[U-Boot] [PATCH v3] usb: add support for generic EHCI devices
This driver is meant to be used with any EHCI-compatible host controller in case if there's no need for platform-specific glue such as setup of controller or PHY's power mode via GPIOs etc.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Marek Vasut marex@denx.de Cc: Stephen Warren swarren@nvidia.com ---
Changes compared to v2: * Driver is disabled by default now * Use uintptr_t instead of uint32_t for "struct ehci_hcor" address calculation
Changes compared to v1: * Updated commit message with removal of Synopsys board mention * Cleaned-up ehci_usb_remove()
drivers/usb/host/Kconfig | 7 ++++++ drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-generic.c | 51 +++++++++++++++++++++++++++++++++++++++++ 3 files changed, 59 insertions(+) create mode 100644 drivers/usb/host/ehci-generic.c
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 2a2bffe..6bb9caa 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -73,4 +73,11 @@ config USB_EHCI_UNIPHIER ---help--- Enables support for the on-chip EHCI controller on UniPhier SoCs.
+config USB_EHCI_GENERIC + bool "Support for generic EHCI USB controller" + depends on OF_CONTROL + default n + ---help--- + Enables support for generic EHCI controller. + endif diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index f70f38c..b9b4471 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -32,6 +32,7 @@ else obj-$(CONFIG_USB_EHCI_FSL) += ehci-fsl.o endif obj-$(CONFIG_USB_EHCI_FARADAY) += ehci-faraday.o +obj-$(CONFIG_USB_EHCI_GENERIC) += ehci-generic.o obj-$(CONFIG_USB_EHCI_EXYNOS) += ehci-exynos.o obj-$(CONFIG_USB_EHCI_MXC) += ehci-mxc.o obj-$(CONFIG_USB_EHCI_MXS) += ehci-mxs.o diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c new file mode 100644 index 0000000..22e1ad0 --- /dev/null +++ b/drivers/usb/host/ehci-generic.c @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2015 Alexey Brodkin abrodkin@synopsys.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include "ehci.h" + +/* + * Even though here we don't explicitly use "struct ehci_ctrl" + * ehci_register() expects it to be the first thing that resides in + * device's private data. + */ +struct generic_ehci { + struct ehci_ctrl ctrl; +}; + +static int ehci_usb_probe(struct udevice *dev) +{ + struct ehci_hccr *hccr = (struct ehci_hccr *)dev_get_addr(dev); + struct ehci_hcor *hcor; + + hcor = (struct ehci_hcor *)((uintptr_t)hccr + + HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + + return ehci_register(dev, hccr, hcor, NULL, 0, USB_INIT_HOST); +} + +static int ehci_usb_remove(struct udevice *dev) +{ + return ehci_deregister(dev); +} + +static const struct udevice_id ehci_usb_ids[] = { + { .compatible = "generic-ehci" }, + { } +}; + +U_BOOT_DRIVER(usb_ehci) = { + .name = "ehci_generic", + .id = UCLASS_USB, + .of_match = ehci_usb_ids, + .probe = ehci_usb_probe, + .remove = ehci_usb_remove, + .ops = &ehci_usb_ops, + .priv_auto_alloc_size = sizeof(struct generic_ehci), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +}; +
Hi Marek,
- Driver is disabled by default now
- Use uintptr_t instead of uint32_t for "struct ehci_hcor" address calculation
- Updated commit message with removal of Synopsys board mention
- Cleaned-up ehci_usb_remove()
git doesn't Cc people from "Reviewed-by" tags, so adding you and Simon here. Sorry for that noise.
-Alexey
- bool "Support for generic EHCI USB controller"
- depends on OF_CONTROL
- default n
- ---help---
This should depend on EHCI_HCD somehow, no (since it's using ehci_deregister and friends) ?
- { .compatible = "generic-ehci" },
The driver name should be ehci_generic, not usb_ehci, otherwise this will collide with other drivers who do the same mistake.
