[PATCH 1/1] efi_loader: use '%#x' instead of '0x%x'
We can save a few bytes by using '%#x' instead of '0x%x' in printf statements.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_loader/efi_boottime.c | 20 ++++++++++---------- lib/efi_loader/efi_device_path_to_text.c | 20 ++++++++++---------- lib/efi_loader/efi_hii_config.c | 2 +- lib/efi_loader/efi_image_loader.c | 10 +++++----- lib/efi_loader/efi_memory.c | 4 ++-- lib/efi_loader/efi_signature.c | 2 +- lib/efi_loader/efi_variable_tee.c | 2 +- 7 files changed, 30 insertions(+), 30 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 4f52284b4c6..01a5182b417 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -372,7 +372,7 @@ static unsigned long EFIAPI efi_raise_tpl(efi_uintn_t new_tpl) { efi_uintn_t old_tpl = efi_tpl;
- EFI_ENTRY("0x%zx", new_tpl); + EFI_ENTRY("%#zx", new_tpl);
if (new_tpl < efi_tpl) EFI_PRINT("WARNING: new_tpl < current_tpl in %s\n", __func__); @@ -395,7 +395,7 @@ static unsigned long EFIAPI efi_raise_tpl(efi_uintn_t new_tpl) */ static void EFIAPI efi_restore_tpl(efi_uintn_t old_tpl) { - EFI_ENTRY("0x%zx", old_tpl); + EFI_ENTRY("%#zx", old_tpl);
if (old_tpl > efi_tpl) EFI_PRINT("WARNING: old_tpl > current_tpl in %s\n", __func__); @@ -431,7 +431,7 @@ static efi_status_t EFIAPI efi_allocate_pages_ext(int type, int memory_type, { efi_status_t r;
- EFI_ENTRY("%d, %d, 0x%zx, %p", type, memory_type, pages, memory); + EFI_ENTRY("%d, %d, %#zx, %p", type, memory_type, pages, memory); r = efi_allocate_pages(type, memory_type, pages, memory); return EFI_EXIT(r); } @@ -453,7 +453,7 @@ static efi_status_t EFIAPI efi_free_pages_ext(uint64_t memory, { efi_status_t r;
- EFI_ENTRY("%llx, 0x%zx", memory, pages); + EFI_ENTRY("%llx, %#zx", memory, pages); r = efi_free_pages(memory, pages); return EFI_EXIT(r); } @@ -797,7 +797,7 @@ efi_status_t EFIAPI efi_create_event_ex(uint32_t type, efi_uintn_t notify_tpl, { efi_status_t ret;
- EFI_ENTRY("%d, 0x%zx, %p, %p, %pUs", type, notify_tpl, notify_function, + EFI_ENTRY("%d, %#zx, %p, %p, %pUs", type, notify_tpl, notify_function, notify_context, event_group);
/* @@ -839,7 +839,7 @@ static efi_status_t EFIAPI efi_create_event_ext( void *context), void *notify_context, struct efi_event **event) { - EFI_ENTRY("%d, 0x%zx, %p, %p", type, notify_tpl, notify_function, + EFI_ENTRY("%d, %#zx, %p, %p", type, notify_tpl, notify_function, notify_context); return EFI_EXIT(efi_create_event(type, notify_tpl, notify_function, notify_context, NULL, event)); @@ -2337,7 +2337,7 @@ static efi_status_t EFIAPI efi_set_watchdog_timer(unsigned long timeout, unsigned long data_size, uint16_t *watchdog_data) { - EFI_ENTRY("%ld, 0x%llx, %ld, %p", timeout, watchdog_code, + EFI_ENTRY("%ld, %#llx, %ld, %p", timeout, watchdog_code, data_size, watchdog_data); return EFI_EXIT(efi_set_watchdog(timeout)); } @@ -2982,7 +2982,7 @@ static void EFIAPI efi_copy_mem(void *destination, const void *source, */ static void EFIAPI efi_set_mem(void *buffer, size_t size, uint8_t value) { - EFI_ENTRY("%p, %ld, 0x%x", buffer, (unsigned long)size, value); + EFI_ENTRY("%p, %ld, %#x", buffer, (unsigned long)size, value); memset(buffer, value, size); EFI_EXIT(EFI_SUCCESS); } @@ -3123,7 +3123,7 @@ static efi_status_t EFIAPI efi_open_protocol struct efi_handler *handler; efi_status_t r = EFI_INVALID_PARAMETER;
