[U-Boot] [PATCH 1/6] usb : musb : Add high speed field in usb_device structure
This patch adds support for identification of high speed devices. For high spped devices that are connected via hubs, the information that the device is high speed is recorded. This is required by Mentor USB Host controller driver.
Signed-off-by: Ravi Babu ravibabu@ti.com Signed-off-by: Swaminathan S swami.iyer@ti.com Signed-off-by: Thomas Abraham t-abraham@ti.com Signed-off-by: Ajay Kumar Gupta ajay.gupta@ti.com --- common/usb.c | 1 + include/usb.h | 1 + include/usb_defs.h | 1 + 3 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/common/usb.c b/common/usb.c index ee18152..f8379c9 100644 --- a/common/usb.c +++ b/common/usb.c @@ -1137,6 +1137,7 @@ void usb_hub_port_connect_change(struct usb_device *dev, int port) /* Allocate a new device struct for it */ usb = usb_alloc_new_device(); usb->slow = (portstatus & USB_PORT_STAT_LOW_SPEED) ? 1 : 0; + usb->high = (portstatus & USB_PORT_STAT_HIGH_SPEED) ? 1 : 0;
dev->children[port] = usb; usb->parent = dev; diff --git a/include/usb.h b/include/usb.h index 510df95..e6aa551 100644 --- a/include/usb.h +++ b/include/usb.h @@ -139,6 +139,7 @@ enum { struct usb_device { int devnum; /* Device number on USB bus */ int slow; /* Slow device? */ + int high; /* High speed device? */ char mf[32]; /* manufacturer */ char prod[32]; /* product */ char serial[32]; /* serial number */ diff --git a/include/usb_defs.h b/include/usb_defs.h index 353019f..500a0ad 100644 --- a/include/usb_defs.h +++ b/include/usb_defs.h @@ -216,6 +216,7 @@ #define USB_PORT_STAT_RESET 0x0010 #define USB_PORT_STAT_POWER 0x0100 #define USB_PORT_STAT_LOW_SPEED 0x0200 +#define USB_PORT_STAT_HIGH_SPEED 0x0400
/* wPortChange bits */ #define USB_PORT_STAT_C_CONNECTION 0x0001
Hello Thomas,
Nice work, but I have a few comments.
2008/12/16 Thomas Abraham t-abraham@ti.com:
This patch clashes with the work of Michael Trimarchi who added high speed support somewhat different. Look in the U-boot-usb git tree (next branch) where his patches are already pending for the next release. (http://git.denx.de/?p=u-boot/u-boot-usb.git;a=shortlog;h=refs/heads/next)
Same, Michael combined slow+high into 1 single element called 'speed', what I would prefer here.
Can you please rebase your work on the U-boot-usb tree, 'next' branch? And streamline these changes with the work Michael already has done?
Kind Regards,
Remy
1.5.6
Hi Remy,
-----Original Message----- From: l.pinguin@gmail.com [mailto:l.pinguin@gmail.com] On Behalf Of Remy Bohmer Sent: Wednesday, December 17, 2008 1:48 AM To: Abraham, Thomas
<snip>
Ok. I will rebase with u-boot-usb next branch.
For mentor usb controller, it would still be necessary to record the speed of the device when it is found connected to a hub port. So the update of usb->speed would have to be done as below in 'usb_hub_port_connect_change' function. Would this be acceptable?
/* Allocate a new device struct for it */ usb = usb_alloc_new_device(); usb->speed = (portstatus & USB_PORT_STAT_LOW_SPEED) ? 1 : 0; +usb->speed = (portstatus & USB_PORT_STAT_HIGH_SPEED) ? 1 : 0;
Kind Regards,
Remy
Thanks, Thomas.
Hello Michael,
Would this change break anything you are working on? Or do you have a better suggestion?
Kind Regards,
Remy
Abraham, Thomas wrote:
Hi Remy,
<snip>
I'll send a patch. I think that the correct way to do it is: + + if (portstatus & USB_PORT_STAT_HIGH_SPEED) + usb->speed = USB_SPEED_HIGH; + else if (portstatus & USB_PORT_STAT_LOW_SPEED) + usb->speed = USB_SPEED_LOW; + else + usb->speed = USB_SPEED_FULL;
Like linux does.
Kind Regards,
Remy
Thanks, Thomas.
Regards Michael
Abraham, Thomas
michael
Remy Bohmer
Thomas Abraham
