[PATCH 1/2] config: Add 'update_bootimg' command to update flash.bin on Phytec's imx8mm
This command allows easy update on SD card (hence the update_mmc_part=1) of the flash.bin generated during u-boot build.
Signed-off-by: Lukasz Majewski lukma@denx.de --- include/configs/phycore_imx8mm.h | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index ce6dc87c69..fdeb11933f 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -29,6 +29,17 @@ "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ "mmcpart=1\0" \ "mmcroot=2\0" \ + "update_mmc_part=1\0" \ + "update_offset=0x42\0" \ + "update_filename=flash.bin\0" \ + "hostname=/tftpboot/lukma/\0" \ + "update_bootimg=" \ + "mmc dev ${mmcdev} ; " \ + "if dhcp ${hostname}/${update_filename} ; then " \ + "setexpr fw_sz ${filesize} / 0x200 ; " /* SD block size */ \ + "setexpr fw_sz ${fw_sz} + 1 ; " \ + "mmc write ${loadaddr} ${update_offset} ${fw_sz} ; " \ + "fi\0" \ "mmcautodetect=yes\0" \ "mmcargs=setenv bootargs console=${console} " \ "root=/dev/mmcblk${mmcdev}p${mmcroot} rootwait rw\0" \
This change adds support for PCIe connected nvme disk - phyBOARD-Polis base board.
One needs to call following commands in u-boot:
pci enum nvme scan nvme info
And then ones to access proper file system (like fat[ls|load|write], ext4[ls|load|write]).
Signed-off-by: Lukasz Majewski lukma@denx.de --- configs/phycore-imx8mm_defconfig | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/configs/phycore-imx8mm_defconfig b/configs/phycore-imx8mm_defconfig index 22d419024f..e6854aa571 100644 --- a/configs/phycore-imx8mm_defconfig +++ b/configs/phycore-imx8mm_defconfig @@ -12,6 +12,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx8mm-phyboard-polis-rdk" CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_TARGET_PHYCORE_IMX8MM=y +CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y @@ -23,6 +24,7 @@ CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x3E0000 CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_PCI=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y @@ -32,6 +34,7 @@ CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadimage; the CONFIG_DEFAULT_FDT_FILE="oftree" CONFIG_SYS_CBSIZE=2048 CONFIG_SYS_PBSIZE=2074 +CONFIG_CYCLIC_MAX_CPU_TIME_US=1000 CONFIG_BOARD_LATE_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_SYS_MALLOC=y @@ -59,6 +62,7 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -110,10 +114,15 @@ CONFIG_PHY_TI_DP83867=y CONFIG_PHY_GIGE=y CONFIG_FEC_MXC=y CONFIG_MII=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_IMX=y +CONFIG_PHY=y +CONFIG_PHY_IMX8M_PCIE=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y -CONFIG_DM_REGULATOR=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y
Hi Lukasz,
Please explain why this option was added.
Hi Fabio,
Hi Lukasz,
It must have been slipped in...
Default value is 5000 for this SoM.
IMHO it would be safe to remove it (and use default value) - I will prepare v2 without it. Thanks for spotting it.
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Erika Unter HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hi Lukasz,
I don't think all the users will like to use this tftpboot path :-)
On Thu, Aug 01, 2024 at 10:13:13AM -0300, Fabio Estevam wrote:
Hi Lukasz,
And while we're touching these boards, can we get them migrated to plain text environment please?
Hi Lukasz,
- "update_mmc_part=1\0" \
You define the update_mmc_part variable here, but do not use it anywhere. You use the mmcdev variable later which is good, because the function then works not only for SD-Card, but also for eMMC.
In the commit description you say it is for updating SD-Card, which would be mmc dev 1, but the name of the variable would indicate that is is for a partition. As I understand it you want to update just the U-Boot, which is not inside any partition, so you would not need this variable.
- "update_offset=0x42\0" \
- "update_filename=flash.bin\0" \
- "hostname=/tftpboot/lukma/\0" \
We adivse to use /srv/tftp as tftp dir in our BSP documentation. But I don't think you need that variable at all, because the dhcp command should find the tftp dir automatically.
- "update_bootimg=" \
Does this work? For me it does not. As far as I know the syntax of this command is "dhcp <loadaddr> <filename>". So I would expect this to be: dhcp ${loadaddr} ${update_filename}
Why do you add one here? Is this important for something? For me it works also without the one. It is also described in our BSP documentation without adding one. See: https://phytec.github.io/doc-bsp-yocto/bsp/imx8/imx8mp/mainline-head.html#fl...
(This is for our imx8mp mainline release but is the same for imx8mm with another offset).
Benjamin
"mmcautodetect=yes\0" \ "mmcargs=setenv bootargs console=${console} " \ "root=/dev/mmcblk${mmcdev}p${mmcroot} rootwait rw\0" \"fi\0" \
Hi Benjamin,
Hi Lukasz,
Yes, for updating u-boot it is not required. I will remove it.
I can follow your documentation adn add /srv/tftp
When you don't provide the <loadaddr> the one from ${loadaddr} is used by default.
However, yes - the latter - i.e. one with ${loadaddr} is more readable and shall be used.
SD block size */ \
\"setexpr fw_sz ${fw_sz} + 1 ; "
Yes, it is. The / division is only giving you the value without reminder. As the filesize can be not aligned to 0x200 you wouldn't flash the whole binary.
Sometimes it works, sometimes not - it depends if you crop the relevant part.
If you are 100% sure that all the time the size of the binary is aligned to 0x200, then you can omit the 1 as well.
Benjamin
"mmcautodetect=yes\0" \ "mmcargs=setenv bootargs console=${console} " \ "root=/dev/mmcblk${mmcdev}p${mmcroot} rootwait"fi\0" \
rw\0" \
Lukasz Majewski
Benjamin Hahn
Fabio Estevam
Lukasz Majewski
