[U-Boot] Please pull u-boot-sunxi master
Hi Tom,
Here is another sunxi pull-req for v2016.01, highlights:
-Add support for A83 SoC -Misc. small bugfixes
The following changes since commit 789fa275b3750e60c60cb3d18eabc9467892c257:
x86: Remove HAVE_ACPI_RESUME (2015-12-09 17:44:56 +0800)
http://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to bb3654629a6b2ab131de96489f70421f6a848c70:
sunxi: Fix H3 DRAM DQ read delay configuration (2015-12-10 15:45:48 +0100)
---------------------------------------------------------------- Hans de Goede (2): sunxi: Set AHB1 clock to PLL6/3 on all clock_sun6i.h using SoCs sunxi: select SYS_NS16550 from Kconfig
Jens Kuske (1): sunxi: Fix H3 DRAM DQ read delay configuration
Olliver Schinagl (2): sunxi: twi: Enable clocks on sun7i sun4i: clock: Cleanup some whitespace errors
vishnupatekar (8): sunxi: Add Machine Support for A83T SOC sunxi: Add support for UART0 in PB pin group on A83T sunxi: power: axp818: add support for axp818 driver sunxi: power: enabled support for axp818 sunxi: clk: add basic clocks for A83T sunxi: Add support for Allwinner A83T DRAM sunxi: dts: sun8i: Add Allwinner A83T dtsi sunxi: Add suport for A83T HomletV2 Board by Allwinner
arch/arm/Kconfig | 1 + arch/arm/cpu/armv7/sunxi/Makefile | 6 + arch/arm/cpu/armv7/sunxi/board.c | 4 + arch/arm/cpu/armv7/sunxi/clock_sun4i.c | 9 +- arch/arm/cpu/armv7/sunxi/clock_sun6i.c | 3 - arch/arm/cpu/armv7/sunxi/clock_sun8i_a83t.c | 136 +++++++ arch/arm/cpu/armv7/sunxi/cpu_info.c | 2 + arch/arm/cpu/armv7/sunxi/dram_sun8i_a83t.c | 424 +++++++++++++++++++++ arch/arm/cpu/armv7/sunxi/dram_sun8i_h3.c | 12 +- arch/arm/cpu/armv7/sunxi/pmic_bus.c | 7 +- arch/arm/dts/Makefile | 2 + arch/arm/dts/sun8i-a83t-allwinner-h8homlet-v2.dts | 64 ++++ arch/arm/dts/sun8i-a83t.dtsi | 247 ++++++++++++ arch/arm/include/asm/arch-sunxi/clock.h | 4 +- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 4 - arch/arm/include/asm/arch-sunxi/clock_sun8i_a83t.h | 304 +++++++++++++++ arch/arm/include/asm/arch-sunxi/dram.h | 2 + arch/arm/include/asm/arch-sunxi/dram_sun8i_a83t.h | 201 ++++++++++ arch/arm/include/asm/arch-sunxi/gpio.h | 1 + board/sunxi/Kconfig | 9 +- board/sunxi/MAINTAINERS | 5 + board/sunxi/board.c | 13 +- configs/A10-OLinuXino-Lime_defconfig | 1 - configs/A10s-OLinuXino-M_defconfig | 1 - configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/A20-OLinuXino-Lime2_defconfig | 1 - configs/A20-OLinuXino-Lime_defconfig | 1 - configs/A20-OLinuXino_MICRO_defconfig | 1 - configs/A20-Olimex-SOM-EVB_defconfig | 1 - configs/Ainol_AW1_defconfig | 1 - configs/Ampe_A76_defconfig | 1 - configs/Auxtek-T003_defconfig | 1 - configs/Auxtek-T004_defconfig | 1 - configs/Bananapi_defconfig | 1 - configs/Bananapro_defconfig | 1 - configs/CHIP_defconfig | 1 - configs/CSQ_CS908_defconfig | 1 - configs/Chuwi_V7_CW0825_defconfig | 1 - configs/Colombus_defconfig | 1 - configs/Cubieboard2_defconfig | 1 - configs/Cubieboard_defconfig | 1 - configs/Cubietruck_defconfig | 1 - configs/Hummingbird_A31_defconfig | 1 - configs/Hyundai_A7HD_defconfig | 1 - configs/Lamobo_R1_defconfig | 1 - configs/Linksprite_pcDuino3_Nano_defconfig | 1 - configs/Linksprite_pcDuino3_defconfig | 1 - configs/Linksprite_pcDuino_defconfig | 1 - configs/MK808C_defconfig | 1 - configs/MSI_Primo73_defconfig | 1 - configs/MSI_Primo81_defconfig | 1 - configs/Marsboard_A10_defconfig | 1 - configs/Mele_A1000G_quad_defconfig | 1 - configs/Mele_A1000_defconfig | 1 - configs/Mele_I7_defconfig | 1 - configs/Mele_M3_defconfig | 1 - configs/Mele_M5_defconfig | 1 - configs/Mele_M9_defconfig | 1 - configs/Merrii_A80_Optimus_defconfig | 1 - configs/Mini-X_defconfig | 1 - configs/Orangepi_defconfig | 1 - configs/Orangepi_mini_defconfig | 1 - configs/Sinlinx_SinA33_defconfig | 1 - configs/Sinovoip_BPI_M2_defconfig | 1 - configs/UTOO_P66_defconfig | 1 - configs/Wexler_TAB7200_defconfig | 1 - configs/Wits_Pro_A20_DKT_defconfig | 1 - configs/Wobo_i5_defconfig | 1 - configs/Yones_Toptech_BD1078_defconfig | 1 - configs/ba10_tv_box_defconfig | 1 - configs/ga10h_v1_1_defconfig | 1 - configs/gt90h_v4_defconfig | 1 - configs/h8_homlet_v2_defconfig | 24 ++ configs/i12-tvbox_defconfig | 1 - configs/iNet_3F_defconfig | 1 - configs/iNet_3W_defconfig | 1 - configs/iNet_86VS_defconfig | 1 - configs/inet1_defconfig | 1 - configs/inet97fv2_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/inet9f_rev03_defconfig | 1 - configs/jesurun_q5_defconfig | 1 - configs/mixtile_loftq_defconfig | 1 - configs/mk802_a10s_defconfig | 1 - configs/mk802_defconfig | 1 - configs/mk802ii_defconfig | 1 - configs/orangepi_pc_defconfig | 1 - configs/orangepi_plus_defconfig | 1 - configs/pov_protab2_ips9_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 1 - configs/q8_a33_tablet_1024x600_defconfig | 1 - configs/q8_a33_tablet_800x480_defconfig | 1 - configs/r7-tv-dongle_defconfig | 1 - configs/sunxi_Gemei_G9_defconfig | 1 - drivers/power/Kconfig | 40 +- drivers/power/Makefile | 1 + drivers/power/axp818.c | 132 +++++++ include/axp818.h | 75 ++++ include/axp_pmic.h | 3 + include/configs/sun8i.h | 4 + include/configs/sunxi-common.h | 3 +- 103 files changed, 1701 insertions(+), 114 deletions(-) create mode 100644 arch/arm/cpu/armv7/sunxi/clock_sun8i_a83t.c create mode 100644 arch/arm/cpu/armv7/sunxi/dram_sun8i_a83t.c create mode 100644 arch/arm/dts/sun8i-a83t-allwinner-h8homlet-v2.dts create mode 100644 arch/arm/dts/sun8i-a83t.dtsi create mode 100644 arch/arm/include/asm/arch-sunxi/clock_sun8i_a83t.h create mode 100644 arch/arm/include/asm/arch-sunxi/dram_sun8i_a83t.h create mode 100644 configs/h8_homlet_v2_defconfig create mode 100644 drivers/power/axp818.c create mode 100644 include/axp818.h
Regards,
Hans
On Fri, Dec 11, 2015 at 03:03:13PM +0100, Hans de Goede wrote:
Hi Tom,
Hans de Goede
