[U-Boot] [PATCH 0/3] cm_t54: add MAC address and env partiton handling
Add Eth MAC address handling, stored in onboard EEPROM.
cm-t54 config defines eMMC as env storage device. cm-t54 U-Boot environment is stored in the same partition as boot loader. It can be both - eMMC boot or user data partition. Add support for setting environment partition number in runtime.
Dmitry Lifshitz (3): cm-t54: add EEPROM support and MAC address handling env_mmc: support env partition setup in runtime cm-t54: add environment partition runtime detection
board/compulab/cm_t54/cm_t54.c | 85 ++++++++++++++++++++++++++++++++++++++++ common/env_mmc.c | 35 ++++++++++++---- include/configs/cm_t54.h | 10 +++++ 3 files changed, 121 insertions(+), 9 deletions(-)
cm-t54 Eth MAC address is stored in onboard EEPROM. Add EEPROM support and setup stored Eth MAC address.
If EEPROM does not contain a valid MAC, then generate it from the processor ID code (reference code is taken from OMAP5 uEvm board file).
Modify Device Tree blob MAC address field with retrieved data.
Signed-off-by: Dmitry Lifshitz lifshitz@compulab.co.il Acked-by: Igor Grinberg grinberg@compulab.co.il --- board/compulab/cm_t54/cm_t54.c | 63 ++++++++++++++++++++++++++++++++++++++++ include/configs/cm_t54.h | 9 ++++++ 2 files changed, 72 insertions(+), 0 deletions(-)
diff --git a/board/compulab/cm_t54/cm_t54.c b/board/compulab/cm_t54/cm_t54.c index 1a4be72..574ced2 100644 --- a/board/compulab/cm_t54/cm_t54.c +++ b/board/compulab/cm_t54/cm_t54.c @@ -9,6 +9,7 @@ */
#include <common.h> +#include <fdt_support.h> #include <usb.h> #include <mmc.h> #include <palmas.h> @@ -20,6 +21,8 @@ #include <asm/arch/ehci.h> #include <asm/ehci-omap.h>
+#include "../common/eeprom.h" + #define DIE_ID_REG_BASE (OMAP54XX_L4_CORE_BASE + 0x2000) #define DIE_ID_REG_OFFSET 0x200
@@ -99,6 +102,66 @@ int board_mmc_init(bd_t *bis) } #endif
+#ifdef CONFIG_USB_HOST_ETHER + +void ft_board_setup(void *blob, bd_t *bd) +{ + uint8_t enetaddr[6]; + + /* MAC addr */ + if (eth_getenv_enetaddr("usbethaddr", enetaddr)) { + fdt_find_and_setprop(blob, "/smsc95xx@0", "mac-address", + enetaddr, 6, 1); + } +} + +static void generate_mac_addr(uint8_t *enetaddr) +{ + int reg; + + reg = DIE_ID_REG_BASE + DIE_ID_REG_OFFSET; + + /* + * create a fake MAC address from the processor ID code. + * first byte is 0x02 to signify locally administered. + */ + enetaddr[0] = 0x02; + enetaddr[1] = readl(reg + 0x10) & 0xff; + enetaddr[2] = readl(reg + 0xC) & 0xff; + enetaddr[3] = readl(reg + 0x8) & 0xff; + enetaddr[4] = readl(reg) & 0xff; + enetaddr[5] = (readl(reg) >> 8) & 0xff; +} + +/* + * Routine: handle_mac_address + * Description: prepare MAC address for on-board Ethernet. + */ +static int handle_mac_address(void) +{ + uint8_t enetaddr[6]; + int ret; + + ret = eth_getenv_enetaddr("usbethaddr", enetaddr); + if (ret) + return 0; + + ret = cl_eeprom_read_mac_addr(enetaddr); + if (!ret || !is_valid_ether_addr(enetaddr)) + generate_mac_addr(enetaddr); + + if (!is_valid_ether_addr(enetaddr)) + return -1; + + return eth_setenv_enetaddr("usbethaddr", enetaddr); +} + +int board_eth_init(bd_t *bis) +{ + return handle_mac_address(); +} +#endif + #ifdef CONFIG_USB_EHCI static struct omap_usbhs_board_data usbhs_bdata = { .port_mode[0] = OMAP_USBHS_PORT_MODE_UNUSED, diff --git a/include/configs/cm_t54.h b/include/configs/cm_t54.h index 3ca229b..8d474f0 100644 --- a/include/configs/cm_t54.h +++ b/include/configs/cm_t54.h @@ -19,6 +19,15 @@ #undef CONFIG_MISC_INIT_R #undef CONFIG_SPL_OS_BOOT
+/* Device Tree defines */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP + +/* EEPROM related defines */ +#define CONFIG_SYS_I2C_OMAP34XX +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 + /* Enable SD/MMC CD and WP GPIOs */ #define OMAP_HSMMC_USE_GPIO
Applied to u-boot-ti/master, thanks!
Add callback with __weak annotation to allow setup of environment partition number in runtime from a board file.