- .name = "ehci_generic",
- .id = UCLASS_USB,
- .of_match = ehci_usb_ids,
- .probe = ehci_usb_probe,
- .remove = ehci_usb_remove,
- .ops = &ehci_usb_ops,
- .priv_auto_alloc_size = sizeof(struct generic_ehci),
- .flags = DM_FLAG_ALLOC_PRIV_DMA,
Best regards, Marek Vasut
Hi Marek,
- default n
- ---help---
This symbol is in "if USB_EHCI_HCD" so if USB_EHCI_HCD is not enabled EHCI_GENERIC won't be visible and hence USB_EHCI_HCD in defconfig.
Otherwise we'll need to add USB_EHCI_HCD dependency for other EHCI drivers such as USB_EHCI_MARVELL, USB_EHCI_MX6 and USB_EHCI_UNIPHIER. Do we want to do it? :)
Please check drivers/usb/host/Kconfig.
Ok but then some other drivers should be fixed as well, right? See: ----------------------->8------------------------ git grep U_BOOT_DRIVER drivers/usb/host/ drivers/usb/host/dwc2.c:U_BOOT_DRIVER(usb_dwc2) = { drivers/usb/host/ehci-exynos.c:U_BOOT_DRIVER(usb_ehci) = { drivers/usb/host/ehci-generic.c:U_BOOT_DRIVER(usb_ehci) = { drivers/usb/host/ehci-marvell.c:U_BOOT_DRIVER(ehci_mvebu) = { drivers/usb/host/ehci-pci.c:U_BOOT_DRIVER(ehci_pci) = { drivers/usb/host/ehci-sunxi.c:U_BOOT_DRIVER(usb_ehci) = { drivers/usb/host/ehci-tegra.c:U_BOOT_DRIVER(usb_ehci) = { drivers/usb/host/ohci-sunxi.c:U_BOOT_DRIVER(usb_ohci) = { drivers/usb/host/usb-sandbox.c:U_BOOT_DRIVER(usb_sandbox) = { drivers/usb/host/usb-uclass.c:U_BOOT_DRIVER(usb_dev_generic_drv) = { drivers/usb/host/xhci-exynos5.c:U_BOOT_DRIVER(usb_xhci) = { ----------------------->8------------------------
I believe it all works because we don't enable 2 drivers at a time [usually] :)
And in that light I don't see a point in having different names here. Or you think there's a chance to have more than one USB controller enabled simultaneously [and if it is possible at all with current implementation]?
-Alexey
On Monday, November 30, 2015 at 07:13:30 PM, Alexey Brodkin wrote:
Hi Marek,
Hi!
- default n
- ---help---
The order there seems correct. But how is it possible that your driver triggered the build error on the ph1_sld8,ph1_sld3,ph1_ld4 boards ? I suspect because it was enabled by default, but didn't "select" the EHCI_HCD ?
Yes.
CCing Lukasz
This was fixed by a patch I posted just a while ago.
CCing Hans.
Correct. I trapped this on sunxi just today. Propagation of this error must be stopped.
I can have ehci-pci and ehci-somethingelse enabled, so yes, the possibility is here and since Tom triggered it on sunxi, it already happens.
Hi Marek,
Hi Marek,
Nope EHCI_HCD gets selected, but... ehci-generic uses CONFIG_DM_USB :) And ehci_degister()/ehci_deregister() are only defined in EHCI_HCD is CONFIG_DM_USB used.
So I need to add dependency on CONFIG_DM_USB for ehci_generic.
Looking for other examples of dependencies on CONFIG_DM_USB I was surprised to see ehci-exynos, ehci-marvell, ehci-pci, ehci-sunxi and ehci-tegra all are not yet added in Kconfig.
I.e. all those drivers are selected in headers (in include/configs/xxx.h).
Yes.
Ok, I'll fix it for ehci generic as well.
And v4 is about to float on mailing list :)
-Alexey
On Tuesday, December 01, 2015 at 07:54:19 PM, Alexey Brodkin wrote:
Hi Marek,
Hi Marek,
Yes.
I see, thanks!
I'd like to hear Simon's opinion on this.
Hi Marek,
Hi Marek,
Yes.
I see, thanks!
Yes, good to fix this. When CONFIG_DM_USB goes away, we can drop them all.
Alexey Brodkin