- EFI_ENTRY("%p, %pUs, %p, %p, %p, 0x%x", handle, protocol, + EFI_ENTRY("%p, %pUs, %p, %p, %p, %#x", handle, protocol, protocol_interface, agent_handle, controller_handle, attributes);
@@ -3496,7 +3496,7 @@ static efi_status_t EFIAPI efi_exit(efi_handle_t image_handle, if (image_obj->image_type == IMAGE_SUBSYSTEM_EFI_APPLICATION) { ret = efi_tcg2_measure_efi_app_exit(); if (ret != EFI_SUCCESS) { - log_warning("tcg2 measurement fails(0x%lx)\n", + log_warning("tcg2 measurement fails (%#lx)\n", ret); } } diff --git a/lib/efi_loader/efi_device_path_to_text.c b/lib/efi_loader/efi_device_path_to_text.c index 0c7b30a26e7..51732cc0a48 100644 --- a/lib/efi_loader/efi_device_path_to_text.c +++ b/lib/efi_loader/efi_device_path_to_text.c @@ -53,7 +53,7 @@ static char *dp_hardware(char *s, struct efi_device_path *dp) case DEVICE_PATH_SUB_TYPE_MEMORY: { struct efi_device_path_memory *mdp = (struct efi_device_path_memory *)dp; - s += sprintf(s, "MemoryMapped(0x%x,0x%llx,0x%llx)", + s += sprintf(s, "MemoryMapped(%#x,%#llx,%#llx)", mdp->memory_type, mdp->start_address, mdp->end_address); @@ -79,7 +79,7 @@ static char *dp_hardware(char *s, struct efi_device_path *dp) struct efi_device_path_controller *cdp = (struct efi_device_path_controller *)dp;
- s += sprintf(s, "Ctrl(0x%0x)", cdp->controller_number); + s += sprintf(s, "Ctrl(%#0x)", cdp->controller_number); break; } default: @@ -152,7 +152,7 @@ static char *dp_msging(char *s, struct efi_device_path *dp) case DEVICE_PATH_SUB_TYPE_MSG_USB: { struct efi_device_path_usb *udp = (struct efi_device_path_usb *)dp; - s += sprintf(s, "USB(0x%x,0x%x)", udp->parent_port_number, + s += sprintf(s, "USB(%#x,%#x)", udp->parent_port_number, udp->usb_interface); break; } @@ -174,7 +174,7 @@ static char *dp_msging(char *s, struct efi_device_path *dp) struct efi_device_path_usb_class *ucdp = (struct efi_device_path_usb_class *)dp;
- s += sprintf(s, "UsbClass(0x%x,0x%x,0x%x,0x%x,0x%x)", + s += sprintf(s, "UsbClass(%#x,%#x,%#x,%#x,%#x)", ucdp->vendor_id, ucdp->product_id, ucdp->device_class, ucdp->device_subclass, ucdp->device_protocol); @@ -185,7 +185,7 @@ static char *dp_msging(char *s, struct efi_device_path *dp) struct efi_device_path_sata *sdp = (struct efi_device_path_sata *) dp;
- s += sprintf(s, "Sata(0x%x,0x%x,0x%x)", + s += sprintf(s, "Sata(%#x,%#x,%#x)", sdp->hba_port, sdp->port_multiplier_port, sdp->logical_unit_number); @@ -197,7 +197,7 @@ static char *dp_msging(char *s, struct efi_device_path *dp) u32 ns_id;
memcpy(&ns_id, &ndp->ns_id, sizeof(ns_id)); - s += sprintf(s, "NVMe(0x%x,", ns_id); + s += sprintf(s, "NVMe(%#x,", ns_id);
