[U-Boot] [Patch V3] arm: dts: omap3: Re-sync DTS files with Linux 4.13-RC5
The DTS files had some spacing issues and they needed fixing. This pull re-sync's the OMAP3xx related DTS files with Linux 4.13-RC5.
To keep the DTS and DTSI files clean and in sync with Linux, new u-boot.dtsi files are added.
Signed-off-by: Adam Ford aford173@gmail.com
V3: The resync broke card detect on MMC1 on Logic PD's Torpedo, so we add the cd-invert to the Torpedo's -u-boot.dtsi file.
V2: Add the u-boot.dtsi files for OMAP3, OMAP36xx, and Torpedo Remove the need for the second patch in the series --- .../dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi | 45 + arch/arm/dts/logicpd-torpedo-37xx-devkit.dts | 15 +- arch/arm/dts/omap3-cpu-thermal.dtsi | 20 + arch/arm/dts/omap3-u-boot.dtsi | 19 + arch/arm/dts/omap3.dtsi | 1676 +++++----- arch/arm/dts/omap34xx-omap36xx-clocks.dtsi | 448 +-- .../omap36xx-am35xx-omap3430es2plus-clocks.dtsi | 452 +-- arch/arm/dts/omap36xx-clocks.dtsi | 148 +- arch/arm/dts/omap36xx-omap3430es2plus-clocks.dtsi | 368 +-- arch/arm/dts/omap36xx-u-boot.dtsi | 10 + arch/arm/dts/omap36xx.dtsi | 172 +- arch/arm/dts/omap3xxx-clocks.dtsi | 3292 ++++++++++---------- arch/arm/mach-omap2/omap3/Kconfig | 1 + 13 files changed, 3382 insertions(+), 3284 deletions(-)
diff --git a/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi new file mode 100644 index 0000000..85cb548 --- /dev/null +++ b/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2017 + * Logic PD - http://www.logicpd.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/ { + chosen { + stdout-path = &uart1; + }; +}; + +&i2c1 { + clock-frequency = <400000>; +}; + +&i2c2 { + clock-frequency = <400000>; +}; + +&mmc1 { + cd-inverted; +}; + +&mmc2 { + status = "disabled"; +}; + +&mmc3 { + status = "disabled"; +}; + +&uart1 { + reg-shift = <2>; +}; + +&uart2 { + reg-shift = <2>; +}; + +&uart3 { + reg-shift = <2>; +}; + diff --git a/arch/arm/dts/logicpd-torpedo-37xx-devkit.dts b/arch/arm/dts/logicpd-torpedo-37xx-devkit.dts index de603a4..43e9364 100644 --- a/arch/arm/dts/logicpd-torpedo-37xx-devkit.dts +++ b/arch/arm/dts/logicpd-torpedo-37xx-devkit.dts @@ -14,10 +14,6 @@ model = "LogicPD Zoom DM3730 Torpedo + Wireless Development Kit"; compatible = "logicpd,dm3730-torpedo-devkit", "ti,omap3630", "ti,omap3";
- chosen { - stdout-path = &uart1; - }; - gpio_keys { compatible = "gpio-keys"; pinctrl-names = "default"; @@ -196,15 +192,12 @@ interrupts-extended = <&intc 83 &omap3_pmx_core 0x11a>; pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins &mmc1_cd>; + cd-gpios = <&gpio4 31 IRQ_TYPE_LEVEL_LOW>; /* gpio127 */ vmmc-supply = <&vmmc1>; bus-width = <4>; cap-power-off-card; };
-&mmc2 { - status = "disabled"; -}; - &omap3_pmx_core { gpio_key_pins: pinmux_gpio_key_pins { pinctrl-single,pins = < @@ -256,9 +249,9 @@ OMAP3_CORE1_IOPAD(0x2110, PIN_INPUT | MUX_MODE0) /* cam_xclka.cam_xclka */ OMAP3_CORE1_IOPAD(0x2112, PIN_INPUT | MUX_MODE0) /* cam_pclk.cam_pclk */
- OMAP3_CORE1_IOPAD(0x2114, PIN_INPUT | MUX_MODE0) /* cam_d0.cam_d0 */ - OMAP3_CORE1_IOPAD(0x2116, PIN_INPUT | MUX_MODE0) /* cam_d1.cam_d1 */ - OMAP3_CORE1_IOPAD(0x2118, PIN_INPUT | MUX_MODE0) /* cam_d2.cam_d2 */ + OMAP3_CORE1_IOPAD(0x2116, PIN_INPUT | MUX_MODE0) /* cam_d0.cam_d0 */ + OMAP3_CORE1_IOPAD(0x2118, PIN_INPUT | MUX_MODE0) /* cam_d1.cam_d1 */ + OMAP3_CORE1_IOPAD(0x211a, PIN_INPUT | MUX_MODE0) /* cam_d2.cam_d2 */ OMAP3_CORE1_IOPAD(0x211c, PIN_INPUT | MUX_MODE0) /* cam_d3.cam_d3 */ OMAP3_CORE1_IOPAD(0x211e, PIN_INPUT | MUX_MODE0) /* cam_d4.cam_d4 */ OMAP3_CORE1_IOPAD(0x2120, PIN_INPUT | MUX_MODE0) /* cam_d5.cam_d5 */ diff --git a/arch/arm/dts/omap3-cpu-thermal.dtsi b/arch/arm/dts/omap3-cpu-thermal.dtsi new file mode 100644 index 0000000..235ecfd --- /dev/null +++ b/arch/arm/dts/omap3-cpu-thermal.dtsi @@ -0,0 +1,20 @@ +/* + * Device Tree Source for OMAP3 SoC CPU thermal + * + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#include <dt-bindings/thermal/thermal.h> + +cpu_thermal: cpu_thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <1000>; /* milliseconds */ + coefficients = <0 20000>; + + /* sensor ID */ + thermal-sensors = <&bandgap 0>; +}; diff --git a/arch/arm/dts/omap3-u-boot.dtsi b/arch/arm/dts/omap3-u-boot.dtsi new file mode 100644 index 0000000..288e057 --- /dev/null +++ b/arch/arm/dts/omap3-u-boot.dtsi @@ -0,0 +1,19 @@ +/* + * Copyright (C) 2017 + * Logic PD - http://www.logicpd.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +&uart1 { + reg-shift = <2>; +}; + +&uart2 { + reg-shift = <2>; +}; + +&uart3 { + reg-shift = <2>; +}; + diff --git a/arch/arm/dts/omap3.dtsi b/arch/arm/dts/omap3.dtsi index a0f2412..e6f9c9a 100644 --- a/arch/arm/dts/omap3.dtsi +++ b/arch/arm/dts/omap3.dtsi @@ -13,842 +13,846 @@ #include <dt-bindings/pinctrl/omap.h>
/ { - compatible = "ti,omap3430", "ti,omap3"; - interrupt-parent = <&intc>; - #address-cells = <1>; - #size-cells = <1>; - chosen { }; - - aliases { - i2c0 = &i2c1; - i2c1 = &i2c2; - i2c2 = &i2c3; - serial0 = &uart1; - serial1 = &uart2; - serial2 = &uart3; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu@0 { - compatible = "arm,cortex-a8"; - device_type = "cpu"; - reg = <0x0>; - - clocks = <&dpll1_ck>; - clock-names = "cpu"; - - clock-latency = <300000>; /* From omap-cpufreq driver */ - }; - }; - - pmu@54000000 { - compatible = "arm,cortex-a8-pmu"; - reg = <0x54000000 0x800000>; - interrupts = <3>; - ti,hwmods = "debugss"; - }; - - /* - * The soc node represents the soc top level view. It is used for IPs - * that are not memory mapped in the MPU view or for the MPU itself. - */ - soc { - compatible = "ti,omap-infra"; - mpu { - compatible = "ti,omap3-mpu"; - ti,hwmods = "mpu"; - }; - - iva: iva { - compatible = "ti,iva2.2"; - ti,hwmods = "iva"; - - dsp { - compatible = "ti,omap3-c64"; - }; - }; - }; - - /* - * XXX: Use a flat representation of the OMAP3 interconnect. - * The real OMAP interconnect network is quite complex. - * Since it will not bring real advantage to represent that in DT for - * the moment, just use a fake OCP bus entry to represent the whole bus - * hierarchy. - */ - ocp@68000000 { - compatible = "ti,omap3-l3-smx", "simple-bus"; - reg = <0x68000000 0x10000>; - interrupts = <9 10>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - ti,hwmods = "l3_main"; - - l4_core: l4@48000000 { - compatible = "ti,omap3-l4-core", "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x48000000 0x1000000>; - - scm: scm@2000 { - compatible = "ti,omap3-scm", "simple-bus"; - reg = <0x2000 0x2000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x2000 0x2000>; - - omap3_pmx_core: pinmux@30 { - compatible = "ti,omap3-padconf", - "pinctrl-single"; - reg = <0x30 0x238>; - #address-cells = <1>; - #size-cells = <0>; - #interrupt-cells = <1>; - interrupt-controller; - pinctrl-single,register-width = <16>; - pinctrl-single,function-mask = <0xff1f>; - }; - - scm_conf: scm_conf@270 { - compatible = "syscon", "simple-bus"; - reg = <0x270 0x330>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x270 0x330>; - - pbias_regulator: pbias_regulator@2b0 { - compatible = "ti,pbias-omap3", "ti,pbias-omap"; - reg = <0x2b0 0x4>; - syscon = <&scm_conf>; - pbias_mmc_reg: pbias_mmc_omap2430 { - regulator-name = "pbias_mmc_omap2430"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3000000>; - }; - }; - - scm_clocks: clocks { - #address-cells = <1>; - #size-cells = <0>; - }; - }; - - scm_clockdomains: clockdomains { - }; - - omap3_pmx_wkup: pinmux@a00 { - compatible = "ti,omap3-padconf", - "pinctrl-single"; - reg = <0xa00 0x5c>; - #address-cells = <1>; - #size-cells = <0>; - #interrupt-cells = <1>; - interrupt-controller; - pinctrl-single,register-width = <16>; - pinctrl-single,function-mask = <0xff1f>; - }; - }; - }; - - aes: aes@480c5000 { - compatible = "ti,omap3-aes"; - ti,hwmods = "aes"; - reg = <0x480c5000 0x50>; - interrupts = <0>; - dmas = <&sdma 65 &sdma 66>; - dma-names = "tx", "rx"; - }; - - prm: prm@48306000 { - compatible = "ti,omap3-prm"; - reg = <0x48306000 0x4000>; - interrupts = <11>; - - prm_clocks: clocks { - #address-cells = <1>; - #size-cells = <0>; - }; - - prm_clockdomains: clockdomains { - }; - }; - - cm: cm@48004000 { - compatible = "ti,omap3-cm"; - reg = <0x48004000 0x4000>; - - cm_clocks: clocks { - #address-cells = <1>; - #size-cells = <0>; - }; - - cm_clockdomains: clockdomains { - }; - }; - - counter32k: counter@48320000 { - compatible = "ti,omap-counter32k"; - reg = <0x48320000 0x20>; - ti,hwmods = "counter_32k"; - }; - - intc: interrupt-controller@48200000 { - compatible = "ti,omap3-intc"; - interrupt-controller; - #interrupt-cells = <1>; - reg = <0x48200000 0x1000>; - }; - - sdma: dma-controller@48056000 { - compatible = "ti,omap3630-sdma", "ti,omap3430-sdma"; - reg = <0x48056000 0x1000>; - interrupts = <12>, - <13>, - <14>, - <15>; - #dma-cells = <1>; - dma-channels = <32>; - dma-requests = <96>; - }; - - gpio1: gpio@48310000 { - compatible = "ti,omap3-gpio"; - reg = <0x48310000 0x200>; - interrupts = <29>; - ti,hwmods = "gpio1"; - ti,gpio-always-on; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@49050000 { - compatible = "ti,omap3-gpio"; - reg = <0x49050000 0x200>; - interrupts = <30>; - ti,hwmods = "gpio2"; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@49052000 { - compatible = "ti,omap3-gpio"; - reg = <0x49052000 0x200>; - interrupts = <31>; - ti,hwmods = "gpio3"; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio4: gpio@49054000 { - compatible = "ti,omap3-gpio"; - reg = <0x49054000 0x200>; - interrupts = <32>; - ti,hwmods = "gpio4"; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio5: gpio@49056000 { - compatible = "ti,omap3-gpio"; - reg = <0x49056000 0x200>; - interrupts = <33>; - ti,hwmods = "gpio5"; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio6: gpio@49058000 { - compatible = "ti,omap3-gpio"; - reg = <0x49058000 0x200>; - interrupts = <34>; - ti,hwmods = "gpio6"; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - uart1: serial@4806a000 { - compatible = "ti,omap3-uart"; - reg = <0x4806a000 0x2000>; - reg-shift = <2>; - interrupts-extended = <&intc 72>; - dmas = <&sdma 49 &sdma 50>; - dma-names = "tx", "rx"; - ti,hwmods = "uart1"; - clock-frequency = <48000000>; - }; - - uart2: serial@4806c000 { - compatible = "ti,omap3-uart"; - reg = <0x4806c000 0x400>; - interrupts-extended = <&intc 73>; - dmas = <&sdma 51 &sdma 52>; - dma-names = "tx", "rx"; - ti,hwmods = "uart2"; - clock-frequency = <48000000>; - }; - - uart3: serial@49020000 { - compatible = "ti,omap3-uart"; - reg = <0x49020000 0x400>; - interrupts-extended = <&intc 74>; - dmas = <&sdma 53 &sdma 54>; - dma-names = "tx", "rx"; - ti,hwmods = "uart3"; - clock-frequency = <48000000>; - }; - - i2c1: i2c@48070000 { - compatible = "ti,omap3-i2c"; - reg = <0x48070000 0x80>; - interrupts = <56>; - dmas = <&sdma 27 &sdma 28>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - ti,hwmods = "i2c1"; - }; - - i2c2: i2c@48072000 { - compatible = "ti,omap3-i2c"; - reg = <0x48072000 0x80>; - interrupts = <57>; - dmas = <&sdma 29 &sdma 30>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - ti,hwmods = "i2c2"; - }; - - i2c3: i2c@48060000 { - compatible = "ti,omap3-i2c"; - reg = <0x48060000 0x80>; - interrupts = <61>; - dmas = <&sdma 25 &sdma 26>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - ti,hwmods = "i2c3"; - }; - - mailbox: mailbox@48094000 { - compatible = "ti,omap3-mailbox"; - ti,hwmods = "mailbox"; - reg = <0x48094000 0x200>; - interrupts = <26>; - #mbox-cells = <1>; - ti,mbox-num-users = <2>; - ti,mbox-num-fifos = <2>; - mbox_dsp: dsp { - ti,mbox-tx = <0 0 0>; - ti,mbox-rx = <1 0 0>; - }; - }; - - mcspi1: spi@48098000 { - compatible = "ti,omap2-mcspi"; - reg = <0x48098000 0x100>; - interrupts = <65>; - #address-cells = <1>; - #size-cells = <0>; - ti,hwmods = "mcspi1"; - ti,spi-num-cs = <4>; - dmas = <&sdma 35>, - <&sdma 36>, - <&sdma 37>, - <&sdma 38>, - <&sdma 39>, - <&sdma 40>, - <&sdma 41>, - <&sdma 42>; - dma-names = "tx0", "rx0", "tx1", "rx1", - "tx2", "rx2", "tx3", "rx3"; - }; - - mcspi2: spi@4809a000 { - compatible = "ti,omap2-mcspi"; - reg = <0x4809a000 0x100>; - interrupts = <66>; - #address-cells = <1>; - #size-cells = <0>; - ti,hwmods = "mcspi2"; - ti,spi-num-cs = <2>; - dmas = <&sdma 43>, - <&sdma 44>, - <&sdma 45>, - <&sdma 46>; - dma-names = "tx0", "rx0", "tx1", "rx1"; - }; - - mcspi3: spi@480b8000 { - compatible = "ti,omap2-mcspi"; - reg = <0x480b8000 0x100>; - interrupts = <91>; - #address-cells = <1>; - #size-cells = <0>; - ti,hwmods = "mcspi3"; - ti,spi-num-cs = <2>; - dmas = <&sdma 15>, - <&sdma 16>, - <&sdma 23>, - <&sdma 24>; - dma-names = "tx0", "rx0", "tx1", "rx1"; - }; - - mcspi4: spi@480ba000 { - compatible = "ti,omap2-mcspi"; - reg = <0x480ba000 0x100>; - interrupts = <48>; - #address-cells = <1>; - #size-cells = <0>; - ti,hwmods = "mcspi4"; - ti,spi-num-cs = <1>; - dmas = <&sdma 70>, <&sdma 71>; - dma-names = "tx0", "rx0"; - }; - - hdqw1w: 1w@480b2000 { - compatible = "ti,omap3-1w"; - reg = <0x480b2000 0x1000>; - interrupts = <58>; - ti,hwmods = "hdq1w"; - }; - - mmc1: mmc@4809c000 { - compatible = "ti,omap3-hsmmc"; - reg = <0x4809c000 0x200>; - interrupts = <83>; - ti,hwmods = "mmc1"; - ti,dual-volt; - dmas = <&sdma 61>, <&sdma 62>; - dma-names = "tx", "rx"; - pbias-supply = <&pbias_mmc_reg>; - }; - - mmc2: mmc@480b4000 { - compatible = "ti,omap3-hsmmc"; - reg = <0x480b4000 0x200>; - interrupts = <86>; - ti,hwmods = "mmc2"; - dmas = <&sdma 47>, <&sdma 48>; - dma-names = "tx", "rx"; - }; - - mmc3: mmc@480ad000 { - compatible = "ti,omap3-hsmmc"; - reg = <0x480ad000 0x200>; - interrupts = <94>; - ti,hwmods = "mmc3"; - dmas = <&sdma 77>, <&sdma 78>; - dma-names = "tx", "rx"; - }; - - mmu_isp: mmu@480bd400 { - #iommu-cells = <0>; - compatible = "ti,omap2-iommu"; - reg = <0x480bd400 0x80>; - interrupts = <24>; - ti,hwmods = "mmu_isp"; - ti,#tlb-entries = <8>; - }; - - mmu_iva: mmu@5d000000 { - #iommu-cells = <0>; - compatible = "ti,omap2-iommu"; - reg = <0x5d000000 0x80>; - interrupts = <28>; - ti,hwmods = "mmu_iva"; - status = "disabled"; - }; - - wdt2: wdt@48314000 { - compatible = "ti,omap3-wdt"; - reg = <0x48314000 0x80>; - ti,hwmods = "wd_timer2"; - }; - - mcbsp1: mcbsp@48074000 { - compatible = "ti,omap3-mcbsp"; - reg = <0x48074000 0xff>; - reg-names = "mpu"; - interrupts = <16>, /* OCP compliant interrupt */ - <59>, /* TX interrupt */ - <60>; /* RX interrupt */ - interrupt-names = "common", "tx", "rx"; - ti,buffer-size = <128>; - ti,hwmods = "mcbsp1"; - dmas = <&sdma 31>, - <&sdma 32>; - dma-names = "tx", "rx"; - clocks = <&mcbsp1_fck>; - clock-names = "fck"; - status = "disabled"; - }; - - mcbsp2: mcbsp@49022000 { - compatible = "ti,omap3-mcbsp"; - reg = <0x49022000 0xff>, - <0x49028000 0xff>; - reg-names = "mpu", "sidetone"; - interrupts = <17>, /* OCP compliant interrupt */ - <62>, /* TX interrupt */ - <63>, /* RX interrupt */ - <4>; /* Sidetone */ - interrupt-names = "common", "tx", "rx", "sidetone"; - ti,buffer-size = <1280>; - ti,hwmods = "mcbsp2", "mcbsp2_sidetone"; - dmas = <&sdma 33>, - <&sdma 34>; - dma-names = "tx", "rx"; - clocks = <&mcbsp2_fck>, <&mcbsp2_ick>; - clock-names = "fck", "ick"; - status = "disabled"; - }; - - mcbsp3: mcbsp@49024000 { - compatible = "ti,omap3-mcbsp"; - reg = <0x49024000 0xff>, - <0x4902a000 0xff>; - reg-names = "mpu", "sidetone"; - interrupts = <22>, /* OCP compliant interrupt */ - <89>, /* TX interrupt */ - <90>, /* RX interrupt */ - <5>; /* Sidetone */ - interrupt-names = "common", "tx", "rx", "sidetone"; - ti,buffer-size = <128>; - ti,hwmods = "mcbsp3", "mcbsp3_sidetone"; - dmas = <&sdma 17>, - <&sdma 18>; - dma-names = "tx", "rx"; - clocks = <&mcbsp3_fck>, <&mcbsp3_ick>; - clock-names = "fck", "ick"; - status = "disabled"; - }; - - mcbsp4: mcbsp@49026000 { - compatible = "ti,omap3-mcbsp"; - reg = <0x49026000 0xff>; - reg-names = "mpu"; - interrupts = <23>, /* OCP compliant interrupt */ - <54>, /* TX interrupt */ - <55>; /* RX interrupt */ - interrupt-names = "common", "tx", "rx"; - ti,buffer-size = <128>; - ti,hwmods = "mcbsp4"; - dmas = <&sdma 19>, - <&sdma 20>; - dma-names = "tx", "rx"; - clocks = <&mcbsp4_fck>; - clock-names = "fck"; - status = "disabled"; - }; - - mcbsp5: mcbsp@48096000 { - compatible = "ti,omap3-mcbsp"; - reg = <0x48096000 0xff>; - reg-names = "mpu"; - interrupts = <27>, /* OCP compliant interrupt */ - <81>, /* TX interrupt */ - <82>; /* RX interrupt */ - interrupt-names = "common", "tx", "rx"; - ti,buffer-size = <128>; - ti,hwmods = "mcbsp5"; - dmas = <&sdma 21>, - <&sdma 22>; - dma-names = "tx", "rx"; - clocks = <&mcbsp5_fck>; - clock-names = "fck"; - status = "disabled"; - }; - - sham: sham@480c3000 { - compatible = "ti,omap3-sham"; - ti,hwmods = "sham"; - reg = <0x480c3000 0x64>; - interrupts = <49>; - dmas = <&sdma 69>; - dma-names = "rx"; - }; - - smartreflex_core: smartreflex@480cb000 { - compatible = "ti,omap3-smartreflex-core"; - ti,hwmods = "smartreflex_core"; - reg = <0x480cb000 0x400>; - interrupts = <19>; - }; - - smartreflex_mpu_iva: smartreflex@480c9000 { - compatible = "ti,omap3-smartreflex-iva"; - ti,hwmods = "smartreflex_mpu_iva"; - reg = <0x480c9000 0x400>; - interrupts = <18>; - }; - - timer1: