[U-Boot] OMAP3 clocks initialization not consistent with x-loader?
x-loader has the following comment and if statement for all boards supporting omap36xx SoC:
----------------------cut----------------------------------------
* On OMAP3630, DDR data corruption has been observed on OFF mode * exit if the sys clock was lower than 26M. As a work around, * OMAP3630 is operated at 26M sys clock and this internal division * is not performed. */ if((is_cpu_family() != CPU_OMAP36XX) && (sys_clkin_sel > 2)) { sr32(PRM_CLKSRC_CTRL, 6, 2, 2);/* input clock divider */ clk_index = sys_clkin_sel/2; } else { sr32(PRM_CLKSRC_CTRL, 6, 2, 1);/* input clock divider */ clk_index = sys_clkin_sel; } ----------------------cut----------------------------------------
U-Boot's omap3 clock initialization does not have that check for omap36xx.
Shouldn't we have it also in U-Boot to workaround that DDR data corruption issue?
Igor Grinberg
