[U-Boot] [PATCH] Error : Not finding asm/arch/gpio.h
While building with omap3_beagle_config configuration, getting an error about not finding asm/arch/gpio.h (which does not exist). Found that header files are moved to arch/arm/include/asm/arch-. Fixed the includes to find the file..
Signed-off-by: Faisal Hassanfaah87@gmail.com Cc: Wolfgang Denkwd@denx.de
--- a/board/cm-bf537e/gpio_cfi_flash.c +++ b/board/cm-bf537e/gpio_cfi_flash.c @@ -8,7 +8,7 @@
#include<common.h> #include<asm/blackfin.h> -#include<asm/gpio.h> +#include<asm/mach-bf537/gpio.h> #include<asm/io.h> #include "gpio_cfi_flash.h"
--- a/board/bf548-ezkit/video.c +++ b/board/bf548-ezkit/video.c @@ -11,7 +11,7 @@ #include<config.h> #include<malloc.h> #include<asm/blackfin.h> -#include<asm/gpio.h> +#include<asm/mach-bf548/gpio.h> #include<asm/portmux.h> #include<asm/mach-common/bits/dma.h> #include<i2c.h> --- a/board/bf548-ezkit/bf548-ezkit.c +++ b/board/bf548-ezkit/bf548-ezkit.c @@ -11,7 +11,7 @@ #include<command.h> #include<netdev.h> #include<asm/blackfin.h> -#include<asm/gpio.h> +#include<asm/mach-bf548/gpio.h> #include<asm/portmux.h> #include<asm/sdh.h>
--- a/board/bf537-stamp/post.c +++ b/board/bf537-stamp/post.c @@ -12,7 +12,7 @@ #include<config.h> #include<command.h> #include<asm/blackfin.h> -#include<asm/gpio.h> +#include<asm/mach-bf537/gpio.h>
/* Using sw10-PF5 as the hotkey */ int post_hotkeys_pressed(void) --- a/board/bf533-stamp/bf533-stamp.c +++ b/board/bf533-stamp/bf533-stamp.c @@ -27,7 +27,7 @@
#include<common.h> #include<netdev.h> -#include<asm/gpio.h> +#include<asm/mach-bf533/gpio.h>
DECLARE_GLOBAL_DATA_PTR;
--- a/board/bf527-sdp/bf527-sdp.c +++ b/board/bf527-sdp/bf527-sdp.c @@ -8,7 +8,7 @@
#include<common.h> #include<asm/blackfin.h> -#include<asm/gpio.h> +#include<asm/mach-bf527/gpio.h> #include<asm/mach-common/bits/pll.h>
int checkboard(void) --- a/board/bf527-ezkit/bf527-ezkit.c +++ b/board/bf527-ezkit/bf527-ezkit.c @@ -12,7 +12,7 @@ #include<net.h> #include<netdev.h> #include<asm/blackfin.h> -#include<asm/gpio.h> +#include<mach-bf527/gpio.h> #include<asm/net.h> #include<asm/mach-common/bits/otp.h>
--- a/board/cm-bf548/video.c +++ b/board/cm-bf548/video.c @@ -11,7 +11,7 @@ #include<config.h> #include<malloc.h> #include<asm/blackfin.h> -#include<asm/gpio.h> +#include<asm/mach-bf548/gpio.h> #include<asm/portmux.h> #include<asm/mach-common/bits/dma.h> #include<i2c.h> --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -38,7 +38,7 @@ #include<asm/arch/mmc_host_def.h> #include<asm/arch/mux.h> #include<asm/arch/sys_proto.h> -#include<asm/arch/gpio.h> +#include<asm/arch-omap3/gpio.h> #include<asm/mach-types.h> #ifdef CONFIG_USB_EHCI #include<usb.h> --- a/board/ti/beagle/led.c +++ b/board/ti/beagle/led.c @@ -22,7 +22,7 @@ #include<asm/arch/cpu.h> #include<asm/io.h> #include<asm/arch/sys_proto.h> -#include<asm/arch/gpio.h> +#include<asm/arch-omap3/gpio.h>
static unsigned int saved_state[2] = {STATUS_LED_OFF, STATUS_LED_OFF};
Dear Faisal H,
In message CADyx3a0pYfW9Ee0kC0h6OQOGtFAd5ceviJvUv9ufSPaRTeOmxw@mail.gmail.com you wrote:
What has building for OMAP3 boards to do with files from the Blackfin source tree?
Please fix the commit message. And please put the respective architecture custodian on Cc:, not me.
Thanks.
"make <board>_config" sets a link for asm/arch to arch/arm/include/asm/arch-. The file is not moved.
Then in my understanding asm/arch/gpio.h is included in asm/gpio.h, and must not be included directly. Have I missed something ?
However, asm/gpio.h is the correct general interface. The specific part for the microprocessor is included with #include <asm/arch/gpio.h> in asm/gpio.h.
You should not need to change it if the links are correctly set. If not, it is another bug.
IMHO this change is wrong, and it is correct how it is done currently.
Best regards, Stefano Babic
NAK on all the Blackfin pieces as that arch properly sets up asm/gpio.h for people to include (all the board/*bf5*/ dirs). -mike
Faisal H
Mike Frysinger
Stefano Babic