Signed-off-by: Dmitry Lifshitz lifshitz@compulab.co.il Signed-off-by: Igor Grinberg grinberg@compulab.co.il --- common/env_mmc.c | 35 ++++++++++++++++++++++++++--------- 1 files changed, 26 insertions(+), 9 deletions(-)
diff --git a/common/env_mmc.c b/common/env_mmc.c index 045428c..5d4b5f4 100644 --- a/common/env_mmc.c +++ b/common/env_mmc.c @@ -62,6 +62,30 @@ int env_init(void) return 0; }
+ +#ifdef CONFIG_SYS_MMC_ENV_PART +__weak uint mmc_get_env_part(struct mmc *mmc) +{ + return CONFIG_SYS_MMC_ENV_PART; +} + +static int mmc_set_env_part(struct mmc *mmc) +{ + uint part = mmc_get_env_part(mmc); + + if (part != mmc->part_num) { + if (mmc_switch_part(CONFIG_SYS_MMC_ENV_DEV, part)) { + puts("MMC partition switch failed\n"); + return -1; + } + } + + return 0; +} +#else +static inline int mmc_set_env_part(struct mmc *mmc) {return 0; }; +#endif + static int init_mmc_for_env(struct mmc *mmc) { if (!mmc) { @@ -74,15 +98,8 @@ static int init_mmc_for_env(struct mmc *mmc) return -1; }
-#ifdef CONFIG_SYS_MMC_ENV_PART - if (CONFIG_SYS_MMC_ENV_PART != mmc->part_num) { - if (mmc_switch_part(CONFIG_SYS_MMC_ENV_DEV, - CONFIG_SYS_MMC_ENV_PART)) { - puts("MMC partition switch failed\n"); - return -1; - } - } -#endif + if (mmc_set_env_part(mmc)) + return -1;
return 0; }
ping..
- return CONFIG_SYS_MMC_ENV_PART;
- uint part = mmc_get_env_part(mmc);
- if (part != mmc->part_num) {
return -1;
return -1;
-#endif
return -1;
On Sun, May 25, 2014 at 10:23:46AM +0300, Igor Grinberg wrote:
ping..
return -1;
return -1;
-#endif
return -1;
Pantelis, weren't you going to pick this up? Thanks!
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Hi Tom,
rc3 is out...
ping..
Can we please have this in for 2014.07?
Thanks!
- -- Regards, Igor.
Hi Dmitry,
I took a good look at the patch and there's a problem.
return -1;
Just before this hunk, we have this:
#ifdef CONFIG_SYS_MMC_ENV_PART int dev = CONFIG_SYS_MMC_ENV_DEV;
#ifdef CONFIG_SPL_BUILD dev = 0; #endif #endif
This appears to be broken for SPL in case that CONFIG_SYS_MMC_ENV_DEV is not 0.
SPL hardcoded dev to 0, while mmc_switch_part is implicitly operating on CONFIG_SYS_MMC_ENV_DEV.
Please rework it so that the SPL case is unaffected.
return -1;
-#endif
return -1;
1.7.5.4
Regards
-- Pantelis
Hi Pantelis,
On 06/12/2014 06:10 PM, Pantelis Antoniou wrote:
Hi Dmitry,
Signed-off-by: Dmitry Lifshitzlifshitz@compulab.co.il Signed-off-by: Igor Grinberggrinberg@compulab.co.il
return -1;
Exactly as it was broken before the patch, right?
This patch does not change the behavior and its purpose is not fixing the current code.
The bug describe can be fixed by later patch and possibly will require additional review and testing.
Given that this patch does not change the behavior, can it be accepted please ?
Regards,
Dmitry
return -1;
-#endif
return -1;
1.7.5.4
Add environment partition runtime detection callback.
Signed-off-by: Dmitry Lifshitz lifshitz@compulab.co.il Acked-by: Igor Grinberg grinberg@compulab.co.il --- board/compulab/cm_t54/cm_t54.c | 22 ++++++++++++++++++++++ include/configs/cm_t54.h | 1 + 2 files changed, 23 insertions(+), 0 deletions(-)
diff --git a/board/compulab/cm_t54/cm_t54.c b/board/compulab/cm_t54/cm_t54.c index 574ced2..11e77f9 100644 --- a/board/compulab/cm_t54/cm_t54.c +++ b/board/compulab/cm_t54/cm_t54.c @@ -13,6 +13,7 @@ #include <usb.h> #include <mmc.h> #include <palmas.h> +#include <spl.h>
#include <asm/gpio.h> #include <asm/arch/sys_proto.h> @@ -74,6 +75,27 @@ static int cm_t54_palmas_regulator_set(u8 vreg, u8 vval, u8 creg, u8 cval) return 0; }
+/* + * Routine: mmc_get_env_part + * Description: setup environment storage device partition. + */ +#ifdef CONFIG_SYS_MMC_ENV_PART +uint mmc_get_env_part(struct mmc *mmc) +{ + u32 bootmode = gd->arch.omap_boot_params.omap_bootmode; + uint bootpart = CONFIG_SYS_MMC_ENV_PART; + + /* + * If booted from eMMC boot partition then force eMMC + * FIRST boot partition to be env storage + */ + if (bootmode == BOOT_DEVICE_MMC2_2) + bootpart = 1; + + return bootpart; +} +#endif + #if defined(CONFIG_GENERIC_MMC) && !defined(CONFIG_SPL_BUILD) #define SB_T54_CD_GPIO 228 #define SB_T54_WP_GPIO 229 diff --git a/include/configs/cm_t54.h b/include/configs/cm_t54.h index 8d474f0..680aac3 100644 --- a/include/configs/cm_t54.h +++ b/include/configs/cm_t54.h @@ -49,6 +49,7 @@
#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ +#define CONFIG_SYS_MMC_ENV_PART 0 #define CONFIG_ENV_OFFSET 0xc0000 /* (in bytes) 768 KB */ #define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
Hi Tom,
What about patch 2/3 (env_mmc: support env partition setup in runtime)?
- -- Regards, Igor.
Dmitry Lifshitz
Igor Grinberg
Pantelis Antoniou