timer@48318000 { - compatible = "ti,omap3430-timer"; - reg = <0x48318000 0x400>; - interrupts = <37>; - ti,hwmods = "timer1"; - ti,timer-alwon; - }; - - timer2: timer@49032000 { - compatible = "ti,omap3430-timer"; - reg = <0x49032000 0x400>; - interrupts = <38>; - ti,hwmods = "timer2"; - }; - - timer3: timer@49034000 { - compatible = "ti,omap3430-timer"; - reg = <0x49034000 0x400>; - interrupts = <39>; - ti,hwmods = "timer3"; - }; - - timer4: timer@49036000 { - compatible = "ti,omap3430-timer"; - reg = <0x49036000 0x400>; - interrupts = <40>; - ti,hwmods = "timer4"; - }; - - timer5: timer@49038000 { - compatible = "ti,omap3430-timer"; - reg = <0x49038000 0x400>; - interrupts = <41>; - ti,hwmods = "timer5"; - ti,timer-dsp; - }; - - timer6: timer@4903a000 { - compatible = "ti,omap3430-timer"; - reg = <0x4903a000 0x400>; - interrupts = <42>; - ti,hwmods = "timer6"; - ti,timer-dsp; - }; - - timer7: timer@4903c000 { - compatible = "ti,omap3430-timer"; - reg = <0x4903c000 0x400>; - interrupts = <43>; - ti,hwmods = "timer7"; - ti,timer-dsp; - }; - - timer8: timer@4903e000 { - compatible = "ti,omap3430-timer"; - reg = <0x4903e000 0x400>; - interrupts = <44>; - ti,hwmods = "timer8"; - ti,timer-pwm; - ti,timer-dsp; - }; - - timer9: timer@49040000 { - compatible = "ti,omap3430-timer"; - reg = <0x49040000 0x400>; - interrupts = <45>; - ti,hwmods = "timer9"; - ti,timer-pwm; - }; - - timer10: timer@48086000 { - compatible = "ti,omap3430-timer"; - reg = <0x48086000 0x400>; - interrupts = <46>; - ti,hwmods = "timer10"; - ti,timer-pwm; - }; - - timer11: timer@48088000 { - compatible = "ti,omap3430-timer"; - reg = <0x48088000 0x400>; - interrupts = <47>; - ti,hwmods = "timer11"; - ti,timer-pwm; - }; - - timer12: timer@48304000 { - compatible = "ti,omap3430-timer"; - reg = <0x48304000 0x400>; - interrupts = <95>; - ti,hwmods = "timer12"; - ti,timer-alwon; - ti,timer-secure; - }; - - usbhstll: usbhstll@48062000 { - compatible = "ti,usbhs-tll"; - reg = <0x48062000 0x1000>; - interrupts = <78>; - ti,hwmods = "usb_tll_hs"; - }; - - usbhshost: usbhshost@48064000 { - compatible = "ti,usbhs-host"; - reg = <0x48064000 0x400>; - ti,hwmods = "usb_host_hs"; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - usbhsohci: ohci@48064400 { - compatible = "ti,ohci-omap3"; - reg = <0x48064400 0x400>; - interrupt-parent = <&intc>; - interrupts = <76>; - }; - - usbhsehci: ehci@48064800 { - compatible = "ti,ehci-omap"; - reg = <0x48064800 0x400>; - interrupt-parent = <&intc>; - interrupts = <77>; - }; - }; - - gpmc: gpmc@6e000000 { - compatible = "ti,omap3430-gpmc"; - ti,hwmods = "gpmc"; - reg = <0x6e000000 0x02d0>; - interrupts = <20>; - dmas = <&sdma 4>; - dma-names = "rxtx"; - gpmc,num-cs = <8>; - gpmc,num-waitpins = <4>; - #address-cells = <2>; - #size-cells = <1>; - interrupt-controller; - #interrupt-cells = <2>; - gpio-controller; - #gpio-cells = <2>; - }; - - usb_otg_hs: usb_otg_hs@480ab000 { - compatible = "ti,omap3-musb"; - reg = <0x480ab000 0x1000>; - interrupts = <92>, <93>; - interrupt-names = "mc", "dma"; - ti,hwmods = "usb_otg_hs"; - multipoint = <1>; - num-eps = <16>; - ram-bits = <12>; - }; - - dss: dss@48050000 { - compatible = "ti,omap3-dss"; - reg = <0x48050000 0x200>; - status = "disabled"; - ti,hwmods = "dss_core"; - clocks = <&dss1_alwon_fck>; - clock-names = "fck"; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - dispc@48050400 { - compatible = "ti,omap3-dispc"; - reg = <0x48050400 0x400>; - interrupts = <25>; - ti,hwmods = "dss_dispc"; - clocks = <&dss1_alwon_fck>; - clock-names = "fck"; - }; - - dsi: encoder@4804fc00 { - compatible = "ti,omap3-dsi"; - reg = <0x4804fc00 0x200>, - <0x4804fe00 0x40>, - <0x4804ff00 0x20>; - reg-names = "proto", "phy", "pll"; - interrupts = <25>; - status = "disabled"; - ti,hwmods = "dss_dsi1"; - clocks = <&dss1_alwon_fck>, <&dss2_alwon_fck>; - clock-names = "fck", "sys_clk"; - }; - - rfbi: encoder@48050800 { - compatible = "ti,omap3-rfbi"; - reg = <0x48050800 0x100>; - status = "disabled"; - ti,hwmods = "dss_rfbi"; - clocks = <&dss1_alwon_fck>, <&dss_ick>; - clock-names = "fck", "ick"; - }; - - venc: encoder@48050c00 { - compatible = "ti,omap3-venc"; - reg = <0x48050c00 0x100>; - status = "disabled"; - ti,hwmods = "dss_venc"; - clocks = <&dss_tv_fck>; - clock-names = "fck"; - }; - }; - - ssi: ssi-controller@48058000 { - compatible = "ti,omap3-ssi"; - ti,hwmods = "ssi"; - - status = "disabled"; - - reg = <0x48058000 0x1000>, - <0x48059000 0x1000>; - reg-names = "sys", - "gdd"; - - interrupts = <71>; - interrupt-names = "gdd_mpu"; - - #address-cells = <1>; - #size-cells = <1>; - ranges; - - ssi_port1: ssi-port@4805a000 { - compatible = "ti,omap3-ssi-port"; - - reg = <0x4805a000 0x800>, - <0x4805a800 0x800>; - reg-names = "tx", - "rx"; - - interrupt-parent = <&intc>; - interrupts = <67>, - <68>; - }; - - ssi_port2: ssi-port@4805b000 { - compatible = "ti,omap3-ssi-port"; - - reg = <0x4805b000 0x800>, - <0x4805b800 0x800>; - reg-names = "tx", - "rx"; - - interrupt-parent = <&intc>; - interrupts = <69>, - <70>; - }; - }; - }; + compatible = "ti,omap3430", "ti,omap3"; + interrupt-parent = <&intc>; + #address-cells = <1>; + #size-cells = <1>; + chosen { }; + + aliases { + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a8"; + device_type = "cpu"; + reg = <0x0>; + + clocks = <&dpll1_ck>; + clock-names = "cpu"; + + clock-latency = <300000>; /* From omap-cpufreq driver */ + }; + }; + + pmu@54000000 { + compatible = "arm,cortex-a8-pmu"; + reg = <0x54000000 0x800000>; + interrupts = <3>; + ti,hwmods = "debugss"; + }; + + /* + * The soc node represents the soc top level view. It is used for IPs + * that are not memory mapped in the MPU view or for the MPU itself. + */ + soc { + compatible = "ti,omap-infra"; + mpu { + compatible = "ti,omap3-mpu"; + ti,hwmods = "mpu"; + }; + + iva: iva { + compatible = "ti,iva2.2"; + ti,hwmods = "iva"; + + dsp { + compatible = "ti,omap3-c64"; + }; + }; + }; + + /* + * XXX: Use a flat representation of the OMAP3 interconnect. + * The real OMAP interconnect network is quite complex. + * Since it will not bring real advantage to represent that in DT for + * the moment, just use a fake OCP bus entry to represent the whole bus + * hierarchy. + */ + ocp@68000000 { + compatible = "ti,omap3-l3-smx", "simple-bus"; + reg = <0x68000000 0x10000>; + interrupts = <9 10>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + ti,hwmods = "l3_main"; + + l4_core: l4@48000000 { + compatible = "ti,omap3-l4-core", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x48000000 0x1000000>; + + scm: scm@2000 { + compatible = "ti,omap3-scm", "simple-bus"; + reg = <0x2000 0x2000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x2000 0x2000>; + + omap3_pmx_core: pinmux@30 { + compatible = "ti,omap3-padconf", + "pinctrl-single"; + reg = <0x30 0x238>; + #address-cells = <1>; + #size-cells = <0>; + #pinctrl-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0xff1f>; + }; + + scm_conf: scm_conf@270 { + compatible = "syscon", "simple-bus"; + reg = <0x270 0x330>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x270 0x330>; + + pbias_regulator: pbias_regulator@2b0 { + compatible = "ti,pbias-omap3", "ti,pbias-omap"; + reg = <0x2b0 0x4>; + syscon = <&scm_conf>; + pbias_mmc_reg: pbias_mmc_omap2430 { + regulator-name = "pbias_mmc_omap2430"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + }; + }; + + scm_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + scm_clockdomains: clockdomains { + }; + + omap3_pmx_wkup: pinmux@a00 { + compatible = "ti,omap3-padconf", + "pinctrl-single"; + reg = <0xa00 0x5c>; + #address-cells = <1>; + #size-cells = <0>; + #pinctrl-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0xff1f>; + }; + }; + }; + + aes: aes@480c5000 { + compatible = "ti,omap3-aes"; + ti,hwmods = "aes"; + reg = <0x480c5000 0x50>; + interrupts = <0>; + dmas = <&sdma 65 &sdma 66>; + dma-names = "tx", "rx"; + }; + + prm: prm@48306000 { + compatible = "ti,omap3-prm"; + reg = <0x48306000 0x4000>; + interrupts = <11>; + + prm_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + prm_clockdomains: clockdomains { + }; + }; + + cm: cm@48004000 { + compatible = "ti,omap3-cm"; + reg = <0x48004000 0x4000>; + + cm_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + cm_clockdomains: clockdomains { + }; + }; + + counter32k: counter@48320000 { + compatible = "ti,omap-counter32k"; + reg = <0x48320000 0x20>; + ti,hwmods = "counter_32k"; + }; + + intc: interrupt-controller@48200000 { + compatible = "ti,omap3-intc"; + interrupt-controller; + #interrupt-cells = <1>; + reg = <0x48200000 0x1000>; + }; + + sdma: dma-controller@48056000 { + compatible = "ti,omap3630-sdma", "ti,omap3430-sdma"; + reg = <0x48056000 0x1000>; + interrupts = <12>, + <13>, + <14>, + <15>; + #dma-cells = <1>; + dma-channels = <32>; + dma-requests = <96>; + }; + + gpio1: gpio@48310000 { + compatible = "ti,omap3-gpio"; + reg = <0x48310000 0x200>; + interrupts = <29>; + ti,hwmods = "gpio1"; + ti,gpio-always-on; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@49050000 { + compatible = "ti,omap3-gpio"; + reg = <0x49050000 0x200>; + interrupts = <30>; + ti,hwmods = "gpio2"; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@49052000 { + compatible = "ti,omap3-gpio"; + reg = <0x49052000 0x200>; + interrupts = <31>; + ti,hwmods = "gpio3"; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio4: gpio@49054000 { + compatible = "ti,omap3-gpio"; + reg = <0x49054000 0x200>; + interrupts = <32>; + ti,hwmods = "gpio4"; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio5: gpio@49056000 { + compatible = "ti,omap3-gpio"; + reg = <0x49056000 0x200>; + interrupts = <33>; + ti,hwmods = "gpio5"; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio6: gpio@49058000 { + compatible = "ti,omap3-gpio"; + reg = <0x49058000 0x200>; + interrupts = <34>; + ti,hwmods = "gpio6"; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + uart1: serial@4806a000 { + compatible = "ti,omap3-uart"; + reg = <0x4806a000 0x2000>; + reg-shift = <2>; + interrupts-extended = <&intc 72>; + dmas = <&sdma 49 &sdma 50>; + dma-names = "tx", "rx"; + ti,hwmods = "uart1"; + clock-frequency = <48000000>; + }; + + uart2: serial@4806c000 { + compatible = "ti,omap3-uart"; + reg = <0x4806c000 0x400>; + reg-shift = <2>; + interrupts-extended = <&intc 73>; + dmas = <&sdma 51 &sdma 52>; + dma-names = "tx", "rx"; + ti,hwmods = "uart2"; + clock-frequency = <48000000>; + }; + + uart3: serial@49020000 { + compatible = "ti,omap3-uart"; + reg = <0x49020000 0x400>; + reg-shift = <2>; + interrupts-extended = <&intc 74>; + dmas = <&sdma 53 &sdma 54>; + dma-names = "tx", "rx"; + ti,hwmods = "uart3"; + clock-frequency = <48000000>; + }; + + i2c1: i2c@48070000 { + compatible = "ti,omap3-i2c"; + reg = <0x48070000 0x80>; + interrupts = <56>; + dmas = <&sdma 27 &sdma 28>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + ti,hwmods = "i2c1"; + }; + + i2c2: i2c@48072000 { + compatible = "ti,omap3-i2c"; + reg = <0x48072000 0x80>; + interrupts = <57>; + dmas = <&sdma 29 &sdma 30>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + ti,hwmods = "i2c2"; + }; + + i2c3: i2c@48060000 { + compatible = "ti,omap3-i2c"; + reg = <0x48060000 0x80>; + interrupts = <61>; + dmas = <&sdma 25 &sdma 26>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + ti,hwmods = "i2c3"; + }; + + mailbox: mailbox@48094000 { + compatible = "ti,omap3-mailbox"; + ti,hwmods = "mailbox"; + reg = <0x48094000 0x200>; + interrupts = <26>; + #mbox-cells = <1>; + ti,mbox-num-users = <2>; + ti,mbox-num-fifos = <2>; + mbox_dsp: dsp { + ti,mbox-tx = <0 0 0>; + ti,mbox-rx = <1 0 0>; + }; + }; + + mcspi1: spi@48098000 { + compatible = "ti,omap2-mcspi"; + reg = <0x48098000 0x100>; + interrupts = <65>; + #address-cells = <1>; + #size-cells = <0>; + ti,hwmods = "mcspi1"; + ti,spi-num-cs = <4>; + dmas = <&sdma 35>, + <&sdma 36>, + <&sdma 37>, + <&sdma 38>, + <&sdma 39>, + <&sdma 40>, + <&sdma 41>, + <&sdma 42>; + dma-names = "tx0", "rx0", "tx1", "rx1", + "tx2", "rx2", "tx3", "rx3"; + }; + + mcspi2: spi@4809a000 { + compatible = "ti,omap2-mcspi"; + reg = <0x4809a000 0x100>; + interrupts = <66>; + #address-cells = <1>; + #size-cells = <0>; + ti,hwmods = "mcspi2"; + ti,spi-num-cs = <2>; + dmas = <&sdma 43>, + <&sdma 44>, + <&sdma 45>, + <&sdma 46>; + dma-names = "tx0", "rx0", "tx1", "rx1"; + }; + + mcspi3: spi@480b8000 { + compatible = "ti,omap2-mcspi"; + reg = <0x480b8000 0x100>; + interrupts = <91>; + #address-cells = <1>; + #size-cells = <0>; + ti,hwmods = "mcspi3"; + ti,spi-num-cs = <2>; + dmas = <&sdma 15>, + <&sdma 16>, + <&sdma 23>, + <&sdma 24>; + dma-names = "tx0", "rx0", "tx1", "rx1"; + }; + + mcspi4: spi@480ba000 { + compatible = "ti,omap2-mcspi"; + reg = <0x480ba000 0x100>; + interrupts = <48>; + #address-cells = <1>; + #size-cells = <0>; + ti,hwmods = "mcspi4"; + ti,spi-num-cs = <1>; + dmas = <&sdma 70>, <&sdma 71>; + dma-names = "tx0", "rx0"; + }; + + hdqw1w: 1w@480b2000 { + compatible = "ti,omap3-1w"; + reg = <0x480b2000 0x1000>; + interrupts = <58>; + ti,hwmods = "hdq1w"; + }; + + mmc1: mmc@4809c000 { + compatible = "ti,omap3-hsmmc"; + reg = <0x4809c000 0x200>; + interrupts = <83>; + ti,hwmods = "mmc1"; + ti,dual-volt; + dmas = <&sdma 61>, <&sdma 62>; + dma-names = "tx", "rx"; + pbias-supply = <&pbias_mmc_reg>; + }; + + mmc2: mmc@480b4000 { + compatible = "ti,omap3-hsmmc"; + reg = <0x480b4000 0x200>; + interrupts = <86>; + ti,hwmods = "mmc2"; + dmas = <&sdma 47>, <&sdma 48>; + dma-names = "tx", "rx"; + }; + + mmc3: mmc@480ad000 { + compatible = "ti,omap3-hsmmc"; + reg = <0x480ad000 0x200>; + interrupts = <94>; + ti,hwmods = "mmc3"; + dmas = <&sdma 77>, <&sdma 78>; + dma-names = "tx", "rx"; + }; + + mmu_isp: mmu@480bd400 { + #iommu-cells = <0>; + compatible = "ti,omap2-iommu"; + reg = <0x480bd400 0x80>; + interrupts = <24>; + ti,hwmods = "mmu_isp"; + ti,#tlb-entries = <8>; + }; + + mmu_iva: mmu@5d000000 { + #iommu-cells = <0>; + compatible = "ti,omap2-iommu"; + reg = <0x5d000000 0x80>; + interrupts = <28>; + ti,hwmods = "mmu_iva"; + status = "disabled"; + }; + + wdt2: wdt@48314000 { + compatible = "ti,omap3-wdt"; + reg = <0x48314000 0x80>; + ti,hwmods = "wd_timer2"; + }; + + mcbsp1: mcbsp@48074000 { + compatible = "ti,omap3-mcbsp"; + reg = <0x48074000 0xff>; + reg-names = "mpu"; + interrupts = <16>, /* OCP compliant interrupt */ + <59>, /* TX interrupt */ + <60>; /* RX interrupt */ + interrupt-names = "common", "tx", "rx"; + ti,buffer-size = <128>; + ti,hwmods = "mcbsp1"; + dmas = <&sdma 31>, + <&sdma 32>; + dma-names = "tx", "rx"; + clocks = <&mcbsp1_fck>; + clock-names = "fck"; + status = "disabled"; + }; + + mcbsp2: mcbsp@49022000 { + compatible = "ti,omap3-mcbsp"; + reg = <0x49022000 0xff>, + <0x49028000 0xff>; + reg-names = "mpu", "sidetone"; + interrupts = <17>, /* OCP compliant interrupt */ + <62>, /* TX interrupt */ + <63>, /* RX interrupt */ + <4>; /* Sidetone */ + interrupt-names = "common", "tx", "rx", "sidetone"; + ti,buffer-size = <1280>; + ti,hwmods = "mcbsp2", "mcbsp2_sidetone"; + dmas = <&sdma 33>, + <&sdma 34>; + dma-names = "tx", "rx"; + clocks = <&mcbsp2_fck>, <&mcbsp2_ick>; + clock-names = "fck", "ick"; + status = "disabled"; + }; + + mcbsp3: mcbsp@49024000 { + compatible = "ti,omap3-mcbsp"; + reg = <0x49024000 0xff>, + <0x4902a000 0xff>; + reg-names = "mpu", "sidetone"; + interrupts = <22>, /* OCP compliant interrupt */ + <89>, /* TX interrupt */ + <90>, /* RX interrupt */ + <5>; /* Sidetone */ + interrupt-names = "common", "tx", "rx", "sidetone"; + ti,buffer-size = <128>; + ti,hwmods = "mcbsp3", "mcbsp3_sidetone"; + dmas = <&sdma 17>, + <&sdma 18>; + dma-names = "tx", "rx"; + clocks = <&mcbsp3_fck>, <&mcbsp3_ick>; + clock-names = "fck", "ick"; + status = "disabled"; + }; + + mcbsp4: mcbsp@49026000 { + compatible = "ti,omap3-mcbsp"; + reg = <0x49026000 0xff>; + reg-names = "mpu"; + interrupts = <23>, /* OCP compliant interrupt */ + <54>, /* TX interrupt */ + <55>; /* RX interrupt */ + interrupt-names = "common", "tx", "rx"; + ti,buffer-size = <128>; + ti,hwmods = "mcbsp4"; + dmas = <&sdma 19>, + <&sdma 20>; + dma-names = "tx", "rx"; + clocks = <&mcbsp4_fck>; + clock-names = "fck"; + status = "disabled"; + }; + + mcbsp5: mcbsp@48096000 { + compatible = "ti,omap3-mcbsp"; + reg = <0x48096000 0xff>; + reg-names = "mpu"; + interrupts = <27>, /* OCP compliant interrupt */ + <81>, /* TX interrupt */ + <82>; /* RX interrupt */ + interrupt-names = "common", "tx", "rx"; + ti,buffer-size = <128>; + ti,hwmods = "mcbsp5"; + dmas = <&sdma 21>, + <&sdma 22>; + dma-names = "tx", "rx"; + clocks = <&mcbsp5_fck>; + clock-names = "fck"; + status = "disabled"; + }; + + sham: sham@480c3000 { + compatible = "ti,omap3-sham"; + ti,hwmods = "sham"; + reg = <0x480c3000 0x64>; + interrupts = <49>; + dmas = <&sdma 69>; + dma-names = "rx"; + }; + + smartreflex_core: smartreflex@480cb000 { + compatible = "ti,omap3-smartreflex-core"; + ti,hwmods = "smartreflex_core"; + reg = <0x480cb000 0x400>; + interrupts = <19>; + }; + + smartreflex_mpu_iva: smartreflex@480c9000 { + compatible = "ti,omap3-smartreflex-iva"; + ti,hwmods = "smartreflex_mpu_iva"; + reg = <0x480c9000 0x400>; + interrupts = <18>; + }; + + timer1: timer@48318000 { + compatible = "ti,omap3430-timer"; + reg = <0x48318000 0x400>; + interrupts = <37>; + ti,hwmods = "timer1"; + ti,timer-alwon; + }; + + timer2: timer@49032000 { + compatible = "ti,omap3430-timer"; + reg = <0x49032000 0x400>; + interrupts = <38>; + ti,hwmods = "timer2"; + }; + + timer3: timer@49034000 { + compatible = "ti,omap3430-timer"; + reg = <0x49034000 0x400>; + interrupts = <39>; + ti,hwmods = "timer3"; + }; + + timer4: timer@49036000 { + compatible = "ti,omap3430-timer"; + reg = <0x49036000 0x400>; + interrupts = <40>; + ti,hwmods = "timer4"; + }; + + timer5: timer@49038000 { + compatible = "ti,omap3430-timer"; + reg = <0x49038000 0x400>; + interrupts = <41>; + ti,hwmods = "timer5"; + ti,timer-dsp; + }; + + timer6: timer@4903a000 { + compatible = "ti,omap3430-timer"; + reg = <0x4903a000 0x400>; + interrupts = <42>; + ti,hwmods = "timer6"; + ti,timer-dsp; + }; + + timer7: timer@4903c000 { + compatible = "ti,omap3430-timer"; + reg = <0x4903c000 0x400>; + interrupts = <43>; + ti,hwmods = "timer7"; + ti,timer-dsp; + }; + + timer8: timer@4903e000 { + compatible = "ti,omap3430-timer"; + reg = <0x4903e000 0x400>; + interrupts = <44>; + ti,hwmods = "timer8"; + ti,timer-pwm; + ti,timer-dsp; + }; + + timer9: timer@49040000 { + compatible = "ti,omap3430-timer"; + reg = <0x49040000 0x400>; + interrupts = <45>; + ti,hwmods = "timer9"; + ti,timer-pwm; + }; + + timer10: timer@48086000 { + compatible = "ti,omap3430-timer"; + reg = <0x48086000 0x400>; + interrupts = <46>; + ti,hwmods = "timer10"; + ti,timer-pwm; + }; + + timer11: timer@48088000 { + compatible = "ti,omap3430-timer"; + reg = <0x48088000 0x400>; + interrupts = <47>; + ti,hwmods = "timer11"; + ti,timer-pwm; + }; + + timer12: timer@48304000 { + compatible = "ti,omap3430-timer"; + reg = <0x48304000 0x400>; + interrupts = <95>; + ti,hwmods = "timer12"; + ti,timer-alwon; + ti,timer-secure; + }; + + usbhstll: usbhstll@48062000 { + compatible = "ti,usbhs-tll"; + reg = <0x48062000 0x1000>; + interrupts = <78>; + ti,hwmods = "usb_tll_hs"; + }; + + usbhshost: usbhshost@48064000 { + compatible = "ti,usbhs-host"; + reg = <0x48064000 0x400>; + ti,hwmods = "usb_host_hs"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + usbhsohci: ohci@48064400 { + compatible = "ti,ohci-omap3"; + reg = <0x48064400 0x400>; + interrupt-parent = <&intc>; + interrupts = <76>; + }; + + usbhsehci: ehci@48064800 { + compatible = "ti,ehci-omap"; + reg = <0x48064800 0x400>; + interrupt-parent = <&intc>; + interrupts = <77>; + }; + }; + + gpmc: gpmc@6e000000 { + compatible = "ti,omap3430-gpmc"; + ti,hwmods = "gpmc"; + reg = <0x6e000000 0x02d0>; + interrupts = <20>; + dmas = <&sdma 4>; + dma-names = "rxtx"; + gpmc,num-cs = <8>; + gpmc,num-waitpins = <4>; + #address-cells = <2>; + #size-cells = <1>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-controller; + #gpio-cells = <2>; + }; + + usb_otg_hs: usb_otg_hs@480ab000 { + compatible = "ti,omap3-musb"; + reg = <0x480ab000 0x1000>; + interrupts = <92>, <93>; + interrupt-names = "mc", "dma"; + ti,hwmods = "usb_otg_hs"; + multipoint = <1>; + num-eps = <16>; + ram-bits = <12>; + }; + + dss: dss@48050000 { + compatible = "ti,omap3-dss"; + reg = <0x48050000 0x200>; + status = "disabled"; + ti,hwmods = "dss_core"; + clocks = <&dss1_alwon_fck>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + dispc@48050400 { + compatible = "ti,omap3-dispc"; + reg = <0x48050400 0x400>; + interrupts = <25>; + ti,hwmods = "dss_dispc"; + clocks = <&dss1_alwon_fck>; + clock-names = "fck"; + }; + + dsi: encoder@4804fc00 { + compatible = "ti,omap3-dsi"; + reg = <0x4804fc00 0x200>, + <0x4804fe00 0x40>, + <0x4804ff00 0x20>; + reg-names = "proto", "phy", "pll"; + interrupts = <25>; + status = "disabled"; + ti,hwmods = "dss_dsi1"; + clocks = <&dss1_alwon_fck>, <&dss2_alwon_fck>; + clock-names = "fck", "sys_clk"; + }; + + rfbi: encoder@48050800 { + compatible = "ti,omap3-rfbi"; + reg = <0x48050800 0x100>; + status = "disabled"; + ti,hwmods = "dss_rfbi"; + clocks = <&dss1_alwon_fck>, <&dss_ick>; + clock-names = "fck", "ick"; + }; + + venc: encoder@48050c00 { + compatible = "ti,omap3-venc"; + reg = <0x48050c00 0x100>; + status = "disabled"; + ti,hwmods = "dss_venc"; + clocks = <&dss_tv_fck>; + clock-names = "fck"; + }; + }; + + ssi: ssi-controller@48058000 { + compatible = "ti,omap3-ssi"; + ti,hwmods = "ssi"; + + status = "disabled"; + + reg = <0x48058000 0x1000>, + <0x48059000 0x1000>; + reg-names = "sys", + "gdd"; + + interrupts = <71>; + interrupt-names = "gdd_mpu"; + + #address-cells = <1>; + #size-cells = <1>; + ranges; + + ssi_port1: ssi-port@4805a000 { + compatible = "ti,omap3-ssi-port"; + + reg = <0x4805a000 0x800>, + <0x4805a800 0x800>; + reg-names = "tx", + "rx"; + + interrupt-parent = <&intc>; + interrupts = <67>, + <68>; + }; + + ssi_port2: ssi-port@4805b000 { + compatible = "ti,omap3-ssi-port"; + + reg = <0x4805b000 0x800>, + <0x4805b800 0x800>; + reg-names = "tx", + "rx"; + + interrupt-parent = <&intc>; + interrupts = <69>, + <70>; + }; + }; + }; };
/include/ "omap3xxx-clocks.dtsi" diff --git a/arch/arm/dts/omap34xx-omap36xx-clocks.dtsi b/arch/arm/dts/omap34xx-omap36xx-clocks.dtsi index db47f12..858aa07 100644 --- a/arch/arm/dts/omap34xx-omap36xx-clocks.dtsi +++ b/arch/arm/dts/omap34xx-omap36xx-clocks.dtsi @@ -8,261 +8,261 @@ * published by the Free Software Foundation. */ &cm_clocks { - security_l4_ick2: security_l4_ick2 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&l4_ick>; - clock-mult = <1>; - clock-div = <1>; - }; + security_l4_ick2: security_l4_ick2 { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l4_ick>; + clock-mult = <1>; + clock-div = <1>; + };
- aes1_ick: aes1_ick@a14 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&security_l4_ick2>; - ti,bit-shift = <3>; - reg = <0x0a14>; - }; + aes1_ick: aes1_ick@a14 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&security_l4_ick2>; + ti,bit-shift = <3>; + reg = <0x0a14>; + };
- rng_ick: rng_ick@a14 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&security_l4_ick2>; - reg = <0x0a14>; - ti,bit-shift = <2>; - }; + rng_ick: rng_ick@a14 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&security_l4_ick2>; + reg = <0x0a14>; + ti,bit-shift = <2>; + };
- sha11_ick: sha11_ick@a14 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&security_l4_ick2>; - reg = <0x0a14>; - ti,bit-shift = <1>; - }; + sha11_ick: sha11_ick@a14 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&security_l4_ick2>; + reg = <0x0a14>; + ti,bit-shift = <1>; + };
- des1_ick: des1_ick@a14 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&security_l4_ick2>; - reg = <0x0a14>; - ti,bit-shift = <0>; - }; + des1_ick: des1_ick@a14 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&security_l4_ick2>; + reg = <0x0a14>; + ti,bit-shift = <0>; + };
- cam_mclk: cam_mclk@f00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&dpll4_m5x2_ck>; - ti,bit-shift = <0>; - reg = <0x0f00>; - ti,set-rate-parent; - }; + cam_mclk: cam_mclk@f00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll4_m5x2_ck>; + ti,bit-shift = <0>; + reg = <0x0f00>; + ti,set-rate-parent; + };
- cam_ick: cam_ick@f10 { - #clock-cells = <0>; - compatible = "ti,omap3-no-wait-interface-clock"; - clocks = <&l4_ick>; - reg = <0x0f10>; - ti,bit-shift = <0>; - }; + cam_ick: cam_ick@f10 { + #clock-cells = <0>; + compatible = "ti,omap3-no-wait-interface-clock"; + clocks = <&l4_ick>; + reg = <0x0f10>; + ti,bit-shift = <0>; + };
- csi2_96m_fck: csi2_96m_fck@f00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&core_96m_fck>; - reg = <0x0f00>; - ti,bit-shift = <1>; - }; + csi2_96m_fck: csi2_96m_fck@f00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&core_96m_fck>; + reg = <0x0f00>; + ti,bit-shift = <1>; + };
- security_l3_ick: security_l3_ick { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&l3_ick>; - clock-mult = <1>; - clock-div = <1>; - }; + security_l3_ick: security_l3_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l3_ick>; + clock-mult = <1>; + clock-div = <1>; + };
- pka_ick: pka_ick@a14 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&security_l3_ick>; - reg = <0x0a14>; - ti,bit-shift = <4>; - }; + pka_ick: pka_ick@a14 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&security_l3_ick>; + reg = <0x0a14>; + ti,bit-shift = <4>; + };
- icr_ick: icr_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <29>; - }; + icr_ick: icr_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <29>; + };
- des2_ick: des2_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <26>; - }; + des2_ick: des2_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <26>; + };
- mspro_ick: mspro_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <23>; - }; + mspro_ick: mspro_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <23>; + };
- mailboxes_ick: mailboxes_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <7>; - }; + mailboxes_ick: mailboxes_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <7>; + };
- ssi_l4_ick: ssi_l4_ick { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&l4_ick>; - clock-mult = <1>; - clock-div = <1>; - }; + ssi_l4_ick: ssi_l4_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l4_ick>; + clock-mult = <1>; + clock-div = <1>; + };
- sr1_fck: sr1_fck@c00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&sys_ck>; - reg = <0x0c00>; - ti,bit-shift = <6>; - }; + sr1_fck: sr1_fck@c00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&sys_ck>; + reg = <0x0c00>; + ti,bit-shift = <6>; + };
- sr2_fck: sr2_fck@c00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&sys_ck>; - reg = <0x0c00>; - ti,bit-shift = <7>; - }; + sr2_fck: sr2_fck@c00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&sys_ck>; + reg = <0x0c00>; + ti,bit-shift = <7>; + };
- sr_l4_ick: sr_l4_ick { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&l4_ick>; - clock-mult = <1>; - clock-div = <1>; - }; + sr_l4_ick: sr_l4_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l4_ick>; + clock-mult = <1>; + clock-div = <1>; + };
- dpll2_fck: dpll2_fck@40 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&core_ck>; - ti,bit-shift = <19>; - ti,max-div = <7>; - reg = <0x0040>; - ti,index-starts-at-one; - }; + dpll2_fck: dpll2_fck@40 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&core_ck>; + ti,bit-shift = <19>; + ti,max-div = <7>; + reg = <0x0040>; + ti,index-starts-at-one; + };
- dpll2_ck: dpll2_ck@4 { - #clock-cells = <0>; - compatible = "ti,omap3-dpll-clock"; - clocks = <&sys_ck>, <&dpll2_fck>; - reg = <0x0004>, <0x0024>, <0x0040>, <0x0034>; - ti,low-power-stop; - ti,lock; - ti,low-power-bypass; - }; + dpll2_ck: dpll2_ck@4 { + #clock-cells = <0>; + compatible = "ti,omap3-dpll-clock"; + clocks = <&sys_ck>, <&dpll2_fck>; + reg = <0x0004>, <0x0024>, <0x0040>, <0x0034>; + ti,low-power-stop; + ti,lock; + ti,low-power-bypass; + };
- dpll2_m2_ck: dpll2_m2_ck@44 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&dpll2_ck>; - ti,max-div = <31>; - reg = <0x0044>; - ti,index-starts-at-one; - }; + dpll2_m2_ck: dpll2_m2_ck@44 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll2_ck>; + ti,max-div = <31>; + reg = <0x0044>; + ti,index-starts-at-one; + };
- iva2_ck: iva2_ck@0 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&dpll2_m2_ck>; - reg = <0x0000>; - ti,bit-shift = <0>; - }; + iva2_ck: iva2_ck@0 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&dpll2_m2_ck>; + reg = <0x0000>; + ti,bit-shift = <0>; + };
- modem_fck: modem_fck@a00 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&sys_ck>; - reg = <0x0a00>; - ti,bit-shift = <31>; - }; + modem_fck: modem_fck@a00 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&sys_ck>; + reg = <0x0a00>; + ti,bit-shift = <31>; + };
- sad2d_ick: sad2d_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&l3_ick>; - reg = <0x0a10>; - ti,bit-shift = <3>; - }; + sad2d_ick: sad2d_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&l3_ick>; + reg = <0x0a10>; + ti,bit-shift = <3>; + };
- mad2d_ick: mad2d_ick@a18 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&l3_ick>; - reg = <0x0a18>; - ti,bit-shift = <3>; - }; + mad2d_ick: mad2d_ick@a18 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&l3_ick>; + reg = <0x0a18>; + ti,bit-shift = <3>; + };
- mspro_fck: mspro_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_96m_fck>; - reg = <0x0a00>; - ti,bit-shift = <23>; - }; + mspro_fck: mspro_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_96m_fck>; + reg = <0x0a00>; + ti,bit-shift = <23>; + }; };
&cm_clockdomains { - cam_clkdm: cam_clkdm { - compatible = "ti,clockdomain"; - clocks = <&cam_ick>, <&csi2_96m_fck>; - }; + cam_clkdm: cam_clkdm { + compatible = "ti,clockdomain"; + clocks = <&cam_ick>, <&csi2_96m_fck>; + };
- iva2_clkdm: iva2_clkdm { - compatible = "ti,clockdomain"; - clocks = <&iva2_ck>; - }; + iva2_clkdm: iva2_clkdm { + compatible = "ti,clockdomain"; + clocks = <&iva2_ck>; + };
- dpll2_clkdm: dpll2_clkdm { - compatible = "ti,clockdomain"; - clocks = <&dpll2_ck>; - }; + dpll2_clkdm: dpll2_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll2_ck>; + };
- wkup_clkdm: wkup_clkdm { - compatible = "ti,clockdomain"; - clocks = <&gpio1_dbck>, <&wdt2_fck>, <&wdt2_ick>, <&wdt1_ick>, - <&gpio1_ick>, <&omap_32ksync_ick>, <&gpt12_ick>, - <&gpt1_ick>, <&sr1_fck>, <&sr2_fck>; - }; + wkup_clkdm: wkup_clkdm { + compatible = "ti,clockdomain"; + clocks = <&gpio1_dbck>, <&wdt2_fck>, <&wdt2_ick>, <&wdt1_ick>, + <&gpio1_ick>, <&omap_32ksync_ick>, <&gpt12_ick>, + <&gpt1_ick>, <&sr1_fck>, <&sr2_fck>; + };
- d2d_clkdm: d2d_clkdm { - compatible = "ti,clockdomain"; - clocks = <&modem_fck>, <&sad2d_ick>, <&mad2d_ick>; - }; + d2d_clkdm: d2d_clkdm { + compatible = "ti,clockdomain"; + clocks = <&modem_fck>, <&sad2d_ick>, <&mad2d_ick>; + };
- core_l4_clkdm: core_l4_clkdm { - compatible = "ti,clockdomain"; - clocks = <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, - <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, - <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, - <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, - <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, - <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, - <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, - <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, - <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>, <&icr_ick>, - <&des2_ick>, <&mspro_ick>, <&mailboxes_ick>, - <&mspro_fck>; - }; + core_l4_clkdm: core_l4_clkdm { + compatible = "ti,clockdomain"; + clocks = <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, + <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, + <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, + <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, + <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, + <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, + <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, + <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, + <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>, <&icr_ick>, + <&des2_ick>, <&mspro_ick>, <&mailboxes_ick>, + <&mspro_fck>; + }; }; diff --git a/arch/arm/dts/omap36xx-am35xx-omap3430es2plus-clocks.dtsi b/arch/arm/dts/omap36xx-am35xx-omap3430es2plus-clocks.dtsi index 572cb53..15d1866 100644 --- a/arch/arm/dts/omap36xx-am35xx-omap3430es2plus-clocks.dtsi +++ b/arch/arm/dts/omap36xx-am35xx-omap3430es2plus-clocks.dtsi @@ -8,235 +8,235 @@ * published by the Free Software Foundation. */ &prm_clocks { - corex2_d3_fck: corex2_d3_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&corex2_fck>; - clock-mult = <1>; - clock-div = <3>; - }; - - corex2_d5_fck: corex2_d5_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&corex2_fck>; - clock-mult = <1>; - clock-div = <5>; - }; + corex2_d3_fck: corex2_d3_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&corex2_fck>; + clock-mult = <1>; + clock-div = <3>; + }; + + corex2_d5_fck: corex2_d5_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&corex2_fck>; + clock-mult = <1>; + clock-div = <5>; + }; }; &cm_clocks { - dpll5_ck: dpll5_ck@d04 { - #clock-cells = <0>; - compatible = "ti,omap3-dpll-clock"; - clocks = <&sys_ck>, <&sys_ck>; - reg = <0x0d04>, <0x0d24>, <0x0d4c>, <0x0d34>; - ti,low-power-stop; - ti,lock; - }; - - dpll5_m2_ck: dpll5_m2_ck@d50 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&dpll5_ck>; - ti,max-div = <31>; - reg = <0x0d50>; - ti,index-starts-at-one; - }; - - sgx_gate_fck: sgx_gate_fck@b00 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&core_ck>; - ti,bit-shift = <1>; - reg = <0x0b00>; - }; - - core_d3_ck: core_d3_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&core_ck>; - clock-mult = <1>; - clock-div = <3>; - }; - - core_d4_ck: core_d4_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&core_ck>; - clock-mult = <1>; - clock-div = <4>; - }; - - core_d6_ck: core_d6_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&core_ck>; - clock-mult = <1>; - clock-div = <6>; - }; - - omap_192m_alwon_fck: omap_192m_alwon_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll4_m2x2_ck>; - clock-mult = <1>; - clock-div = <1>; - }; - - core_d2_ck: core_d2_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&core_ck>; - clock-mult = <1>; - clock-div = <2>; - }; - - sgx_mux_fck: sgx_mux_fck@b40 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&core_d3_ck>, <&core_d4_ck>, <&core_d6_ck>, <&cm_96m_fck>, <&omap_192m_alwon_fck>, <&core_d2_ck>, <&corex2_d3_fck>, <&corex2_d5_fck>; - reg = <0x0b40>; - }; - - sgx_fck: sgx_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&sgx_gate_fck>, <&sgx_mux_fck>; - }; - - sgx_ick: sgx_ick@b10 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&l3_ick>; - reg = <0x0b10>; - ti,bit-shift = <0>; - }; - - cpefuse_fck: cpefuse_fck@a08 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&sys_ck>; - reg = <0x0a08>; - ti,bit-shift = <0>; - }; - - ts_fck: ts_fck@a08 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&omap_32k_fck>; - reg = <0x0a08>; - ti,bit-shift = <1>; - }; - - usbtll_fck: usbtll_fck@a08 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&dpll5_m2_ck>; - reg = <0x0a08>; - ti,bit-shift = <2>; - }; - - usbtll_ick: usbtll_ick@a18 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a18>; - ti,bit-shift = <2>; - }; - - mmchs3_ick: mmchs3_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <30>; - }; - - mmchs3_fck: mmchs3_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_96m_fck>; - reg = <0x0a00>; - ti,bit-shift = <30>; - }; - - dss1_alwon_fck: dss1_alwon_fck_3430es2@e00 { - #clock-cells = <0>; - compatible = "ti,dss-gate-clock"; - clocks = <&dpll4_m4x2_ck>; - ti,bit-shift = <0>; - reg = <0x0e00>; - ti,set-rate-parent; - }; - - dss_ick: dss_ick_3430es2@e10 { - #clock-cells = <0>; - compatible = "ti,omap3-dss-interface-clock"; - clocks = <&l4_ick>; - reg = <0x0e10>; - ti,bit-shift = <0>; - }; - - usbhost_120m_fck: usbhost_120m_fck@1400 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&dpll5_m2_ck>; - reg = <0x1400>; - ti,bit-shift = <1>; - }; - - usbhost_48m_fck: usbhost_48m_fck@1400 { - #clock-cells = <0>; - compatible = "ti,dss-gate-clock"; - clocks = <&omap_48m_fck>; - reg = <0x1400>; - ti,bit-shift = <0>; - }; - - usbhost_ick: usbhost_ick@1410 { - #clock-cells = <0>; - compatible = "ti,omap3-dss-interface-clock"; - clocks = <&l4_ick>; - reg = <0x1410>; - ti,bit-shift = <0>; - }; + dpll5_ck: dpll5_ck@d04 { + #clock-cells = <0>; + compatible = "ti,omap3-dpll-clock"; + clocks = <&sys_ck>, <&sys_ck>; + reg = <0x0d04>, <0x0d24>, <0x0d4c>, <0x0d34>; + ti,low-power-stop; + ti,lock; + }; + + dpll5_m2_ck: dpll5_m2_ck@d50 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll5_ck>; + ti,max-div = <31>; + reg = <0x0d50>; + ti,index-starts-at-one; + }; + + sgx_gate_fck: sgx_gate_fck@b00 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&core_ck>; + ti,bit-shift = <1>; + reg = <0x0b00>; + }; + + core_d3_ck: core_d3_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&core_ck>; + clock-mult = <1>; + clock-div = <3>; + }; + + core_d4_ck: core_d4_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&core_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + core_d6_ck: core_d6_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&core_ck>; + clock-mult = <1>; + clock-div = <6>; + }; + + omap_192m_alwon_fck: omap_192m_alwon_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll4_m2x2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + core_d2_ck: core_d2_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&core_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + sgx_mux_fck: sgx_mux_fck@b40 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&core_d3_ck>, <&core_d4_ck>, <&core_d6_ck>, <&cm_96m_fck>, <&omap_192m_alwon_fck>, <&core_d2_ck>, <&corex2_d3_fck>, <&corex2_d5_fck>; + reg = <0x0b40>; + }; + + sgx_fck: sgx_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&sgx_gate_fck>, <&sgx_mux_fck>; + }; + + sgx_ick: sgx_ick@b10 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&l3_ick>; + reg = <0x0b10>; + ti,bit-shift = <0>; + }; + + cpefuse_fck: cpefuse_fck@a08 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&sys_ck>; + reg = <0x0a08>; + ti,bit-shift = <0>; + }; + + ts_fck: ts_fck@a08 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&omap_32k_fck>; + reg = <0x0a08>; + ti,bit-shift = <1>; + }; + + usbtll_fck: usbtll_fck@a08 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&dpll5_m2_ck>; + reg = <0x0a08>; + ti,bit-shift = <2>; + }; + + usbtll_ick: usbtll_ick@a18 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a18>; + ti,bit-shift = <2>; + }; + + mmchs3_ick: mmchs3_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <30>; + }; + + mmchs3_fck: mmchs3_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_96m_fck>; + reg = <0x0a00>; + ti,bit-shift = <30>; + }; + + dss1_alwon_fck: dss1_alwon_fck_3430es2@e00 { + #clock-cells = <0>; + compatible = "ti,dss-gate-clock"; + clocks = <&dpll4_m4x2_ck>; + ti,bit-shift = <0>; + reg = <0x0e00>; + ti,set-rate-parent; + }; + + dss_ick: dss_ick_3430es2@e10 { + #clock-cells = <0>; + compatible = "ti,omap3-dss-interface-clock"; + clocks = <&l4_ick>; + reg = <0x0e10>; + ti,bit-shift = <0>; + }; + + usbhost_120m_fck: usbhost_120m_fck@1400 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll5_m2_ck>; + reg = <0x1400>; + ti,bit-shift = <1>; + }; + + usbhost_48m_fck: usbhost_48m_fck@1400 { + #clock-cells = <0>; + compatible = "ti,dss-gate-clock"; + clocks = <&omap_48m_fck>; + reg = <0x1400>; + ti,bit-shift = <0>; + }; + + usbhost_ick: usbhost_ick@1410 { + #clock-cells = <0>; + compatible = "ti,omap3-dss-interface-clock"; + clocks = <&l4_ick>; + reg = <0x1410>; + ti,bit-shift = <0>; + }; };
&cm_clockdomains { - dpll5_clkdm: dpll5_clkdm { - compatible = "ti,clockdomain"; - clocks = <&dpll5_ck>; - }; - - sgx_clkdm: sgx_clkdm { - compatible = "ti,clockdomain"; - clocks = <&sgx_ick>; - }; - - dss_clkdm: dss_clkdm { - compatible = "ti,clockdomain"; - clocks = <&dss_tv_fck>, <&dss_96m_fck>, <&dss2_alwon_fck>, - <&dss1_alwon_fck>, <&dss_ick>; - }; - - core_l4_clkdm: core_l4_clkdm { - compatible = "ti,clockdomain"; - clocks = <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, - <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, - <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, - <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, - <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, - <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, - <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, - <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, - <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>, - <&cpefuse_fck>, <&ts_fck>, <&usbtll_fck>, - <&usbtll_ick>, <&mmchs3_ick>, <&mmchs3_fck>; - }; - - usbhost_clkdm: usbhost_clkdm { - compatible = "ti,clockdomain"; - clocks = <&usbhost_120m_fck>, <&usbhost_48m_fck>, - <&usbhost_ick>; - }; + dpll5_clkdm: dpll5_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll5_ck>; + }; + + sgx_clkdm: sgx_clkdm { + compatible = "ti,clockdomain"; + clocks = <&sgx_ick>; + }; + + dss_clkdm: dss_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dss_tv_fck>, <&dss_96m_fck>, <&dss2_alwon_fck>, + <&dss1_alwon_fck>, <&dss_ick>; + }; + + core_l4_clkdm: core_l4_clkdm { + compatible = "ti,clockdomain"; + clocks = <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, + <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, + <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, + <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, + <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, + <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, + <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, + <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, + <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>, + <&cpefuse_fck>, <&ts_fck>, <&usbtll_fck>, + <&usbtll_ick>, <&mmchs3_ick>, <&mmchs3_fck>; + }; + + usbhost_clkdm: usbhost_clkdm { + compatible = "ti,clockdomain"; + clocks = <&usbhost_120m_fck>, <&usbhost_48m_fck>, + <&usbhost_ick>; + }; }; diff --git a/arch/arm/dts/omap36xx-clocks.dtsi b/arch/arm/dts/omap36xx-clocks.dtsi index 9c7ed03..a21d1f0 100644 --- a/arch/arm/dts/omap36xx-clocks.dtsi +++ b/arch/arm/dts/omap36xx-clocks.dtsi @@ -8,103 +8,103 @@ * published by the Free Software Foundation. */ &cm_clocks { - dpll4_ck: dpll4_ck@d00 { - #clock-cells = <0>; - compatible = "ti,omap3-dpll-per-j-type-clock"; - clocks = <&sys_ck>, <&sys_ck>; - reg = <0x0d00>, <0x0d20>, <0x0d44>, <0x0d30>; - }; + dpll4_ck: dpll4_ck@d00 { + #clock-cells = <0>; + compatible = "ti,omap3-dpll-per-j-type-clock"; + clocks = <&sys_ck>, <&sys_ck>; + reg = <0x0d00>, <0x0d20>, <0x0d44>, <0x0d30>; + };
- dpll4_m5x2_ck: dpll4_m5x2_ck@d00 { - #clock-cells = <0>; - compatible = "ti,hsdiv-gate-clock"; - clocks = <&dpll4_m5x2_mul_ck>; - ti,bit-shift = <0x1e>; - reg = <0x0d00>; - ti,set-rate-parent; - ti,set-bit-to-disable; - }; + dpll4_m5x2_ck: dpll4_m5x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,hsdiv-gate-clock"; + clocks = <&dpll4_m5x2_mul_ck>; + ti,bit-shift = <0x1e>; + reg = <0x0d00>; + ti,set-rate-parent; + ti,set-bit-to-disable; + };
- dpll4_m2x2_ck: dpll4_m2x2_ck@d00 { - #clock-cells = <0>; - compatible = "ti,hsdiv-gate-clock"; - clocks = <&dpll4_m2x2_mul_ck>; - ti,bit-shift = <0x1b>; - reg = <0x0d00>; - ti,set-bit-to-disable; - }; + dpll4_m2x2_ck: dpll4_m2x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,hsdiv-gate-clock"; + clocks = <&dpll4_m2x2_mul_ck>; + ti,bit-shift = <0x1b>; + reg = <0x0d00>; + ti,set-bit-to-disable; + };
- dpll3_m3x2_ck: dpll3_m3x2_ck@d00 { - #clock-cells = <0>; - compatible = "ti,hsdiv-gate-clock"; - clocks = <&dpll3_m3x2_mul_ck>; - ti,bit-shift = <0xc>; - reg = <0x0d00>; - ti,set-bit-to-disable; - }; + dpll3_m3x2_ck: dpll3_m3x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,hsdiv-gate-clock"; + clocks = <&dpll3_m3x2_mul_ck>; + ti,bit-shift = <0xc>; + reg = <0x0d00>; + ti,set-bit-to-disable; + };
- dpll4_m3x2_ck: dpll4_m3x2_ck@d00 { - #clock-cells = <0>; - compatible = "ti,hsdiv-gate-clock"; - clocks = <&dpll4_m3x2_mul_ck>; - ti,bit-shift = <0x1c>; - reg = <0x0d00>; - ti,set-bit-to-disable; - }; + dpll4_m3x2_ck: dpll4_m3x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,hsdiv-gate-clock"; + clocks = <&dpll4_m3x2_mul_ck>; + ti,bit-shift = <0x1c>; + reg = <0x0d00>; + ti,set-bit-to-disable; + };
- dpll4_m6x2_ck: dpll4_m6x2_ck@d00 { - #clock-cells = <0>; - compatible = "ti,hsdiv-gate-clock"; - clocks = <&dpll4_m6x2_mul_ck>; - ti,bit-shift = <0x1f>; - reg = <0x0d00>; - ti,set-bit-to-disable; - }; + dpll4_m6x2_ck: dpll4_m6x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,hsdiv-gate-clock"; + clocks = <&dpll4_m6x2_mul_ck>; + ti,bit-shift = <0x1f>; + reg = <0x0d00>; + ti,set-bit-to-disable; + };
- uart4_fck: uart4_fck@1000 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&per_48m_fck>; - reg = <0x1000>; - ti,bit-shift = <18>; - }; + uart4_fck: uart4_fck@1000 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&per_48m_fck>; + reg = <0x1000>; + ti,bit-shift = <18>; + }; };
&dpll4_m2x2_mul_ck { - clock-mult = <1>; + clock-mult = <1>; };
&dpll4_m3x2_mul_ck { - clock-mult = <1>; + clock-mult = <1>; };
&dpll4_m4x2_mul_ck { - ti,clock-mult = <1>; + ti,clock-mult = <1>; };
&dpll4_m5x2_mul_ck { - ti,clock-mult = <1>; + ti,clock-mult = <1>; };
&dpll4_m6x2_mul_ck { - clock-mult = <1>; + clock-mult = <1>; };
&cm_clockdomains { - dpll4_clkdm: dpll4_clkdm { - compatible = "ti,clockdomain"; - clocks = <&dpll4_ck>; - }; + dpll4_clkdm: dpll4_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll4_ck>; + };
- per_clkdm: per_clkdm { - compatible = "ti,clockdomain"; - clocks = <&uart3_fck>, <&gpio6_dbck>, <&gpio5_dbck>, - <&gpio4_dbck>, <&gpio3_dbck>, <&gpio2_dbck>, - <&wdt3_fck>, <&gpio6_ick>, <&gpio5_ick>, <&gpio4_ick>, - <&gpio3_ick>, <&gpio2_ick>, <&wdt3_ick>, <&uart3_ick>, - <&uart4_ick>, <&gpt9_ick>, <&gpt8_ick>, <&gpt7_ick>, - <&gpt6_ick>, <&gpt5_ick>, <&gpt4_ick>, <&gpt3_ick>, - <&gpt2_ick>, <&mcbsp2_ick>, <&mcbsp3_ick>, - <&mcbsp4_ick>, <&uart4_fck>; - }; + per_clkdm: per_clkdm { + compatible = "ti,clockdomain"; + clocks = <&uart3_fck>, <&gpio6_dbck>, <&gpio5_dbck>, + <&gpio4_dbck>, <&gpio3_dbck>, <&gpio2_dbck>, + <&wdt3_fck>, <&gpio6_ick>, <&gpio5_ick>, <&gpio4_ick>, + <&gpio3_ick>, <&gpio2_ick>, <&wdt3_ick>, <&uart3_ick>, + <&uart4_ick>, <&gpt9_ick>, <&gpt8_ick>, <&gpt7_ick>, + <&gpt6_ick>, <&gpt5_ick>, <&gpt4_ick>, <&gpt3_ick>, + <&gpt2_ick>, <&mcbsp2_ick>, <&mcbsp3_ick>, + <&mcbsp4_ick>, <&uart4_fck>; + }; }; diff --git a/arch/arm/dts/omap36xx-omap3430es2plus-clocks.dtsi b/arch/arm/dts/omap36xx-omap3430es2plus-clocks.dtsi index a9eec1b..1a4fbdf 100644 --- a/arch/arm/dts/omap36xx-omap3430es2plus-clocks.dtsi +++ b/arch/arm/dts/omap36xx-omap3430es2plus-clocks.dtsi @@ -8,191 +8,191 @@ * published by the Free Software Foundation. */ &cm_clocks { - ssi_ssr_gate_fck_3430es2: ssi_ssr_gate_fck_3430es2@a00 { - #clock-cells = <0>; - compatible = "ti,composite-no-wait-gate-clock"; - clocks = <&corex2_fck>; - ti,bit-shift = <0>; - reg = <0x0a00>; - }; - - ssi_ssr_div_fck_3430es2: ssi_ssr_div_fck_3430es2@a40 { - #clock-cells = <0>; - compatible = "ti,composite-divider-clock"; - clocks = <&corex2_fck>; - ti,bit-shift = <8>; - reg = <0x0a40>; - ti,dividers = <0>, <1>, <2>, <3>, <4>, <0>, <6>, <0>, <8>; - }; - - ssi_ssr_fck: ssi_ssr_fck_3430es2 { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&ssi_ssr_gate_fck_3430es2>, <&ssi_ssr_div_fck_3430es2>; - }; - - ssi_sst_fck: ssi_sst_fck_3430es2 { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&ssi_ssr_fck>; - clock-mult = <1>; - clock-div = <2>; - }; - - hsotgusb_ick_3430es2: hsotgusb_ick_3430es2@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-hsotgusb-interface-clock"; - clocks = <&core_l3_ick>; - reg = <0x0a10>; - ti,bit-shift = <4>; - }; - - ssi_l4_ick: ssi_l4_ick { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&l4_ick>; - clock-mult = <1>; - clock-div = <1>; - }; - - ssi_ick: ssi_ick_3430es2@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-ssi-interface-clock"; - clocks = <&ssi_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <0>; - }; - - usim_gate_fck: usim_gate_fck@c00 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&omap_96m_fck>; - ti,bit-shift = <9>; - reg = <0x0c00>; - }; - - sys_d2_ck: sys_d2_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&sys_ck>; - clock-mult = <1>; - clock-div = <2>; - }; - - omap_96m_d2_fck: omap_96m_d2_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_96m_fck>; - clock-mult = <1>; - clock-div = <2>; - }; - - omap_96m_d4_fck: omap_96m_d4_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_96m_fck>; - clock-mult = <1>; - clock-div = <4>; - }; - - omap_96m_d8_fck: omap_96m_d8_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_96m_fck>; - clock-mult = <1>; - clock-div = <8>; - }; - - omap_96m_d10_fck: omap_96m_d10_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_96m_fck>; - clock-mult = <1>; - clock-div = <10>; - }; - - dpll5_m2_d4_ck: dpll5_m2_d4_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll5_m2_ck>; - clock-mult = <1>; - clock-div = <4>; - }; - - dpll5_m2_d8_ck: dpll5_m2_d8_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll5_m2_ck>; - clock-mult = <1>; - clock-div = <8>; - }; - - dpll5_m2_d16_ck: dpll5_m2_d16_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll5_m2_ck>; - clock-mult = <1>; - clock-div = <16>; - }; - - dpll5_m2_d20_ck: dpll5_m2_d20_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll5_m2_ck>; - clock-mult = <1>; - clock-div = <20>; - }; - - usim_mux_fck: usim_mux_fck@c40 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&sys_ck>, <&sys_d2_ck>, <&omap_96m_d2_fck>, <&omap_96m_d4_fck>, <&omap_96m_d8_fck>, <&omap_96m_d10_fck>, <&dpll5_m2_d4_ck>, <&dpll5_m2_d8_ck>, <&dpll5_m2_d16_ck>, <&dpll5_m2_d20_ck>; - ti,bit-shift = <3>; - reg = <0x0c40>; - ti,index-starts-at-one; - }; - - usim_fck: usim_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&usim_gate_fck>, <&usim_mux_fck>; - }; - - usim_ick: usim_ick@c10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&wkup_l4_ick>; - reg = <0x0c10>; - ti,bit-shift = <9>; - }; + ssi_ssr_gate_fck_3430es2: ssi_ssr_gate_fck_3430es2@a00 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&corex2_fck>; + ti,bit-shift = <0>; + reg = <0x0a00>; + }; + + ssi_ssr_div_fck_3430es2: ssi_ssr_div_fck_3430es2@a40 { + #clock-cells = <0>; + compatible = "ti,composite-divider-clock"; + clocks = <&corex2_fck>; + ti,bit-shift = <8>; + reg = <0x0a40>; + ti,dividers = <0>, <1>, <2>, <3>, <4>, <0>, <6>, <0>, <8>; + }; + + ssi_ssr_fck: ssi_ssr_fck_3430es2 { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&ssi_ssr_gate_fck_3430es2>, <&ssi_ssr_div_fck_3430es2>; + }; + + ssi_sst_fck: ssi_sst_fck_3430es2 { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&ssi_ssr_fck>; + clock-mult = <1>; + clock-div = <2>; + }; + + hsotgusb_ick_3430es2: hsotgusb_ick_3430es2@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-hsotgusb-interface-clock"; + clocks = <&core_l3_ick>; + reg = <0x0a10>; + ti,bit-shift = <4>; + }; + + ssi_l4_ick: ssi_l4_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l4_ick>; + clock-mult = <1>; + clock-div = <1>; + }; + + ssi_ick: ssi_ick_3430es2@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-ssi-interface-clock"; + clocks = <&ssi_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <0>; + }; + + usim_gate_fck: usim_gate_fck@c00 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&omap_96m_fck>; + ti,bit-shift = <9>; + reg = <0x0c00>; + }; + + sys_d2_ck: sys_d2_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&sys_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + omap_96m_d2_fck: omap_96m_d2_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_96m_fck>; + clock-mult = <1>; + clock-div = <2>; + }; + + omap_96m_d4_fck: omap_96m_d4_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_96m_fck>; + clock-mult = <1>; + clock-div = <4>; + }; + + omap_96m_d8_fck: omap_96m_d8_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_96m_fck>; + clock-mult = <1>; + clock-div = <8>; + }; + + omap_96m_d10_fck: omap_96m_d10_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_96m_fck>; + clock-mult = <1>; + clock-div = <10>; + }; + + dpll5_m2_d4_ck: dpll5_m2_d4_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll5_m2_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + dpll5_m2_d8_ck: dpll5_m2_d8_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll5_m2_ck>; + clock-mult = <1>; + clock-div = <8>; + }; + + dpll5_m2_d16_ck: dpll5_m2_d16_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll5_m2_ck>; + clock-mult = <1>; + clock-div = <16>; + }; + + dpll5_m2_d20_ck: dpll5_m2_d20_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll5_m2_ck>; + clock-mult = <1>; + clock-div = <20>; + }; + + usim_mux_fck: usim_mux_fck@c40 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_ck>, <&sys_d2_ck>, <&omap_96m_d2_fck>, <&omap_96m_d4_fck>, <&omap_96m_d8_fck>, <&omap_96m_d10_fck>, <&dpll5_m2_d4_ck>, <&dpll5_m2_d8_ck>, <&dpll5_m2_d16_ck>, <&dpll5_m2_d20_ck>; + ti,bit-shift = <3>; + reg = <0x0c40>; + ti,index-starts-at-one; + }; + + usim_fck: usim_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&usim_gate_fck>, <&usim_mux_fck>; + }; + + usim_ick: usim_ick@c10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&wkup_l4_ick>; + reg = <0x0c10>; + ti,bit-shift = <9>; + }; };
