[U-Boot-Users] [PATCH] Avoid assigning PCI resources from zero address
If a PCI IDE card happens to get a zero address assigned to it, the Linux IDE core complains and IDE drivers fails to work. Also, assigning zero to a BAR was illegal according to PCI 2.1 (the later revisions seem to have excluded the sentence about "0" being considered an invalid address) -- so, use a reasonable starting value of 0x1000 (that's what the most Linux archs are using).
Alternatively, one might have fixed the calls to pci_set_region() individually (some code even seems to have taken care of this issue) but that would have been a lot more work. :-)
Signed-off-by: Sergei Shtylyov sshtylyov@ru.mvista.com
drivers/pci_auto.c | 7 ++++++- 1 files changed, 6 insertions(+), 1 deletion(-)
Index: u-boot/drivers/pci_auto.c =================================================================== --- u-boot.orig/drivers/pci_auto.c +++ u-boot/drivers/pci_auto.c @@ -34,7 +34,12 @@
void pciauto_region_init(struct pci_region* res) { - res->bus_lower = res->bus_start; + /* + * Avoid allocating PCI resources from address 0 -- this is illegal + * according to PCI 2.1 and moreover, this is known to cause Linux IDE + * drivers to fail. Use a reasonable starting value of 0x1000 instead. + */ + res->bus_lower = res->bus_start ? res->bus_start : 0x1000; }
void pciauto_region_align(struct pci_region *res, unsigned long size)
Sergei Shtylyov