/* Display byte 7 first, byte 0 last */ for (int i = 0; i < 8; ++i) @@ -264,18 +264,18 @@ static char *dp_media(char *s, struct efi_device_path *dp)
memcpy(&signature, sig, sizeof(signature)); s += sprintf( - s, "HD(%d,MBR,0x%08x,0x%llx,0x%llx)", + s, "HD(%d,MBR,%#08x,%#llx,%#llx)", hddp->partition_number, signature, start, end); break; } case SIG_TYPE_GUID: s += sprintf( - s, "HD(%d,GPT,%pUl,0x%llx,0x%llx)", + s, "HD(%d,GPT,%pUl,%#llx,%#llx)", hddp->partition_number, sig, start, end); break; default: s += sprintf( - s, "HD(%d,0x%02x,0,0x%llx,0x%llx)", + s, "HD(%d,%#02x,0,%#llx,%#llx)", hddp->partition_number, hddp->partmap_type, start, end); break; @@ -286,7 +286,7 @@ static char *dp_media(char *s, struct efi_device_path *dp) case DEVICE_PATH_SUB_TYPE_CDROM_PATH: { struct efi_device_path_cdrom_path *cddp = (struct efi_device_path_cdrom_path *)dp; - s += sprintf(s, "CDROM(%u,0x%llx,0x%llx)", cddp->boot_entry, + s += sprintf(s, "CDROM(%u,%#llx,%#llx)", cddp->boot_entry, cddp->partition_start, cddp->partition_size); break; } diff --git a/lib/efi_loader/efi_hii_config.c b/lib/efi_loader/efi_hii_config.c index ae0f3ecd3b1..0c8e2445d7a 100644 --- a/lib/efi_loader/efi_hii_config.c +++ b/lib/efi_loader/efi_hii_config.c @@ -127,7 +127,7 @@ form_callback(const struct efi_hii_config_access_protocol *this, union efi_ifr_type_value *value, efi_browser_action_request_t *action_request) { - EFI_ENTRY("%p, 0x%zx, 0x%x, 0x%x, %p, %p", this, action, + EFI_ENTRY("%p, %#zx, %#x, %#x, %p, %p", this, action, question_id, type, value, action_request);
return EFI_EXIT(EFI_DEVICE_ERROR); diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index 0ddf69a0918..2cea7a81849 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -72,7 +72,7 @@ static efi_status_t efi_print_image_info(struct efi_loaded_image_obj *obj, image->image_base, image->image_base + image->image_size - 1); if (pc && pc >= image->image_base && pc < image->image_base + image->image_size) - printf(" pc=0x%zx", pc - image->image_base); + printf(" pc=%#zx", pc - image->image_base); if (image->file_path) printf(" '%pD'", image->file_path); printf("\n"); @@ -459,7 +459,7 @@ bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp, efi_image_region_add(regs, efi + sorted[i]->PointerToRawData, efi + sorted[i]->PointerToRawData + size, 0); - log_debug("section[%d](%s): raw: 0x%x-0x%x, virt: %x-%x\n", + log_debug("section[%d](%s): raw: %#x-%#x, virt: %x-%x\n", i, sorted[i]->Name, sorted[i]->PointerToRawData, sorted[i]->PointerToRawData + size, @@ -493,7 +493,7 @@ bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp, } *auth = efi + authoff; *auth_len = authsz; - log_debug("WIN_CERTIFICATE: 0x%x, size: 0x%x\n", authoff, + log_debug("WIN_CERTIFICATE: %#x, size: %#x\n", authoff, authsz); } else { *auth = NULL; @@ -648,7 +648,7 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) continue; }