&cm_clockdomains { - core_l3_clkdm: core_l3_clkdm { - compatible = "ti,clockdomain"; - clocks = <&sdrc_ick>, <&hsotgusb_ick_3430es2>; - }; - - wkup_clkdm: wkup_clkdm { - compatible = "ti,clockdomain"; - clocks = <&gpio1_dbck>, <&wdt2_fck>, <&wdt2_ick>, <&wdt1_ick>, - <&gpio1_ick>, <&omap_32ksync_ick>, <&gpt12_ick>, - <&gpt1_ick>, <&usim_ick>; - }; - - core_l4_clkdm: core_l4_clkdm { - compatible = "ti,clockdomain"; - clocks = <&cpefuse_fck>, <&ts_fck>, <&usbtll_fck>, - <&usbtll_ick>, <&mmchs3_ick>, <&mmchs3_fck>, - <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, - <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, - <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, - <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, - <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, - <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, - <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, - <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, - <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>, - <&ssi_ick>; - }; + core_l3_clkdm: core_l3_clkdm { + compatible = "ti,clockdomain"; + clocks = <&sdrc_ick>, <&hsotgusb_ick_3430es2>; + }; + + wkup_clkdm: wkup_clkdm { + compatible = "ti,clockdomain"; + clocks = <&gpio1_dbck>, <&wdt2_fck>, <&wdt2_ick>, <&wdt1_ick>, + <&gpio1_ick>, <&omap_32ksync_ick>, <&gpt12_ick>, + <&gpt1_ick>, <&usim_ick>; + }; + + core_l4_clkdm: core_l4_clkdm { + compatible = "ti,clockdomain"; + clocks = <&cpefuse_fck>, <&ts_fck>, <&usbtll_fck>, + <&usbtll_ick>, <&mmchs3_ick>, <&mmchs3_fck>, + <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, + <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, + <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, + <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, + <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, + <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, + <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, + <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, + <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>, + <&ssi_ick>; + }; }; diff --git a/arch/arm/dts/omap36xx-u-boot.dtsi b/arch/arm/dts/omap36xx-u-boot.dtsi new file mode 100644 index 0000000..2190052 --- /dev/null +++ b/arch/arm/dts/omap36xx-u-boot.dtsi @@ -0,0 +1,10 @@ +/* + * Copyright (C) 2017 + * Logic PD - http://www.logicpd.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +&uart4 { + reg-shift = <2>; +}; diff --git a/arch/arm/dts/omap36xx.dtsi b/arch/arm/dts/omap36xx.dtsi index fc22f0d..a0f2d9e 100644 --- a/arch/arm/dts/omap36xx.dtsi +++ b/arch/arm/dts/omap36xx.dtsi @@ -13,103 +13,109 @@ #include "omap3.dtsi"
/ { - aliases { - serial3 = &uart4; - }; + aliases { + serial3 = &uart4; + };
- cpus { - /* OMAP3630/OMAP37xx 'standard device' variants OPP50 to OPP130 */ - cpu@0 { - operating-points = < - /* kHz uV */ - 300000 1012500 - 600000 1200000 - 800000 1325000 - >; - clock-latency = <300000>; /* From legacy driver */ - }; - }; + cpus { + /* OMAP3630/OMAP37xx 'standard device' variants OPP50 to OPP130 */ + cpu: cpu@0 { + operating-points = < + /* kHz uV */ + 300000 1012500 + 600000 1200000 + 800000 1325000 + >; + clock-latency = <300000>; /* From legacy driver */ + }; + };
- ocp@68000000 { - uart4: serial@49042000 { - compatible = "ti,omap3-uart"; - reg = <0x49042000 0x400>; - interrupts = <80>; - dmas = <&sdma 81 &sdma 82>; - dma-names = "tx", "rx"; - ti,hwmods = "uart4"; - clock-frequency = <48000000>; - }; + ocp@68000000 { + uart4: serial@49042000 { + compatible = "ti,omap3-uart"; + reg = <0x49042000 0x400>; + reg-shift = <2>; + interrupts = <80>; + dmas = <&sdma 81 &sdma 82>; + dma-names = "tx", "rx"; + ti,hwmods = "uart4"; + clock-frequency = <48000000>; + };
- abb_mpu_iva: regulator-abb-mpu { - compatible = "ti,abb-v1"; - regulator-name = "abb_mpu_iva"; - #address-cells = <0>; - #size-cells = <0>; - reg = <0x483072f0 0x8>, <0x48306818 0x4>; - reg-names = "base-address", "int-address"; - ti,tranxdone-status-mask = <0x4000000>; - clocks = <&sys_ck>; - ti,settling-time = <30>; - ti,clock-cycles = <8>; - ti,abb_info = < - /*uV ABB efuse rbb_m fbb_m vset_m*/ - 1012500 0 0 0 0 0 - 1200000 0 0 0 0 0 - 1325000 0 0 0 0 0 - 1375000 1 0 0 0 0 - >; - }; + abb_mpu_iva: regulator-abb-mpu { + compatible = "ti,abb-v1"; + regulator-name = "abb_mpu_iva"; + #address-cells = <0>; + #size-cells = <0>; + reg = <0x483072f0 0x8>, <0x48306818 0x4>; + reg-names = "base-address", "int-address"; + ti,tranxdone-status-mask = <0x4000000>; + clocks = <&sys_ck>; + ti,settling-time = <30>; + ti,clock-cycles = <8>; + ti,abb_info = < + /*uV ABB efuse rbb_m fbb_m vset_m*/ + 1012500 0 0 0 0 0 + 1200000 0 0 0 0 0 + 1325000 0 0 0 0 0 + 1375000 1 0 0 0 0 + >; + };
- omap3_pmx_core2: pinmux@480025a0 { - compatible = "ti,omap3-padconf", "pinctrl-single"; - reg = <0x480025a0 0x5c>; - #address-cells = <1>; - #size-cells = <0>; - #interrupt-cells = <1>; - interrupt-controller; - pinctrl-single,register-width = <16>; - pinctrl-single,function-mask = <0xff1f>; - }; + omap3_pmx_core2: pinmux@480025a0 { + compatible = "ti,omap3-padconf", "pinctrl-single"; + reg = <0x480025a0 0x5c>; + #address-cells = <1>; + #size-cells = <0>; + #pinctrl-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0xff1f>; + };
- isp: isp@480bc000 { - compatible = "ti,omap3-isp"; - reg = <0x480bc000 0x12fc - 0x480bd800 0x0600>; - interrupts = <24>; - iommus = <&mmu_isp>; - syscon = <&scm_conf 0x2f0>; - ti,phy-type = <OMAP3ISP_PHY_TYPE_CSIPHY>; - #clock-cells = <1>; - ports { - #address-cells = <1>; - #size-cells = <0>; - }; - }; + isp: isp@480bc000 { + compatible = "ti,omap3-isp"; + reg = <0x480bc000 0x12fc + 0x480bd800 0x0600>; + interrupts = <24>; + iommus = <&mmu_isp>; + syscon = <&scm_conf 0x2f0>; + ti,phy-type = <OMAP3ISP_PHY_TYPE_CSIPHY>; + #clock-cells = <1>; + ports { + #address-cells = <1>; + #size-cells = <0>; + }; + };
- bandgap@48002524 { - reg = <0x48002524 0x4>; - compatible = "ti,omap36xx-bandgap"; - #thermal-sensor-cells = <0>; - }; - }; + bandgap: bandgap@48002524 { + reg = <0x48002524 0x4>; + compatible = "ti,omap36xx-bandgap"; + #thermal-sensor-cells = <0>; + }; + }; + + thermal_zones: thermal-zones { + #include "omap3-cpu-thermal.dtsi" + }; };
/* OMAP3630 needs dss_96m_fck for VENC */ &venc { - clocks = <&dss_tv_fck>, <&dss_96m_fck>; - clock-names = "fck", "tv_dac_clk"; + clocks = <&dss_tv_fck>, <&dss_96m_fck>; + clock-names = "fck", "tv_dac_clk"; };
&ssi { - status = "ok"; + status = "ok";
- clocks = <&ssi_ssr_fck>, - <&ssi_sst_fck>, - <&ssi_ick>; - clock-names = "ssi_ssr_fck", - "ssi_sst_fck", - "ssi_ick"; + clocks = <&ssi_ssr_fck>, + <&ssi_sst_fck>, + <&ssi_ick>; + clock-names = "ssi_ssr_fck", + "ssi_sst_fck", + "ssi_ick"; };
/include/ "omap34xx-omap36xx-clocks.dtsi" diff --git a/arch/arm/dts/omap3xxx-clocks.dtsi b/arch/arm/dts/omap3xxx-clocks.dtsi index 7455ab5..9bd9164 100644 --- a/arch/arm/dts/omap3xxx-clocks.dtsi +++ b/arch/arm/dts/omap3xxx-clocks.dtsi @@ -8,1658 +8,1658 @@ * published by the Free Software Foundation. */ &prm_clocks { - virt_16_8m_ck: virt_16_8m_ck { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <16800000>; - }; - - osc_sys_ck: osc_sys_ck@d40 { - #clock-cells = <0>; - compatible = "ti,mux-clock"; - clocks = <&virt_12m_ck>, <&virt_13m_ck>, <&virt_19200000_ck>, <&virt_26000000_ck>, <&virt_38_4m_ck>, <&virt_16_8m_ck>; - reg = <0x0d40>; - }; - - sys_ck: sys_ck@1270 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&osc_sys_ck>; - ti,bit-shift = <6>; - ti,max-div = <3>; - reg = <0x1270>; - ti,index-starts-at-one; - }; - - sys_clkout1: sys_clkout1@d70 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&osc_sys_ck>; - reg = <0x0d70>; - ti,bit-shift = <7>; - }; - - dpll3_x2_ck: dpll3_x2_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll3_ck>; - clock-mult = <2>; - clock-div = <1>; - }; - - dpll3_m2x2_ck: dpll3_m2x2_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll3_m2_ck>; - clock-mult = <2>; - clock-div = <1>; - }; - - dpll4_x2_ck: dpll4_x2_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll4_ck>; - clock-mult = <2>; - clock-div = <1>; - }; - - corex2_fck: corex2_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll3_m2x2_ck>; - clock-mult = <1>; - clock-div = <1>; - }; - - wkup_l4_ick: wkup_l4_ick { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&sys_ck>; - clock-mult = <1>; - clock-div = <1>; - }; + virt_16_8m_ck: virt_16_8m_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <16800000>; + }; + + osc_sys_ck: osc_sys_ck@d40 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&virt_12m_ck>, <&virt_13m_ck>, <&virt_19200000_ck>, <&virt_26000000_ck>, <&virt_38_4m_ck>, <&virt_16_8m_ck>; + reg = <0x0d40>; + }; + + sys_ck: sys_ck@1270 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&osc_sys_ck>; + ti,bit-shift = <6>; + ti,max-div = <3>; + reg = <0x1270>; + ti,index-starts-at-one; + }; + + sys_clkout1: sys_clkout1@d70 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&osc_sys_ck>; + reg = <0x0d70>; + ti,bit-shift = <7>; + }; + + dpll3_x2_ck: dpll3_x2_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll3_ck>; + clock-mult = <2>; + clock-div = <1>; + }; + + dpll3_m2x2_ck: dpll3_m2x2_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll3_m2_ck>; + clock-mult = <2>; + clock-div = <1>; + }; + + dpll4_x2_ck: dpll4_x2_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll4_ck>; + clock-mult = <2>; + clock-div = <1>; + }; + + corex2_fck: corex2_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll3_m2x2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + wkup_l4_ick: wkup_l4_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&sys_ck>; + clock-mult = <1>; + clock-div = <1>; + }; };
&scm_clocks { - mcbsp5_mux_fck: mcbsp5_mux_fck@68 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&core_96m_fck>, <&mcbsp_clks>; - ti,bit-shift = <4>; - reg = <0x68>; - }; - - mcbsp5_fck: mcbsp5_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&mcbsp5_gate_fck>, <&mcbsp5_mux_fck>; - }; - - mcbsp1_mux_fck: mcbsp1_mux_fck@4 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&core_96m_fck>, <&mcbsp_clks>; - ti,bit-shift = <2>; - reg = <0x04>; - }; - - mcbsp1_fck: mcbsp1_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&mcbsp1_gate_fck>, <&mcbsp1_mux_fck>; - }; - - mcbsp2_mux_fck: mcbsp2_mux_fck@4 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&per_96m_fck>, <&mcbsp_clks>; - ti,bit-shift = <6>; - reg = <0x04>; - }; - - mcbsp2_fck: mcbsp2_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&mcbsp2_gate_fck>, <&mcbsp2_mux_fck>; - }; - - mcbsp3_mux_fck: mcbsp3_mux_fck@68 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&per_96m_fck>, <&mcbsp_clks>; - reg = <0x68>; - }; - - mcbsp3_fck: mcbsp3_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&mcbsp3_gate_fck>, <&mcbsp3_mux_fck>; - }; - - mcbsp4_mux_fck: mcbsp4_mux_fck@68 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&per_96m_fck>, <&mcbsp_clks>; - ti,bit-shift = <2>; - reg = <0x68>; - }; - - mcbsp4_fck: mcbsp4_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&mcbsp4_gate_fck>, <&mcbsp4_mux_fck>; - }; + mcbsp5_mux_fck: mcbsp5_mux_fck@68 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&core_96m_fck>, <&mcbsp_clks>; + ti,bit-shift = <4>; + reg = <0x68>; + }; + + mcbsp5_fck: mcbsp5_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&mcbsp5_gate_fck>, <&mcbsp5_mux_fck>; + }; + + mcbsp1_mux_fck: mcbsp1_mux_fck@4 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&core_96m_fck>, <&mcbsp_clks>; + ti,bit-shift = <2>; + reg = <0x04>; + }; + + mcbsp1_fck: mcbsp1_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&mcbsp1_gate_fck>, <&mcbsp1_mux_fck>; + }; + + mcbsp2_mux_fck: mcbsp2_mux_fck@4 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&per_96m_fck>, <&mcbsp_clks>; + ti,bit-shift = <6>; + reg = <0x04>; + }; + + mcbsp2_fck: mcbsp2_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&mcbsp2_gate_fck>, <&mcbsp2_mux_fck>; + }; + + mcbsp3_mux_fck: mcbsp3_mux_fck@68 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&per_96m_fck>, <&mcbsp_clks>; + reg = <0x68>; + }; + + mcbsp3_fck: mcbsp3_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&mcbsp3_gate_fck>, <&mcbsp3_mux_fck>; + }; + + mcbsp4_mux_fck: mcbsp4_mux_fck@68 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&per_96m_fck>, <&mcbsp_clks>; + ti,bit-shift = <2>; + reg = <0x68>; + }; + + mcbsp4_fck: mcbsp4_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&mcbsp4_gate_fck>, <&mcbsp4_mux_fck>; + }; }; &cm_clocks { - dummy_apb_pclk: dummy_apb_pclk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <0x0>; - }; - - omap_32k_fck: omap_32k_fck { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <32768>; - }; - - virt_12m_ck: virt_12m_ck { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <12000000>; - }; - - virt_13m_ck: virt_13m_ck { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <13000000>; - }; - - virt_19200000_ck: virt_19200000_ck { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <19200000>; - }; - - virt_26000000_ck: virt_26000000_ck { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <26000000>; - }; - - virt_38_4m_ck: virt_38_4m_ck { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <38400000>; - }; - - dpll4_ck: dpll4_ck@d00 { - #clock-cells = <0>; - compatible = "ti,omap3-dpll-per-clock"; - clocks = <&sys_ck>, <&sys_ck>; - reg = <0x0d00>, <0x0d20>, <0x0d44>, <0x0d30>; - }; - - dpll4_m2_ck: dpll4_m2_ck@d48 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&dpll4_ck>; - ti,max-div = <63>; - reg = <0x0d48>; - ti,index-starts-at-one; - }; - - dpll4_m2x2_mul_ck: dpll4_m2x2_mul_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll4_m2_ck>; - clock-mult = <2>; - clock-div = <1>; - }; - - dpll4_m2x2_ck: dpll4_m2x2_ck@d00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&dpll4_m2x2_mul_ck>; - ti,bit-shift = <0x1b>; - reg = <0x0d00>; - ti,set-bit-to-disable; - }; - - omap_96m_alwon_fck: omap_96m_alwon_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll4_m2x2_ck>; - clock-mult = <1>; - clock-div = <1>; - }; - - dpll3_ck: dpll3_ck@d00 { - #clock-cells = <0>; - compatible = "ti,omap3-dpll-core-clock"; - clocks = <&sys_ck>, <&sys_ck>; - reg = <0x0d00>, <0x0d20>, <0x0d40>, <0x0d30>; - }; - - dpll3_m3_ck: dpll3_m3_ck@1140 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&dpll3_ck>; - ti,bit-shift = <16>; - ti,max-div = <31>; - reg = <0x1140>; - ti,index-starts-at-one; - }; - - dpll3_m3x2_mul_ck: dpll3_m3x2_mul_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll3_m3_ck>; - clock-mult = <2>; - clock-div = <1>; - }; - - dpll3_m3x2_ck: dpll3_m3x2_ck@d00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&dpll3_m3x2_mul_ck>; - ti,bit-shift = <0xc>; - reg = <0x0d00>; - ti,set-bit-to-disable; - }; - - emu_core_alwon_ck: emu_core_alwon_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll3_m3x2_ck>; - clock-mult = <1>; - clock-div = <1>; - }; - - sys_altclk: sys_altclk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <0x0>; - }; - - mcbsp_clks: mcbsp_clks { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <0x0>; - }; - - dpll3_m2_ck: dpll3_m2_ck@d40 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&dpll3_ck>; - ti,bit-shift = <27>; - ti,max-div = <31>; - reg = <0x0d40>; - ti,index-starts-at-one; - }; - - core_ck: core_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll3_m2_ck>; - clock-mult = <1>; - clock-div = <1>; - }; - - dpll1_fck: dpll1_fck@940 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&core_ck>; - ti,bit-shift = <19>; - ti,max-div = <7>; - reg = <0x0940>; - ti,index-starts-at-one; - }; - - dpll1_ck: dpll1_ck@904 { - #clock-cells = <0>; - compatible = "ti,omap3-dpll-clock"; - clocks = <&sys_ck>, <&dpll1_fck>; - reg = <0x0904>, <0x0924>, <0x0940>, <0x0934>; - }; - - dpll1_x2_ck: dpll1_x2_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll1_ck>; - clock-mult = <2>; - clock-div = <1>; - }; - - dpll1_x2m2_ck: dpll1_x2m2_ck@944 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&dpll1_x2_ck>; - ti,max-div = <31>; - reg = <0x0944>; - ti,index-starts-at-one; - }; - - cm_96m_fck: cm_96m_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_96m_alwon_fck>; - clock-mult = <1>; - clock-div = <1>; - }; - - omap_96m_fck: omap_96m_fck@d40 { - #clock-cells = <0>; - compatible = "ti,mux-clock"; - clocks = <&cm_96m_fck>, <&sys_ck>; - ti,bit-shift = <6>; - reg = <0x0d40>; - }; - - dpll4_m3_ck: dpll4_m3_ck@e40 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&dpll4_ck>; - ti,bit-shift = <8>; - ti,max-div = <32>; - reg = <0x0e40>; - ti,index-starts-at-one; - }; - - dpll4_m3x2_mul_ck: dpll4_m3x2_mul_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll4_m3_ck>; - clock-mult = <2>; - clock-div = <1>; - }; - - dpll4_m3x2_ck: dpll4_m3x2_ck@d00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&dpll4_m3x2_mul_ck>; - ti,bit-shift = <0x1c>; - reg = <0x0d00>; - ti,set-bit-to-disable; - }; - - omap_54m_fck: omap_54m_fck@d40 { - #clock-cells = <0>; - compatible = "ti,mux-clock"; - clocks = <&dpll4_m3x2_ck>, <&sys_altclk>; - ti,bit-shift = <5>; - reg = <0x0d40>; - }; - - cm_96m_d2_fck: cm_96m_d2_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&cm_96m_fck>; - clock-mult = <1>; - clock-div = <2>; - }; - - omap_48m_fck: omap_48m_fck@d40 { - #clock-cells = <0>; - compatible = "ti,mux-clock"; - clocks = <&cm_96m_d2_fck>, <&sys_altclk>; - ti,bit-shift = <3>; - reg = <0x0d40>; - }; - - omap_12m_fck: omap_12m_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_48m_fck>; - clock-mult = <1>; - clock-div = <4>; - }; - - dpll4_m4_ck: dpll4_m4_ck@e40 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&dpll4_ck>; - ti,max-div = <32>; - reg = <0x0e40>; - ti,index-starts-at-one; - }; - - dpll4_m4x2_mul_ck: dpll4_m4x2_mul_ck { - #clock-cells = <0>; - compatible = "ti,fixed-factor-clock"; - clocks = <&dpll4_m4_ck>; - ti,clock-mult = <2>; - ti,clock-div = <1>; - ti,set-rate-parent; - }; - - dpll4_m4x2_ck: dpll4_m4x2_ck@d00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&dpll4_m4x2_mul_ck>; - ti,bit-shift = <0x1d>; - reg = <0x0d00>; - ti,set-bit-to-disable; - ti,set-rate-parent; - }; - - dpll4_m5_ck: dpll4_m5_ck@f40 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&dpll4_ck>; - ti,max-div = <63>; - reg = <0x0f40>; - ti,index-starts-at-one; - }; - - dpll4_m5x2_mul_ck: dpll4_m5x2_mul_ck { - #clock-cells = <0>; - compatible = "ti,fixed-factor-clock"; - clocks = <&dpll4_m5_ck>; - ti,clock-mult = <2>; - ti,clock-div = <1>; - ti,set-rate-parent; - }; - - dpll4_m5x2_ck: dpll4_m5x2_ck@d00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&dpll4_m5x2_mul_ck>; - ti,bit-shift = <0x1e>; - reg = <0x0d00>; - ti,set-bit-to-disable; - ti,set-rate-parent; - }; - - dpll4_m6_ck: dpll4_m6_ck@1140 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&dpll4_ck>; - ti,bit-shift = <24>; - ti,max-div = <63>; - reg = <0x1140>; - ti,index-starts-at-one; - }; - - dpll4_m6x2_mul_ck: dpll4_m6x2_mul_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll4_m6_ck>; - clock-mult = <2>; - clock-div = <1>; - }; - - dpll4_m6x2_ck: dpll4_m6x2_ck@d00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&dpll4_m6x2_mul_ck>; - ti,bit-shift = <0x1f>; - reg = <0x0d00>; - ti,set-bit-to-disable; - }; - - emu_per_alwon_ck: emu_per_alwon_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll4_m6x2_ck>; - clock-mult = <1>; - clock-div = <1>; - }; - - clkout2_src_gate_ck: clkout2_src_gate_ck@d70 { - #clock-cells = <0>; - compatible = "ti,composite-no-wait-gate-clock"; - clocks = <&core_ck>; - ti,bit-shift = <7>; - reg = <0x0d70>; - }; - - clkout2_src_mux_ck: clkout2_src_mux_ck@d70 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&core_ck>, <&sys_ck>, <&cm_96m_fck>, <&omap_54m_fck>; - reg = <0x0d70>; - }; - - clkout2_src_ck: clkout2_src_ck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&clkout2_src_gate_ck>, <&clkout2_src_mux_ck>; - }; - - sys_clkout2: sys_clkout2@d70 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&clkout2_src_ck>; - ti,bit-shift = <3>; - ti,max-div = <64>; - reg = <0x0d70>; - ti,index-power-of-two; - }; - - mpu_ck: mpu_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&dpll1_x2m2_ck>; - clock-mult = <1>; - clock-div = <1>; - }; - - arm_fck: arm_fck@924 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&mpu_ck>; - reg = <0x0924>; - ti,max-div = <2>; - }; - - emu_mpu_alwon_ck: emu_mpu_alwon_ck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&mpu_ck>; - clock-mult = <1>; - clock-div = <1>; - }; - - l3_ick: l3_ick@a40 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&core_ck>; - ti,max-div = <3>; - reg = <0x0a40>; - ti,index-starts-at-one; - }; - - l4_ick: l4_ick@a40 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&l3_ick>; - ti,bit-shift = <2>; - ti,max-div = <3>; - reg = <0x0a40>; - ti,index-starts-at-one; - }; - - rm_ick: rm_ick@c40 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&l4_ick>; - ti,bit-shift = <1>; - ti,max-div = <3>; - reg = <0x0c40>; - ti,index-starts-at-one; - }; - - gpt10_gate_fck: gpt10_gate_fck@a00 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&sys_ck>; - ti,bit-shift = <11>; - reg = <0x0a00>; - }; - - gpt10_mux_fck: gpt10_mux_fck@a40 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&omap_32k_fck>, <&sys_ck>; - ti,bit-shift = <6>; - reg = <0x0a40>; - }; - - gpt10_fck: gpt10_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&gpt10_gate_fck>, <&gpt10_mux_fck>; - }; - - gpt11_gate_fck: gpt11_gate_fck@a00 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&sys_ck>; - ti,bit-shift = <12>; - reg = <0x0a00>; - }; - - gpt11_mux_fck: gpt11_mux_fck@a40 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&omap_32k_fck>, <&sys_ck>; - ti,bit-shift = <7>; - reg = <0x0a40>; - }; - - gpt11_fck: gpt11_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&gpt11_gate_fck>, <&gpt11_mux_fck>; - }; - - core_96m_fck: core_96m_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_96m_fck>; - clock-mult = <1>; - clock-div = <1>; - }; - - mmchs2_fck: mmchs2_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_96m_fck>; - reg = <0x0a00>; - ti,bit-shift = <25>; - }; - - mmchs1_fck: mmchs1_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_96m_fck>; - reg = <0x0a00>; - ti,bit-shift = <24>; - }; - - i2c3_fck: i2c3_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_96m_fck>; - reg = <0x0a00>; - ti,bit-shift = <17>; - }; - - i2c2_fck: i2c2_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_96m_fck>; - reg = <0x0a00>; - ti,bit-shift = <16>; - }; - - i2c1_fck: i2c1_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_96m_fck>; - reg = <0x0a00>; - ti,bit-shift = <15>; - }; - - mcbsp5_gate_fck: mcbsp5_gate_fck@a00 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&mcbsp_clks>; - ti,bit-shift = <10>; - reg = <0x0a00>; - }; - - mcbsp1_gate_fck: mcbsp1_gate_fck@a00 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&mcbsp_clks>; - ti,bit-shift = <9>; - reg = <0x0a00>; - }; - - core_48m_fck: core_48m_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_48m_fck>; - clock-mult = <1>; - clock-div = <1>; - }; - - mcspi4_fck: mcspi4_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_48m_fck>; - reg = <0x0a00>; - ti,bit-shift = <21>; - }; - - mcspi3_fck: mcspi3_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_48m_fck>; - reg = <0x0a00>; - ti,bit-shift = <20>; - }; - - mcspi2_fck: mcspi2_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_48m_fck>; - reg = <0x0a00>; - ti,bit-shift = <19>; - }; - - mcspi1_fck: mcspi1_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_48m_fck>; - reg = <0x0a00>; - ti,bit-shift = <18>; - }; - - uart2_fck: uart2_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_48m_fck>; - reg = <0x0a00>; - ti,bit-shift = <14>; - }; - - uart1_fck: uart1_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_48m_fck>; - reg = <0x0a00>; - ti,bit-shift = <13>; - }; - - core_12m_fck: core_12m_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_12m_fck>; - clock-mult = <1>; - clock-div = <1>; - }; - - hdq_fck: hdq_fck@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_12m_fck>; - reg = <0x0a00>; - ti,bit-shift = <22>; - }; - - core_l3_ick: core_l3_ick { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&l3_ick>; - clock-mult = <1>; - clock-div = <1>; - }; - - sdrc_ick: sdrc_ick@a10 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_l3_ick>; - reg = <0x0a10>; - ti,bit-shift = <1>; - }; - - gpmc_fck: gpmc_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&core_l3_ick>; - clock-mult = <1>; - clock-div = <1>; - }; - - core_l4_ick: core_l4_ick { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&l4_ick>; - clock-mult = <1>; - clock-div = <1>; - }; - - mmchs2_ick: mmchs2_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <25>; - }; - - mmchs1_ick: mmchs1_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <24>; - }; - - hdq_ick: hdq_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <22>; - }; - - mcspi4_ick: mcspi4_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <21>; - }; - - mcspi3_ick: mcspi3_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <20>; - }; - - mcspi2_ick: mcspi2_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <19>; - }; - - mcspi1_ick: mcspi1_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <18>; - }; - - i2c3_ick: i2c3_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <17>; - }; - - i2c2_ick: i2c2_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <16>; - }; - - i2c1_ick: i2c1_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <15>; - }; - - uart2_ick: uart2_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <14>; - }; - - uart1_ick: uart1_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <13>; - }; - - gpt11_ick: gpt11_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <12>; - }; - - gpt10_ick: gpt10_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <11>; - }; - - mcbsp5_ick: mcbsp5_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <10>; - }; - - mcbsp1_ick: mcbsp1_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <9>; - }; - - omapctrl_ick: omapctrl_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <6>; - }; - - dss_tv_fck: dss_tv_fck@e00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&omap_54m_fck>; - reg = <0x0e00>; - ti,bit-shift = <2>; - }; - - dss_96m_fck: dss_96m_fck@e00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&omap_96m_fck>; - reg = <0x0e00>; - ti,bit-shift = <2>; - }; - - dss2_alwon_fck: dss2_alwon_fck@e00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&sys_ck>; - reg = <0x0e00>; - ti,bit-shift = <1>; - }; - - dummy_ck: dummy_ck { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <0>; - }; - - gpt1_gate_fck: gpt1_gate_fck@c00 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&sys_ck>; - ti,bit-shift = <0>; - reg = <0x0c00>; - }; - - gpt1_mux_fck: gpt1_mux_fck@c40 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&omap_32k_fck>, <&sys_ck>; - reg = <0x0c40>; - }; - - gpt1_fck: gpt1_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&gpt1_gate_fck>, <&gpt1_mux_fck>; - }; - - aes2_ick: aes2_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - ti,bit-shift = <28>; - reg = <0x0a10>; - }; - - wkup_32k_fck: wkup_32k_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_32k_fck>; - clock-mult = <1>; - clock-div = <1>; - }; - - gpio1_dbck: gpio1_dbck@c00 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&wkup_32k_fck>; - reg = <0x0c00>; - ti,bit-shift = <3>; - }; - - sha12_ick: sha12_ick@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <27>; - }; - - wdt2_fck: wdt2_fck@c00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&wkup_32k_fck>; - reg = <0x0c00>; - ti,bit-shift = <5>; - }; - - wdt2_ick: wdt2_ick@c10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&wkup_l4_ick>; - reg = <0x0c10>; - ti,bit-shift = <5>; - }; - - wdt1_ick: wdt1_ick@c10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&wkup_l4_ick>; - reg = <0x0c10>; - ti,bit-shift = <4>; - }; - - gpio1_ick: gpio1_ick@c10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&wkup_l4_ick>; - reg = <0x0c10>; - ti,bit-shift = <3>; - }; - - omap_32ksync_ick: omap_32ksync_ick@c10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&wkup_l4_ick>; - reg = <0x0c10>; - ti,bit-shift = <2>; - }; - - gpt12_ick: gpt12_ick@c10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&wkup_l4_ick>; - reg = <0x0c10>; - ti,bit-shift = <1>; - }; - - gpt1_ick: gpt1_ick@c10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&wkup_l4_ick>; - reg = <0x0c10>; - ti,bit-shift = <0>; - }; - - per_96m_fck: per_96m_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_96m_alwon_fck>; - clock-mult = <1>; - clock-div = <1>; - }; - - per_48m_fck: per_48m_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_48m_fck>; - clock-mult = <1>; - clock-div = <1>; - }; - - uart3_fck: uart3_fck@1000 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&per_48m_fck>; - reg = <0x1000>; - ti,bit-shift = <11>; - }; - - gpt2_gate_fck: gpt2_gate_fck@1000 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&sys_ck>; - ti,bit-shift = <3>; - reg = <0x1000>; - }; - - gpt2_mux_fck: gpt2_mux_fck@1040 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&omap_32k_fck>, <&sys_ck>; - reg = <0x1040>; - }; - - gpt2_fck: gpt2_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&gpt2_gate_fck>, <&gpt2_mux_fck>; - }; - - gpt3_gate_fck: gpt3_gate_fck@1000 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&sys_ck>; - ti,bit-shift = <4>; - reg = <0x1000>; - }; - - gpt3_mux_fck: gpt3_mux_fck@1040 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&omap_32k_fck>, <&sys_ck>; - ti,bit-shift = <1>; - reg = <0x1040>; - }; - - gpt3_fck: gpt3_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&gpt3_gate_fck>, <&gpt3_mux_fck>; - }; - - gpt4_gate_fck: gpt4_gate_fck@1000 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&sys_ck>; - ti,bit-shift = <5>; - reg = <0x1000>; - }; - - gpt4_mux_fck: gpt4_mux_fck@1040 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&omap_32k_fck>, <&sys_ck>; - ti,bit-shift = <2>; - reg = <0x1040>; - }; - - gpt4_fck: gpt4_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&gpt4_gate_fck>, <&gpt4_mux_fck>; - }; - - gpt5_gate_fck: gpt5_gate_fck@1000 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&sys_ck>; - ti,bit-shift = <6>; - reg = <0x1000>; - }; - - gpt5_mux_fck: gpt5_mux_fck@1040 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&omap_32k_fck>, <&sys_ck>; - ti,bit-shift = <3>; - reg = <0x1040>; - }; - - gpt5_fck: gpt5_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&gpt5_gate_fck>, <&gpt5_mux_fck>; - }; - - gpt6_gate_fck: gpt6_gate_fck@1000 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&sys_ck>; - ti,bit-shift = <7>; - reg = <0x1000>; - }; - - gpt6_mux_fck: gpt6_mux_fck@1040 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&omap_32k_fck>, <&sys_ck>; - ti,bit-shift = <4>; - reg = <0x1040>; - }; - - gpt6_fck: gpt6_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&gpt6_gate_fck>, <&gpt6_mux_fck>; - }; - - gpt7_gate_fck: gpt7_gate_fck@1000 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&sys_ck>; - ti,bit-shift = <8>; - reg = <0x1000>; - }; - - gpt7_mux_fck: gpt7_mux_fck@1040 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&omap_32k_fck>, <&sys_ck>; - ti,bit-shift = <5>; - reg = <0x1040>; - }; - - gpt7_fck: gpt7_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&gpt7_gate_fck>, <&gpt7_mux_fck>; - }; - - gpt8_gate_fck: gpt8_gate_fck@1000 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&sys_ck>; - ti,bit-shift = <9>; - reg = <0x1000>; - }; - - gpt8_mux_fck: gpt8_mux_fck@1040 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&omap_32k_fck>, <&sys_ck>; - ti,bit-shift = <6>; - reg = <0x1040>; - }; - - gpt8_fck: gpt8_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&gpt8_gate_fck>, <&gpt8_mux_fck>; - }; - - gpt9_gate_fck: gpt9_gate_fck@1000 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&sys_ck>; - ti,bit-shift = <10>; - reg = <0x1000>; - }; - - gpt9_mux_fck: gpt9_mux_fck@1040 { - #clock-cells = <0>; - compatible = "ti,composite-mux-clock"; - clocks = <&omap_32k_fck>, <&sys_ck>; - ti,bit-shift = <7>; - reg = <0x1040>; - }; - - gpt9_fck: gpt9_fck { - #clock-cells = <0>; - compatible = "ti,composite-clock"; - clocks = <&gpt9_gate_fck>, <&gpt9_mux_fck>; - }; - - per_32k_alwon_fck: per_32k_alwon_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&omap_32k_fck>; - clock-mult = <1>; - clock-div = <1>; - }; - - gpio6_dbck: gpio6_dbck@1000 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&per_32k_alwon_fck>; - reg = <0x1000>; - ti,bit-shift = <17>; - }; - - gpio5_dbck: gpio5_dbck@1000 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&per_32k_alwon_fck>; - reg = <0x1000>; - ti,bit-shift = <16>; - }; - - gpio4_dbck: gpio4_dbck@1000 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&per_32k_alwon_fck>; - reg = <0x1000>; - ti,bit-shift = <15>; - }; - - gpio3_dbck: gpio3_dbck@1000 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&per_32k_alwon_fck>; - reg = <0x1000>; - ti,bit-shift = <14>; - }; - - gpio2_dbck: gpio2_dbck@1000 { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&per_32k_alwon_fck>; - reg = <0x1000>; - ti,bit-shift = <13>; - }; - - wdt3_fck: wdt3_fck@1000 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&per_32k_alwon_fck>; - reg = <0x1000>; - ti,bit-shift = <12>; - }; - - per_l4_ick: per_l4_ick { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&l4_ick>; - clock-mult = <1>; - clock-div = <1>; - }; - - gpio6_ick: gpio6_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <17>; - }; - - gpio5_ick: gpio5_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <16>; - }; - - gpio4_ick: gpio4_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <15>; - }; - - gpio3_ick: gpio3_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <14>; - }; - - gpio2_ick: gpio2_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <13>; - }; - - wdt3_ick: wdt3_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <12>; - }; - - uart3_ick: uart3_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <11>; - }; - - uart4_ick: uart4_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <18>; - }; - - gpt9_ick: gpt9_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <10>; - }; - - gpt8_ick: gpt8_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <9>; - }; - - gpt7_ick: gpt7_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <8>; - }; - - gpt6_ick: gpt6_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <7>; - }; - - gpt5_ick: gpt5_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <6>; - }; - - gpt4_ick: gpt4_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <5>; - }; - - gpt3_ick: gpt3_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <4>; - }; - - gpt2_ick: gpt2_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <3>; - }; - - mcbsp2_ick: mcbsp2_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <0>; - }; - - mcbsp3_ick: mcbsp3_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <1>; - }; - - mcbsp4_ick: mcbsp4_ick@1010 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&per_l4_ick>; - reg = <0x1010>; - ti,bit-shift = <2>; - }; - - mcbsp2_gate_fck: mcbsp2_gate_fck@1000 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&mcbsp_clks>; - ti,bit-shift = <0>; - reg = <0x1000>; - }; - - mcbsp3_gate_fck: mcbsp3_gate_fck@1000 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&mcbsp_clks>; - ti,bit-shift = <1>; - reg = <0x1000>; - }; - - mcbsp4_gate_fck: mcbsp4_gate_fck@1000 { - #clock-cells = <0>; - compatible = "ti,composite-gate-clock"; - clocks = <&mcbsp_clks>; - ti,bit-shift = <2>; - reg = <0x1000>; - }; - - emu_src_mux_ck: emu_src_mux_ck@1140 { - #clock-cells = <0>; - compatible = "ti,mux-clock"; - clocks = <&sys_ck>, <&emu_core_alwon_ck>, <&emu_per_alwon_ck>, <&emu_mpu_alwon_ck>; - reg = <0x1140>; - }; - - emu_src_ck: emu_src_ck { - #clock-cells = <0>; - compatible = "ti,clkdm-gate-clock"; - clocks = <&emu_src_mux_ck>; - }; - - pclk_fck: pclk_fck@1140 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&emu_src_ck>; - ti,bit-shift = <8>; - ti,max-div = <7>; - reg = <0x1140>; - ti,index-starts-at-one; - }; - - pclkx2_fck: pclkx2_fck@1140 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&emu_src_ck>; - ti,bit-shift = <6>; - ti,max-div = <3>; - reg = <0x1140>; - ti,index-starts-at-one; - }; - - atclk_fck: atclk_fck@1140 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&emu_src_ck>; - ti,bit-shift = <4>; - ti,max-div = <3>; - reg = <0x1140>; - ti,index-starts-at-one; - }; - - traceclk_src_fck: traceclk_src_fck@1140 { - #clock-cells = <0>; - compatible = "ti,mux-clock"; - clocks = <&sys_ck>, <&emu_core_alwon_ck>, <&emu_per_alwon_ck>, <&emu_mpu_alwon_ck>; - ti,bit-shift = <2>; - reg = <0x1140>; - }; - - traceclk_fck: traceclk_fck@1140 { - #clock-cells = <0>; - compatible = "ti,divider-clock"; - clocks = <&traceclk_src_fck>; - ti,bit-shift = <11>; - ti,max-div = <7>; - reg = <0x1140>; - ti,index-starts-at-one; - }; - - secure_32k_fck: secure_32k_fck { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <32768>; - }; - - gpt12_fck: gpt12_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&secure_32k_fck>; - clock-mult = <1>; - clock-div = <1>; - }; - - wdt1_fck: wdt1_fck { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clocks = <&secure_32k_fck>; - clock-mult = <1>; - clock-div = <1>; - }; + dummy_apb_pclk: dummy_apb_pclk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0x0>; + }; + + omap_32k_fck: omap_32k_fck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + }; + + virt_12m_ck: virt_12m_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + virt_13m_ck: virt_13m_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <13000000>; + }; + + virt_19200000_ck: virt_19200000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <19200000>; + }; + + virt_26000000_ck: virt_26000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <26000000>; + }; + + virt_38_4m_ck: virt_38_4m_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <38400000>; + }; + + dpll4_ck: dpll4_ck@d00 { + #clock-cells = <0>; + compatible = "ti,omap3-dpll-per-clock"; + clocks = <&sys_ck>, <&sys_ck>; + reg = <0x0d00>, <0x0d20>, <0x0d44>, <0x0d30>; + }; + + dpll4_m2_ck: dpll4_m2_ck@d48 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll4_ck>; + ti,max-div = <63>; + reg = <0x0d48>; + ti,index-starts-at-one; + }; + + dpll4_m2x2_mul_ck: dpll4_m2x2_mul_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll4_m2_ck>; + clock-mult = <2>; + clock-div = <1>; + }; + + dpll4_m2x2_ck: dpll4_m2x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll4_m2x2_mul_ck>; + ti,bit-shift = <0x1b>; + reg = <0x0d00>; + ti,set-bit-to-disable; + }; + + omap_96m_alwon_fck: omap_96m_alwon_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll4_m2x2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + dpll3_ck: dpll3_ck@d00 { + #clock-cells = <0>; + compatible = "ti,omap3-dpll-core-clock"; + clocks = <&sys_ck>, <&sys_ck>; + reg = <0x0d00>, <0x0d20>, <0x0d40>, <0x0d30>; + }; + + dpll3_m3_ck: dpll3_m3_ck@1140 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll3_ck>; + ti,bit-shift = <16>; + ti,max-div = <31>; + reg = <0x1140>; + ti,index-starts-at-one; + }; + + dpll3_m3x2_mul_ck: dpll3_m3x2_mul_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll3_m3_ck>; + clock-mult = <2>; + clock-div = <1>; + }; + + dpll3_m3x2_ck: dpll3_m3x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll3_m3x2_mul_ck>; + ti,bit-shift = <0xc>; + reg = <0x0d00>; + ti,set-bit-to-disable; + }; + + emu_core_alwon_ck: emu_core_alwon_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll3_m3x2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + sys_altclk: sys_altclk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0x0>; + }; + + mcbsp_clks: mcbsp_clks { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0x0>; + }; + + dpll3_m2_ck: dpll3_m2_ck@d40 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll3_ck>; + ti,bit-shift = <27>; + ti,max-div = <31>; + reg = <0x0d40>; + ti,index-starts-at-one; + }; + + core_ck: core_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll3_m2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + dpll1_fck: dpll1_fck@940 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&core_ck>; + ti,bit-shift = <19>; + ti,max-div = <7>; + reg = <0x0940>; + ti,index-starts-at-one; + }; + + dpll1_ck: dpll1_ck@904 { + #clock-cells = <0>; + compatible = "ti,omap3-dpll-clock"; + clocks = <&sys_ck>, <&dpll1_fck>; + reg = <0x0904>, <0x0924>, <0x0940>, <0x0934>; + }; + + dpll1_x2_ck: dpll1_x2_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll1_ck>; + clock-mult = <2>; + clock-div = <1>; + }; + + dpll1_x2m2_ck: dpll1_x2m2_ck@944 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll1_x2_ck>; + ti,max-div = <31>; + reg = <0x0944>; + ti,index-starts-at-one; + }; + + cm_96m_fck: cm_96m_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_96m_alwon_fck>; + clock-mult = <1>; + clock-div = <1>; + }; + + omap_96m_fck: omap_96m_fck@d40 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&cm_96m_fck>, <&sys_ck>; + ti,bit-shift = <6>; + reg = <0x0d40>; + }; + + dpll4_m3_ck: dpll4_m3_ck@e40 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll4_ck>; + ti,bit-shift = <8>; + ti,max-div = <32>; + reg = <0x0e40>; + ti,index-starts-at-one; + }; + + dpll4_m3x2_mul_ck: dpll4_m3x2_mul_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll4_m3_ck>; + clock-mult = <2>; + clock-div = <1>; + }; + + dpll4_m3x2_ck: dpll4_m3x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll4_m3x2_mul_ck>; + ti,bit-shift = <0x1c>; + reg = <0x0d00>; + ti,set-bit-to-disable; + }; + + omap_54m_fck: omap_54m_fck@d40 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&dpll4_m3x2_ck>, <&sys_altclk>; + ti,bit-shift = <5>; + reg = <0x0d40>; + }; + + cm_96m_d2_fck: cm_96m_d2_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&cm_96m_fck>; + clock-mult = <1>; + clock-div = <2>; + }; + + omap_48m_fck: omap_48m_fck@d40 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&cm_96m_d2_fck>, <&sys_altclk>; + ti,bit-shift = <3>; + reg = <0x0d40>; + }; + + omap_12m_fck: omap_12m_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_48m_fck>; + clock-mult = <1>; + clock-div = <4>; + }; + + dpll4_m4_ck: dpll4_m4_ck@e40 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll4_ck>; + ti,max-div = <32>; + reg = <0x0e40>; + ti,index-starts-at-one; + }; + + dpll4_m4x2_mul_ck: dpll4_m4x2_mul_ck { + #clock-cells = <0>; + compatible = "ti,fixed-factor-clock"; + clocks = <&dpll4_m4_ck>; + ti,clock-mult = <2>; + ti,clock-div = <1>; + ti,set-rate-parent; + }; + + dpll4_m4x2_ck: dpll4_m4x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll4_m4x2_mul_ck>; + ti,bit-shift = <0x1d>; + reg = <0x0d00>; + ti,set-bit-to-disable; + ti,set-rate-parent; + }; + + dpll4_m5_ck: dpll4_m5_ck@f40 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll4_ck>; + ti,max-div = <63>; + reg = <0x0f40>; + ti,index-starts-at-one; + }; + + dpll4_m5x2_mul_ck: dpll4_m5x2_mul_ck { + #clock-cells = <0>; + compatible = "ti,fixed-factor-clock"; + clocks = <&dpll4_m5_ck>; + ti,clock-mult = <2>; + ti,clock-div = <1>; + ti,set-rate-parent; + }; + + dpll4_m5x2_ck: dpll4_m5x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll4_m5x2_mul_ck>; + ti,bit-shift = <0x1e>; + reg = <0x0d00>; + ti,set-bit-to-disable; + ti,set-rate-parent; + }; + + dpll4_m6_ck: dpll4_m6_ck@1140 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll4_ck>; + ti,bit-shift = <24>; + ti,max-div = <63>; + reg = <0x1140>; + ti,index-starts-at-one; + }; + + dpll4_m6x2_mul_ck: dpll4_m6x2_mul_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll4_m6_ck>; + clock-mult = <2>; + clock-div = <1>; + }; + + dpll4_m6x2_ck: dpll4_m6x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll4_m6x2_mul_ck>; + ti,bit-shift = <0x1f>; + reg = <0x0d00>; + ti,set-bit-to-disable; + }; + + emu_per_alwon_ck: emu_per_alwon_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll4_m6x2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + clkout2_src_gate_ck: clkout2_src_gate_ck@d70 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&core_ck>; + ti,bit-shift = <7>; + reg = <0x0d70>; + }; + + clkout2_src_mux_ck: clkout2_src_mux_ck@d70 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&core_ck>, <&sys_ck>, <&cm_96m_fck>, <&omap_54m_fck>; + reg = <0x0d70>; + }; + + clkout2_src_ck: clkout2_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&clkout2_src_gate_ck>, <&clkout2_src_mux_ck>; + }; + + sys_clkout2: sys_clkout2@d70 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&clkout2_src_ck>; + ti,bit-shift = <3>; + ti,max-div = <64>; + reg = <0x0d70>; + ti,index-power-of-two; + }; + + mpu_ck: mpu_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll1_x2m2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + arm_fck: arm_fck@924 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&mpu_ck>; + reg = <0x0924>; + ti,max-div = <2>; + }; + + emu_mpu_alwon_ck: emu_mpu_alwon_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&mpu_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + l3_ick: l3_ick@a40 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&core_ck>; + ti,max-div = <3>; + reg = <0x0a40>; + ti,index-starts-at-one; + }; + + l4_ick: l4_ick@a40 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&l3_ick>; + ti,bit-shift = <2>; + ti,max-div = <3>; + reg = <0x0a40>; + ti,index-starts-at-one; + }; + + rm_ick: rm_ick@c40 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&l4_ick>; + ti,bit-shift = <1>; + ti,max-div = <3>; + reg = <0x0c40>; + ti,index-starts-at-one; + }; + + gpt10_gate_fck: gpt10_gate_fck@a00 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&sys_ck>; + ti,bit-shift = <11>; + reg = <0x0a00>; + }; + + gpt10_mux_fck: gpt10_mux_fck@a40 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&omap_32k_fck>, <&sys_ck>; + ti,bit-shift = <6>; + reg = <0x0a40>; + }; + + gpt10_fck: gpt10_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&gpt10_gate_fck>, <&gpt10_mux_fck>; + }; + + gpt11_gate_fck: gpt11_gate_fck@a00 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&sys_ck>; + ti,bit-shift = <12>; + reg = <0x0a00>; + }; + + gpt11_mux_fck: gpt11_mux_fck@a40 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&omap_32k_fck>, <&sys_ck>; + ti,bit-shift = <7>; + reg = <0x0a40>; + }; + + gpt11_fck: gpt11_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&gpt11_gate_fck>, <&gpt11_mux_fck>; + }; + + core_96m_fck: core_96m_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_96m_fck>; + clock-mult = <1>; + clock-div = <1>; + }; + + mmchs2_fck: mmchs2_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_96m_fck>; + reg = <0x0a00>; + ti,bit-shift = <25>; + }; + + mmchs1_fck: mmchs1_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_96m_fck>; + reg = <0x0a00>; + ti,bit-shift = <24>; + }; + + i2c3_fck: i2c3_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_96m_fck>; + reg = <0x0a00>; + ti,bit-shift = <17>; + }; + + i2c2_fck: i2c2_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_96m_fck>; + reg = <0x0a00>; + ti,bit-shift = <16>; + }; + + i2c1_fck: i2c1_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_96m_fck>; + reg = <0x0a00>; + ti,bit-shift = <15>; + }; + + mcbsp5_gate_fck: mcbsp5_gate_fck@a00 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&mcbsp_clks>; + ti,bit-shift = <10>; + reg = <0x0a00>; + }; + + mcbsp1_gate_fck: mcbsp1_gate_fck@a00 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&mcbsp_clks>; + ti,bit-shift = <9>; + reg = <0x0a00>; + }; + + core_48m_fck: core_48m_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_48m_fck>; + clock-mult = <1>; + clock-div = <1>; + }; + + mcspi4_fck: mcspi4_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_48m_fck>; + reg = <0x0a00>; + ti,bit-shift = <21>; + }; + + mcspi3_fck: mcspi3_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_48m_fck>; + reg = <0x0a00>; + ti,bit-shift = <20>; + }; + + mcspi2_fck: mcspi2_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_48m_fck>; + reg = <0x0a00>; + ti,bit-shift = <19>; + }; + + mcspi1_fck: mcspi1_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_48m_fck>; + reg = <0x0a00>; + ti,bit-shift = <18>; + }; + + uart2_fck: uart2_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_48m_fck>; + reg = <0x0a00>; + ti,bit-shift = <14>; + }; + + uart1_fck: uart1_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_48m_fck>; + reg = <0x0a00>; + ti,bit-shift = <13>; + }; + + core_12m_fck: core_12m_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_12m_fck>; + clock-mult = <1>; + clock-div = <1>; + }; + + hdq_fck: hdq_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_12m_fck>; + reg = <0x0a00>; + ti,bit-shift = <22>; + }; + + core_l3_ick: core_l3_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l3_ick>; + clock-mult = <1>; + clock-div = <1>; + }; + + sdrc_ick: sdrc_ick@a10 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_l3_ick>; + reg = <0x0a10>; + ti,bit-shift = <1>; + }; + + gpmc_fck: gpmc_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&core_l3_ick>; + clock-mult = <1>; + clock-div = <1>; + }; + + core_l4_ick: core_l4_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l4_ick>; + clock-mult = <1>; + clock-div = <1>; + }; + + mmchs2_ick: mmchs2_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <25>; + }; + + mmchs1_ick: mmchs1_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <24>; + }; + + hdq_ick: hdq_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <22>; + }; + + mcspi4_ick: mcspi4_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <21>; + }; + + mcspi3_ick: mcspi3_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <20>; + }; + + mcspi2_ick: mcspi2_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <19>; + }; + + mcspi1_ick: mcspi1_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <18>; + }; + + i2c3_ick: i2c3_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <17>; + }; + + i2c2_ick: i2c2_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <16>; + }; + + i2c1_ick: i2c1_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <15>; + }; + + uart2_ick: uart2_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <14>; + }; + + uart1_ick: uart1_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <13>; + }; + + gpt11_ick: gpt11_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <12>; + }; + + gpt10_ick: gpt10_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <11>; + }; + + mcbsp5_ick: mcbsp5_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <10>; + }; + + mcbsp1_ick: mcbsp1_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <9>; + }; + + omapctrl_ick: omapctrl_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <6>; + }; + + dss_tv_fck: dss_tv_fck@e00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&omap_54m_fck>; + reg = <0x0e00>; + ti,bit-shift = <2>; + }; + + dss_96m_fck: dss_96m_fck@e00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&omap_96m_fck>; + reg = <0x0e00>; + ti,bit-shift = <2>; + }; + + dss2_alwon_fck: dss2_alwon_fck@e00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&sys_ck>; + reg = <0x0e00>; + ti,bit-shift = <1>; + }; + + dummy_ck: dummy_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; + + gpt1_gate_fck: gpt1_gate_fck@c00 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&sys_ck>; + ti,bit-shift = <0>; + reg = <0x0c00>; + }; + + gpt1_mux_fck: gpt1_mux_fck@c40 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&omap_32k_fck>, <&sys_ck>; + reg = <0x0c40>; + }; + + gpt1_fck: gpt1_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&gpt1_gate_fck>, <&gpt1_mux_fck>; + }; + + aes2_ick: aes2_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + ti,bit-shift = <28>; + reg = <0x0a10>; + }; + + wkup_32k_fck: wkup_32k_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_32k_fck>; + clock-mult = <1>; + clock-div = <1>; + }; + + gpio1_dbck: gpio1_dbck@c00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&wkup_32k_fck>; + reg = <0x0c00>; + ti,bit-shift = <3>; + }; + + sha12_ick: sha12_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <27>; + }; + + wdt2_fck: wdt2_fck@c00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&wkup_32k_fck>; + reg = <0x0c00>; + ti,bit-shift = <5>; + }; + + wdt2_ick: wdt2_ick@c10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&wkup_l4_ick>; + reg = <0x0c10>; + ti,bit-shift = <5>; + }; + + wdt1_ick: wdt1_ick@c10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&wkup_l4_ick>; + reg = <0x0c10>; + ti,bit-shift = <4>; + }; + + gpio1_ick: gpio1_ick@c10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&wkup_l4_ick>; + reg = <0x0c10>; + ti,bit-shift = <3>; + }; + + omap_32ksync_ick: omap_32ksync_ick@c10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&wkup_l4_ick>; + reg = <0x0c10>; + ti,bit-shift = <2>; + }; + + gpt12_ick: gpt12_ick@c10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&wkup_l4_ick>; + reg = <0x0c10>; + ti,bit-shift = <1>; + }; + + gpt1_ick: gpt1_ick@c10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&wkup_l4_ick>; + reg = <0x0c10>; + ti,bit-shift = <0>; + }; + + per_96m_fck: per_96m_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_96m_alwon_fck>; + clock-mult = <1>; + clock-div = <1>; + }; + + per_48m_fck: per_48m_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_48m_fck>; + clock-mult = <1>; + clock-div = <1>; + }; + + uart3_fck: uart3_fck@1000 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&per_48m_fck>; + reg = <0x1000>; + ti,bit-shift = <11>; + }; + + gpt2_gate_fck: gpt2_gate_fck@1000 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&sys_ck>; + ti,bit-shift = <3>; + reg = <0x1000>; + }; + + gpt2_mux_fck: gpt2_mux_fck@1040 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&omap_32k_fck>, <&sys_ck>; + reg = <0x1040>; + }; + + gpt2_fck: gpt2_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&gpt2_gate_fck>, <&gpt2_mux_fck>; + }; + + gpt3_gate_fck: gpt3_gate_fck@1000 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&sys_ck>; + ti,bit-shift = <4>; + reg = <0x1000>; + }; + + gpt3_mux_fck: gpt3_mux_fck@1040 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&omap_32k_fck>, <&sys_ck>; + ti,bit-shift = <1>; + reg = <0x1040>; + }; + + gpt3_fck: gpt3_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&gpt3_gate_fck>, <&gpt3_mux_fck>; + }; + + gpt4_gate_fck: gpt4_gate_fck@1000 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&sys_ck>; + ti,bit-shift = <5>; + reg = <0x1000>; + }; + + gpt4_mux_fck: gpt4_mux_fck@1040 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&omap_32k_fck>, <&sys_ck>; + ti,bit-shift = <2>; + reg = <0x1040>; + }; + + gpt4_fck: gpt4_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&gpt4_gate_fck>, <&gpt4_mux_fck>; + }; + + gpt5_gate_fck: gpt5_gate_fck@1000 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&sys_ck>; + ti,bit-shift = <6>; + reg = <0x1000>; + }; + + gpt5_mux_fck: gpt5_mux_fck@1040 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&omap_32k_fck>, <&sys_ck>; + ti,bit-shift = <3>; + reg = <0x1040>; + }; + + gpt5_fck: gpt5_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&gpt5_gate_fck>, <&gpt5_mux_fck>; + }; + + gpt6_gate_fck: gpt6_gate_fck@1000 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&sys_ck>; + ti,bit-shift = <7>; + reg = <0x1000>; + }; + + gpt6_mux_fck: gpt6_mux_fck@1040 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&omap_32k_fck>, <&sys_ck>; + ti,bit-shift = <4>; + reg = <0x1040>; + }; + + gpt6_fck: gpt6_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&gpt6_gate_fck>, <&gpt6_mux_fck>; + }; + + gpt7_gate_fck: gpt7_gate_fck@1000 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&sys_ck>; + ti,bit-shift = <8>; + reg = <0x1000>; + }; + + gpt7_mux_fck: gpt7_mux_fck@1040 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&omap_32k_fck>, <&sys_ck>; + ti,bit-shift = <5>; + reg = <0x1040>; + }; + + gpt7_fck: gpt7_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&gpt7_gate_fck>, <&gpt7_mux_fck>; + }; + + gpt8_gate_fck: gpt8_gate_fck@1000 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&sys_ck>; + ti,bit-shift = <9>; + reg = <0x1000>; + }; + + gpt8_mux_fck: gpt8_mux_fck@1040 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&omap_32k_fck>, <&sys_ck>; + ti,bit-shift = <6>; + reg = <0x1040>; + }; + + gpt8_fck: gpt8_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&gpt8_gate_fck>, <&gpt8_mux_fck>; + }; + + gpt9_gate_fck: gpt9_gate_fck@1000 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&sys_ck>; + ti,bit-shift = <10>; + reg = <0x1000>; + }; + + gpt9_mux_fck: gpt9_mux_fck@1040 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&omap_32k_fck>, <&sys_ck>; + ti,bit-shift = <7>; + reg = <0x1040>; + }; + + gpt9_fck: gpt9_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&gpt9_gate_fck>, <&gpt9_mux_fck>; + }; + + per_32k_alwon_fck: per_32k_alwon_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_32k_fck>; + clock-mult = <1>; + clock-div = <1>; + }; + + gpio6_dbck: gpio6_dbck@1000 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&per_32k_alwon_fck>; + reg = <0x1000>; + ti,bit-shift = <17>; + }; + + gpio5_dbck: gpio5_dbck@1000 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&per_32k_alwon_fck>; + reg = <0x1000>; + ti,bit-shift = <16>; + }; + + gpio4_dbck: gpio4_dbck@1000 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&per_32k_alwon_fck>; + reg = <0x1000>; + ti,bit-shift = <15>; + }; + + gpio3_dbck: gpio3_dbck@1000 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&per_32k_alwon_fck>; + reg = <0x1000>; + ti,bit-shift = <14>; + }; + + gpio2_dbck: gpio2_dbck@1000 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&per_32k_alwon_fck>; + reg = <0x1000>; + ti,bit-shift = <13>; + }; + + wdt3_fck: wdt3_fck@1000 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&per_32k_alwon_fck>; + reg = <0x1000>; + ti,bit-shift = <12>; + }; + + per_l4_ick: per_l4_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l4_ick>; + clock-mult = <1>; + clock-div = <1>; + }; + + gpio6_ick: gpio6_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <17>; + }; + + gpio5_ick: gpio5_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <16>; + }; + + gpio4_ick: gpio4_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <15>; + }; + + gpio3_ick: gpio3_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <14>; + }; + + gpio2_ick: gpio2_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <13>; + }; + + wdt3_ick: wdt3_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <12>; + }; + + uart3_ick: uart3_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <11>; + }; + + uart4_ick: uart4_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <18>; + }; + + gpt9_ick: gpt9_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <10>; + }; + + gpt8_ick: gpt8_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <9>; + }; + + gpt7_ick: gpt7_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <8>; + }; + + gpt6_ick: gpt6_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <7>; + }; + + gpt5_ick: gpt5_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <6>; + }; + + gpt4_ick: gpt4_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <5>; + }; + + gpt3_ick: gpt3_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <4>; + }; + + gpt2_ick: gpt2_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <3>; + }; + + mcbsp2_ick: mcbsp2_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <0>; + }; + + mcbsp3_ick: mcbsp3_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <1>; + }; + + mcbsp4_ick: mcbsp4_ick@1010 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&per_l4_ick>; + reg = <0x1010>; + ti,bit-shift = <2>; + }; + + mcbsp2_gate_fck: mcbsp2_gate_fck@1000 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&mcbsp_clks>; + ti,bit-shift = <0>; + reg = <0x1000>; + }; + + mcbsp3_gate_fck: mcbsp3_gate_fck@1000 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&mcbsp_clks>; + ti,bit-shift = <1>; + reg = <0x1000>; + }; + + mcbsp4_gate_fck: mcbsp4_gate_fck@1000 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&mcbsp_clks>; + ti,bit-shift = <2>; + reg = <0x1000>; + }; + + emu_src_mux_ck: emu_src_mux_ck@1140 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_ck>, <&emu_core_alwon_ck>, <&emu_per_alwon_ck>, <&emu_mpu_alwon_ck>; + reg = <0x1140>; + }; + + emu_src_ck: emu_src_ck { + #clock-cells = <0>; + compatible = "ti,clkdm-gate-clock"; + clocks = <&emu_src_mux_ck>; + }; + + pclk_fck: pclk_fck@1140 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&emu_src_ck>; + ti,bit-shift = <8>; + ti,max-div = <7>; + reg = <0x1140>; + ti,index-starts-at-one; + }; + + pclkx2_fck: pclkx2_fck@1140 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&emu_src_ck>; + ti,bit-shift = <6>; + ti,max-div = <3>; + reg = <0x1140>; + ti,index-starts-at-one; + }; + + atclk_fck: atclk_fck@1140 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&emu_src_ck>; + ti,bit-shift = <4>; + ti,max-div = <3>; + reg = <0x1140>; + ti,index-starts-at-one; + }; + + traceclk_src_fck: traceclk_src_fck@1140 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_ck>, <&emu_core_alwon_ck>, <&emu_per_alwon_ck>, <&emu_mpu_alwon_ck>; + ti,bit-shift = <2>; + reg = <0x1140>; + }; + + traceclk_fck: traceclk_fck@1140 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&traceclk_src_fck>; + ti,bit-shift = <11>; + ti,max-div = <7>; + reg = <0x1140>; + ti,index-starts-at-one; + }; + + secure_32k_fck: secure_32k_fck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + }; + + gpt12_fck: gpt12_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&secure_32k_fck>; + clock-mult = <1>; + clock-div = <1>; + }; + + wdt1_fck: wdt1_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&secure_32k_fck>; + clock-mult = <1>; + clock-div = <1>; + }; };
&cm_clockdomains { - core_l3_clkdm: core_l3_clkdm { - compatible = "ti,clockdomain"; - clocks = <&sdrc_ick>; - }; - - dpll3_clkdm: dpll3_clkdm { - compatible = "ti,clockdomain"; - clocks = <&dpll3_ck>; - }; - - dpll1_clkdm: dpll1_clkdm { - compatible = "ti,clockdomain"; - clocks = <&dpll1_ck>; - }; - - per_clkdm: per_clkdm { - compatible = "ti,clockdomain"; - clocks = <&uart3_fck>, <&gpio6_dbck>, <&gpio5_dbck>, - <&gpio4_dbck>, <&gpio3_dbck>, <&gpio2_dbck>, - <&wdt3_fck>, <&gpio6_ick>, <&gpio5_ick>, <&gpio4_ick>, - <&gpio3_ick>, <&gpio2_ick>, <&wdt3_ick>, <&uart3_ick>, - <&uart4_ick>, <&gpt9_ick>, <&gpt8_ick>, <&gpt7_ick>, - <&gpt6_ick>, <&gpt5_ick>, <&gpt4_ick>, <&gpt3_ick>, - <&gpt2_ick>, <&mcbsp2_ick>, <&mcbsp3_ick>, - <&mcbsp4_ick>; - }; - - emu_clkdm: emu_clkdm { - compatible = "ti,clockdomain"; - clocks = <&emu_src_ck>; - }; - - dpll4_clkdm: dpll4_clkdm { - compatible = "ti,clockdomain"; - clocks = <&dpll4_ck>; - }; - - wkup_clkdm: wkup_clkdm { - compatible = "ti,clockdomain"; - clocks = <&gpio1_dbck>, <&wdt2_fck>, <&wdt2_ick>, <&wdt1_ick>, - <&gpio1_ick>, <&omap_32ksync_ick>, <&gpt12_ick>, - <&gpt1_ick>; - }; - - dss_clkdm: dss_clkdm { - compatible = "ti,clockdomain"; - clocks = <&dss_tv_fck>, <&dss_96m_fck>, <&dss2_alwon_fck>; - }; - - core_l4_clkdm: core_l4_clkdm { - compatible = "ti,clockdomain"; - clocks = <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, - <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, - <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, - <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, - <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, - <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, - <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, - <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, - <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>; - }; + core_l3_clkdm: core_l3_clkdm { + compatible = "ti,clockdomain"; + clocks = <&sdrc_ick>; + }; + + dpll3_clkdm: dpll3_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll3_ck>; + }; + + dpll1_clkdm: dpll1_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll1_ck>; + }; + + per_clkdm: per_clkdm { + compatible = "ti,clockdomain"; + clocks = <&uart3_fck>, <&gpio6_dbck>, <&gpio5_dbck>, + <&gpio4_dbck>, <&gpio3_dbck>, <&gpio2_dbck>, + <&wdt3_fck>, <&gpio6_ick>, <&gpio5_ick>, <&gpio4_ick>, + <&gpio3_ick>, <&gpio2_ick>, <&wdt3_ick>, <&uart3_ick>, + <&uart4_ick>, <&gpt9_ick>, <&gpt8_ick>, <&gpt7_ick>, + <&gpt6_ick>, <&gpt5_ick>, <&gpt4_ick>, <&gpt3_ick>, + <&gpt2_ick>, <&mcbsp2_ick>, <&mcbsp3_ick>, + <&mcbsp4_ick>; + }; + + emu_clkdm: emu_clkdm { + compatible = "ti,clockdomain"; + clocks = <&emu_src_ck>; + }; + + dpll4_clkdm: dpll4_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll4_ck>; + }; + + wkup_clkdm: wkup_clkdm { + compatible = "ti,clockdomain"; + clocks = <&gpio1_dbck>, <&wdt2_fck>, <&wdt2_ick>, <&wdt1_ick>, + <&gpio1_ick>, <&omap_32ksync_ick>, <&gpt12_ick>, + <&gpt1_ick>; + }; + + dss_clkdm: dss_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dss_tv_fck>, <&dss_96m_fck>, <&dss2_alwon_fck>; + }; + + core_l4_clkdm: core_l4_clkdm { + compatible = "ti,clockdomain"; + clocks = <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, + <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, + <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, + <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, + <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, + <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, + <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, + <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, + <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>; + }; }; diff --git a/arch/arm/mach-omap2/omap3/Kconfig b/arch/arm/mach-omap2/omap3/Kconfig index 7b298d6..e140e21 100644 --- a/arch/arm/mach-omap2/omap3/Kconfig +++ b/arch/arm/mach-omap2/omap3/Kconfig @@ -111,6 +111,7 @@ config TARGET_OMAP3_LOGIC select DM select DM_SERIAL select DM_GPIO + select OMAP3_GPIO_3 select OMAP3_GPIO_4 select OMAP3_GPIO_6
On Fri, Aug 25, 2017 at 07:33:26AM -0500, Adam Ford wrote:
The DTS files had some spacing issues and they needed fixing. This pull re-sync's the OMAP3xx related DTS files with Linux 4.13-RC5.
To keep the DTS and DTSI files clean and in sync with Linux, new u-boot.dtsi files are added.
Signed-off-by: Adam Ford aford173@gmail.com
V3: The resync broke card detect on MMC1 on Logic PD's Torpedo, so we add the cd-invert to the Torpedo's -u-boot.dtsi file.
V2: Add the u-boot.dtsi files for OMAP3, OMAP36xx, and Torpedo Remove the need for the second patch in the series
Adam Ford
