[U-Boot] [PATCH] dts: samsung: arndale: Fix include path
As per new convention ARCH_CPU_DTS is not defined in "dtc/Makefile". Hence Arndale comilation is failing. Fix this by adding proper include file in "board/samsung/dts/exynos5250-arndale.dts".
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- board/samsung/dts/exynos5250-arndale.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/samsung/dts/exynos5250-arndale.dts b/board/samsung/dts/exynos5250-arndale.dts index c700e45..202f2ea 100644 --- a/board/samsung/dts/exynos5250-arndale.dts +++ b/board/samsung/dts/exynos5250-arndale.dts @@ -8,7 +8,7 @@ */
/dts-v1/; -/include/ ARCH_CPU_DTS +#include "exynos5250.dtsi"
/ { model = "SAMSUNG Arndale board based on EXYNOS5250";
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Chander Kashyap
Minkyu Kang
