[U-Boot] [PATCH 5/5] sf: Add bank selection support for dual stacked access
For upper memory, bank selection on dual stacked access needs to subtract the calculated banks from the number of banks available on a single memory.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- drivers/mtd/spi/spi_flash.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index f7443fa..58d5899 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -190,6 +190,9 @@ int spi_flash_cmd_erase(struct spi_flash *flash, u32 offset, size_t len) u8 bank_sel;
bank_sel = erase_addr / SPI_FLASH_16MB_BOUN; + if ((is_dual == SPI_FLASH_CONN_DUALSTACKED) && + (flash->spi->u_page == 1)) + bank_sel -= ((flash->size / 2) / SPI_FLASH_16MB_BOUN);
ret = spi_flash_cmd_bankaddr_write(flash, bank_sel); if (ret) { @@ -242,6 +245,9 @@ int spi_flash_cmd_write_multi(struct spi_flash *flash, u32 offset, u8 bank_sel;
bank_sel = write_addr / SPI_FLASH_16MB_BOUN; + if ((is_dual == SPI_FLASH_CONN_DUALSTACKED) && + (flash->spi->u_page == 1)) + bank_sel -= ((flash->size / 2) / SPI_FLASH_16MB_BOUN);
ret = spi_flash_cmd_bankaddr_write(flash, bank_sel); if (ret) { @@ -330,12 +336,19 @@ int spi_flash_cmd_read_fast(struct spi_flash *flash, u32 offset, } #ifdef CONFIG_SPI_FLASH_BAR bank_sel = read_addr / SPI_FLASH_16MB_BOUN; + if ((is_dual == SPI_FLASH_CONN_DUALSTACKED) && + (flash->spi->u_page == 1)) + bank_sel -= ((flash->size / 2) / SPI_FLASH_16MB_BOUN);
ret = spi_flash_cmd_bankaddr_write(flash, bank_sel); if (ret) { debug("SF: fail to set bank%d\n", bank_sel); return ret; } + + if ((is_dual == SPI_FLASH_CONN_DUALSTACKED) && + (flash->spi->u_page == 1)) + bank_sel += ((flash->size / 2) / SPI_FLASH_16MB_BOUN); #endif remain_len = (bank_boun * (bank_sel + 1) - read_addr); if (len < remain_len)
