4] ddr: vybrid: various fixes
http://patchwork.ozlabs.org/cover/1007547/
Are also related to DDR_MC setup on Vybrid and fix/cleanup some issues.
Changes in v2:
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Lukasz Majewski
sbabic@denx.de