- log_debug("WIN_CERTIFICATE_TYPE: 0x%x\n", + log_debug("WIN_CERTIFICATE_TYPE: %#x\n", wincert->wCertificateType);
auth = (u8 *)wincert + sizeof(*wincert); @@ -859,7 +859,7 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle, }
if (!supported) { - log_err("Machine type 0x%04x is not supported\n", + log_err("Machine type %#04x is not supported\n", nt->FileHeader.Machine); return EFI_LOAD_ERROR; } diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index d2f5d563f2a..c42c9cccd79 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -278,7 +278,7 @@ efi_status_t efi_add_memory_map_pg(u64 start, u64 pages, uint64_t carved_pages = 0; struct efi_event *evt;
- EFI_PRINT("%s: 0x%llx 0x%llx %d %s\n", __func__, + EFI_PRINT("%s: %#llx %#llx %d %s\n", __func__, start, pages, memory_type, overlap_conventional ? "yes" : "no");
@@ -530,7 +530,7 @@ efi_status_t efi_free_pages(uint64_t memory, efi_uintn_t pages)
/* Sanity check */ if (!memory || (memory & EFI_PAGE_MASK) || !pages) { - printf("%s: illegal free 0x%llx, 0x%zx\n", __func__, + printf("%s: illegal free %#llx, %#zx\n", __func__, memory, pages); return EFI_INVALID_PARAMETER; } diff --git a/lib/efi_loader/efi_signature.c b/lib/efi_loader/efi_signature.c index 184eac8cddb..29ef2681c06 100644 --- a/lib/efi_loader/efi_signature.c +++ b/lib/efi_loader/efi_signature.c @@ -468,7 +468,7 @@ static bool efi_signature_check_revocation(struct pkcs7_signed_info *sinfo,
memcpy(&revoc_time, sig_data->data + len, sizeof(revoc_time)); - EFI_PRINT("revocation time: 0x%llx\n", revoc_time); + EFI_PRINT("revocation time: %#llx\n", revoc_time); /* * TODO: compare signing timestamp in sinfo * with revocation time diff --git a/lib/efi_loader/efi_variable_tee.c b/lib/efi_loader/efi_variable_tee.c index 8b6b0a39086..c5069186f99 100644 --- a/lib/efi_loader/efi_variable_tee.c +++ b/lib/efi_loader/efi_variable_tee.c @@ -257,7 +257,7 @@ static int ffa_discover_mm_sp_id(void)
mm_sp_id = descs[0].info.id;
- log_info("EFI: MM partition ID 0x%x\n", mm_sp_id); + log_info("EFI: MM partition ID %#x\n", mm_sp_id);
return 0; }
On Sat, 2 Nov 2024 at 07:07, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
EFI_ENTRY("%#zx", new_tpl); if (new_tpl < efi_tpl) EFI_PRINT("WARNING: new_tpl < current_tpl in %s\n", __func__);
EFI_ENTRY("%#zx", old_tpl); if (old_tpl > efi_tpl) EFI_PRINT("WARNING: old_tpl > current_tpl in %s\n", __func__);
EFI_ENTRY("%d, %#zx, %p, %p, %pUs", type, notify_tpl, notify_function, notify_context, event_group); /*
s += sprintf(s, "NVMe(%#x,", ns_id); /* Display byte 7 first, byte 0 last */ for (int i = 0; i < 8; ++i)
EFI_ENTRY("%p, %#zx, %#x, %#x, %p, %p", this, action, question_id, type, value, action_request); return EFI_EXIT(EFI_DEVICE_ERROR);
log_debug("WIN_CERTIFICATE_TYPE: %#x\n", wincert->wCertificateType); auth = (u8 *)wincert + sizeof(*wincert);
if (!supported) {
log_info("EFI: MM partition ID %#x\n", mm_sp_id); return 0;
2.45.2
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
