[PATCH v3] configs: add mvebu_espressobin_ultra-88f3720_defconfig
Add support for a Marvell Armada 3720 device variant
Signed-off-by: Benjamin Schneider ben@bens.haus ---
Changes in v3: - Fix typo in MAINTAINERS
board/Marvell/mvebu_armada-37xx/MAINTAINERS | 5 + .../mvebu_espressobin_ultra-88f3720_defconfig | 106 ++++++++++++++++++ 2 files changed, 111 insertions(+) create mode 100644 configs/mvebu_espressobin_ultra-88f3720_defconfig
diff --git a/board/Marvell/mvebu_armada-37xx/MAINTAINERS b/board/Marvell/mvebu_armada-37xx/MAINTAINERS index 9b0afeef10..e96499e161 100644 --- a/board/Marvell/mvebu_armada-37xx/MAINTAINERS +++ b/board/Marvell/mvebu_armada-37xx/MAINTAINERS @@ -9,3 +9,8 @@ ESPRESSOBin BOARD M: Konstantin Porotchkin kostap@marvell.com S: Maintained F: configs/mvebu_espressobin-88f3720_defconfig + +ESPRESSOBin Ultra BOARD +M: Ben Schneider ben@bens.haus +S: Maintained +F: configs/mvebu_espressobin_ultra-88f3720_defconfig diff --git a/configs/mvebu_espressobin_ultra-88f3720_defconfig b/configs/mvebu_espressobin_ultra-88f3720_defconfig new file mode 100644 index 0000000000..c6ffaaabca --- /dev/null +++ b/configs/mvebu_espressobin_ultra-88f3720_defconfig @@ -0,0 +1,106 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_ARCH_MVEBU=y +CONFIG_TEXT_BASE=0x00000000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xff0000 +CONFIG_TARGET_MVEBU_ARMADA_37XX=y +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x3F0000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_DM_GPIO=y +CONFIG_OF_UPSTREAM=y +CONFIG_DEFAULT_DEVICE_TREE="marvell/armada-3720-espressobin-ultra" +CONFIG_SYS_LOAD_ADDR=0x6000000 +CONFIG_PCI=y +CONFIG_AHCI=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_DISTRO_DEFAULTS=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_USE_PREBOOT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SYS_MAXARGS=32 +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SATA=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_BTRFS=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_SQUASHFS=y +CONFIG_CMD_FS_UUID=y +CONFIG_MAC_PARTITION=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ARP_TIMEOUT=200 +CONFIG_NET_RETRY_COUNT=50 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_AHCI_PCI=y +CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y +CONFIG_CLK=y +CONFIG_CLK_MVEBU=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MV=y +CONFIG_MISC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_FIXED=y +CONFIG_PHY_GIGE=y +CONFIG_DM_DSA=y +CONFIG_MV88E6XXX=y +CONFIG_MVNETA=y +CONFIG_MVMDIO=y +CONFIG_NVME_PCI=y +CONFIG_PCI_AARDVARK=y +CONFIG_PHY=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_37XX=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DEFAULT_ENV_IS_RW=y +CONFIG_MVEBU_A3700_UART=y +CONFIG_MVEBU_A3700_SPI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +# CONFIG_WATCHDOG_AUTOSTART is not set +CONFIG_WDT=y +CONFIG_WDT_ARMADA_37XX=y +CONFIG_SHA1=y +CONFIG_DM_RTC=y +CONFIG_RTC_PCF8563=y +# CONFIG_DEBUG_UART=y +# CONFIG_DEBUG_UART_BASE=0xd0012000 +# CONFIG_DEBUG_UART_CLOCK=25804800 +# CONFIG_DEBUG_UART_SHIFT=2 +# CONFIG_DEBUG_UART_ANNOUNCE=y
Applied to u-boot-marvell/master
Thanks, Stefan
Changes in v3:
Viele Grüße, Stefan Roese
Benjamin Schneider
Stefan Roese
